- grounding is important! (pics up)
- Question about AEM Cold Air Intake
- Need Some Help
- 2002 Honda Civic EX timing belt change
- Legal carb sticker
- Help Me Please
- fog light help
- shaving armrest?
- shaving armrest?
- wiring side marker
- Q about the Viper 5000 Starter kill and valet button
- racing seat install?
- Carbon Fiber front lip
- Ignition timing retard mechanically...is it possible?!?
- Blacked Out Headlight Question..
- just installed oem auto trans filter kit!
- Fuel guage sending unit.
- Tach signal
- Thoughts on bypassing rev-limiter
- Diy Exhaust Questions
- Wheel Allignment
- Reset Airbag Light after Race Seat Install
- Sidemarker Installation
- 5 point harness install help asap..
- What other N/A mods should I do?
- SRS Light Problems
- traction...
- Engine builders, Enter this thread!
- No more GAS tanks!!!
- advise in positioning inline fuel pump
- didnt know where to post...
- DIY LED Interior
- Removing plastic around steeringwheel... no DIY, please help!
- Tach wire color -Already searched
- tach not working
- Installing Air/Fuel Ratio gauge !HELP!
- DIY: Hardwire radar detector install
- now because of my seats, my srs light is on.. and retarted
- Rsx Wheel in EK???
- Sweeping Idle
- Misfire on cylinder1,2,3,4, HELP
- any DIY on RPM switch??
- lighted key ignition ring
- Vtec??
- Boosted Civics check this out
- will bumper fit?
- whrench heads, would the car run this way?
- Rebuilding ECM
- Radar Detector Hardwire
- HKS exhaust
- Electronic Rust protection
- steering wheel question
- I need help bleeding my clutch
- Need Help... people from Miami read especially
- How much gas does CAI or SRI have saved you if any?
- been a while
- 2 Questions for anyone who has installed a Fujita F5 CAI (02 DX/LX A/T)
- throttle body spacer
- What parts from 2000 EL fits?
- How to get off overspray?
- Exterior Side trim piece
- --Car doesn't start after emanage
- stock gearing and aero specs
- vtec kick in point
- cam question
- Bottom Line: DX --> EX Exhaust swap
- looking for a front end for good price..help..
- hardwire passport where to buy
- Head question
- Will the 04/05 Coupe Grille fit an 04 Sedan?
- DIY: Blacked out altezza tail lights
- door courtesy lights mod
- HID install problem...
- 2004 Coupe tails on 2001 Coupe
- Door Panel on a 1.7 EL
- DIY for motor mount?
- ES motor mount question
- LX to EX swap o2 wiring
- headlight harness HELLP...
- Narrowband signal to ECU
- Is SAFC useless on N\A motor?
- Clutch Fluid Replacement
- Will b16 or b18 work in em2?
- Managing oil filter in oil changes...
- dc2 mirrors on a sedan, anyone done it yet??
- What light goes in tyc?
- Question about Installing Car Alarm/Starter/Lock&Unlock
- Wiring into fuse
- How do I make my trunk pop?
- High Beam Not Working - HELP...
- Noob... A little info please
- DIY: Shave Front License Plate
- Top Dead Center SENSOR Replacement.
- IAT(intake Air Temp) sensor
- D16 intake
- aem v2 painting?
- quick motor mount question! READ!
- Oem Keyless Entry
- im not sure if this is the right place to post this.. but anyway
- RPM in the morning
- rsx 3.5 on m/t '02
- power windows slow
- How to install AEM adjustable Cam Gear
- 2door and 4door motor mounts the same?
- Finally got power locks
- Auto EX.
- rsx muffler
- HELP with foglight install...
- need help deciding on what 2 do about a true vis carbon fiber wing
- DIY Black Foglights
- engine identification
- aiming your after market projectors on 04 civic
- splicing the + and - to the 12v adapater
- OK, so it's not Honda related...
- Cleanest Throttle Body and IACV
- Valve cover gasket
- store windows kit
- Why is the OEM clutch not stiff??
- preview: LED license plate lighting
- DIY auto to manual tranny swap!?
- 01 SI-G Sri on 01 Lx
- Sensor!!!!
- Oil Change.
- V-Tec Light???
- DIY lowering spring install?
- DIY Grounding
- K-20 head stud tourqe specs
- painted slips (pics)
- Mounting OEM 01-03 fog lights?
- D17 & high compression
- d17 request
- Selling Automatic Transmission Pieces
- Question about the positive battery cables.
- EMANAGE INSTALL QUESTION also emanage blue to ultimate?
- Header Help
- Si vs RSX Steering Wheel
- Front Sway 01 LX?
- AEM V2 Fitment
- Help!!!
- interchangablilty between ep3 and em2?
- 04 oem aero side install
- Factory Power Lock Actuator
- emanage not working!! HELP!
- will a d16 intake manifold fit a d17 manifold
- o2sim where????
- painting valve cover powder coat red...
- Pop Trunk.
- making speedometer lighting blue?
- D-Series Tranny
- FUEL MANAGEMENT QUESTION! quick question.
- Switch Drum Brakes to Disc?
- BEST DIY EVER(56k you have to wait its worth it)
- Help i need e-tool quick (emanage)
- spoon mirrors
- header question
- 05 civic carpeting
- Help With Emanage Street Tuning!
- DIY instally TYC projectors
- differences in 01-03 engine and 04-05
- 03+ cluster in a 05 DX
- Has any one did this swap?
- emanage question
- quick release hub and steering wheel
- headunit removal 01 civic hatchback uk help needed
- interior
- Started taking a head apart
- timers
- ...OBD II B computer question...00' si computer
- vtec contoler
- oil changing???
- auto to manual
- Crank Pully????
- Cams....?
- Cluster Swap.... I promise this is at least 50% intelligent
- will our d17 head fit a zc?
- ep si steering hud fit r car
- megan strait pipe causing check engine light
- 8th Gen Vtec head on 7th Gen
- Ghey!!!
- got some strange exhaust idea's get in here guru's
- question
- Noise from the front.
- Fog Lights
- REAR BUMPER REMOVAL with diagram
- Stock deck problems help!
- which sliders for dc5r recaros?
- 6 speed tranny in 5 speed 01 civic
- turbo kit for 05 civic ex
- Cold Cathode DIY
- Control arm bushings
- LX exhaust on a DX????
- To anyone who has installed an oil pressure guage, please help!
- rsx injectors make a diffence on NA cars?
- Aem Pulley Kit (belt sizes)
- installin OEM headlight switch.
- Anybody want to sell stock exhaust?
- DIY Alternator High Output Upgrade
- Ep3 Steering Wheel????
- PArking break link?
- Dont want to waste money......
- vertical door/wires question
- DIY: So You Cracked Your Fogs? Fix it!
- underdrive pulleys
- exhaust manifold
- 2005 Civic SE (VP) Cluster Wiring
- body kit re-installation help!
- Headlamp issue! help=repped+ty
- transmission diy????????
- Problem- 1998 JDM Honda Civic
- Will FIT steering wheel fit em2
- tapped oil pan question?
- tranny swap
- 04-05 ebay fog help!!...
- midpipe question
- DIY Weapon-R Secret Fixing loose temp sensor...
- ReBuildables . . *
- VAFC2 and Mechanical Sim
- pulleys and impact wrench help please!
- haywire!!!
- Can you disable passenger airbag?
- PROJECTOR Headlights help
- Probably a crazy question...
- Just finished...
- help
- 04-05 Trunks?
- how u open headlights?
- will em airbag fit in ep steering wheel?
- Light bulb
- Headlights ?
- ob2 scanner?
- How do I replace this???
- D16 clutch
- Muffler for 2004 Civic VP coupe?
- If I own a VP civic! Is it an LX,DX,EX?
- 7th Gen Civic Service Manual (non-Hatchback)
- parking lights
- would it be useful?
- Will Someone Black Out My Headlight Housing?
- Interior Question
- DIY engine cleaning
- vafc-ii problems
- intake manifold
- what does this plug do? (vtec head)
- alternator out caused speedometer to go out?
- emanage + apexi avcr = good?
- I Need Help!!!!!!!!!!!!!!!
- Magnaflow Cat help...
- question for those who know b series and d17y8
- Some ideas I'd like to share with you...
- camshaft question
