View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57
  1. picture posting
  2. is it possible to ...
  3. Short throw shifter
  4. E-brake boot
  5. Greddy Emanage ultimate
  6. Seat Belt Minder Disable HOW!??
  7. Blue Glow Needles DIY
  8. can ex parts work for a lx model?
  9. What brand is good for engine assembly lube?
  10. Seat Question
  11. huge problems with swap and vafc-ii
  12. Opinions and Input
  13. blinker problem
  14. Stupid Question
  15. Viper 5000 + Remote Start
  16. purple LED light conversion
  17. WRX engine in a civic????!!???!
  18. resonator box
  19. raise hood
  20. Photos for simple DIY - installation of Optima 75/25 battery.
  21. spoiler question
  22. brake change time
  23. Canadian heated power mirror wires
  24. Car hickup. any ideas whats wrong?
  25. Backseat
  26. AC Functions
  27. What should I use for an intake tube?
  28. nology hotwires
  29. How to change headlights for Civic 05
  30. switching high and low beams
  31. HHO Generator In A Civic?
  32. Restoring grip on leather steering wheel..
  33. wiring a alpine 310 into 04 ex coupe?
  34. CAI Filter oil needed?
  35. Gas Question
  36. making your own gasket?
  37. How can I make a civic ex transmission ratio closer???
  38. racing seat install
  39. Headlight flash with alarm relay wiring
  40. ECU questions
  41. Making the car better for high speed handling?
  42. window frame on door
  43. Ignition system in our D17?
  44. Free Honda / Acura pdf Service Manuals
  45. help
  46. tranny for 02 civic
  47. water temp gauge and oil temp gauge install.
  48. Spark Plug Cover
  49. Wiper switch assembly - LX to EX??
  50. i need dash help!!!!!!!!!
  51. Tail Light Mod
  52. Attempted Viper 5000 Install!
  53. engine damper?
  54. Head unit removal DIY.
  55. DIY Header help
  56. kaminari 05 lip kit
  57. Ebay Intake
  58. RSX 05 Leather conversion question of the nation!!! FOUND THE ANSWER BABY!
  59. question about gear ratios
  60. A/F Ratio Question
  61. need one fast!!!!
  62. how to remove stock radio
  63. What type of ecu does the civic ex has?
  64. Need Some Help
  65. rear speake removal
  66. 2005 SI Gauge help
  67. DIY: Change Oil Filter,
  68. Breaking in Period?
  69. Another gauge question
  70. Ripped body kit - Can I fix it?
  71. Advance Timing??
  72. Honda Accord 2000 cd install help
  73. fuel relay clicking
  74. [FYI] Car Terminology Explained!
  75. Need the Honda Part numbers for the following....
  76. another crazy turbo question
  77. Blacking Out/Clearing headlights hellppp
  78. e-manage blue vs ultimate?
  79. Whats up next?
  80. Can't get key out...please help
  81. sunroof
  82. "Dealer-installed" Courtesy lights '06 Sedan
  83. Headlights/tail Lights
  84. Accelerator Kill?
  85. double din install kit
  86. d16 and d17 manifolds...
  87. Auto to manual conversion finished.
  88. trunk lock problem
  89. b20 intake manifold on d17?
  90. Can I use a Auto 01 EX ecu in my manual 01 EX?
  91. overheating problem
  92. car keys locked in, trunk open!! help please
  93. VAFC2 tune, please help!
  94. are some d15b7 and d16z6 parts interchangeable?
  95. 2002 EX Dash Removal
  96. Rear seats?
  97. -Lip fitment question?
  98. - Kinda confused here! Help
  99. AC Condensor fan not working.
  100. Shift knob diam anyone?
  101. 91 Honda Civic heater
  102. Gauges that are not for Racing?
  103. what clusters will fit ?
  104. Painting interior..diy?
  105. Did it my self
  106. 2003 4-dr. Lx Gas Mileage Help!!
  107. base of rear seat removal
  108. cluster wiring
  109. need help figuring revving issue
  110. Seatbelt wont retract after accident
  111. climate control
  112. How to replace a front rotor
  113. Lost bolt, need new one
  114. 91 Civic 1.5L timing recommendations??
  115. Install Racing Harness(3/4 point) w/ stock seats
  116. any available diy`s on rsx seats
  117. vafc2 same as af regulator ?
  118. Question about RSX Seat Bracket Covers
  119. Electrical Troubles?
  120. Key Reflash
  121. Throttle Problems
  122. getting the crank pulley bolt off
  123. car turns like crap in the SNOW !!!
  124. Clutch: Did I get ripped off?
  125. Expert Opinions Needed!!!
  126. Greddy Motor Oil
  127. Greddy Motor Oil...
  128. hooking up sub & amp to stock radio...?
  129. A'PEXi Super Grounding System ?
  130. Thank you and goodbye
  131. high rpm clutch feel....
  132. Missing Engine Harness
  133. d17a2 head swap
  134. A little DIY I did today. Might interest some people, real simple and clean.
  135. D16 Header for D17A
  136. need spooling help ....
  137. Quick headlight bulb question
  138. installing timing belt tensioner
  139. ABS light problem
  140. after accident issues
  141. ??transmission??
  142. Dx header?!?!?
  143. How bad is it changing the alternator on a 2001 EX?
  144. Paint Removal from plastic surfaces?
  145. Anyone sell a big 3 kit for a 2001 EX?
  146. 4GET vacf2 and emange ???
  147. foglights
  148. Does anyone know ??
  149. K20A2 intake manifold
  150. Engine oil pre-pressurisation?
  151. Honda Genuine ATF or DexronIII?
  152. power steering removal question.
  153. DIY Aluminum Shifter Bushings and Revo Short Shifter Install - PICS!!
  154. How to aim 01-03 headlights?
  155. single cam question
  156. Wiseco pistons ?
  157. Will this work for my EM2?
  158. Anybody got a Diy on 99 ex pad and rotor xchange?
  159. HELP civic door checker?
  160. Dome light screws
  161. B16A questions!!
  162. Center Dash LED conversion
  163. Sparking Problem on 95 del sol
  164. Frank swap..price?
  165. new member: 95 civic cigarette lighter problem
  166. ***Re-wrapping armrest***
  167. DIY Defi Control Unit + Boost Gauge
  168. 05 Civic cold start grind.
  169. engine build-up
  170. rca plugs on stock headunit 05 civic sedan?
  171. OEM Fog Switch Pin out
  172. Auto power windows? Gearbox help
  173. alternator?
  174. fuel door/ trunk release
  175. where did this thread go???????
  176. Car shakes periodically need help
  177. Fitting 99-00 TypeR Front Lips to 04-05
  178. Header problem Help please....
  179. I am about to give up!!
  180. Need help! Going to dealership, need info
  181. A new coil every 5 months?
  182. Break Lights Won't Turn Off.
  183. Cold Air induction and fuel mileage
  184. having problems with installing the oem intake....
  185. about to change head gasket and timing belt. UPDATE! 2/22/07
  186. help 98 civic won't start
  187. DIY: Make your own eyelids out of carbon fiber
  188. I Have Access To Acura/honda Tsb's/recalls/and Repairs.if Any One Needs Help.
  189. Flywheel Compatibility ?
  190. need key copied
  191. H.I.D Questions....
  192. Problems with rear wheel
  193. Resonator problems
  194. How to? '92 Civic DX driveshaft replacement
  195. what other parts do i need?
  196. CAI reccemendation for 04 Civic EX
  197. Emanage Questions
  198. anyone use a plug and play harness
  199. motorswap
  200. Changing the Condenser on Saturday any advice?
  201. secondary o2 sensor problem on a '98 civic Dx
  202. Attn all painters
  203. Reasoning behind HID kits being illegal
  204. when swapping cylinder heads..
  205. exhaust leak @ turbo mani/block. help!
  206. "Lights On" alert sound not working or dome light
  207. soo... i got some side markers... help me install!!
  208. how to wire up led scanner to alarm i need help!!
  209. awesome site on fiberglass and CF molding
  210. auto to manual swap!! and it's turbo'd!!
  211. I have finially done it!!!!
  212. Changing out headlights (bulbs)
  213. Cluster Wires Question ..
  214. Engine Mount positions
  215. cylinder head removal question
  216. LX to EX headswap AND N/A Stage1 or Stage2
  217. aftermarket gauges. mechanical/electrical. pros and cons?
  218. Turn off DRL
  219. S2000-Civic conversion
  220. Ran into a problem
  221. help!! two quick "?s"
  222. Car runs lean, 18-20 AFR. ***UPDATE*** post 19.
  223. Sounds like running fluid
  224. boiling coolant... COME IN.
  225. bulb to led mirror,cruise control?
  226. modding ek 99 civic
  227. d16y8 im
  228. Engine Swap- AC?
  229. Taillights are not working....help me asap
  230. Suede Interior [Pictures Inside]
  231. DIY: Change the color of your door panels with suede!!
  232. Finally got my intake.
  233. V-Tec and How it works
  234. 97 civic radio
  235. headlight fit-a-ment
  236. need help asap
  237. need a new radiator?! COME IN!
  238. Newbie wanting service help
  239. How to install projector fog lights?
  240. is my motor blown?! UPDATED......
  241. sunroof rattle
  242. is this the right part? (pic)
  243. S2000 steering wheel wiring question
  244. need help. again.
  245. auto tranny controller
  246. E brake removal
  247. Locating VSS??? 2002 Civic
  248. how to remove auto tranny drain bolt?!?
  249. Anyone have any experience with the Skunk 2 Short Shifter?
  250. www.tein.com
