- Final Drive Ratio
- 10w 30???
- PRO PERFORMANCE CHIP HElp?????????
- 04 Rear Bumper on an 02.
- Anyone with Prinout of Recall for seat rocking back and forth
- Shops to take out stripped nut
- Is this performance computer worth the money?
- cluster swap question
- civic type R shift knob opinions
- Injectors and Tranny Flush For 350?
- Engine Cleaner: Sea Foam Product actually WORKS!!!
- What are the differences between E-Manage and VAFC II???
- Should I Buy A Performance Chip???
- help with hyperblinker
- i need your help guys!!!!
- Wiring Spoiler Brake Light
- How does this really work?
- Check engine code
- Blinking "maint reqd" engine light at startup?
- Oil changing FAQ
- heated mirrors for civic???
- Turbo + Cat = ?
- What would you prefer?
- Paint off side skirts
- Popping When I turn....
- im looking for an 80mm shift light that will fit in a gauge cluster
- Ignition Problems!
- Dx vs Ex exhaust
- installed header, now problems
- 01 civic lx overheating like crazy...please help
- WTF? Some one has to know whats up!
- Rear Deck Idea For Rattles (Pics Included)
- what is this thing?
- Help with Grille-Tech Grille?????
- How do I remove the rear deck of a 4 door
- B16b engine question
- Sparco hood pin install
- stock AUTO civic dyno?
- gahh what was that thing about the vtec light...
- damn power lock....
- How much are we talking?
- friend needs help
- Change Manual Transmission Fluid
- HELP! P0740 code problem
- 2.25 homemade exhaust (pics) Now with video
- What is up with Hondawerx.com? O and I have a lower grill Q too!
- Do you have sunroof dimples?
- strokin' the D17
- tach impulse pickup?
- remove 04 door panel
- Control Arm bushing removal and ES replacement
- Removing Carpet In A Civic (need Help)
- Crower Rod?
- Another Jack Question
- Rev Question
- Disconnected Guage Cluster
- My HKS Exhaust
- does this mean that... (regarding VTEC engagement)
- 60/40 bench removal
- Five bolt hub retro/switch
- 2 Step
- Problem w/ dash lights
- Thermal vs Standard??
- Help with pulling head.
- Shifting Question
- All those that have swapped Steering Wheels..please read!!
- Removing WW 3 piece spoiler
- Gear Ratios
- o2 question
- Do they make a 2-step for our car
- The D17 VTEC controversy (solved).
- Bought a new part today
- radiator fan broken...car overheating
- Hellllllllllllppppppppppp
- Anyone ever change their differntial fluid?
- How long to change Mobil 1 oil/filter?
- Aftermarket Rims/Stock Suspension?
- vtec controller help
- Help installing gauge
- Question for A/C Techs?
- When Brakes are applied.
- window conversion
- Beep Beep
- Shop/Service Manual for 03 Civic Ex
- DIY Ground kit facts
- What is fuel relay?
- Honda dealer installing aftermarket clutch and flywheel for 10.00
- tach install
- Digital fuel gauge??
- DIY Help??
- Cluster swap help
- what trannys will bolt up to d17?
- exhaust rattle fix?
- Cluster Needles Not Moving!???
- How to remove the shifter panel?
- 3rd gear grind...
- delete plz
- VTEC on an LX?
- ground kit material
- HELP: removing kit glue / double-sided tape
- HELP: Question about unit of some sort by gas tank
- DIY RSX seats
- Transmission Problems
- how do I make a 15 or 14 sec car
- removing ac and power steering
- 3rd brake light
- Sparkplugs
- Qs about altezzas
- p1298
- DIY: First time changing brake pads
- Vid – my vic getting dyno tuned! Screaming!
- venom 400
- Sealing my tail lights?
- Power Shifting
- removing taillights
- Steering wheel removal
- keyless entry
- valve stem install
- When did you first change your fuel filter?
- Anyone have details on changing Timing Belt
- bore and stroke ?...
- d16/d17 ???
- Black out headlights... question
- clutch
- HID Kit on '05 Reverb
- 03+ Cluster
- My Motives
- S2000 Gauge Cluster In 7Th Gen Civics?
- Help installing AC Air/Fuel Ratio Gauge
- o2 sim questions
- Carbon Fiber Hood problem.
- ratteling noise under the hood
- VP to EX exhaust?
- just installed header and car runs like shit
- Have you greased your clutch today?
- Simple aero dynamics and wind resistance question
- venom 400 problem
- Tuned vtec controller
- Rev-Matching
- Can 2001 to 2005 Civics be Jimmied???
- DIY 04-05 Clear/Blue Turn Signals
- Spark Plug Cleaning
- ECU questions from a Noob
- Question on Alternators
- Fuel Pressure Regulator
- HIDs into projectors
- LOW Beam/ HIgh beam
- strut bar
- Headlight alignment on 2004+?
- throttle response
- nuespeed tie bar, problem and question
- anyone with 2k1's ever install Intermittent wiper controls?
- clutch smell/ intake noise
- exhaust temp
- What size is the Engine Block Coolant Bolt?
- need help - 01 to 03 gauge cluster swap
- 04-05 headlights
- LX to EX exhaust
- DIY squeeky clutch problem HELP FAST
- How do i fix SRS light?
- Greddy E-01
- Rsx-s mufflers
- Need some brake help...
- Power Steering..
- Exhaust gasket question
- Fiberglass
- Sparco Install
- to bore or not to bore TB?
- Custom IM
- Where is it????
- [HELLLLPP] No Audio Power@!!
- RS front lip install
- Ester based synth oil???
- Dent Removal question?
- Help removing oem suspension
- CD-Changer
- Horn Replacement Wiring for 2 Horns
- mods to make power at 8k?
- Safc
- Help w/door lock assembly
- 03-04 civic lights fitment?
- Need help installing coilovers!!!!
- Engine severely shakes [SOLUTION FOUND]
- best cam for making HP?
- I need major HELP
- Is it possible to switch from NA tune to N20 tune with Emanage on the fly?
- Need your help ASAP Please! Car wont move!!!
- Replacing the ECU add HP ?
- I Need Tranny Help Asap
- installing front seats????
- will this header bolt on to our D17?
- Burnt out bulb
- Power window regulator motor
- air fuel ratio
- OEM Exhaust Tip question
- 2000 Accord EX 4cyl probelms?
- 05 Civic Help...
- Stock Head-unit
- gauge installation
- Size of Tailights
- Si cluster
- Mugen knob?
- clutch wear, for all the MT people out there...
- Touch up & Accessory Painting
- MT TB same as AT TB ?
- Where is my SCS connect?
- Transmission letter lights
- trunk popper
- how many amps should i be getting
- Question on cleaning engine through throttle Body
- vtec on a switch
- Honda's electronic governors
- Car might be sucking water in, help
- Speedometer help
- recall notice
- Exhaust Gasket Leaking
- grounding kit tech and SUNS
- how come my trunk doesn't stay up?
- i did search... now is it worth it?
- Air Intake Filter?
- Ponys+Tranny= Pwr Lss...Fix?
- 01 neon head lights??
- Great EL cable diy
- ecu for 01 civic
- ? About taillights
- weird noise. Suspecting exhaust system. Need help!!!
- How much is our sunroof tinted?
- DIY: Wire oem fog lights to ignition
- Interesting read: Clutch Troubleshooting
- Dash Lights and aillights problem (possible Fix)
- welp, fixed brake system. remember kids, dont press pedal when pads are off...
- HELP o2 sensor
- vafc2 question help?!?!
- removing tint?
- how do you adjust the headlight for 02 civic?
- Which Wire??
- ACT Stage 2 ain't sh1t, purrfect auto sux a$$!!!
- S2000 exhaust
- Whining noise from motor?
- Maintenance Light
- Back & Forth Revving HELP PLEAZE!!
- K20 Swap???
- VAFC2 help!!
- VTEC Controller
- Car problem idle funny
- car acting up rev meter bouncing up and down
- Painting Urethane!
- Recalls!!!
- Auto trans problem ?
- oxygen sensor
