- Quick information on HID for cars
- OEM Spoiler (Trunk Spring Questions)
- How do I replace my automatic shift knob?
- b16/b18 and h22a
- Please help with new exhaust parts, ( I think I posted in wrong forum first time.)
- What size socket to change spark plugs?
- Badge removal - how to clean the outline of the badge ??
- What's the easiest way to adjust timing?
- DIY: Timing belt 96-00.
- No start, weak spark, belt noise... Any ideas?
- Anyone have trouble getting into first?
- Help!! Speedometer Broke...
- No reverse lights...
- Tranny Swapppppppp
- 2001 Transmission Swap HELP!!
- personal steering wheel?
- Question for swapped members..
- New rotors or resurface? And brakes.
- EP3 front seats!!!
- Complete DIY write up on aftermarket steering wheel installation
- 1991 hatch with a d15.. most power bolt on?
- 87 Si Clutch Help
- CV joint covered in oil, boot busted.
- Low City MPG From my New Civic Hybrid
- '00 Civic shuts off when A/C is turned on?
- Bulb Info Please??
- shifter nightmare!
- oil pan question
- Anyone know what side skirts these are???
- 02 sensor trouble
- Tire Rotation per Honda or "as taught"
- Please help, car won't start after starter motor was replaced
- Civic questions
- New brakes, but no shims?
- Outer boot: I don't get it.
- SRS Light On WITH Code 7-2 "Internal failure of SRS unit"
- bad morning
- Trunk mounted radiator, think it's worth it?
- AEM brakes bedding procedure?
- DIY auxillary wiring for a '93 LX
- Will this ECU work in a 02 ex?
- CF hoods
- My Stupid window
- need help replacing fuel tank 2004 civic
- Timing belt replacement after 7 years, but only 26K miles?
- replacing ac pump
- Cheaper OEM Part's
- rsx dash questions and wiring..
- Coil pack screw missing an spark plug issue
- gen?
- DIY needed for installing a starter
- Cruise control sticks or hesitates
- ESMM install...help (DIY pg 2)
- Opinions on b18b engine and build
- Help with iat sensor
- Math class about cars
- OEM or Sylvania Silverstars
- Condenser Fan Fuse Blowing, Refrigerant Pressure High
- Bolt Info Needed Please!!!
- Where can I get bondo for the door panel D.I.Y?
- Interesting header article
- looking for advice on v6 swap
- 2002 Civic Lx Engine Swap
- 98 spoiler removal
- quick question
- 3 Questions!
- Question About Stock Radio???
- Troubleshooting won't start
- 02 Civic Bumper!!
- Need help
- DIY 01-03 civic reverse glow gauge 5mt
- Transmission problems. Help plz, lol!
- Calipers
- Quick Question on K20 swap
- wont turn over
- How To Replace Headlight Blubs on 06 Civic EX Coupe.
- 2004 Civic Si: Please help locating Cabin Filter
- K20a swap
- IACV code ?
- Automatic to manual: is it possible?
- '91 Civic H/B only two plugs firing
- Front Thump Noise
- painting headlights problem.....
- Popping/Klunking Noise
- Coil Packs
- 1.7 to 2.0 engine swap
- Anyone have this Service Manual?
- i need help fast
- key won't turn at all, pls help. =[
- P/s
- HELP!!!!!! 2001 - 2004 Civic Ex Auto Trannys.
- 98 civic sir DASH
- Iridium vs. Platuinum vs. Std
- steering wheel lock.
- help....fog lights???
- Sway Bar Needed?
- Throttle body spacer and idle problem
- Engine swap question. Stock-Vtec
- My Honda
- its missin
- trans swap?
- Help on a problem
- SRS Removal?
- 06-07 Foglight install (D.I.Y)
- Help on a problem please, damp spots...
- Help please!! 2001 civic ex
- '94 DX getting the best of me
- Just got my Fugita CAI
- boost gauge question
- Clutch Noise
- 2 quick questions.
- AEM air filter in 6th gen?
- How do you stabalize engine/tranny?
- 2003 civic ebay fog lights electrical install
- Bumper Question
- Stock airbox removal and sri install
- Is a new set of headers worth it? 03 EX
- My windows doesnt work..
- Adding an AC unit to a '93 2d Civic DX?
- Engine shakes at 3500 rpm range
- chattering noise under hood. HELP
- ECU chip trouble
- Need DIY Lower Control Arm removal (front compliance bushing)
- scratch removal
- Remote Start Help
- Hybride regeneration
- B series motor into 89 wagon
- DIY: RSX seats. (02 seats into 03 civic)
- Gutting
- The ultimate DX/LX header/exhaust FAQ
- need some help
- 99 UK coupe eng man probs D16Y7
- 6th gen lower mount problem
- Need Help
- Why Cant I Get The Motor Out?!
- Help
- Flywheel Question
- Blinker Wont Click Back...
- 00 civic coupe swap options!
- DIY: Painting your steelies feat. a card trick
- Question
- Would this busted part cause my trans problem?
- B16a2 Problems!!need Help
- HELP!!! need template.
- Why does civic speed fluctuate?
- Where is EGR on a 91 Civic
- installing new steering wheel
- Are all RSX leather seats heated
- How are cylinders numbered?
- 1993 sir will not start please help
- 97 civic heater bloer not working
- Fans
- 99 heater blower problems etc
- 2006 honda civic srs module location
- keyless entry installation
- Hds = Obd2 ???
- Ls Vtec build!!!
- Swaped A2 motor into LX - **PROBLEM SOLVED**
- Any D.I.Y. for changing gauge skin?
- I Need Some Help!!!
- 7th gen stereo antenna help
- 06 civic coupe radio reset code
- So one of my abs sensors is....
- b18 injectors same as d16??
- P1456? loose gas cap??
- Headlight for 99 Civic
- DIY Custom Hub Caps
- 2000 SI front and back end conversion for 96
- 01 civic auto trans Drive light flashing
- How much trouble to replace airbags in a '97 Civic?
- 16" snows on steel wheels on my 07' si??
- 00 Civic SI problem PLease help!
- 02 LX heat issues.....
- 07 Si - High Idle - Cold
- Where can i find the engine code for 00civic(jap import)
- ecu troubles!!!
- help wiring projectors on anzo projector headlights for 1994 civic
- Help on a turbo for 2000 D15
- Free Performance: A weight loss plan for her
- Problem's with 03 EX Sedan
- 8th Gen Factory subwoofer Replacement
- Several brake questions (long post)
- type-S axle back?
- dyi powerlocks and power windows on 04 civic
- Door Mirror Replacement
- Skunk2 Intake Install Issue
- Tach install question 2001 civic dx
- Fog Lights on 8th gen coupe
- aftermarket d17 rod bolt.
- Tach install problems 2001 civic Please Help
- mini-me headswap info needed
- car parts location question
- Battery relocation help!!
- SRS Light problem
- valve cover gasket help???
- Speed Sensor Problem? 96 EJ1
- How To: DIY Red Lit Gauge Needle's (6th Gen)
- Fabrication tool!
- generic pcv valve part #
- Why is my voltage flaky?
- Belt Squeeling Question
- Apexi VafcII owners manual
- help with vtec
- Stereo tech question
- Problem with aftermarket tach?
- '94 EX door lock/electrical problems/question
- So, what engine is this?
- engine putts and sputters when a load is applied
- Need to replace lower oxygen sensor for my 2000 Civic HX
- My Ecu Is Bad????
- Removed ac from 97 need help
- Valve lash
- 95 civic coupe problem
- So wtf do I do now? (Cracked thermostat housing, pics)
- disarm alarm - help!!!!!
- timing
- another mini-me but more technical ha ha
- Wind Noise 96 Civic Windows or Door?
- Energy Suspension motor mount inserts on an automatic?
- need stock ride hide measurments
- location of Ecu?
- WANTED 01 civic lx exhaust manifold torque spec's
- ARP Rod Bolts Install
- Automatic Transmission Flush
- Wide band help!
- 89 1.5 with a 6 code, help!!
- revo SS (greys kit, whats in it?)
- 93 Civic isn't getting any fire
- Can someone identify this part?
- Proper Harness Installation without Bar??
- DIY sidemarker LED retrofit, part 2
- Need help with Radio Code
- Just got HID fogs. Is this how I switch a relay?
- new to retrofit .. question?
- cool air intake problem
- E-manage Blue 93 Honda Civic EX/VTI VTec Not working HELP!!
- custom hidden silencer?
- My new toy
- DIY for parking lights installation?
- IS my engine really gone?
- 2003 LX Front Bumper Dented in Snow
- DIY Strutking MT Pedal Kit Install
- Stage 2 NA build questions - Haters keep out
- Help with taking apart IAT sensor
- Generator belt tension: What tool?
- DIY StrutKing MT Shifter Cable Bushings Install
- '05 Civic Sedan - iPod?
- head gasket DIY help
- I need advice!?!
- DIY: Gearbox's Projector Retrofit
