- Sedan Tail light removal
- Is it hard to put stock springs back on?!?
- Front Lip install....
- A/C Issue
- 04 Civic Sedan Grill on Coupe
- Need Help!!! Want Front Sway Bar On My Vp
- S2000 AP2 Steering Wheels Question
- apexi NEO
- Experts... HeLp!! My Door Won't OpEn!!! DId this ever happened to you?
- installing window visors!?
- Removing Manual Mirror Control?
- Remove battery for coolant flush?
- blacking out tail lights?
- DIY wrap parts in CF
- need help for foglights
- Ecu
- paint?
- usd B16a 4d ek mounts are realoooohly bad, what should i use?
- Tint question
- Another Rev limit question.
- Tightening down the steering knuckle nut?
- hello guys newbi here need help on crooked steering wheel n mount
- info on my 93 del sol si
- Help with Smog/CARB
- Motor Mounts or Engine Damper?
- DIY Front Liscense Plate Removal
- need tranny rebuild
- Need Help!!!
- replacing main pulley the one that hold three belts
- Anyone with Red H Badge (front)?
- Seat Belts
- Drl... Again!!
- apexi neo wiring
- Are valve covers swapable?
- DIY for adjusting TPS?
- VTEC timing belt
- tinting tails......
- Digimoto settings for tuning
- Help!!! timing belt problems
- power steering removal question
- Screw the rev limit!!! How do you remove the Speed governor
- Catback Replacement, 94 Civic Hatchback
- If anybody can anwser my questions?
- DIY: Install Tracking System
- Hood Pin Install?
- Cam shaft 180 degrees out
- now LED sidemarkers...
- Help!! Tranny Blown !!
- EX axles in LX tranny.. does it work?
- TL steering wheel ?
- How to install a tach in my 2000 si
- Question about VAFCII setting on 03 SI Htchback
- n/a k20a3 vs. turbo d17a2
- AC Pressure Switch
- has anyone ever swapped this k series in there 7thgen???
- stupid, but quick cluster question
- 01 and Up Civic Online Manual From Me RdZLyZ
- Spider Cracks inside headlights?
- EX Head VTEC Controller
- Head unit to speaker instalations
- Oil Gurus! Questions not answered regarding Synthetic oil.
- front lower control arm suspension bushing replacement
- switching to power windows and trunk?
- can anyone find this starter kit info?
- sucks ownin a vp 04 help needed
- how much hp with n/a setup
- 2002 Lx Header problem
- 98 + 00 wats the difference ??
- k20 injectors w/ SF fmu??? does it work?
- Tachometer plug and play
- I need ideas for RSX Seat Mod
- oil in my downpipe w/ white smoke. car bogs out.. wtf?
- Im New and I need help!
- OBD1 ecu relearn proceedure?
- Do not use this paint
- K&n
- srs light keep on turning on...reset..on
- airbag connection
- Short Throw Shifter Recommendations
- Air conditioning DIY?
- How to replace the distributor rotor?
- 94-00 civic motor ?'s
- 1991 civic 4wd performance upgrades?
- Civic 05 DX Alarm Install Questions
- Valve Cover Painting
- installing a spoiler need help ASAP
- Free Honda Modifications
- Quick cluster question.
- Replacing the clutch in an '87 Civic, tips needed
- RSX seat cutting
- Add Pictures = Get FREE T-Shirt
- 05-06 Rsx Seats
- Removing door panel from a 2002 civic
- Oil filter thread size
- OEM sides - trouble finding hardware
- 8thgen seats in a 7thgen?
- Radiator Replacement
- Looking for 05 Stereo Install
- 03 Civic Hybrid: Can't put the part back in. Need help!
- Debadging 07 SI
- Sedan Door Handle Removal
- window tints
- Man, i dont like the underside of my car!
- Prepping block surface and cylinder head,etc
- Time to tidy up the Teins!
- DIY add cruise control on my 92civic
- How do you get your car to sound like this?
- dash kit
- New civic (1993) tune up help/ smog
- 3/4 Gear noisey 5 speed
- 98 Civic Alarm wouldn't shut off & won't start-Help me
- new engine for my civic
- Cluster Question
- motor mount question
- Synthetic Tranny Fluid? 5 speed...
- honda shuttle
- Noob: A couple of quick questions
- Recommendations on new civic speakers
- 98 civic driveshaft boot
- Leaking water from bottom?
- Disassembling Side Mirrors
- how can I choose a suitable inverter for my laptop
- Voltage Regulator, where is?
- making a diy for new apexi neo
- Noob: Questions about OBD2 and Check Engine Light
- sup everyone.
- signal light question, please help
- Wiring hybrid cluster diagrams inside!!!
- couple questions before begin wiring neo
- Setting the timing...
- question for all shop mechanics
- '96-'98 DX cruise control upgrade
- How many members w/ stripped interior?
- B16a2 Conversion
- How to determine engine
- Stock Intake Issues... Quickie Help Please
- Check Engine
- How do I change the air filter in a 2005 honda civic ex sedan?
- ep3 dash??
- Smog Help.
- 3rd gen. engine swap with 4th gen.???
- Help!! Can't remove U-clip!!
- engine noise
- a/c compressor
- 5 point harness
- D17 injector plate on a Y8 mani? Would it work?
- Custom Interior Trim --> What should I do??
- complete dismantle
- PCV valve ?
- exhaust
- air conditioning
- HID question?
- valve cover bolt broken in head...
- aftermarket d17 rod bolts?
- WHERE TO GET ALUM. BUSHINGS (shifter)
- DIY (EVERYONE Must Read this one)
- Timing problems on 87 1.5 si
- car trouble! please help!!
- AC Recharge kit overcharged my system! What now?
- manifold heats up to red color. HELP PLEASE!!
- P1259 Mis-fire?
- DIY Removing air vents on '01-'05 EL/Civics
- How Do I Turn Off Seat Belt Reminder!!
- diy dent removal?????
- Battery and Gauges dying, help please!
- Help w/ electric fan
- 7thgencivic exhaust question
- 01 Civic Voltage Regulator
- 92 hb si sohc vtec want help to make me faster
- Cali Smog folks...
- Honda EGR problems..
- nitrous
- 97 Engine Swap
- Volt gauge not working
- I want installation of throttle
- Turbo??
- 98 Civic EX Horn Problem (Won't Stop Blowing)
- 92 Transmission Problem
- Valve clearance too tight?
- torque converter opinions
- Coolant change
- new intake manifold...rev problems now
- I Need more trunk space!
- taking apart headlights???
- help!! on replacing belts
- remove corner tail lights
- need help shedding light on new topic
- 2002 EX coupe -- Clicking sound from clutch when engaging and disengaging. Any ideas?
- Adding a sixth gear?
- Honda d17a2 head code????
- Wiring diagram help.
- UPDATE: FUBAR'd - Speedfoos DIY Valve Cover Painting
- Uneven wear of brake pads...
- My Stealership 2001 & Later Civic Service Schedule w/prices
- My valve cover project- stay tuned
- 93 civic Si temperature control broken...
- engine oil for 1.6 93' Si
- DIY - Speedfoos' Koyo Radiator and OBX hose install!
- First Time Civic Owner! HELP lol
- Putting in new window. Any tips???
- Hello iphone in my CIVIC
- Solution to running no hood pins with cf and not be scared!
- auto to 5 speed swap
- 1993 Honda Civic Ex.. 1.5 Litre L4
- some one please help!
- Installing new belts, should I add belt dressing?
- Black Out
- Removing Factory Muffler
- Can't get pulley bolt off. Argh!
- DIY: AutoPower Rollbar/cage Install by integ108
- Left engine mount busted. (pics)
- Crank pulley TDC, confused.
- How do I remove spark plug seals?
- Questions On Air Ride Suspension
- Successfully installed new timing belt.
- Question on a 1990 Honda civic HB Dash
- Little Swap Info Needed
- Is this a good clutch?
- HID retrofit!
- k24 swap help needed?
- AEM tru power pulleys
- Engine/tranny shakes at low RPM takeoff.
- Crower Vavle Spring Install
- Change Backseats in sedan???
- Removing the auto tranny, help! (pics)
- New/Excessive noise problem?
- DIY - Valve spring/retainer/valve removal - VIDEO
- Lights keep flashing by it self? HELP!!
- ls vtec swap 98 civic
- Fender and bumper swap?
- Need feedback on performance mod
- timing question...
- DIY: Changing Spark Plugs w/pics (noob version)
- Carputer D.I.Y.
- need help, a/c compressor belt, which one?
- Changing out the tail light cover..help.
- Need HELP!!!!!!
- Help with auto shifting problems
- diy blackedout headlights
- universal o2 sensor?
- b18c conversion
- Engine swap question?
- help cylinder with out spark plug back fired
- $5 Rebate on Fram Oil Change
- Tein-S or Eibach PICS
- afc neo mounting questions?
- cf honda front emblem insert
- 2001 LX Stereo Install
- Now that you've heard Blk4blk2K1's degrade to brakes,this is why Big brakes are good!
