- installing a tach
- whats the cut off
- Switching Headlight Bulbs
- intake exhaust general q
- Coming Soon: DIY for painting M3 mirrors.
- I know what you re gonna say
- DIY: Taking Apart your M3 Mirrors
- leather steering wheel cover
- Exhaust system upgrades and rear roll bar clearances
- gauge installation
- painting your fog lights
- Tech Chat and DIY's Forum Rules: Please Read Before Posting!!!
- shaving
- DIY: My Red dash lights
- Adding Back up Camera
- Changing Lights on dash for 2005 civic
- Noob here with a new 2005 civic. What is the usaual order of mods?
- ***UPDATED***I really, REALLY need some help!!!
- DIY paint mirror /lip
- Re-Attaching Cruise Wiring
- stupid diy but its free and my favorite.
- Question about Sandable Primer
- fuel pump assy
- How to remove valve cover?
- What is a good (keyword) quiet after market exhaust?
- if this is more DIY then move it please?
- window/door issues
- Once you go black, you never go back
- DIY: adjusting cruise control cable on an 01
- Modified Power Windows...wtf?
- D17 Info???
- 04-05 taillights
- Calling all automatics!
- Auto Door Locks...
- constant 12v source....
- supercharge anyone?
- is this a good idea?
- Got a question bout a tranny swap
- Headlight Installation?
- just random ???'s
- Clearing headlights!
- 05 clear headlights?
- Headgasket?
- bypass valve for injen RD1565
- How to get through firewall
- HKS Hi-Power Rear-Section
- Switching headlight Bulbs
- changing the heater
- Anyone ever change a Cable Reel?
- Putting a lip kit on?
- Shift lever disassembly?
- ECU and Info it holds
- NA Injector
- Wire Harness for Spoiler
- rsx rear seat install question
- help me!
- Dash painting Help!
- transmission swap scam
- Want power locks for my 05 Civic Vp
- Throttle Body Spacer ????
- using different trannys
- A'PEXi Time?
- HP Racing
- power windows 04 civic
- WTB HELP: How to replace these parts?
- Hood Shocks?
- Before I swap my gauge cluster.....
- Im installing automatic locks... how do I connect them to the alarm?
- Piston-rod specs
- Question about Altezzas
- Need Help with lambo doors..
- how would I be able to tell if trunk/hood/door shock sensors were installed on my car
- problem with black out headlight
- Altezza for 04-05?
- Lock and Alternator Question
- Torque converter
- Which Is The 4th Bolt That Doesnt Fit For Rsx Seats?
- Honda Civic 2003 install tail lights
- installing seat harnesses
- need help with hood latch?
- Adding cruise to a DX/VP?
- Removing Rear Bumper, '03 Civic EX Sedan!!!! HELP!!!!
- Trouble with A/C Compressor
- hu relocation
- Header Install
- m3 mirrors
- Points...Rep Whatever You Want...
- 92-95 Civic m3 mirrors
- Need Help Quick!!!!
- OBX Throttle body spacer and AEM CAI
- civic hx 02
- chair extension
- quick & cheap ways to get some more power ?
- Mounting front license place (after searched like millions forum post)
- can someone explain a push start?
- LX header question?
- Anyone using these ?
- b16a1/b16a2
- RSX front conversion on 7th gen Civic?
- for those with sidemarkers... do you have rust problems?
- using lx tranny in ex model
- cbr throttle bodies on a civic
- Spark plug wires...
- setting the clock.
- Intake Manifold R&D
- Mechanical water temp gauge install
- open ended or closed
- headlight conversion
- esmm
- Peeps who have redid their door panels...
- I should know this, but I dont....lil help needed
- 05 CIVIC EX OR 05 CIVIC SI(CANADA) Intake and strut bar
- Valve Lash / Head Gasket
- Adjusting Coupe Bumpers to Fit Sedan
- Milled Head
- Problem with slave cylinder.
- Stock airbox question
- RSX Interior Question
- DIY 5 Bolt Conversion
- DX upgrade?
- e-manage versus vafc-2 for vtec and fuel control.
- wire harness
- Custom red glow cluster *DONE* pics pics pics!!!
- Painting rear rotors
- 05-EX-4DR Fog Light Installation Instructions
- VAFC2 and E-manage
- 05 Sedan Headlight Blackout....
- Rod knock?
- fogs wont turn on ?
- DIY, timing belt / Valve adjustment
- Center Console Armrest Removal
- Tips on driving manual?
- Did anyone try this? (DC adapter + viscous side-side adapter)
- taking off catalytic converter, hp gain?
- coilover DIY
- 05-EX-4D Bumper Remove, Plastic Fasteners?
- Calculation of R/S Ratio
- 05-EX-4D Parking Light + Wire Access
- Rsx type-s injectors
- 1540 bracket, L Bracket
- Removing sound deadening material from trunk?
- 06 civic ex swap into 01 ex....
- Trouble bolting RandomTech cat to Kamikaze Shorty
- compression ratio...
- spring problem?
- stripped screw?
- short shifter help
- Stock Spark plug?
- Drive by Wire
- Changing breaks on a '96 Honda Civic
- Stupid question but... where is the distributor??
- 93 Civic Ex temp
- Question about Sideskirts!! Need Help!!
- Civic Top Hose Adapter
- Rear seat removal?
- adding a 12v dc socket
- need intake help
- Will they fit my car?
- EX header on DX (again....)
- Engine stand bolts
- Shift light connection???
- How to take crankshaft out?
- LoL, stupid dent..
- new exhaust
- Under drive pulleys
- VAFC2 help.
- Best headers for an lx
- RS Grilll...
- slipping into gear... bad?
- Intake Performance (Gas Mileage)
- DIY Fender Removal?
- PnP: NA vs Turbo
- DIY: get your car rain-ready
- Sqeaky clutch? fix it then..
- shaving side moldings
- 00-05 DX same engine?
- Debadging Front H emblem
- THOR Two-Way LCD Display Alarm System with Remote Engine Start
- how to remove rubber that attached to air filter housing mount?
- how to remove front bumper?
- anyone with front air intake?
- Fogs from eBay?
- I should make another DIY: Hood Prop
- why not put air filter over the TB? just thought
- How to split the tranny case?
- EX Headers on an HX MT!
- Help With ECU Piggy back PLEASE
- Dumb question
- My Auxillary Port
- How to add led blinkers?
- Any installing spoiler DIY here?
- WTF Grill wont come off HELP
- need help
- DIY: Upgrading stock keyless entry to Accord / CR-V style fob-head key
- INJEN IS intake
- Difference Between 2dr and 4dr...
- changing the lights on tone
- Is There A Diy For The Electrical Wiring For 01-03 Fog Lights?
- Wiper Arm Removal
- quick question
- a good way to check codes?
- Header Install Problem
- VTEC light, having some problems
- Ep3 sport seat fitment !!??
- Aem Ems 30-1030 Released Today!!!
- Is it possible to tweak urethane body kits?
- Primering your car for paint
- another one!!! d16y8 manifold on d17!!!
- 04 Projector Headlights
- Speedo Help
- Quicky on exhaust coupe vs sedan
- Where does the rear strut bar go?
- transmission conversion
- Hks Sld
- How to remove cigarette lighter/12v outlet?
- Whats the difference between theserear strut bars?
- does my car have a vtec engine????
- AutoX/Daily Driver..Is this possible??
- Engine Swap/O2 Sensor CEL
- License plate relocator DIY ?
- Has anyone changed the color of the license plate lights?
- weight reduction info.
- Sylvania Silverstar 9005
- need grey's kit
- Clutch wear symptoms
- SRI Intake Installation Help
- Orientation of the ECU plugs
- AEM Pully kits?
- RSX-S axle-back on Sedan*** New question
- need help wiring sidemarkers!!
- best way to reduce exhaust vibrations?
- Quicker steering -- possible steering rack swap?
- bumper removal
- removing interior door panel
- Revo Short Shifter Help ASAP PLease
- clutch master cylinder
- Air/Fuel Ratio Gauge. Will it screw up my o2 sensor?
- Real 2000 SiR by vin #
- Problems after T-belt/cam gear change?
- adding gas changes ignition timing?
- 5spd convertion question
- painting dash panel question
- DIY RSX rear sway
- clearing out headlights?
- CAI on 02 civic??
- Changing Pollen Filter in my Odyssey
- A different swap question...
- Ex 421 Header For Lx??
- AEM CAI - easy install for a novice DIY'er?
- turbo-back exhaust without resonator?
