- Front Seat removal help *searched*
- HELP!! Cam problem!
- aiming tyc headlight???
- Can you weld stainless to aluminum
- power windows
- wow finally got my foglight
- Resistor Box
- anyone blacked out their headlights like this?
- Disabling keyless entry horn.
- manifold swap in honda tuning magazine
- DIY: Build your own custom iPod Mount!
- esplier exhaust ques.
- manually disable the speed limiter
- Airbag Light come on after disconnecting the battery.
- DIY for s2000 push button starter kit?
- what epoxy to use
- How to strip paint off my front bumper?
- ex exhaust system in an lx
- how hard would it be to change...
- diy for HID projectors in tyc projector headlights?????
- need DIY on removal of dash.
- Revo Short shifter Install help asap!
- Need DIY for hood raising.. to all who help shall receive rep.
- Foglight wiring
- has any one flashed there ecu
- loss of teeth on belt...noises???
- 1st Mod, Need some help
- alternator
- mirrors
- some tranny problems...
- hyper blinker mod?
- obx muffler
- ground required ??
- cell phone charger
- Need tester for plug and play dash LEDs
- d17
- v2 intake and throttle body spacer
- head swap
- Help! 2006 Civic LX won't start - immobilizer problem?
- I need some help please.
- Painting Exhaust?
- Need Help Automatic Shift Knob
- Is it worth it?
- Cluster removal - help please
- New Idea For More Power
- DIY rankings
- Torque Wrench Extension for Strut Top Nut...
- how much to install fog lights
- Question on K20A3
- Shifter/boot
- How do i get the stupid shift knob off??
- tranny swap?
- rotor screws importance
- headlight eyelids
- anyone got a DIY for Apexi SAFC
- anyone know OEM spec and Dimensions
- Tien TruCoilovers Adjustment
- need gauge cluster help
- Short Ram Intake Physics / theory
- APEXi exhaust question
- HVAC Lighting problem
- idle tach readings
- Honda Tech Podcast
- fiberglass R34 front bumper removal
- Will a 00 Mugen Lip fit 02?
- turn signal
- Anyone put the lock in a carbon fiber trunk??
- do resistors add up?
- guys, meet your 03+ gauge cluster
- tach intallation help (yes i've tried searching)
- removing stock cd player from 05 civic
- Serious Question
- m3 mirrors w/led's turn signal
- Fender guard help. MODS LOCK PLEASE
- Crower Cam for D17 too expensive
- changing a3 tranny to 6speed
- vafc II question
- K20a Injector
- i need shifter DIY help!?
- hybrid cluster compatible with 03+ EX style?
- VAFC II and the K20A3
- REVO SS remove center console ? HOW?
- Rev Rev...
- Help with my revo ss install...
- d15 head work?
- Supercharger-like whine from smaller pulleys?
- X-brace install problem
- Easy Flip/ Flip Flop Trunk Diy
- ok, d17 reflash capabilities
- Installing a new Grille
- Replacing an 01 gauge cluster with an 05
- Fuel pressure reg question
- Fuel system upgrade
- aiming projectors
- Shifting Hard
- Cluster pinouts
- Magnaflow exhaust
- Tail Blackout Issues
- Anybody in Orlando willing to help with fogs??
- 05 Sedan Tails
- engine removal
- MoTec systems
- RSX seats in 7thgen adjustable ???
- K20a for $6,500 with everything? look inside
- high flow cat for my LX.
- skunk2 adjustable coilovers for 05?
- underdrive pulleys, are they worth it?
- Driver side door panel..
- Front Bumper and VTEC
- Bored throttle body
- Anyone with 01 and/or 04 repair manual?
- Gauge needle alignment
- Chasis damaged?
- exhuast pipe diameter
- DIY on greddy boost controller?
- Magnetic oil drain plug
- what settings do i use on my e-manage? (rotary)
- fabric change in 04?
- URGENT! whers my emanage support tool key
- projector fog retro complete (night pics inside)
- how to black out the headlights?
- **UPDATED with pic...DIY 04-05 foglights+removal of the center console
- Help for wiring a Switch
- short or noT?
- How to install power windows?
- 04 civic lx supercharger
- Has anyone done a wire-tuck on a 7thgen?
- anyone have the DIY on changing brakes on a 02 ex sedan?
- How To Remove Shift Knob?
- Just wondering
- Head studs
- So What do you Recharge your AC with?
- URGENT! - cluster help
- Headlight Removal Help!!
- Need some general A/C Help
- Alarm question
- Clearing Headlights + Glue = PROBLEMS!!
- Interior LED Setup?
- 05 door handles?
- short shifter
- ABS is crazzzyyyy
- My EM2 doesn't have A/C...
- need help with my stupid alarm
- lx to ex exhaust system swap
- Power Steering Question
- GTECH, what a goldmine.
- bleeding the brakes
- throttle body spacer question plz help
- suspension question: Koni yellows & me
- engine bay cleaning question
- Am I Retarded Or Is This Not Too Big Of A Deal
- Replacing motor mounts Civic Si 2002
- Header Advice
- header bolt/nut
- engine hoist trouble
- ABS light how to fix ?
- headlight install please help!!!
- Si Head Swaps
- Help With Headers
- chrome grille molding removal and FS/Trade
- Uninstalling Radio
- DRL question...
- Airbag light
- Dyno day
- Anyone done this?
- Help a Gener Out
- hids in tycs
- HP header/cat combo PROBLEM
- Adding headroom
- Stupid Exhaust Question
- power actuator for driver side door install??
- Power steering Delete
- Help !!! stuck on installing revo ss
- tach problem
- How long does it take DIY timing belt?
- swapping out center console (between the seats)
- head light bulb upgrade and diy soon!
- Broken door handle/ lock cyclinder replacement
- Clearing Your 7th Gen Civic Headlights
- How to take Radio Bezel?
- wheelchair help
- d16v1 supercharging
- Myths of the VAFCII
- Help me finding 2pin connector
- Advice on tools and spark plugs (updated u gotta read this)
- Drl
- Advice on Kaminari Side Skirt install.
- would a 96-00 gauge bezel fit a 05 civic
- 04 ex bumper question
- for those who have done a engine swap??
- Is There A Diy For The Lambo Kit Instalation?
- All these CLIPS
- Door Lock/Actuator--Read Before Ordering Parts!!
- Someone make a sticky on how to shut off your AC while the defroster is on.
- 2 questions
- I lost my waste gate spring!
- big3 wiring help
- Diy Esmm
- Help!! Tranny Gone Bad!!!
- Removing HVAC and A/C plastic....
- Stock shifter
- Replace Tranny
- What are the torque specs for installing spark plugs?
- Brother's Rex Q
- Painting a body kit?
- header help
- Help! Remove Crankshaft Drivebelt Pulley
- Wha has installed a Cruise Control on a 7th gen VP or DX??
- vafc II engine light
- Gqpping plugs
- OBX Throttle Body Spacer and Injen SRI
- Carpet removal
- Removing and replaceing side mirror
- need help with shift light asap
- Push button ignition & steering wheel lock
- brakepad replacement not fitting
- Replacing Alterntor Mount....can't wait, NOT!
- Fog lights for 05 civic
- Coolant Level
- Cluster Pinouts for Canadian Civic?
- ep3 axles fit 7thgen?
- A different view on mods
- 2nd mod need help
- D17 ECU and Computer Question.....
- shifter knob
- headlght fuse burnt out... help please.
- Quick questions
- 2001 LX Camber Kit Install
- Easy upgrade question
- DC sports header
- e-manage
- Checking my timing belt
- Are all 01-05 2dr/4dr mufflers the same?
- RSX-S Swap on Civic DX
- power steering touching alternator?
- Case Bearings ??
- Removing trim pieces on auto??
- Need Headlight Strobe DIY
- What would happen if...?
- rsx rear sway and evo2 exhaust
- glove box lock
- Torque Converters Explained... (for all you Automatic guys)
- Badge removal (yes i searched)
- Make o4 civic fast for 5K in CA?
- Can you install front sway bar for dx?
- Aluminum heads
- Where can I buy this?
- Keyless Entry remote
- Inverter Dissassenbly And Relocation
- New gauge cluster
