View Full Version : Honda Civic DIYs and Civic Tech Chat
  1. Should i get dual exhaust or kit first?
  2. Honda doesn't sell just gauges..
  3. Gull-wing doors on 2K1
  4. To camber correct or not to camber correct.
  5. CLEARING CORNER LENSES
  6. Question for anyone with aftermarket seats
  7. Remeber lowonairs trick hood?
  8. Hey Grey, quick question about ur brembo.
  9. Going to attempt to clear headlights
  10. DIY Center and Rear Console
  11. Where to put this?
  12. rear emblem question
  13. Goin To Honda Friday for info on dash lights
  14. DIY TRUNK?
  15. hiding neons??/
  16. DIY: Painting inserts??
  17. full throttle sensor
  18. DIY : groundcontrol coils install
  19. Mylar..Info
  20. interior painting...
  21. Clearing Headlights on a 98/99 Civ
  22. Vtec conversition
  23. Guage Question, not indiglo or EL
  24. DIY White Gauges -- part 4?
  25. What is the offset for H&R 1.3" dropped. 215/45/17 ?
  26. Urgent:Done with DIY Headlight, Sealant extra
  27. I NEED HELP!! Something went wrong
  28. TORQUE SPEC on BOLTS!?!
  29. Replace HORN....
  30. Back up for the AEM sri DIY install?
  31. screws attached to radio
  32. DX TO LX GAUGE CLUSTER WORKS
  33. Throttle cable problem
  34. Throttle cable DIY
  35. FOG LIGHT/DRIVING LIGHT QUESTIONS
  36. turn signal bulb
  37. installing bypass valve for injen cai
  38. Can't slam our car!!!!!
  39. losing performance
  40. looking for bulb and help
  41. TIMING GEAR???
  42. How much HP gain from CAI & Exhaust??
  43. Door panel removal?
  44. to purge or not to purge
  45. MOUNTS???
  46. N2O question looking cool
  47. Adding Daylight Running Lights
  48. how do projectors work?
  49. CO2 in intake
  50. Is there a DIY for pulley installation?
  51. Thermal Dynamics...
  52. body roll & strut bar?
  53. how do i remove my dash?
  54. LED lights?
  55. 2 NItrous questions
  56. What is purging
  57. Co2 Cooling System *NEW IDEA*
  58. Neuspeed upper front strut bar install...
  59. A Question for u Tech Wizards
  60. anyone tried painting the fabric?
  61. DC Sports TCS
  62. Air Ride and 01EXtc
  63. Varad LED scanner
  64. Cai rubbing on hood
  65. REAR TINT & DEFROSTER
  66. OBX Exhaust Sys....
  67. Suicide Doors
  68. vinyl interior
  69. i need help
  70. Grillcraft lower bumper grill kit........
  71. my new carbon fiber hood doesnt latch into place
  72. how to install racing seat brackets?
  73. Need info on LED size
  74. Help with Street Glow Gold series......
  75. throttle cable for 5speeds
  76. Rear Window defroster sucks
  77. OBX Exhaust Prob.....
  78. Automatic Tranny Problem
  79. DIY tachometer Help?
  80. ATTN: DIY pulleys; people whu did it
  81. ENGINE WEIGHT????
  82. Does This Shoe Make Me Look Fat?
  83. Lowered Ride... Rougher Ride?
  84. Couple questions regarding lowering the 2001
  85. Ping/clank Noise. Annoyed. Help Please.
  86. OEM fog lights - light pattern
  87. Backfiring Already?
  88. DIY Reverse Indiglo Gauges (with pics! again)
  89. cat back exhaust price
  90. I NEED HELP!!!!!!!
  91. Lowering with Octane?
  92. problem with my sri installation
  93. Am I Ruining my car by.......
  94. cold air Intake... short ram air intake... teach me!
  95. Kaminari kit QUESTION!!
  96. 17's and ECU??
  97. read too many threads, still not entirely sure what to do....
  98. LED's for 7440 Rear Turning Signal
  99. Install lowering springs first or strut bar?
  100. [ Differential ]
  101. Searching Threads and came across......AzNMan
  102. O2 sensor locations (HX vs others) PICs
  103. HID LIGHTS
  104. what size screw would you recommend for securing mesh to my new xenon bumper?
  105. Experts only!!!....
  106. Exhaust Hitting Bumper...........
  107. Front Bumper Question
  108. injen sri install????
  109. What is delta pressure?
  110. Transmission gearing..change?
  111. How to adjust Ground Control coilovers?????
  112. a brake question???
  113. Magnaflow DIY???
  114. Where to buy dampers?
  115. Aftermarket battery helping pulley woes?
  116. thinking about taking out back seat....
  117. Guys, How low can a 2k1 civic with a body kit go?
  118. Air bags
  119. gotta small problem. i hope.
  120. Front Upper Strut Installing?
  121. Going dual exhaust!!!!
  122. Whirring Noise from car
  123. HOW DO YOU TAKE OUT A/C VENTS?
  124. WHat is the difference between the EX and the 1.7i ES model?
  125. Differing results with eibach pro?? Poll..
  126. Will This Work?
  127. possible newb question, be warned...
  128. Nitrous Application Questions
  129. Did you have to modify your front perch when installing Ground Control Coilovers?
  130. need help installing air/fuel meter
  131. need help on cam gear
  132. Ok...how to install hood pins?
  133. HELP Removing Steering Wheel?
  134. Do new rims=need for alignment?
  135. who has H&R sports?
  136. o2 sensor
  137. How much is it gonna cost me?
  138. please check my tire numbers fast !
  139. taking off the glove box
  140. Scuff marks on my interior door panels
  141. Ground Control DIY Article
  142. remove resonator.. yai or nai?
  143. Touching up Paint chips
  144. Useless piece of metal?
  145. Anyone had probs getting an alignment? *please read*
  146. Switches
  147. 2 things..paint code, and where to get
  148. Custom Airbox.
  149. is this our car?
  150. Does REAR STRUT BAR do any good to your car?
  151. LED's
  152. Installing Locking Lug Nuts?
  153. Installing Shift Knobs
  154. rear section exhausts....
  155. Installing volt meter
  156. What Tire Pressure?
  157. cleaning injen CAI air filter
  158. 2002 Sedan Rear Speaker Install
  159. Any problem with Front Strut Bar?
  160. Help w/ removing Bumber for headlight clearing
  161. MY DIY painting of ACTUAL VALVE COVER
  162. Someone with swapping experience please help!! (Not for 2k1 civic)
  163. Someone with swapping experience please help!! (Not for 2k1 Civic)
  164. Need Help Relocating My Spare Tire.. . .
  165. Integra Type-R Swaybars
  166. What oil do you guys use .HELP
  167. i dont see a resonator??
  168. HELP: Streeing Wheel Removel?!?!?!?!
  169. Dash Lights: Cruise Ctrl, Pwr Mirror & Moonroof switches
  170. 'The A Panel' removal help.
  171. ATTN ALL: Plastic Parts behide Steering Wheel?!?!?
  172. How Indiglo Works (TECH ARTICLE for you peeps w/ questions about how they worK)
  173. Why relocate tire....waste of energy!!!
  174. D series exhast manifold????
  175. turning off a/c when you turn on defroster
  176. RPM Level at 62mph
  177. Tightening the Clutch
  178. 215 or 205?
  179. ATTN ALL: Steering wheel?!?!?!?
  180. RSX shift mech.
  181. missing threads
  182. Head Unit Relocation
  183. DIY side markers
  184. cleared headlights but...
  185. QUICK ?
  186. Where's that rear deck removal DIY that someone posted before?...
  187. Clearing headlight same for 6th gen Civic?
  188. Techs Plzzzz Answer...
  189. Washer fluid warning light
  190. modified stock intake?????
  191. Rim Requirments!
  192. tanabe super racing medalion
  193. Head light bulbs
  194. Everybody else is doing it..
  195. Exhaust??
  196. diy springs
  197. what do you guys think
  198. shocks set-up
  199. Ebrake Button?
  200. Compartment/Switch Board Set-Ups
  201. Anyone install fuel pressure meter???
  202. bypass on Injen CAI
  203. CAR REVING UP AND DOWN BY ITSELF
  204. Should I bother with camber adjust??
  205. Carbon fiber hood buffing? PLEASE HELP!!
  206. Car Higher in Front than Rear
  207. SuperCharger/Turbo
  208. Anyone with the TYC Projectors installed......
  209. super charger
  210. Anyone with a trick trunk??? I need help asap!!!
  211. Intrusive or Resistance Engine?
  212. hows the octane fiberglass kit look like???
  213. Ghosty's New DIY
  214. ? 4 those of you w/ nitrous oxide
  215. (Ghetto-style) Turbo!
  216. front hood deflector....take it off or leave it on???
  217. trunk latch DIY
  218. DIY relocating HU
  219. LOWERing problem!!!!!!
  220. Can anyone supply pics of the rear lower arm where the endlink is?
  221. custom 2.25" piping
  222. What to do w/Intake?
  223. What cars to T25 turbos come on???
  224. reset check engine light
  225. Troubleshoot Wheel Vibration?
  226. CRAP! #)*&$
  227. WHY 17 WHY NOT 18inch
  228. QUESTION ABOUT CHROME PROJECTORs AND BULBS~!~!~!
  229. My Altezza's are foging
  230. DIY Painting Trim Pieces
  231. HURRY HELP...HOW DO I TAKE THIS OFF
  232. Side View mirror
  233. That lil' clear reflector in the corner of the headlights...
  234. Please help quick!!!
  235. removing trim piece
  236. Idle Vibration
  237. sanding
  238. Differences of 2001 lx and 2002 lx
  239. info on the D17a2
  240. Hyper Whites ... and yes i searched
  241. Does your e-brake suck?
  242. Does ABS disable after dropping car?
  243. Splash Gaurds
  244. poly camber kit
  245. brake conversions?
  246. Gas cap and Check Engine Light
  247. where can i get a bypass valve for my injen CAI?
  248. ram air hood anyone??
  249. EGT Gauge
  250. Installing Mesh Grill?
