- 2003 Civic Header
- Another HID retro question
- 2004 white civic Mod?
- '08 Honda Civic vs. '02 Silverado 5.3
- DIY: Stainless Steel Braided Brake Lines
- 2005 Civic 2dr EX Key Copy
- 95 Civic computer hack
- Pics/Where to find - mini trunk lip spoiler and mazda 3 type rear ass
- motor mount question
- Disregard double thread
- "Rumble Strips" Upon Acceleration
- Removing Door Handles Help?
- Civic FD2R Ultimate Tuning Video
- Looking For Someone To Rebuild My Honda
- Short Shift Help !!
- Want To Put XM Radio In My 07 Civic LX
- AEM v2 installed, IAT sensor question
- Ractive external tach help!
- True Noob Q: Are All EX's VTEC's?
- HELP! Engine seized!
- Rebuilding an engine. Any suggestions?
- Color Change Est.
- Trunk mesurments
- Trunk mesurments
- white exhaust smoke
- cat back question
- Rebuilt motor install problems not wanting to shift
- motor and trany swap 01 civic
- Passenger Low Beam Headlight Not Working
- Need Quick Answers Please Ty
- civic won't start when driven in hot weather
- advice on a EK4 that has never been thrashed
- Starter & or Battery problem ?
- need help on how to install AEM v2 intake on 98 civc
- Honda Civic 2001 ( D17 Engine..
- D17 engine replacement
- How To Install Rear Quarter Window
- Engine Rebuild Progress
- what ecu chip?
- turbo mod
- Are 96-00 EX exhaust manifolds the same
- Can sombody send me a link for installing 07 civic ex OEM fog lights?? in dash
- Freakin Civic -- Cylinder Misfire Problem Persists!
- Can sombody confirm that this is the wrong harness for 07 civic fog lights
- How do you clear a mainteance reminder?
- Fuel Injector Problem?
- Do short throw shifters hurt your car at all?
- sound system help
- Is it possible to convert a SOHC to a DOHC??
- How much does a Hondata ecu help?????
- Wiring Harness
- painting rims
- Master cylinder reservoir.
- sohc vtec performance help?
- How much does a k20z3 cost???
- SRS unit location?
- auto cluster guage?
- MUHAHAHAHA suspension time! tell me what you think
- K2 Motor
- i got a 1998 civic and im having problems with the o2 sensors
- rough idle
- bad short ram
- The ultimate Intake FAQ – Intake questions and answers here!!!
- would just this muffler give me better sound
- Idling Problem! Help! ?
- wiring help needed
- Looking for the lighters of store
- Has cp, fuel, spark, NO START wtf
- A/C Questions for a 97
- Need help locating main fuel pump relay......
- Awesome fogs, no pics but ill try and get some soon
- Interior protectant?
- 2004 Civic Cigarette Lighter Fuse
- Cv Axle keeps popping out .. NEED HELP ASAP
- 91 honda wont get above 2500 rpms
- SWAP Cluster CIVIC 2001 DX to 2004 LX???
- Oil Leak!!
- So what should I do about my trany?
- 94 Civic SOHC V-TEC Ignition Coil Help
- IAT sensor replace
- Radio Bezel
- Ebay foglight install help
- help.....engine noise tick
- Drivers Airbag Question...
- AEM V2 Replica
- Fog Light HELP please…
- Rebuilding my Motor!!!!!
- 91 cv joint spline size
- 97 HX Low RPM misfire
- Thermostat help
- Timing belt install *video* Pretty Detailed
- HELP!!!!!! 04 civic si compressor locked up!
- 98 civic ex manual trans help
- general questions
- how to change the alternator
- 2001 Civic EX - Windshield Wiper Fluid Not Squirting
- important question
- Does NEbody have any opinion on Omni Power High Compression valves??
- Make the intake truly cold
- Painting the chrome hood molding/grille lip?
- Ansa
- Recurrent trouble code P0131 (O2 sensor)
- 1994 civic changing from dual carb engine to injection sohc vtec
- Idle at 2500 rpm when cold normal?
- illegal/legal
- Help Please, building motor ( R18 )
- stock radio question. please help!
- buildin the motor up!
- 06 si turbo manifolds?
- trunk leak Suggestions??
- Poll...Synthetic or Regular?
- panel removal
- What kind of battery?
- What axles do you recommend?
- Help! no fuel to engine.
- ever replaced a broke hood release?
- auto tranny fluid check
- Turning Problems
- 96 ex suspension upgrade Q's
- Brake Fluid Change Maintenance
- Tire Noise
- New DEPO Tail lights install??
- Tranny housing paint?
- motor question
- 05 LX 4door, Front Wheel Bearing damage,help on this
- 93 civic 4 door EX engine swap now doesnt run...
- A/C Expansion Valve Location
- Semi-Basic Engine Swap Help
- Quick Question on 98 civic battery terminals
- Need Help With After-Market Keyless Remote
- Foos > Ingalls - Damian can use his Stiffy soon
- low idling prob.. any help?
- Type R rear lip and exhaust?
- 94 civic 1.5
- 94 civic cooling fan motor doesn't go on. idle varies
- For those with KPRO D17 - Cold Cranking
- 4 pin --> 5 pin O2 sensors
- Help removing my seats
- Color matched trunk moulding
- Enginge Misfire Hesitation in 4th and 5th gear
- I think I need new shocks, and bad.
- Engine Converstion
- ebrake handle 2002 civic si
- Blue wire on aftermarket stereos
- 1991 honda civic dx
- Is it a timing belt issue?
- Cool differential swap video.
- Door Lock/Actuator Part Number for '03 Civic
- this is more of a dvd player problem than it is a civic problem but...
- High Pitched Noise in the front end! HELP!
- how to remove factory head unit from my 2005 civic
- hello forum, i have a problem!!!!
- A 94 Honda civic exhaust
- Engine hesitation
- civic wont crank... HELP!!!!!
- Civic seat foam any aval?
- Civic EG8 Hard Start
- 2007 Civic Windshield Wipers
- Where can i get the black rubber/plastic bracket for my rear foglight?
- Hatch strut mounts?
- DIY: valve cover paint
- Overheating Problem
- im really confused!!
- what kind of welder do i need?
- 03 honda civic ex sedan city driver tuneup
- Overheating Problem???????
- would this bolt on...
- Primary hood latch stuck open!!!
- DIY: Converting primary o2 sensor from narrow to wide band for KPRO USE ONLY
- Batt light/no start
- 93 civic 4dr ex sidemarker question
- help finding my transmission type
- Squeeking Noise
- 2002 Honda Civic Ebay foglights
- help
- Tsudo Type X
- Kinda new at this
- 99 civic ex question about my engine it sounds loud?
- Cahnge Seats!!!!!
- Wierd sound front wheel area...
- Jdm bumper pole question's
- halo projector wiring
- The 02 Sensor Thread
- Radio Code !!!
- engine swap questions
- question on exhaust manifold?????
- 05 LX Removing Front HUB, stuck with Lower arm and Hub. cant separate.
- Torque setting d16y8
- D17 Psi?
- 98 honda dx shifter
- looking for cheap crush washers 18mm 90471-PX4-000
- Fuel Pump DIY?
- Performance suggestions for '92 VX?
- DYI 60K service
- 1997 civic reverse lights
- ARE STAINLESS STEEL BRAKE LINES BAD for ABS???
- how install aero kit on my 2004 civic si-g coupe
- Ticking sound (D17A2)
- Got an '89 Civic last night. What next?
- Help Find TrunkLid?
- Need help please...lx to ex swap!!
- EK9 momo steering wheel
- ef hatch grs brakes
- RSX seat airbag question
- 96 ZC motor is there a such thing
- Guess whats getting installed tomorrow :)
- b16 ex coupe
- DIY: Check odometer on disconnected Cluster
- D16Z6 cam holder, rocker assembly and cam in D17A2 head
- Coolant & ATF change for 1st time...
- B16A problems
- Cigarette Lighter Socket, 04 Civic
- Programming Civic remote or transponder key
- d16z6 mods?
- d16z6 problems
- project advise please!!!!
- 1996 honda civic ex automactic swap to manual
- symptoms of a broken side motor mount?
- HELP! Does anyone have a 2004/2005 Civic Special Edition? (cdn)
- removing 01-03 Sedan door moulding...
- how do u remove the LENSE on the side mirror?
- ECU problems or what?
- buddy club catback ?s
- Need help with Omni front lower control arm install
- H2B plans
- Underglow Ideas for DIY
- Can i make a skunk2 fit in my civic?
- Changing the tranny oil... Is it too late??
- MONZA Exhaust
- Replacing Headlight Bulb
- Changing Dashboard Lighting
- best?
- IM THE PROUD OWNER :rockon:
- yellow headlights
- help with ground wires
- Clip foor door panel?
- Is this paint good to black out my head lights
- smokes like theirs no tomarrow
- New ignition system
- h22a or b18-16a into a 97 civic
- replacing hood release for 1998 honda civic si coupe
- cat...
- Help W/Rear Brake Light Bulb Replacement
- just got an 05 ex special edition...
- Underglow and engine dress up
- Timing belt change
- Center console armrest
- how to turn off passenger airbag? 03 ex
- 05LX front brake Cylinder damage or not?
- 2005 LX SE Shocks Questions
