- 2000 Honda Civic Radio code..Please help!
- Need some help with the Cluster & Dash LEDs
- i searched for it no luck, valve clearance ?s
- Got money to blow on an NA build need input
- Program remote - '03 Civic EX
- 90 sedan auto mounted brake light
- 90 sedan auto door jammed
- 90 sedan auto passenger mirror
- D16Z6, Will it hold up?
- Putting a D17A2 into 99 Civic EX - Some questions
- Honda Adds SPORTY Si to Civic 5-Door range
- Rsx spindles
- Automatic Y8 intake help
- snorkel for short ram on 2000 civic ex
- 98 civic won't run!!!!!!!!
- Disable Auto Door Lock/DRL Disable
- 2.5 vs 2.25 for mild NA build?
- Lookin for gearbox
- Car is unstable 60+ mph (can't keep it straight)
- Goin to the dyno... need 9-14 other people
- Civic Help!
- Operation: Radio Relocation
- Swapped D16Y7 engine into 2000 EX w/ D16Y8, but Engine will NOT Start
- Who does chip burning on CFs?
- HELP NEEDED!! Civic Roof Question
- Reset meter won't reset
- Need bigtime help here!!
- 94 civic dx turns over wont start
- Constant Power to Aux Jack and Windows?
- need help quick
- Megan Racing Exhaust: Compatible?
- motor swap
- Removing Ignition tumbler
- good trans?
- DC Headers compatible with Skunk2 test pipe??
- Need advice on buying/installing catalytic converter
- '01 MCU replacement help
- installing cz209 clarion head unit
- Tail light disaster
- DIY. Making an old rusted heatshield look new again.
- k20a3 b.s.
- Help w/low Idle when Compressor is on
- Leak around front of gas tank need help?
- Torn CV boot need DIY help!
- New civic help!
- lil question
- cHECK OUT
- Battery Change
- 2008 civic brake change (Front)
- Can you rethread heads?
- Keyless entry programming.
- 96 Civic Ex igniter interchange with 95 DX?
- Ball joints.
- Door latch wont unlatch... door stuck shut
- Soft Grinding sound on my 2000 civic se
- 2004 Civic Car Stereo Replacement (Automatic Transmission)
- lowering springs?... need help.
- Audio swap between 1990 DX and 1995 ???
- Clutch interlock
- I need help asap!!!!how do i remove carpet
- Electric window problem
- Programming Key Remote for 05 Honda Civic LX
- automatic trans problem in 99
- vehicle speed sensor
- Cooling fan not running?
- Changing Transmission Fluid in 07 Civic
- TDC sensor replaced - oil sweating/slow leak
- Exhaust System Rehab: 2000 EX
- Trying to replace right CV axle (Please help)
- rat-damaged cables and wires
- DIY: Modifying a OEM bumper to look aftermerket.
- engine swap advice h22a, please help!
- 97 honda civic hx engine problem
- 98 LX center console and gauge LED swap
- Y7 to Y8 Mini Me Swap - ECU install Clarification - Parts Check List for Mini Me Swap
- Need advise on performance mods...
- 95 eg civic cutting out
- Front Main Seal Replacement
- Newbie question
- Bucking - Burning Coolent
- modding led radio lights?
- trouble with cv's in a gsr swapped civic
- Painting/Spraying Front Bumper HELP!!
- Replacing Valves
- New distrib, car almost starts
- Need some ecu info for a swap
- Unpainted moldings...what to do?
- tinting help
- Engine Rebuild - Air Bag Question
- looking for cluster information...
- 09 Civic AT fluid change
- 1997 1.5i lsi gearbox
- Pink/Brown Stereo Wires
- 95 civic engine swap
- door won't open at all
- 97 civic sedan help
- Can anyone help a girl out?
- Driver side, read window no longer working
- Should I replace the fuel filter at 60K?
- 94 civic dx. click.. click .. click.. BOOM
- cluster ideas
- d15z6 mini me?? HELP!!!!
- auto gearbox-ecu?
- What is the ULTIMATE COST-EFFECTIVE Alarm System
- My engine growls.
- manual trans refil
- 1995 del sol engine swap
- dripping tranny fluid after axle shaft replacement
- Transmission swap
- No Start after rewiring
- DIY Internal USB Charging Wire
- passenger cv axle broke. so sad. :(
- 4th Gen 88-91 Civic DX SEDAN DIY Ideas
- 97 Civic EX 1.6 VTEC Engine Swap
- Honda transmission question.
- I need muffler help
- mesh grille?
- Speedi-boots
- DIY changing of grill for 02 civic sedan w/ HID fogs
- 01 Civic front rattling...I am fed up!!!!
- URGENT - PLEASE HELP - Malfunction Indicator Light - vehicle not running at all
- D17A2 help please
- HID questions
- head light questions
- 98 DX, disappearing noise, engine light on, stalls at low RPM.
- buffing the headlights??
- Diagnosing 93 civic front-end noise (video w/ audio)
- i need tips on how to buy a used car
- Can't make up my mind!!!!!!!
- No power going up hill --Stumble.
- emissions help
- check engine light, codes 8 and 16
- Starts but doesn't stay running?!?!?!?
- need a replacement transponder key for '01 civic VTi
- Changing passenger side axle
- DIY Dash Removal: 01 Civic
- Best Buy
- Fluid leak
- OBDII Interface
- 95 civic what about 96 motor
- Brake noise...help!
- mini swap???
- need help to install cvjoint for drivers side
- Help power windows on my 99 civic are very sluggish
- Rotors will not slide off (bent?) lugs
- is there any one that could help me change my head gasket ?
- How do you black out headlights?
- Tranny compatibility....
- Civic won't start after running for 30 minutes
- Missing harness plug on my radio
- Tech Question about Civic 2004
- Computer Reset Time
- AEM Engine managment system, worth the cash?
- exhaust smell in cabin
- D16Y8 Engine Rebuild Questions
- 1999 Honda Civic Replacemnt Part Help
- 01-05 civic tranny swap-Auto to Auto- non2vtec
- Newb has a few questions....
- How To - Fix Headlight Haze
- Why does my abs pump run when i go over bumps
- My door can only lock with a key
- Uneven break pad wear.
- DIY- 1998 Civic Replace Ignition Distributor
- clarion vz309 install need help
- Window Trim Paint?
- ECU issue need help and advice.. 02 si hatch k20a3 ecu # PNF-A03
- AC compressor bracket????
- noise from tranny
- Fog Wiring Ideas?
- Civic Hybrid rolls back on hills.
- tapping lifters, seafoam?
- After replacing timing belt car wont start
