View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57
  1. HOW TO: Swap B-Series Camshafts (VIDEO)
  2. HOW TO: Swap a B-Series Differential (VIDEO)
  3. SsensorsS
  4. srs unit replacement
  5. Can you install a spark plug wrong?
  6. Aftermarket Headlights
  7. Made a rose today
  8. Steering Problem
  9. 2001 civic lx coupe hub cap help
  10. Sideskirt hardware kit
  11. carbon fiber question
  12. 99 ek hatch b16 problem anybody know
  13. Need Plastic Radiator Tank
  14. How does dealer change brake fluid?
  15. 01 civic lx stock cd player/radio removal help
  16. Water in fuel tank!
  17. 99 Civic dash removal
  18. LS B18 and b18c5 head
  19. Unexplainable stalling
  20. Door won't stay unlocked
  21. 1st oil & transmission fluid change at home..
  22. 1991 civic suspension/brakes/fuel problems
  23. HELP! 1997 Civic keeps blowing SP/Alternator Fuses
  24. HELP 90 HB Civic not running right
  25. Axle Nut
  26. Tricks to increase Civic MPG?
  27. is this okay??
  28. Downhillin' Dealership!! [rant]
  29. Need A New Radiator? FYI
  30. 1996 CX retrofit
  31. HELP dash lights out
  32. need some head torque specifications
  33. Ignition Coil Bolt
  34. D16Y7 Power gains
  35. painting polyurethane lip?
  36. 2002 Civic Radio removal
  37. B18C1 with Pm6 zdyne flashed ECU 02 oxygen sensor problems
  38. 01 civic coupe front upper grill help
  39. Valve clearance for 2005 Civic
  40. 60,000 mi. maintainance
  41. 95 civic dx interior
  42. possible timing mess-up
  43. 2000 new headunit install
  44. help please...what would i need besides motor to go from d15b2 to a d16z6
  45. 1998 Civic moonroof not working
  46. Catalytic converter ?
  47. A/C refill in 95 civic
  48. Changing the Throttle Position Sensor on a 2001 Civic
  49. how to change/replace a speed sensor
  50. Need help removing cup holder
  51. piston question
  52. bone stock d17 spins rod bearing?!
  53. Unlock is lock and Lock is unlock.......
  54. Tire sizes
  55. Maybe Someone Can Answer This?
  56. d16 piston rings into d17?
  57. Major Problem Plz Help
  58. first whats up new here, ne one know
  59. 01-03 fog light template
  60. Just Robbed darn
  61. 1985 Honda civic question need help
  62. filtermag magnets? harmful at all?
  63. engine rebuilding tips... very informative!
  64. DIY: Cruise Control FIX w/ LED tail/brake lights
  65. thrust washer install? (crankshaft)
  66. Valve Cover painting
  67. How Do I ? Retrofit Blue LED's on climate control bezel?
  68. Just some random stuff.
  69. Where can I get a Tach for idle RPM?
  70. Removing ecu
  71. reconditioned my headlights this morning...
  72. iPod in a 2005 Civic LX Sedan
  73. no compression due to bent exhaust valves
  74. The Danger of Power Pulleys & Understanding the Harmonic Damper
  75. looking for aftermarket d17 motor mounts?!
  76. BOILER!! :) assembling new block this weekend. got few questions
  77. Del Sol Window Regulator
  78. quick mod to regain lost performance
  79. Fix Alternator/Engine Noise!!
  80. Any serious vibration problems with hasport ekstk motor mounts?
  81. Genki steering wheel and 5 point belts with seat
  82. A/C Compressor: 01 LX <-> 03 Si ?
  83. 2002 honda civic bucking
  84. My Power Locks kinda stop working
  85. Looking to V-tec my B18B, what head and other parts will I need?
  86. ABS system relocation?
  87. Question for all of your DIYers
  88. Rod Bearing Question
  89. The Right Air Filter
  90. So, I'm painting my headlights finally.
  91. HOW TO: Build a GSR Engine (VIDEO)
  92. Replacing 04 LX Exhaust Manifold/converter
  93. Need help
  94. d17a2 rebiuld NEED HELP!!!
  95. Exhaust Manifold Torque specs
  96. Anyone Interested?!??!?!?!
  97. tranny problem...any ideas?
  98. looking for a new dashboard look? pretty cool.
  99. Low Tire Pressure Indicator
  100. Odometer Problems
  101. cf hood refinishing?
  102. Oil in Air Filter Area
  103. How do you remove the roof/headliner????
  104. Heat on o2 sensor cables
  105. Adding Air intake
  106. Axle Stuck in Hub. Help?
  107. Motomaster throttle body cleaner
  108. 97 Civic: Tranny, axle, and mout problems.
  109. Hey since there was an aftermarket audio system installed the powerlocks won't work..
  110. has anyone shaved there wire cover?
  111. Where should I get my ES inserts?
  112. help need a map to make obd1 wirering
  113. window wipers won't squirt
  114. DIY: Torque mounts using urethane.
  115. Feels like a broken motor mount but it isnt...
  116. gauge cluster question-need help for 2005 civic
  117. Am I loosing my MT????? please help
  118. Can I convert manual to auto?
  119. Looking to swap the D Series.
  120. Engine Check Lamp ON, OBD II P0715
  121. catalytic converter
  122. 96 civic CX
  123. Is this a SCAM???
  124. MAP sensor and O2 sensor question
  125. AP2 Steering Wheel Q's
  126. Map sensor/ECU.
  127. Em2 Ecu
  128. Can I measure RPM with this?
  129. How do I check if ECT switch is bad?
  130. "Stumbling" issue
  131. Thermostat: Do I have to remove coolant?
  132. Stroker kit?
  133. exhaust help!
  134. Overheating Problem
  135. blown head gasket
  136. DIY: S2000 Steering Wheel FINALLY
  137. question about Tinting your tail lightsss
  138. Checking the deck for warpage
  139. Shifting into Reverse hard
  140. D16y7cam switch with a B16 Cam
  141. D motor series compatability... specifically shortblocks
  142. Let's talk swaps
  143. 3 months old Stream batteries problem
  144. Looking for si shift boot DIY
  145. What is the point of the resonator?
  146. Engine makes weird sound on struggle.
  147. Problems with Removing the Front Bumper??
  148. Where do I find proper hose clamps?
  149. How to remove paint-stain from leather
  150. Awww man, intake manifold leaking.
  151. what type of springs work well?
  152. Hondada intake manifold gasket?
  153. Saying Hi and Exhaust question
  154. Should i be worried??
  155. Chirping clutch?
  156. headlight conversion
  157. Timing Belt Replacement
  158. Need wiring diagram for projectors
  159. DIY: forgotten tune-up mods
  160. Need help with Changing a Front Strut / Shock Abosorber
  161. IAC valve issues.
  162. Seafoam: Yes or no?
  163. changing 2nd O2 sensor???
  164. Lock actuator problem, please help
  165. Primary o2 Wires (HELP ME MATCH EM UP!)
  166. New engine = no speedo/gas gauge
  167. Another problem, I am so fed up with my car!
  168. Coming soon: The rsx rear seat diy to end all!!!!! Split folding
  169. Another MPG Question
  170. How to make a simple areo part (rear lip)
  171. switching alarm outputs?
  172. Ask Me About DIY Stuff V2!
  173. 03 Stock seatbelt buckel VS 02 stock SI seatbelt buckle
  174. remove immobilizer?
  175. Replaced my broken motor mount.
  176. Do you agree with this? (startup)
  177. R134A specifically for CIVIC EX 1995
  178. 2008 EX-L Civic Sedan Bass Speaker question
  179. Strut King Short Shifter & Shifter Bushings/Boot Install! 56K No Way!
  180. Does IAC valve need to close completely?
  181. one fog light is dead?
  182. Yes another Retrofit Thread
  183. Please delete me....
  184. I broke my trans...everything's good again!
  185. DIY: Revo SS (short shifter) stiffening, $0.98
  186. trans bearing explosion!
  187. My engine one smells like gas.
  188. How to get axels back in?
  189. Cracked Manifold, Need Help
  190. EX cluster swap problem (searched!)
  191. Valve Cover
  192. need help to install lip kit
  193. Help me locate this part?
  194. Foos Catchcan DIY
  195. How do I clean aluminum?
  196. Weird sound when accelerating uphill.
  197. k20 6-speed on a d17a2
  198. Quick torque and hp
  199. Door lock actuator weirdness '01 civic LX
  200. I need to replace side mirror
  201. Help with Civic 1.6 Sport Please
  202. Civic Sport Xenon bulbs HELP please!
  203. headlight adjustment for 04 civic need help
  204. Field's SFC-VTEC help!!!
  205. B20 Swap High Idle problem
  206. Right Direction
  207. HKS Hi-Power Exhaust - any info
  208. 91 DX Ignition Timing
  209. DIY: REAR EP3 Seats in EM2
  210. wtb a cheap civic
  211. 89 Honda Civic need Help
  212. Hooking up HHO again.
  213. Question about clutch.
  214. 2005 Civic Reverb - How to Disable alarm
  215. B20 into EK Problem
  216. 91 civic with b16a4 swap
  217. Please help. I have these questions.
  218. 02 Civic Si, Both headlights died, highbeams work...recall is not covering my VIN...
  219. Rough idle after battery install
  220. Power Steering on B Series
  221. RPM's Rev in 2nd & 3rd but moves slow
  222. Help me black out my headlights
  223. dc headers on lx?
  224. i need code for the radio 04 civic
  225. headlights dont work but one high beam does???
  226. Coolant hose/Hoses who makes em?
  227. How do I install my Iceman intake?
  228. need upgrades for my dx
  229. What do you think about a custom Tanabe Racing Medallion cat back system?
  230. My exhaust manifold is cracked.
  231. cat back exhausts?
  232. Anyone
  233. Oxygen sensor ID
  234. Does Anyone Know How To Use Touch Up Paint ??
  235. 98 civic timing belt
  236. Can anyone help me identify a part of my engine?
  237. Maintenance Question
  238. Please Help: Accident on 05 civic who to go to Dealer or Geico ARX?
  239. Catalytic Converter 1997 Civic
  240. Civic Specialist!?
  241. Had accident with 7 day old Certified pre owned Civic 05, found out some stuff
  242. When should rotar/distrubuter be replaced?
  243. Timing belt question.
  244. Body kit Inquiries
  245. Paint for type R grill lip SSM
  246. Installing catback help!
  247. My Engine....Swap
  248. Ball Joints
  249. Why do wiper blades suck?
  250. Rear brakes: What do I need?
