View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. k20 or k24
  2. oil problems
  3. emissions
  4. crank pulley problems
  5. Cam/Spark Timing questions
  6. exhaust size
  7. Side skirts wont stay up help!!!!
  8. dual a/f guages
  9. brakes
  10. Question about Headers?
  11. replacing headlight bulbs
  12. RPM Limiting
  13. OEM crank pulley
  14. 05 Civic Head Unit
  15. Has anyone been successful in DIY power door lock (replace actuator)?
  16. Hole in radiator
  17. Sway And Strut Help Alot Or Not
  18. Fuel Pump Fuse Location
  19. LED #'s In Dash
  20. WIll an ex aftercat o2 sensor work for dx?
  21. Only a few N/A mods to go! Will post Dyno Pics
  22. Shorter clutch pedal throw?
  23. Where to find OEM parts?
  24. Size of seat belt bolts
  25. hand brake
  26. New 05 EX starts hard
  27. Average cost to replace alternator?
  28. Help Yal! Unnecessary Vibration
  29. Please help with the fuel pump relay
  30. Pictures of under dash and behind dash, please help point out FUel pump relay
  31. A/C Expansion Valve
  32. clearing headlights
  33. Isn't there any chip tunning for our engines??
  34. Mysterious smoke from the column...
  35. Brake Booster line!
  36. Stock airbox + curiosity= interesting conclusions *update*
  37. Question on fuel filter
  38. D16 valve cover
  39. D17 VTEC head swap
  40. pic of part
  41. spc camber kits
  42. What is the best oil filter wrench/tool out there?
  43. Auto Gauges
  44. Tach Install for DX
  45. Changing plugs
  46. What it take to make a JDM smog?
  47. clicking sound when starting
  48. dropping to D2 from D in auto
  49. using window tint on taillights
  50. Check engine light help
  51. question?
  52. srs light stays on
  53. Smoked Tails
  54. To those who have driven both EX and LX..
  55. Fuel Line?????where Is It?
  56. Gauge cluster swap
  57. Removed seats, now SRS light is on!
  58. rsx injectors into fuel rail
  59. Exhaust for sale! (AGAIN)
  60. What would be the best way to "move" The EX HP to lower end?
  61. Is it hard to get into the outside door panel??
  62. scratch marks on dash
  63. DIY request: coin/change department
  64. car suddenly won't start... rapid clicking noise
  65. Car putters on start-up and I've seen white smoke coming out of tailpipe
  66. What size are the threads on the shift knob?
  67. cruise control wiring
  68. Do they make JDM parts for our cars???
  69. Anyone know how to remove side molding on an '03 sedan?
  70. 02 wire color? quick help please!!!
  71. weird running problem
  72. Windshield Seal Fix?
  73. need help asap !!!!
  74. vtec setting for ex with vafc 2?
  75. New cat..loud and o2 went boom HELP
  76. taking out airbag
  77. Rear RSX Seats
  78. third brake light flash issue
  79. altenator
  80. dry ice
  81. check engine light question
  82. New Header
  83. i lost power from my evo 2 exhaust!help!
  84. solutions to muffler moving around on rear bumper
  85. Projector TYC HID problem
  86. blacked out my headlights!! (updated with pics!!!)
  87. High Reving Engine?
  88. D17a1 bottom end
  89. Can sedan seat belts fit in a coupe?
  90. I would like to install a lap belt.
  91. dual halo projector bulb fitment problem
  92. Exhaust Install
  93. A Few Issues, may have heard of some already
  94. Head Porting Questions
  95. Throttle body
  96. Thermostat? Pump? ehatever, its a major issue now!
  97. MoMo DIY Install Help!
  98. Details on DIY blacking out headlights on 04+
  99. air fuel
  100. aftermarket header and stock downpipe
  101. HELP with headlights
  102. Smoke out of exhaust?
  103. intake temp and rpms?
  104. Need A1 regrind spec sheet
  105. seat belt colors
  106. 6 grand what to do?
  107. Converting center console to 01-02
  108. intake heat shield--need ideas
  109. Fog Lights
  110. grounding TB to chassis or neg post
  111. custom intake heat shield
  112. Tenzo R Rallye-2 Seats
  113. Pleae help? I need cluster wiring diagram 02 civic ex coupe
  114. lost steering last night
  115. Problem my car bogs
  116. car cuts off and on radomly
  117. Shitty start up after rain
  118. ECU help
  119. Ipod to Factory Radio Without Adapter
  120. Proper cold tire pressure for 04-05 Ex coupe?
  121. o2 sensor pulled a check engine light!
  122. Base dyno chart for D17A2 Manual
  123. Anyone with Arizen seats?
  124. taillight bolt broken-help!
  125. Air conditioning...
  126. air conditioning...
  127. To get SRS light reset?
  128. Crazy Tech stuff with CLuster and Comp.
  129. o2 sensor problem
  130. power window fuses blowing
  131. Another Cold Air Intake Question
  132. Another stupid VAFC question
  133. o2 sensor question
  134. HELP...its getting dark and i cant get my mirror apart
  135. Is it possible to re-calibrate speedo/odometer?
  136. regrind from Gude?
  137. amp cuting out
  138. Rattling at rear driver's side
  139. short shifter install help
  140. Sparco seats/steering wheel & SRS system?
  141. wheres my ecu?
  142. Fixed my sunroof rattle
  143. tinting/tail light cover?
  144. Ignition key programming on Honda Civic
  145. WHat you guys use for gaskets
  146. Changed oil help...
  147. engine light need help!!!!
  148. flywheel bolts...
  149. Displacement
  150. clutch pedal question
  151. Very Serious braking problem..Help..
  152. VTM wire
  153. Installing Volt Meter
  154. Problem with a accord
  155. Will the Apex VAFC 1 or FIELDS VAFC work with the 2001 civics??
  156. Need Help Asap
  157. warrenty - CV Joint
  158. Need to find...
  159. please help if you have service manual
  160. breaking in my new clutch
  161. Random Tech. on an LX
  162. Drivetrain shudder in 2002 Civic
  163. Remote entry problem
  164. Car shakes when reachin speeds of 60MPH and more!?!?
  165. Normal for radiator fan to turn on much?
  166. just a question
  167. Putting on S-Tech's, do i need shocks too?
  168. 01-03 coupe taillight trick
  169. 4 dr. diet
  170. Caliper...
  171. Stock Paint (other than touch up bottles)
  172. NOS Octane booster for stock?
  173. Brake vibration
  174. HELP need to recalibrate gauges
  175. Anyone Have Diy Rsx Injector Install?
  176. Anyone Have A Diy Rsx Injector Install?
  177. Anyone Have A Diy Rsx Injector Install?
  178. Do you really need to have the bushings for short shift?
  179. clutch and flywheel
  180. New Springs...
  181. P1361 TDC Sensor Intermittent Interruption
  182. Fixing scratches on door panels
  183. D17 rocks!
  184. Fogs only on iwith lights?
  185. Where to find certain parts
  186. Weight of the "Si" alloy OEM Wheel?
  187. maintance light blinks
  188. Project: Hater-aid
  189. What does this code mean...
  190. srs light
  191. safc 2
  192. Immobalizer
  193. A/C Recharge Question
  194. wireing a remote start on manual
  195. A/C question....
  196. shakey stiring wheel
  197. Help Overheating
  198. Im getting p1607
  199. Moving the AC
  200. f-1 engine
  201. Tranny
  202. kamikaze header
  203. Clutch Peddle
  204. Leaky Trunk
  205. Carpet Taken Out?
  206. ex header on a 01 HX
  207. ex header on a HX
  208. WTF is Backpressure???
  209. How much whp?
  210. PCM ECU Codes CEL BLINK Code ...and Rant
  211. Stock washer nozzels wont fit CF hood
  212. Car shuts off when driving?
  213. Headlight Question
  214. Red Wire. White Wire. Picture plzzzzzz
  215. headswap n cams ?
  216. headswap n cams ?
  217. HID's Install Question
  218. ex head swap
  219. MUGEN TWIN loop -05 civic
  220. Bored? Clean your grounds.
  221. Ex Header/Exhaust fitment on Dx/LX
  222. Problems with the SRS light in my Civic 2001
  223. headlights, blinkers DONT WORK?!?!?
  224. hi flow cat question?
  225. Alternator Sensing Wire
  226. speedometer
  227. help, axles????
  228. FIPK2 or Typhoon?
  229. Engine help?
  230. Anyone heard of LUK Gold Series Clutch?
  231. CAI of a DX/LX on a EX???
  232. Header hitting sub-frame?
  233. braking noise
  234. redline problem on a auto hx
  235. When does VTEC work?
  236. When does VTEC work?
  237. PS Fuse
  238. AC in a k20 7thgen?
  239. AC in a k20 7thgen?
  240. what is normal idle RPM?
  241. No Pressure on My clutch Pedal
  242. What does this trouble code mean?
  243. 7th Gen noob Q.
  244. A/C Problem
  245. Intake hiss
  246. Air/Fuel Ratio Gauge
  247. Does anyone know how to make the rear seatbelts release?
  248. HELP: Car Wont Start, rapid clicking noise
  249. Thread size ?
  250. what to use
