View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Widening the knob hole?
  2. Seat Belt Chime
  3. cat back oem rsx type s
  4. HELP! Will + rep you if you do! My friend drives a 97 Accord LX
  5. Exhaust/Muffler question.....
  6. Question about a lip kit
  7. ecu question
  8. universal 2-step
  9. Problem installing tyc projectors??help
  10. Integra headlight question ...
  11. LX to EX head swap
  12. Click noise
  13. bad gas mileage
  14. Oem Foglights DIY??
  15. another rattle
  16. help!!! clutch problem
  17. new auto or swap to manual
  18. DIY: amber signal without the reflection
  19. Faze tach install ??
  20. What is purple gas?
  21. srs light from type-s seats
  22. where have you plugged your 12v accessory
  23. overheating like crazy, help!!
  24. New 04-05 civic projector aimming
  25. questions on factory alarm system
  26. Screwed...
  27. ReWiring Cruise Control....Anyone?????
  28. SRS Light - Didn't Unplug Anything To Set It Off
  29. Problem with side skirts
  30. Problem with side skirts
  31. Speed Limiter??
  32. Anyone ever change their clutch master cylinder?
  33. Need Clutch/Flywheel Info
  34. extend the O2 sensor wire
  35. Safc Or Greddy Piggy Back
  36. lighting...gauges, brake light
  37. Installing Racing Seats
  38. free garmin eTrex or magellan GPS
  39. Drive Shaft???...
  40. burned out light (guage cluster)
  41. Scratches on HEAD UNIT!!
  42. Best Silencer for 2inch piping from the cat?
  43. Blackout!
  44. what does a bad CV joint mean?
  45. DIY - Smoked Taillights for Sedan
  46. Lookin for the DIY black housings headlignts!!!
  47. Clicking noise when releasing the clutch
  48. Headlight Bolt - Driver's Side
  49. Quick H E L P!!! Bell Housing!!!
  50. VAFC2 help for lx to ex conversion
  51. 02 simulator problem
  52. how much to mill head?
  53. DIY - Smoking your Tail lights.
  54. threads on the shifter?
  55. Clutch question
  56. speedometer problem
  57. Shakey Shifter
  58. Top mount bolts won't come off...help?!
  59. Air Fuel Gauge Hook-up
  60. SHORT SHIFTER, short shifter
  61. She's Dead!!!
  62. need help w/air fuel ratio gauge
  63. Problem with Turbo Timer
  64. Finally a CAM! But not for non-vtec
  65. Just finished installing my new transmission - shifts like butter!
  66. Srs Unit Location
  67. Adjusting rear camber kit
  68. Rear Seat Latch Relocation
  69. Is it worth it......
  70. Where can I buy this???
  71. SI seats in a coupe
  72. question about smoked taillights?
  73. Rear Window Removal
  74. DRL Module location?
  75. Major Fvck Up for the year 2005
  76. Replacing struts. Some problems
  77. Car won't start???
  78. hood latch + rad support
  79. DC Sports TCS
  80. is it only in my head ?
  81. 01 auto tranny to 04+ tranny
  82. MisFire?
  83. Headers Torque Spec. ?????
  84. Possible to paint splash guards?
  85. oil filter comes off counter clockwise or clockwise?
  86. Question on steering wheel!
  87. Valve Cover Fitment?????
  88. Fibre glassing.. hrrmm.. help
  89. Engine light on after shampoo???
  90. diy: my throttle body heater bypass (pic!)
  91. My car is running rich as hell
  92. d16 manifold
  93. Painting Interior Panels
  94. Air/Fuel Gauge and O2 Sensors
  95. 15'' in a 7thgen?
  96. Transmission swap?
  97. AEM EMS Review
  98. Is this worth it?
  99. New problem with Cruise Control.
  100. Sound when Lights Left On Doesn't Work
  101. 04-05 Civic Projector Headlights
  102. Need Header For 04 Civic LX
  103. Flywheels and clutches
  104. ebay cai induction kit
  105. Selling my 2004-2005 Civic Si Wheels + tires
  106. 3 stage vtec
  107. tach installation
  108. 2004 cai into 2005
  109. Weight reduction in preocess *Pics*
  110. Engine/Tranny Problem!! HELP!!
  111. Need Help On Replacing Trunk Release Cable!!!
  112. what interior sedan parts fit in a coupe?
  113. smoke?
  114. performance cv half axle
  115. looking for diy
  116. Turn Signal Help!!!
  117. Question: Where's the IAT sensor?
  118. what mods (N/A) ??
  119. i got a problem and need some help
  120. DIY: Remove badges
  121. SRS unique??
  122. rsx strut bar
  123. Si seat install help
  124. weird sensation
  125. hardest black headlight problem question ever!
  126. Help with emanage on Lx
  127. VAFCII and ex head question
  128. Painting XM Satellite Antennas
  129. Broke Something
  130. A/F gauge rich????
  131. EX Header for LX?
  132. How Do I Put This Cam Gear On And What Degree?!?!
  133. HELP!!! Almost Installed 04-05 fog lights (w/ pics)
  134. What would happen if you were to...
  135. Fuel Hose???
  136. Help... catback problem
  137. Will EX exhaust parts fit an LX?
  138. Cam Install..
  139. Not impressed with MPG!
  140. who has tranny cooler ? on 5 speed
  141. door open/close button problem
  142. different types of exhaust resonators
  143. Vtec problem....
  144. DIY: Cabin Air Filter Replace
  145. remote/acc wire
  146. Venom
  147. 04 Tranny's are awesome!!
  148. Muffler Scilencer
  149. Shaved cylinder head
  150. 02 Fog Light Installation DIY
  151. removing city light bulb on headlamp
  152. DIY Fog Light Help!!!
  153. Autometer water temp Electric gauge
  154. any of ya'll done a power window swap?
  155. exhuast size
  156. Vtec?
  157. Cai
  158. need car to run cooler radiator cap/thermostat ?
  159. bend ignition?
  160. All Wires the Same In Hondas?
  161. programming remote
  162. Turbo effect on Gas Mileage
  163. Intake problem
  164. OEM rsx steering wheel w/airbag
  165. is my downpipe loose?
  166. Cai
  167. Hissing Noise?
  168. engine idle
  169. body kit ?
  170. Axle broke on my 02 Civic SI
  171. Breather hose
  172. 02 ex will not run right
  173. Clutch or Manual Trans problem???
  174. DIY Mods
  175. What mods can i apply to my 01 Civic????
  176. volts dropping
  177. Engine died while driving, D17A, sedan yr 2002
  178. tuning with headers
  179. fiberglass trunk install question
  180. 96 DX Air Intake
  181. Emergency
  182. got my wideband O2 today
  183. Front Sway Bar
  184. Rear brake swap
  185. Exedy ebay clutch?
  186. o2 Sensor
  187. Can the D17 be made into a DOHC ?????
  188. MEgan Racing
  189. No More Mirror Rattle!
  190. Update on the oil cooler project from hell
  191. Everyone Please Verify Something For Me On Your Car!!!
  192. Colder thermostat
  193. HELP!!! Big Problem
  194. e-brake one click = traction control?
  195. resin for cf?
  196. dx to ex swap info...
  197. rsx dash in a civic
  198. Reset ECU after Intake/Header/Exhaust???
  199. Grinding Noise
  200. Yellow Indicators 7443
  201. Sway Bars
  202. HID retro
  203. quick gas gauge question
  204. Anyone know how to reset the ABS indicator light?
  205. 2000 DC 4-2-1 conversion to a 2002?
  206. oil pan bolt tq specs
  207. Alarm installed and won't work...?
  208. Tilting License Plate Frame.
  209. Honda OEM Fog Light Template
  210. Pissed of of rattle: DIY deadening part 2!
  211. Cutch Noises?? Engine Rattle??
  212. Speedometer ?'s
  213. Squeek! Squeek! I'm fvckin tired of it!!! FIXED!!!
  214. Exhaust Installation
  215. Speedometer Drop Out
  216. Problem with ex header?
  217. Whisle noise when AC is on???
  218. Intake Breather Hose
  219. What material?
  220. sun grounding kit vs DIY kit
  221. 2003 civic coupe hood fit a civic sedan?
  222. Does anyone know the gains when swaping out the injectors to RSX ones?!?
  223. body
  224. Automatic to Manual Conversion
  225. Spoiler
  226. Converting to Right Hand Drive
  227. K&N Drop-In Air Filter
  228. Intake
  229. Fuel correction on vafc2
  230. Stock modded intake
  231. Spring Compressor Help!
  232. Sticky Stuff On Rims...Help...
  233. Need help! Problem on 05 LX
  234. taking off the tailight on a coupe
  235. Vibrating idle with 17,000 miles. HELP!
  236. Question regarding Fumoto Oil Drain Vavle
  237. NOS: what kind for pre throttle body? FOG kind?
  238. Turn Signal Problem
  239. Anyone running nitrous and a turbo?
  240. emmision light is on
  241. Headlights.
  242. Just Installed HO Alternator, Voltage reg. Prob??
  243. SAFC and SAFC2 wiring instructions
  244. D17 Crank Bolt
  245. mods
  246. Self tighten crank pulley bolt?
  247. PLEASE HELP! Wiring Diagram for Stock Fuel Pump Harness
  248. turbo or supercharge
  249. 97 cluster red lights
  250. Installing spoiler
