View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57
  1. Overheating Woes...
  2. Couple Part Fitment Questions
  3. Si shift boot?
  4. 16k km service maintenance
  5. Pedal Cover Accelerator drill points?
  6. PB blaster
  7. Other than RSX what seats fit in a 7th gen
  8. Valve for airbag suspension dying?!?!?!
  9. Getting head unit out without marking up around the ends
  10. stock exaust piping size?
  11. DIY Cat Removal? Anyone?
  12. Oil Press Sending Unit? Question ....
  13. Flywheel bolt question HELP ME
  14. Is there are Retrofitting DIY?
  15. those r134a refrigerant bottles
  16. Header question
  17. me wanty more zoom! help.
  18. Aem Short Ram On 02 Ex??
  19. Need E-Mange Maps
  20. 2004 honda civic ex 5 speed is to slow, help!
  21. Will this 2001-2003 dash kit fit 2005?
  22. megan header question.. HELP ASAP
  23. Can I run RSX injectors with S-AFC?
  24. Removing axle back from midpipe HELP
  25. DIY Diagnostics???
  26. Coolant flush??
  27. converting to power windows and other factory upgrades?
  28. t25 turbo flange on our manifold?...
  29. Squeaky clutch
  30. CROWER STAGE 2 CAM installed...
  31. How do you replace the headliner?
  32. I hate to do this but..yet another tach question
  33. engine block
  34. Differences from D17Z3 to D17A2
  35. Blacked out OEM lights
  36. people with oil pressure gauges?
  37. srs light / airbag light question......HELP PLEASE!
  38. Need help with 2005 civic sedan headlights + suggestions ..+ pics of my stock ride
  39. new steering wheel
  40. Obdii Port
  41. carbonfiber cutting??
  42. how long do copper plugs last
  43. jdm dc5 sidemarker
  44. How do I remove door carpeting?
  45. Swapping CIVIC EX and DX Gauge Cluster
  46. Engine Compression
  47. civic ECU question
  48. Acceleration map
  49. how to install new horn
  50. Stuck Cat bolts.
  51. DIY instruction on installing AEM V2 intake
  52. pkh3 problems
  53. auto shift knob issue
  54. Trouble changing air filter
  55. 2004 Honda Civic 4dr LX trim HEADER
  56. Swaping out an '01 LX Civic Engine
  57. new cam and smog
  58. Help with belt sizes!
  59. Jdm Grill
  60. O2 Sensor Wires?
  61. 01 exhaust work
  62. How do I take this out....
  63. Retro fit HID's
  64. 2001 Civic EX (Auto) - O2 Sensor Differences
  65. turbo problem help asap
  66. Is there a Rev Limiter In Park?
  67. Recalibrating gauges.
  68. DIY: aiming headlights the easy way!
  69. Quick question
  70. DX head swap. need advice :)
  71. ex cluster into a vp
  72. 2004 Honda Civic LX Bumper
  73. V-AFC2 install
  74. downpipe?
  75. Do I really need gauges with nitrous?
  76. DIY: Ingalls "SmartArm and FastCam" Adjustable Camber Kit
  77. just a short shifter question
  78. New plugs?
  79. Seperating trans mainbody from torque converter housing?
  80. Can someone measure distance between b-pillars?
  81. Oil Burn 1/2qt. every 500, acceptable?!?!
  82. Trans Fluid for 2003 civic ex?
  83. Help
  84. Itr Pedal Swap In Em2
  85. Procedure When not Driving the car for 1.5 months
  86. n0ob audio question - DIY needed
  87. Need torque specs for header bolts.
  88. Relocating Brake Fluid Reservoir
  89. Peformance module????
  90. custom side mirror turn signals
  91. highbeam drl
  92. what paint for fog lights?
  93. Ac Install
  94. Spring Installation
  95. RSX type-S seats into 01 EX
  96. Rare cluster swap ineed of sum help!
  97. Removing center dash surround?
  98. Custom Seat Covers
  99. Emanage code
  100. How to make low beams stay on when high beams are turned on?
  101. Autometer C2 Oil Pressure guage install question
  102. how to remove intake manifold?
  103. DIY belts replacement?
  104. help anyone diy mesh grille
  105. Exhaust Piping size
  106. car theft
  107. feel stupid but i need help with my grill
  108. CEhck Engine Help
  109. Will a axle back from a 01-up Civic fit a 00 EM1?
  110. ecu questioning
  111. armrest question.
  112. no muffler
  113. energy suspension motor mount installation.
  114. DIY speedo recalibration
  115. 05 RSX seats
  116. sparco brackets and mounting seats in 04
  117. Ex rotary guy need help
  118. diy blackout headlights help
  119. Best way to change interior, if possible
  120. altezza grill for 01-03 civic
  121. DIY: Straight Pipe *Edited*
  122. How do I chagne brake fluid? - one person
  123. Power Folding mirror switch
  124. Some questions about my 02 civic ex
  125. wrong coupler size for intake?
  126. Lock actuator from a EX on a DX??
  127. How cold is your A/C????
  128. Help with Smoked Tail Lights
  129. rear bumper same on EX and LX?
  130. Axle/CV boot question
  131. eibach pro-kit install
  132. progress sway kit for 2001 lx
  133. exhaust gasket maker?
  134. Cracked Exhuast Manifold
  135. need help taking off driver side door panel
  136. Front Bumper Cover Question 02 & 04 Civic
  137. sparco torino 2 install in 04 ex coupe???
  138. Throttle body
  139. aftermarket short ram intake.
  140. d17 aftermarket intake manifold
  141. How do remove seat wires? (yes I searched already)
  142. engine management options???
  143. Over Rev 5sp
  144. xenon kit???
  145. someone please help
  146. Exhaust Questions
  147. tranny swap?
  148. megan strait pipe on 04 ex
  149. How to run oil and water lines for 14b turbo?
  150. cold air intake
  151. CN stage1 E-manage ultimate map help??
  152. DIY License plate bracket with pics!!
  153. EX 4 Door Flip Flop Trunk
  154. removing sedan tail lights/rear bumper
  155. Differences in LX vs EX (2005)
  156. wiring power folding mirrors....
  157. ep3 si mugen grill on 04 coupe ex?
  158. How to Tune a VAFC2 on D17!!
  159. headers on 2001 lx
  160. Help With Exhaust Manifold
  161. HELP wit front brake bolt
  162. Since when do JDM EX Civics come with IMA?
  163. d16 parts work in d17?
  164. paint on front lip..
  165. Boost and 77,000 miles= time for a new clutch
  166. will a 5 spd revo ss work in a 6 spd Type-S??
  167. motor swaps
  168. d16y8 swap problems
  169. DIY: How do you put in a new custom mesh grill
  170. cluster swap
  171. EX Hi flow cat in an LX
  172. 04 headlights in a 02?
  173. smoking my tails.......
  174. grille questions
  175. Check out what I stumbled across..an ecu
  176. will an 01-03 hood fit an 05?
  177. 01-03 to 04-05 front conversion
  178. M3 Mirror install on Coupe
  179. Not Lazy, Just Have Limited Time.
  180. Need Quick Help w/ Mods...Thanks
  181. DIY for drilling out 14mm struts to 16mm
  182. sparco barackets install???
  183. The answer to all of the what intake questions.
  184. Taking out Header Studs...
  185. 05 civic shift boot removal.
  186. zex install help
  187. SRS Light BULB.. Where is it?
  188. Seat brackets missing...how to fix...
  189. Mods and Gas Mileage
  190. Help! headers for 05 civic LX
  191. 7th gen/rsx suspension questions.
  192. Silicon hoses
  193. obx camber kit
  194. Honda Civic emblem question...
  195. Installing seats with srs into vic
  196. HVAC codes please help
  197. lip kit installation
  198. RSX Compatability Question
  199. GX rods-HP capability?
  200. installing rca converter
  201. Re-sealed headlights..still fog up...
  202. return fuel setup
  203. um problem with the floor rug
  204. DIY for Grey's kit for Revo SS?
  205. Wiring Led m3 Mirrors
  206. DC Sports short throw
  207. Interior paint help
  208. Need tech help fast
  209. S2000 Cluster Swap
  210. Ex exhaust swap
  211. will a 05 SI Cluster in a 01 civic work?
  212. pleeease help help help.!!
  213. Gauge cluster bulb size?
  214. What do I need for a power window swap?
  215. problem after paintin caliper
  216. Vafcii?????
  217. Look what i made, a list of shops
  218. building a powerful d17
  219. Need Help: Keyless Entry Remote Problem
  220. Fiberglass subwoofer diy with picture
  221. DX --> EX header/ exhaust conversion please help!
  222. quick question....
  223. Post your build/1/4 mile times/ horsepower
  224. bumper grinding
  225. Setting fuel pressure, using SLPs return kit
  226. Service?/advice
  227. transmission question
  228. New dash kit problemo.
  229. Keyless Entry reprogram
  230. 8th gen engine swap?
  231. factory seat buckle
  232. driver side window shakes
  233. Weapon-R secret intake "sagging" fix
  234. Auto Transmission Rebuild (pics)
  235. d17a2 question
  236. 97 Integra Leather seats in a 2004 Civic--HELP
  237. vtech problem help..........
  238. need help sedan trim peice removal
  239. Acura EL headlight swap?
  240. Ex vs Dx clusters? help....
  241. quick question: installing altezza grill onto an 04
  242. Installing '03-'05 cluster into an 01?
  243. Regarding 7th gen Manual STICKY!?
  244. How to get amp power cable through firewall?
  245. Fog Light Install! With Real Photos Not Pdf Drawings
  246. Making car more stable at high speeds?
  247. Hydraulic Trunk/Hood Lifters?
  248. Adding a horn to my car alarm
  249. question on front bumper removal diy article
  250. Where can I mount 3 amps out of the way?
