- Door Panles
- rsx shift console in civic 01
- Trunk/Fuel Door release cable replacement...
- rsx axel back and bpipe
- Transmissions that fit our cars?
- Exhaust for LX
- Problematic intake air temp sensors?
- whats the point of all this spaggetti?
- Good exhaust set-up?
- Tightened E-Brake, any opinion?
- People who have done head swap
- cant take oil pan off, help
- VAFC 2 setting please share.......
- Trunk Spring reinstall?
- redline problem
- 60,000 mile Transmission fluid change
- 99 SI -Main Shaft bearing - transmission
- Civic VP engine internals?
- Custom Cold Air
- Part # For Throttle Bodie Nut
- lx to ex header?
- Broken bolt and LX > EX exhaust questions
- Help with cluster swap auto 04 into 02
- D17A9 Tuing
- What paint is best to black out headlights?
- Carpet Dye Protectant?
- power stearing
- vin # required for new seat belts?
- megan resonator/greddy evo 2 ????
- Towing
- D18 if you cant find it here.
- Squeaky Rear GroundControl...
- Who has the List of all the TSB's for the 01-05 civic?
- clearing TYC's
- Turn your fans on Manually
- D16Z6 and D16Y8
- Anyone know how to adjust idle range?
- Your mods = ? gains?
- Engine weights
- Dash Lights
- need help findin a way to run exhaust with cat
- what size is better for the power
- Acceleration is DEAD!!
- High RPM Mods
- Civic Axel
- air filters for stock box
- will this Tenzo seat fit our car??
- ecu re-mapping
- Engine light. . .is it time to mod?
- Door Rattles
- help my car was hit from the front
- Driving with e-brake on ... how bad can it be?
- E-manage questions...
- Please review the condition of my spark plugs! [RESOLVED]
- Anyone Know How To Install Projector Headlights
- 01-03 fogs wiring with 04 switch problem, illumination and indicator reversed
- ex/si catback exhaust on my lx.. will it work?
- Mid pipe Question
- body kit installation
- Electrians help!!
- how different is mannual iac and auto iac?
- Will 01-03 front bumper fit an 04?
- sedan people with SI Seats...what did u do about the rears? *and side AIRGBAGS*
- Pulley making weird sound
- Removing Center Console ( Manual Shift Boot )
- low end power?
- diff. btwn resonater and high flow cat.
- A/C problem
- CEL problem?
- ??diy Axleback???
- Strobe under car kit
- quick question
- help install vafc2!
- Stock Clutch or Aftermarkert
- emanage not controlling sub injectors
- how to paint interior?
- battery died
- amp mounting on 04 civic sedan
- How to remove side lining?
- no A/C in my 2002 Honda Civic DX Coupe
- Noise - upon startup
- New ecu
- o2 sensor ?
- Is this part needed for pressure in my slave cylinder?
- glove box removal
- Will gutting the cat help performance?
- Battery Light Issue
- headlight question
- Cheap mods that wont void warranty?
- (QUESTION) No A/C in my 2002 Honda Civic Coupe DX
- headers,hi-flow cat, exhuast fitting?
- dx cold air intake into a ex ?
- Asap...does A Rear Si Bench Fit In A Sedan ????
- starting problem/sort of
- Smoke spitting Prelude...
- Service manual
- burnt ceiling..
- Air conditioning mouisture?
- Checking your MPG?
- Simple question concerning A/C
- bleed brake fluid
- bleed brake fluid
- How to remove trunk molding
- Need help with Viper 791XV IGNITION
- Check Engine Light Problem
- 02 Civic - A/C Problem
- 2nd Alternator shut down! *LOOK*
- throttle adjust
- AUTO - Standard Conversion
- a/c not cold enough
- auto to manual
- [COMPLETE STORY] Some electronic messed up Help!
- [UPDATES - DEALER] Help me! Relay problem? Cable shorted??
- short throw shift adaptor
- A2 Pistons in A1 motor
- Type r grille fit 02 coupe?
- Where is A/C service port?
- '01 Sedan Keyless Entry Questions
- Injen short v.s Injen cold
- a/c removal for turbo..
- A Pop, and wierd first gear? Help!?
- want to put in 03 si steering wheel in 02 civic lx, HELP!
- Removing DX Door Panels
- Engine Swap
- Can you paint a CF hood, and is it worth it?
- Urgent Gauge Cluster Swap Question Question
- Throttle Body Heater Bypass - WHO HAS IT!
- Body kit or lip kit
- messed up throttle?
- '02 SI steering wheel on '01 EX???
- Body kit
- numbers under digital mileage
- b pillar plastic cover removal
- Ticking noise under hood
- 02 sensor extension for exhaust swap
- installin RPM meter
- front lip for civic
- lighting problem
- Oil Pan Cracked!!
- help with changing cabin fliter
- Liquid cooled throttle body, test phase one completed.
- Body kit Help
- 04-05 projector headlights on ebay
- DIY: ground wire upgrade and HVS part II (pics)
- engine knocking???
- o2 sensor..
- how does ecu change timing with temperature?
- why the liquid ITB simply won't work
- Removing Taillights
- I have an AC noise too
- Port and Polish???
- rattle
- Need Help...
- O2 sensor wiring for 04 civic ex
- How to fix windshield wipers?
- k20 swap vs. sti
- d17 in eg hatch, k20a3 in em2
- side repeaters....
- Air condition making my car act funny?
- Any 2005 SE Radio Secrets?
- exhaust tips
- CAI Question
- 99 Honda Civic Si W/ Vafc Ii
- does tint affect radio reception?
- anyone try this? (taking the braces out between fogs)
- F$#ken Goverment Thing
- remote starter problems !!!
- flashing light location ??
- cigarette light wires
- injector question.
- Anyone With Crower Stage 2 Cam Help!!
- Amp Installation on stock stereo
- K2o VS D17A2
- do i have to cut?
- exhaust tip help
- HELP my dash lights wont work
- Coolong Fans
- help!
- Help on fixing my stupidity.
- Engine dies while driving.
- oil pans..
- cd player code for civic 2001 ex
- Help......pcv Valve - Check Engine Light
- HELP.......slider removal from factory seat bracket
- problem shifting hard from 1st to 2nd, please help...
- SAFC2 settings??
- Strange problem... wierd click under dash, rpm drops **Update**
- Fuel Delivery Problems
- Ac
- n/t
- Can I skip getting a wideband if I run emanage?
- 04 Mt
- help with 5 lug conversation with vic coilover
- Rounded off bolts
- How do you install an Air/Fuel Ratio Gauge in a 2004 Honda Civic??
- A/C making car idle low?
- need your guys help
- head swap
- EASY HU relocation!!! check this out
- Air Filter Bolts won't Come off!
- Dyno Proven power: Injen Short Ram vs. Stock
- SEATBELT INDICATOR-ATTENTION 03's
- 2002 honda civic lx 4door
- Jdm D17 Vtec Engine ?
- Cooling Fan
- Need Info about blown engine for 2001 civic
- trunk release idea?
- Washer Fluid Indicator Light Stays Lit
- Cruise Control Relocation Question
- Check Engine-0420 code
- ANy one who DIYed door panels on a Coupe...
- grounding kit
- srs light
- Wideband????
- HELP! HU reception sucks after keyless install
- Help, a dx cluster swap?
- Grinding Stock Cam Shaft?
- Where to plug in code reader?
- SAFC2 Initial Setup??? (Update: Having Problems)
- oil change
- Trunk problem plz help!!
- Is it worth putting performance in my civic?
- The second someone releases a D17A1 cam
- Head light cover
- DC Race Header Problem(Help Quick)
- urgent question-03 gauge cluster
- Bashed up my car a bit...
- *****I need some quick help*****
- Tight clutch padel?
- DIY for headliner removal with pics??? PLEASE!!!
- m3 mirrors
- What do headers do?
- Diy Adding Vinyal And Painting Trim Pieces
- gauge question help!!
- Main Fuse
- JDM Crank Pulley Different
- Injectors causing 1-4 cylinder missfire?
- someone help me out
- How Much do Rims affect?
- ex head swap..
- FORUM RE-ALIGNMENT. confused? read here
- What kind of OBDII scanner?
- I'm searchin and searchin and I can't find any info on AC removal!
- Headlight cover swap.
- Special Edition????
- anyone have an archive of greys diy pedals?
- Cleaning the Fuel Injectors
- front bumper cut outs
- How to mount s/v-afc like this (pic)?
