- solo/DC or Revo?
- New Cams
- v-tec light
- Coilover Controversy
- Any ideas? Help please
- Help !! AEM Short Ram Intake Problem.
- exhaust resonator?
- How fast is the acceleration on Cruise Control?
- recalibrate odometer
- just installed hp
- air turbulance under hood if add new vents???
- Turbo possible after these mods?
- autometer shift light
- lowering springs...
- MagnaFlow Muffler
- Wiring Diagram for ECU
- Wings West Avenger Front Bumper
- A'PEXi LOWERING SPRINGS: anyone?
- musical intake?
- drop with camber kit??
- Anybody know anything about this??
- anyone try this mod yet .. is it worth it???please give opinion
- Anybody got an intake like me??
- Shop In Ohio????????????
- DIY mega thread problem
- Where is the ecu located
- ECU wiring for AFC (pics)
- Camber kits with coilovers?
- HOW TO MAKE SPEEDO BLUE?
- **Re-adjust passenger seat**!!!
- Can someone please give me a DIY for upper grill
- springs: tie rod
- Long Awaited MagnaFlow DIY
- this chip in the key business
- NOIZE IN PIPES
- K20A Engine info...thought it was interesting.
- DIY Soon: Acura RSX Rear Sway Bar Conversion
- Need Injen CAI install help fast!
- What kind of engine?
- just asking for a little help
- ATTN:Slam2k1civic....19s? ANYONE ANSWER
- where would you get illumination from???
- Gas Deductions for Using INTAKES
- scared of CAI!
- Locking the Driver's Door Automatically
- How Do you take pictures W/ neons
- Intake Resonator
- Intruder ?
- Can anyone let me know how exactly to shave my "Civic" emblem off?? DIY link is not workin
- Spark Plugs
- Body coloured strip on boot lid
- Interesting Thread for the nOObs..
- DIY Vinyl Car Seats
- ~~Wiring Setup for 2k1-2k2 civic~~
- How do you install headlight bulbs?
- Wiring neon in trunk
- HELP with my stock alarm
- Mystery Metal Revealed!
- Where is(are) the power windows fuse(s)?
- How 2 Remove....
- SUSPENSION
- switching from gc's to neuspeed springs
- 3M Scotch Gard rocks!!!!!!!!!!!
- RPM GUAGE NOT WORKING HELP!!!!
- backup fuse question
- monster truck konis
- wiring interior neonz... WHODUNNIT???
- Spring Installation
- Brake Pad Install Help.. Quick..
- someone with prolonged use of 17s on their 2k1 please respond
- grinding gears....how bad is it!?
- Question about compustar alarm Please read!!
- Simple solution to shift boot hanging
- Update on compustar alarm!!!please read!!!
- Power Window Not Working!
- summer tires ok for winter?
- Stock Airbox?
- Auto tranny Q
- When do u change ur oil?
- How do you remove the dash?
- autometer question
- Air/fuel meter by Auto METER
- ? about dash illumination
- HELP: check engine light came on!
- DIYers ?....How to change the Wiper BLADES?!?!
- SideMarker Q!! please reply
- TECH heads: Wet or Dry NOS?
- Tint Question
- Fog light switch -Help!
- 2002 dx question
- Installing a strut bar in a manual LX
- Everybody who painted their interior and it is peeling...
- car level
- drill hole in headlights...
- I have 2 newbie ?'s :)
- honda maintenance
- Wireing a black light?
- Man't Required light is going off..?
- has anybody combined
- who has installed...
- resetting srs light?????
- Attention RiceBurnrEX
- DIY Koni Stuts
- Just got car back... Ground strap on spark plug?
- BRAKE PADS!!!
- Shim the front?
- quick question on offset
- Installed Alteeza Grill
- Magnaflow on DX/LX vibration
- Fog Light Help................
- PLEASE HELP!!! SRI Installation; Malfunction Light on?!
- ECU chip
- Newbie question from a member-Rims
- Disable Clutch Start?
- Big Brake Kits for 2k1+ Civic?
- Do we have a DIY on an front upper strut bar??
- holding the grill?
- Painting and re-finishing
- has any one had trouble installing.....
- Where can I get a red leather steering wheel cover??
- ATTN SEDAN OWNERS: where did you put your ..
- PLEASE READ: Tachometer REV Limiter Question?
- Timing?
- rims and putting them on my ride
- offsets..42 or 45
- Program Keyless entry
- DIY: tricked out trunk
- power outlet removal
- Headlight bulbs, H4?
- Attn: Boost.........Air/Flow Meter
- Installing trunk release
- Help with sedan light install
- Greddy Turbo'd RSX info that pertains to us...
- ONCE AND FOR ALL...NITROUS OXIDE 101 FOR NEWBIES AND EXPERIENCED RACERS! THIS IS A MUST READ
- Removing Body kit?
- Scratch remover that works along with factory touch up paint???
- Somethings wrong with my Indiglo Gauges...
- Correct me if I am wrong...
- Clutch, Nobody really did say........
- Civic SI Suspension
- The cvt query
- Attn: Technically/mechanically inclined people
- Dash Lights in Blue!!!
- Possible DIY for Injen CAI problem.
- HELP!!! Anybody who's had condensation in tail lights?
- Wire Loom Question...........
- HELP WITH COILOVER INSTALL ASAP
- Indiglo Type R knob
- Help with installing door handles
- to antidote or whoever else can solve sqeaky springs
- How Do You Remove Superglue?
- 195/70/R14 snow catch went lowered
- dyno testing
- lowering fun
- HOW DO YOU MAKE SPEEDO BLUE?
- RSX Rear Brakes Fit?!?!?!?!?
- DIY Alarm/Remote Start (Wire Colors/Tips)
- 2.25 or 2.50 PIPING?????????????????
- Lowering Car?
- wheel queston PLZ HELP!~
- NEED ECM Wiring Diagram ASAP
- Mirrors...
- Clear headlights
- Help:Check engine light on after stalling
- Please read!-Static or Dynamic wheel balancing?
- wheel/tire weight comparison
- One big mod question...
- Nasty Window Coating after window goes down
- Blue Side View Mirrors??
- Need Some Help Fellas
- How hard is it to clear your headlights?
- Fender Piece. please help
- DC Sports header problem
- HP Racing 4-1 Header not welded right :(
- Does anyone have pictures of
- Help R1 Coilover Install
- tuning
- Question about installing underbody neons
- Replacing Interior Bulbs
- DON'T DO THIS
- Whats a B-Pipe?
- 4 APEXi VTEC CONTROLLER USERS
- Light BULBS
- need car audio advice please!!
- ok to switch to synthetic?
- how do u take aftermarket emblems off ur car
- front bumper lights..and acuras..
- lowering my car
- That Mega DIY Thread
- Dynamat HELP!!!!!!!!!!!
- Tire Pressure Question
- Led Wahers $UCK!!!
- Should I install my Coilovers Myself?
- Muffler Only(all show) Need Expert's Help Please
- New...Had a quick Question
- STOCK vs VTEC ???
- OEM body kit and exhaust
- Am I Killing My Clutch? PLEASE HELP
- carbonfiber help!!!!
- about turbochargers
- How do you use change rear turn signal?!?!
- Muffler installation
- How do I take off the handbrake cover?
- HELP! Sway bar installation!!
- K&N FIPK VS INJEN CAI VS AEM CAI
- 18 inch rims!!! will they fit!!! Please help me before i buy!!!
- I need DIY On reverse indiglo gauges
- Think twice re: Sway bar 19mm
- Rims!!!!!!!!!!!!
- For those who have installed rear camber kits.....
- need help w/ revo
- Smoking Tail Lights
- Engine vibrates a lot
- Installing OEM Spoiler Question
- Manual Transmission Fluid
- Racing Downpipe
- Grinding noise under front passenger seats?
- how do u get a stripped nut off that pain in the a$$ place on header
- Line loc's / roll control ?'s
- front camber after installing koni shocks
- To anyone who can help...
- Will a rim with a +42 offset fit my 2k2 civic si!
- melting wires?
- APC eurotails question
- Questions regarding Rear Spoiler and paint
- Clear bulbs
- Respond to Question ASAP Please!
- Kumosport
- E-Brake Adjustment
- will 2001 GC coils fit on a 2002 civic?
- its kinda off topic but 2k2 cavileer (clear corners)
- Upper Grill?
- Suicide Hood?
- Painting the trim on headlights
- Urgent! Those who installed their Konis...
- Is it hard to Install Lower tie bar?
- turbo
- tire ? for the experts
- Was there ever a DIY for the spare tire relocation?
- does anyone know if this shift knob looks good on the 7th gen civic?
- Is it possible to tuck
- Do i have to buy new headlights or can i just take out the orange corner?
- Rear Suspension Problem
- Interior Paint (besides Foliatec)
- "Tricked Out Trunk"
- Need advice..please respond!!
- Clutch question
- Exhaust Question
- 2002 civic hybrid question. . .
- oil pressure port....
