- Broke my driver side mirror
- The Most Bada$$ Engine
- 97 Civic AC Evaporator
- Tips & Tricks..for more power
- Stuck ignition, steering locked, check my plan?
- Car Clock flashing, won't reset after battery change
- Question about draining clutch fluid?
- Acceleration probs/rattling engine
- Life as a tech failure
- Car won't start
- Diy: How to mold a screen (or anything for that matter)
- HID conversion
- Crappy carbon fiber
- i have an 87 honda crx and im wanting to do an engine swap wat should i use
- vtec/o2 sensor question
- 94 honda civic 1.6 vtec burning oil
- Honda Del Sol Gurgling Noise
- Carb swap!!!! Redline or?
- 2002 Civic DX can i add tach?
- I Need Help Pimping Out My 1996 Honda Civic
- dose any one know where i can find a 87 honda crx parts car ?
- 1990 civic sidemarker gremlins
- '90 civic RUNNING LIGHT gremlins
- non-vtec to vtec
- Engine mounts failing
- Custom Gauge Install issue!!
- Headliner
- diy home made tow hook?
- Engine Bay cleaning question.
- Moving Battery
- Where to Start?
- Where to Start?
- '89 Alternatore Removal Help Needed
- TPSensor
- 1990 civic dx, instaled head, pm3-8 need help to make it work
- 05 civic front inner fender plastic
- dose anyone know how to make a pm3-8 head work on a 1990 civic dx
- Code 9 - Cyp Sensor problems plz help
- Reardeck Spioler
- Euro Plate Mount
- HELP ==> RADIO code
- Hey a newbie here...
- 03 civic DX cluster swap question
- HELP ==> Radio Code (Mine isn't stolen, I think)
- Sea Foam
- selling crystal clear taillights for 93-35 hatch
- Bolt thread pitches?
- anyone no where to get cheaper parts
- Nippon Motors Inc California
- Coolant Questions
- Brake/Clutch Fluid Questions
- Noise from rear passenger side of 2006 Civic EX...
- Rev limiter? Runs bad after 3500rpm
- auto shift problems laggy
- HELP! Engine Codes P0335, P0336
- Can I fix it?
- okay im about to change my spark plugs
- need overheating help!-
- 2003 civic side mirror replace diy?
- Power Steering Fluid
- TDC and mini-me swap
- Cheak Engine Light
- Installing Headers, Purchasing
- 93 Civic Engine Swap
- Replace Windsheild Washer Nozzle on 2007 Civic
- headlights tailights interior ligh and foglight flickering need help!!!!!!!!
- DIY write ups complete. Check them out here.
- to all with afc neo
- rear brakes leaking need help fast
- 2003 civic EX Engine sputtering in idle with Check Engine Light
- Yet another fog light question
- Taking front seats out of 09 Civic sedan
- PGM-FI No.2 Relay removal
- Speaker pods Available for 92-2000
- Building a new engine!
- Silver gear shift plate & touch up paint
- leaking oil from block found spot need advice
- PRoblem....Oil leak
- '99 civic Idle issues after tuneup
- Replacing the stock head unit in a 2001 honda civic lx
- car problem i need help plz
- Where the frick is the alternator belt tensioner?
- R&R steering wheel on 8th Gen Civic
- Newbie needs some help - 2006 Civic sunroof issue
- 2000 Civic Si OEM shifter boot installation?
- Manual question on 98 EX
- 97 civic ex hesitation
- 2nd attempt at a headswap need some help
- Just finished headlights....
- ? about trouble code
- begining upgrades
- Finished Suede :)
- Clicking/poppimg noise from front of car
- i wanna go fast !!!
- 01 LX Project Help
- Custom Painted Stock Wheels Yesterday (Pictures!!!)
- Turbo d15?!?!?!?
- Radiator Replacement Issues
- 93 civic dx
- Exhaust tip question
- Screeching Problem, asuming the belts
- Vacume Hose Issue
- Please help!! need info on a progression of mods & motor
- Shift Linkage
- windshield washer problem on 07 coupe
- 01 Ex lookin for some bass
- Civic 04dx Cluster Swap question
- Turbo-charging an EP3?
- New To Honda's, and Already Stumped
- Head unit options for exact lighting match?
- Opinions... Please!?
- Installing a steering wheel from the EX-L
- 1997 EX Radiator Issue
- Can someone identify this part?
- 02 Rsx Type S seat install question. Yup I did use search and read
- 2001 civic EX After market Header!!!!!!!!!1
- Tachometer
- 97 Civic EX / replace lights behind A/C controls
- Putting in new radio & interior lights..HELP
- Door and window
- transmission range switch
- Trans. Temp. Gauge
- 2002 Honda Civic - ignition switch hard to turn
- 2009 Civic Dome Lights ("Spotlights") won't turn off
- DIY- Thinking of installing.....
- How to remove rear speakers in a 2004 honda civic coupe lx
- Tranny for a B series
- 1980 honda civic wagon
- Apexi NEO with D17a2 head swap - does it work?
- idleing problem 94 v-tch
- Door Lock Actuator..........
- B series Bare blocks
- catalytic converter questions
- replacing airbag (not SRS reset)
- windshield trim
- GREAT way to remove rust completely? ELECTROLYSIS
- LED Bulbs Look Darker than traditional ones on '02 Civic
- B16 SWAP Into 2000 DX
- Expansion valve
- Install Weapon-R intake?
- DIY airbox completed (for the most part)
- OBD Question
- need help on a DIY
- help!! need radio code!!
- My DIY light install finished
- Honda Civic 1992-1995 EG Suspension: control arms, assemblies and more
- Honda Civic 1992-1995 EG Wiper and Washer System: troubleshooting, removal and more
- Honda Civic 1992 - 1995 EG Manual Transmission: Removal, Installation and Overhaul
- Honda Civic 1992 - 1995 Del Sol Power Windows
- Honda Civic 1992-1995 EG Power Windows: tests, troubleshooting and more
- Honda Civic 1992 - 1995 EG Clutch: assemblies, cylinders and more
- Honda Civic 1992-1995 Disc and Drum Brakes: push rods, pads, calipers and more
- Honda Civic 1992-1995 EG Alignment: ride height, camber, caster adjustments and more
- Honda Civic 1992-1995 EG Automatic Transmission Removal and Installation
- Honda Civic 1992-1995 EG Electric Cooling Fans
- Honda Civic 1992-1995 EG Engine Control Unit (ECU): input devices
- Honda Civic 1992-1995 EG Emission Systems: egr, evap and pcv
- Honda Civic 1992-1995 EG Fuel System: injector, pumps and more
- Honda Civic 1992-1995 EG Air Conditioning: oil compressors, lines, fittings and more
- Honda Civic 1992-1995 EG Gauge Cluster: fuel gauge, oil pressure tests and more
- Oil Leak Help Needed
- Honda Civic 1992-1995 EG Idle Speed and Mixture
- Honda Civic 1992-1995 EG and EJ Ignition System: coils, ignition timing and more
- Honda Civic 1992-1995 EG Engines: compression, specs and system backpressure
- Honda Civic 1992-1995 EG and EJ Valve Clearance
- Honda Civic 1992-1995 EG Steering Column: horn pads, steering wheel, air bag and more
- Honda Civic EG 92-95 Drive Axles: fwd shafts, intermediate shafts and etc.
- Trying to Order Parts From Majestic Honda, having problems
- Fuel Pressure Gauge
- A/c problems neeed help!!!!!
- Del Sol Mods
- Sideview mirror
- What Exhaust Manifold is best ?
- 98 civic lx idle problems
- Question on Part Removal (Speedometer Wiring)
- Fuel Pressure Sys.
- crashed my civic and the seatbelts locked.
- window regulator pooped out....searched but have question
- Transmission Problem.. HELP!!!!
- Clutch Master Cylinder...
- Alternator issues
- wiring probs...
- help
- alright lern me up
- Look at this pic, Should I change the crankshaft?
- Wanted to see what other builders thought
- ac problem help please
- Overheating Issue
- Passenger Side Seat adjustment...
- How Come Nobody Addresses Big TB Qs?
- ecu pinout for honda civic fd1
- Rebuilt D17A1 Engine Pre-Lube procedure?
- 7th gen foglight problem - only 1 lights up
- Hello and a quick ignition question.
- lx to ex headswap w/afc quick questions
- Right temperature plugs for my set up?
- DIY: SRS Codes and reading them
- EG hoods...
- 94 d15b7 extreme oil burning HELP!
- 2003 Honda Civic Ex
- engine swap
- Clutch Problems
- engine swap
- Something I was wondering about
- interchangeable?
- Throttle position sensor
- Broken air vent
- Motor swap question
- recommendations on end links
- Axles and A/C questions.
- removing logos
- Rattle and Click
- Wheel stud 94 civic
- Spring clip ?
- 2002 Honda Civic LX 65k Shifting Problem!!! Please Help!
- Factory Recommendations
- driver's seat rocking (bushings)
- 99 Civic lx wont start
- My 98 honda civic shakes when AC is turned on... help?
- Motor Swap
- Air Conditioning goes warm?
- Vacuum hose
- Odd thump while steering
- HELP! Replace Starter 02 Civic EX
- Air Filter Housing
- Complete DIY's on starting, charging, engines, trannys, etc.
- Raise your clutch peddle?
- Final Clarification,2005 DX Sedan Power Window+Power Doorlocks?
- Leak in rear of vehicle?
- Exhaust Confusion
- (4 civic ex Radiator fan in-op
- exhaust question on stock civic
- How stiff is your clutch pedal?
- 90 Civic power cable to amplifier broken
- catalytic converter trouble?
- smoke tail lights
- HELP ! These 11W High Power LEDs Burnt My Fuse Twice!
- Speakers and Stereo
- A/C and Heating problems
- Whole lot of maint/repair next couple weeks
- Where can I get color matched trunk molding?
- 08 Civic SI Sedan - want to increase MPG???
- WS2 universal muffler
- Huge Gas issue
- Netural Safety Wire
- turbo...
- Hearing wierd noises... lol can I getta little help?
- Timing belt questions.
- My car makes super loud noises. Realy getting annoying.
