View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57
  1. d17a2 cylinder head dissasembly........questions
  2. compression, cam timing, octane?
  3. header bolts torque specs
  4. what else can I get for her?
  5. Quick valve clearance question.
  6. Want to put a tach in my 05 auto DX?
  7. DIY Black Housing Headlights on 04-05 civic???
  8. aftermarket hu
  9. HELP! i need the specs of a d17a2 valve (what angle?)
  10. smoked tailights on a sedan...
  11. question about compression test on D17a2???
  12. LX Cat Replacement?
  13. mods for mileage and HP
  14. momo shift boot
  15. mods for mileage and HP (again)
  16. i finally got my tsunami spoiler
  17. DASHBOARD help!
  18. Question about Vp Civic
  19. broken cup holder
  20. Need some help with a Cf hood and latch
  21. SRS light blinks when pulling CEL codes
  22. Easiest way to un do alarm?
  23. Seat Swap Question
  24. blue led dash plz read
  25. auto or manual ecu??
  26. OEM foglight install
  27. flashing headlights
  28. opinion pls!
  29. 2002 civic si stereo removal??
  30. Hmm... Accord horn on a Civic?
  31. What years fit...
  32. painting my interior
  33. e-manage with head swap
  34. 2001-2005 civic EX
  35. removing entire front dash
  36. si wireing
  37. changing 12v outlet to always on
  38. Trunk pop up solenoid install...
  39. Remote Trunk Release
  40. Help
  41. '05 Civic AT shift knob removal?
  42. I need Painting help....
  43. k20 civic, d17 rsx?
  44. Rattle in Rear (SOLVED)!!!
  45. Removing the Head
  46. ebay 05 civic fog lights how to install wiringf
  47. Best ECU
  48. what year intakes fit 2005 Civic EXs
  49. AEM 1070 vs 1030
  50. DOHC and Vtec for civic lx?
  51. D16Y8 intake mani, what needs to be done? (yes ive searched alot)
  52. cant find a duy please help
  53. proper way to shave / replace honda emblem?
  54. 2001 LX header solution
  55. Rsx Door Panels
  56. short shift
  57. Subwoofer repair
  58. wiring diagram
  59. Vafc-2 questions... not again right?
  60. DIY: Auto transmission cooler (pics added)
  61. 04 bulbs??
  62. Computers...
  63. Cluster wiring?
  64. yet another computer question
  65. exterior door handle problems
  66. have not heard of this problem before...
  67. Lx Exhaust to Ex Exhaust
  68. Civic windsreen wiper
  69. tachometer
  70. VP/DX to EX exhaust?
  71. Cleared Headlights
  72. Center Console Piece around auto shifter
  73. Tachometer Installation
  74. Eld
  75. Engine Help ASAP!!!!
  76. runing light fogs
  77. E-Break Noise?
  78. tachometer problem
  79. Disabling Automatic Car Moving Forward
  80. Dyno'd Today
  81. Sagging tsunami front bumper
  82. LIGHT BULB Numbers Needed
  83. Installing Apex-i Vtec controller (98 Civic EX)
  84. 2001 LX to EX Conversion
  85. Changing out headlights
  86. One inch drop and my warranty.
  87. Seatbelt fuse removel on 04 Civic?
  88. pNp HEAD
  89. Help with my M3 power mirrors
  90. DIY: Seatbelt Beep Removal on 04 Vics
  91. Muffler Install
  92. Please help ASAP...mil eliminater wiring
  93. RS grill install
  94. Door Lock Help
  95. Intermittent Wipers
  96. Transmission Temperature Gauge
  97. I need help putting on HID's
  98. intake in civic hx?
  99. DIY for Apexi G Sensor
  100. refilling atf
  101. can I use small air filter?
  102. Need 4 Speed!
  103. radio trim panel removal ;;help
  104. Getting Ready to do an Auto to Manual Conversion
  105. Opposite Post for "can I use small air filter?"
  106. question about header
  107. cylinder order
  108. interior color
  109. what can the dealership find out about my car
  110. Chrome Door Handles
  111. What do u think of a 4' tip outlet on a civic~
  112. inner door locks
  113. Stock air box.
  114. need help with my halo headlights
  115. grounded my car problem
  116. Turbo LX?
  117. Need the manual pages for brake caliper servicing....
  118. I need some opinions!!! SWAP / DIY
  119. new and need some advice
  120. Crower Stage 2 cam and AEM EMS tuning this FRI.!!! 12-09-05
  121. turning AT gauges into MT ones
  122. Auto to Manual Shift Boot DIY?? Where is it HELP
  123. e-manage: Working VTEC on EXs?
  124. headers
  125. auto locking locks
  126. ex to dx engine swap
  127. 1998 Civic- Interior trim removal.
  128. Engine exhaust outlets size?
  129. instrument panel lighting color change
  130. Car likes beer bongs
  131. short ram vs. cold air intake
  132. injectors
  133. ECU tuning for 7thgen Civic
  134. Looking for a 7th gen manual for free? (UPDATED!!!)
  135. grinded 3rd
  136. Tuning SAFC2 without dyno...
  137. Request for Information on Changing Upper Oxygen Sensor
  138. Vtec controller problem!
  139. Flow Bench test: Stock cat converter?
  140. RSX gauges in a 2002 Civic Coupe?
  141. can I put a 2002 EX "AC Compressor" on a 2001 LX?
  142. Help with Throttle body heater bypass
  143. Turbo kit on HND civic?
  144. need pics for throttle cable adjustment
  145. side view mirrors
  146. vafc
  147. how do you reverse brake lights and blinkers?
  148. ebay oem replica fogs installation??
  149. Good INtake???
  150. DIY for blacking out headlights?
  151. Aem Sri
  152. Exhaust Questions
  153. Parts for '04 Dx/Vp
  154. groudning
  155. tein ss?
  156. Wheelbearing DIY
  157. vtec problem
  158. need a scanned copy of a few pages from honda service manual
  159. engine wont rev over 4000 help
  160. dismounting and mounting interiour
  161. Instrument pnl rmvl for LED
  162. Air Element Problem
  163. I Just Took My Wwg5 Kit Off And I Have A Question
  164. What would i need 2 do 2 build up my auto tranny?
  165. I need some info
  166. How much fuel pressure?
  167. might have done something stupid
  168. header fittment
  169. Where to put washer nozzles??
  170. With what and where to grease brakes to stop squeaking?
  171. Help with axle
  172. Bored throttle body?
  173. I've searched but can't find a DIY for clutch and flywheel. please help
  174. New To The Site w/ Performance Question
  175. Trans Cool
  176. Stock Guage Light Went out?
  177. DIY Jacking w/ lowered car SUX
  178. Call out to all seeders
  179. There are no stupid questions.. maybe.
  180. Wiring diagram
  181. v tech controller
  182. how do i? update wiring Q
  183. my diy fix for today
  184. mating an ex exhaust system to a lx header?
  185. 01 Civic Front Seatbelts locked
  186. Splicing 12v instead of plugging in?
  187. Removing tranny from top of engine bay?
  188. Removing Decals?
  189. Help Please!!
  190. DIY extended seat track...
  191. to users of tsi injector block
  192. help, cam won't come off
  193. Figuring out Mean Effective Pressure
  194. Front bumpstops / dustcover
  195. High Octane in civic
  196. oem side skirt metal bracket removal...
  197. Grounding With Kit I bought of Ebay
  198. water temp gauge install?
  199. Looking For HOW TO On Headlight Painting
  200. help with turbo gauge
  201. help with tranny temp gauge
  202. adapter for water temp gauge?
  203. Wiring m3 mirrors for civic ? Help!
  204. dc race header does NOT fit autos!
  205. Changing dials and switches colour
  206. Check Engine Light On
  207. Fuel pressure gauge setup
  208. can i paint my steelies chrome to make it look like.....
  209. 2005 Honda Civic Cluster
  210. LX to EX exhaust conversion question...
  211. SRS Question
  212. how to get rid of the honda emblem's two holes
  213. crx
  214. Sparco Pedal Install HELP!!
  215. vtec in civic hx's?
  216. Aem Ems
  217. Crower Stage 2 and ECU Issues
  218. Help w/ converting to EX Exhaust
  219. How to add ATF?
  220. throttle body bypass, worth it??
  221. Full pillar gauge pod mounting
  222. help installation dc headers
  223. How to remove tinted windows?
  224. PCV valve fitting size?
  225. honda error code?
  226. FYI Regarding Shift Knob/Boot Fix DIY
  227. what to do???
  228. "Goo Gone" not working.
  229. any one know link for diy intake install??
  230. thanks
  231. foglites
  232. Helm Manual and Bolt Sizes
  233. Turn off ABS in Cluster???
  234. catback question, 96 DX hatch
  235. Searched, still need info on y8 intake manifold on 1.7
  236. Sanity Check: AEM V2 fits on an '05 EX M/T?
  237. uk 05 front bumper lower TypeR valance fittings?
  238. Can anyone make DIY for this???
  239. dx to ex exhaust conversion
  240. Chrome trim on back?
  241. '04 Civic VP - Cruise Control
  242. Reversing light switch - where is it????
  243. Can't find oem fog light DIY
  244. can anyone make diy for this.
  245. has this been discussed yet?
  246. really stupid question
  247. Limiter @ 7000 rpm's...
  248. Disable SRS light ? ne1 know how ?
  249. 3rd gen eclipse seats in an 01 civic
  250. Cargo net install
