View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57
  1. exhaust question
  2. Anyone know how to advance timings on a 05 Civic.
  3. carbon fiber reclearcoating DIY
  4. Need help buying a bodykit please!
  5. Lowering the fuse box?
  6. intake doesnt fit
  7. should i do this?
  8. Installing tail lamps
  9. Quick Battery Question
  10. GSR INtake manifold on 7thgen civic?
  11. Dyno tuned settings for V-AFC 2?
  12. VTEC Controler Help
  13. DIY request....
  14. I need a little under the bumper orientation (pertains to foglights)
  15. DIY Boost/Vaccum guage
  16. Type of bulb for Projector Headlight(Dual Halo)
  17. when to check oil?
  18. Can fuel pressure be increased on returnless system?
  19. selenoid valves
  20. manual guage cluster in automatic car
  21. Odometer backlighting
  22. replacement panel clips
  23. White gauge cluster for a 01 EX
  24. Q?: Aftermarket Racing Seats and Problems
  25. Where's the PCV stuff
  26. anyone have problems with there vertical door kit?
  27. Hood Shocks????????
  28. noobage
  29. I've searched but still need help on: SRS Light
  30. PAINTING trim pieces
  31. aero kit install instructions
  32. Need help with DIY amp install on factory...
  33. auto trans operating temp?
  34. injector block NEED HELP ASAP
  35. quick question not worth searching for
  36. ok i was being an idiot
  37. DIY Suggestions?
  38. Liquid electrical tape
  39. EX/LX Cluster in a VP or DX
  40. 02 sensor question?
  41. What is VTEC-E
  42. aem alt/ps pulleys with unorthodox crank pulley
  43. RSX struts
  44. will air bags go off even with srs light on?
  45. Custom Intake
  46. Buying/Programming Key Fob
  47. h23 into 01 civic ex?
  48. DIY oem fog light
  49. how hard is it to do tint urself
  50. DC strut bar & injen intake
  51. Goodbye2 my header, unless u can help
  52. DIY: $5 Solution to Rear Deck Rattles
  53. SRS Light Still On
  54. 02 LX cluster in an 01 EX
  55. Anyone have Viper 3000 alarm? question
  56. DIY: IPod install in 7thGen
  57. new CLUTCH?
  58. 99-00 Type R rear lip on 04-05s..
  59. 99-00 TYPE-R Lip for Dummies (*NEW CLOSE UP PICS of my LIP*)
  60. Foglight help!
  61. center console - question
  62. K&n Fipk 2
  63. lowering/aftermarket exhaust
  64. My DIY threads from 2005
  65. eManage error code 14
  66. trouble taking off steering knuckle?
  67. Is this right?
  68. The right way to put the exhaust mani gasket on?
  69. K&N filter "recharger" kit+ AEM filter
  70. High RPM at high speeds
  71. Idling problems with emanage
  72. nut for shift knob?
  73. re-tinting rear window?
  74. best way to remove the "clutter"?
  75. Temperture Gauge Sensor for 96-00 Civic EX
  76. what colors for 02 sim?
  77. Header?
  78. No Perf. Guages
  79. Quick dash lighting question(already searched)
  80. Diy:how To Remove Gauge Cluster?????
  81. exhaust needs to come down
  82. head swap
  83. Phantom Grip "LSD" Smart opinions,facts?
  84. ebay mufflers
  85. 98 civic aem underdrive pulley install HELP!
  86. '04 DX Exhaust System to EX
  87. quick painting headlight quest .
  88. hi-flow cat fit?
  89. AEM Standalone
  90. What Front Conversion Can We Do To Are 7thgen?
  91. Just wondering
  92. installed right?
  93. 03 DX Gauge cluster swap, will this fit?
  94. Help Pleeeese!!
  95. iceman intake install help
  96. My new toys
  97. S2000 foot pedals (DIY anyone?)
  98. Downpipe really necessary?
  99. B18 engine swap
  100. Question regarding muffler
  101. New Cam Gear
  102. Vtec Help
  103. Air/Fuel Ratio Gauge Not Workin
  104. center console removable
  105. alternator replacment
  106. Halfcut and Welded car
  107. ZEX Booster Inline Fuel Pump Kit ???
  108. Not enough braking power...
  109. Question about Hondabond
  110. Gauge & LED's
  111. Installing Aux input in 2005 Civic
  112. headlight/bulb replacement on 02 ex
  113. trans temp gauge install
  114. nEeD a lil help with my hood
  115. newb question about intakes.
  116. Red Optima Battery Doesnt Fit HELP
  117. Rear Bumper Removal?
  118. magnaflow exhaust question
  119. I need help with suspension/tie rod
  120. high beam bulb into low beam
  121. Which ECU is in the D17A2
  122. Revo Installed, minor mishap, is it ok?
  123. D17 lets do this
  124. what if i dont connect breather tube?
  125. Question regarding Civic 01 17" tires
  126. resetting yer mileage
  127. Question about RSR EX Mag
  128. DIY on ball joints
  129. Projekt 4 door.
  130. magnaflow or greddy
  131. Kinda new to this
  132. engine and tranny swap!!!?!?!?!?!?!
  133. changing mufflers
  134. HELP!!!!!! Mirrors
  135. stupid bumper, HELP!
  136. Headlight Painting - Gloss, Satin Or Flat?
  137. Weight Reduction
  138. new head bolts????
  139. ecu's
  140. Lookin on ebay
  141. Paint DX outer trim pieces
  142. Converting DX stuff to SI
  143. saw this and wanna do it
  144. Need help getting plastic M3 mirror apart
  145. diameter or throttle body?
  146. do sedan headlights fit a coupe?
  147. valve adjustment
  148. Short Ram Intake
  149. performance shops in La area
  150. Would Vinyl Burn??
  151. built auto trans
  152. Indiglo Gauge Faces: How to Attach?
  153. power windows
  154. how many quarts of atf?
  155. JDM Ferio Tails vs. Civic 01 OEM Tails
  156. stock engine mods
  157. Blow Dryer???
  158. tanabe exhaust gasket question
  159. door panel remoale diy???
  160. Wiring up side SRS on RSX seats in an LX?
  161. rsx leathers?
  162. coilovers for the wife
  163. how much can a civic take
  164. my custom ignition equalizer kit
  165. Question on Reverse Light
  166. Manual Cluster
  167. 18's on a civic coupe?
  168. foglights + front oem aero lipz
  169. i grounded the + side of the battery
  170. ?s about stock IM potential
  171. R/S Grill?
  172. Looking for info on the proper way to run no power steering
  173. don't know what this is to....
  174. Help My Other Car Failed Smog
  175. Power steering help!!!???!!!
  176. Removing door handles
  177. RSX traction bars--Was: Traction bars...Help!
  178. cool-air directant w/ short-ram intake?
  179. would it be smart
  180. Stock Fuel Pump
  181. will this srs bypass work?
  182. looking to install cruise control
  183. Question for 2002 Civic HX
  184. Bad Mistake
  185. Switch on tranny
  186. How to adjust stock alarm sensitivity on 2002 Civic EX??
  187. Seat Question...
  188. DIY headlights???
  189. Front Strut Leaking
  190. D16V ECU Scheme Badly Needed!
  191. computer connection
  192. Where can I find ...........?
  193. S.a.e
  194. CEL out of the blue...
  195. Driver seat foam removal?
  196. d16y8 manifold
  197. Tunning on a new clutch?
  198. Spark plug non fouler part # PLEASE
  199. Custom Headliner?
  200. Looking to install Coil-overs
  201. another wiper?
  202. Help on CEL codes...Updated: pictures + new ?
  203. Tuneing??
  204. Installing OBX Header
  205. D17 ECU schematic plz...
  206. close this thread
  207. Im A lost one...
  208. I need your help
  209. boosting my d17...should I??
  210. ECU for 01 Civic LX
  211. Removing power steering....
  212. Crower Stage 2 cam with Emanage Experience New Dyno 3/19/06
  213. Quick fuel rail question....
  214. fuel consumption question again
  215. HX Question
  216. Where to start tuning/upgrading?
  217. newb with the vafc2 needs help
  218. Dsm Side Mount Intercoolers
  219. Trim piece question
  220. resonator on evo 2
  221. 30k check up
  222. Help Me Find A Thread!
  223. town fair tire - alignment sux
  224. Can I get a yes/no on the brake booster vac line being 3/8"?
  225. RSX Cluster in Civic?
  226. Need Help !!!
  227. Alternator Change on an Integra....
  228. Remote programing
  229. Cluster Wire Help
  230. Torque specs for cam install
  231. Bent rim
  232. Aem Cai Diy
  233. CCFL Angel Eyes
  234. DYI: Replacing Front Bushings *A arms*
  235. Tach conversion
  236. blow off valve....
  237. VTEC light
  238. DYI: Replacing Transmission Seal
  239. Tming belt install pics (for those interested)
  240. Sorry Bout Blow Off Valve Question....
  241. 02 Civic rear brake swap
  242. pure O2 in the intake (dont laugh lol)
  243. cluster swap
  244. do i have k20a2 or k20a3 injectors??? how can i tell?
  245. resistor on injector
  246. How to disable SRS light with aftermarket steering wheel?
  247. stock radio removal?
  248. Sick of my exhaust!
  249. 03 center console removal
  250. Gauge
