- How to change windshield wipers?
- Need help with rust on bolts on exhaust.
- ? about carbon fiber
- LX to EX Exhaust??
- Hyper Blinker on accident?
- Rattle problem
- Help! How do I adjust my windshield washer nozzles?
- ex exhaust to lx header
- new cd player in 7th gen
- Fog install trouble
- Exhaust Diameters
- handbrake issue
- mixing motor oil (by rating)
- Short Shift Adapter
- 02 Fog Light Installation
- advantage of a y8 manifold?
- SRS light
- spark plugs
- Removing Front Bumper... Airbag Danger?
- Loving the RedZone! Internals to follow
- Driver's side airbag sensor
- My steering
- Which oil filter wrench do I use for the small honda oil filters?
- DIY Stereo Install Problems
- pics for clutch DIY
- High Compression?
- Water out tailpipe?
- fillers for ABS plastic?? bondo?
- DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
- Question bout taillights
- need help on tyc head lights
- EX Exhaust on an LX?
- W T F!!!
- EX to LX Head Swap Emanage Question
- rsx gauge cluster swap
- Aiming Headlights
- So i blacked out my headlights
- spark plugs
- Speed Chip? Or pure shit?
- short throw
- M3 mirrors mounting problem
- intake question
- Return conversion fuel system +
- Parking Light Part #
- Secondary O2 Sensor Wiring Help
- tune up...
- Pinouts
- HELP! wrist pins
- Best product for adhering Body kit
- key fob
- abs light on
- Pedal replacement
- water pump problem?
- So I took my car in for a new axle
- Exaust / o2 Sensor
- Help altenator
- I'm having a tough time finding a reputable speedometer shop x_X
- READ: How to operate your vehicle
- Cargo net install? Omg help!
- center console..
- Removing Door Handle
- Spoon what?
- Didn't change the oil till 10K, now the MAINT. RQD light's on
- RPM question
- I need some help guys *stuck at work right now*
- 04 DX headers??????
- STUPID transmission question
- What is it?
- Reverb 6 disc replacement
- Question on Adjusting the Throttle Cable
- RPM Signal wire?
- what to buy
- o2 sensor on 04 si
- anyone built a d17 before
- ECU computer replaced
- Price of timing belt change?
- Wheel bearing replacement
- Can u install Cruise Control on an 05 Civic Sedan VP
- RSX dash
- Hella Supertone install with OEM foglights (with pics)
- Wet Speakers
- my headlights switch is broken
- ECU Harness
- Will 01-03 short ram intake fit 04 auto?
- Anyone used one of these before for taillight tinting?
- Civic won't start
- CHECK ENGINE LIGHT Questions
- To anyone that have 20" passenger side wipers
- Fuel Pressure
- Removing headlights on '05 LX
- unhooking or dead battery
- RSX type S axelback
- My Cluster burned, FUK!!!!!!!
- Quick Battery Question
- Got Problems! IM NOT SURE IF IS THE NX OR THE EXHAUST!
- Front bumper clip leftover
- EM2 Wiring diagrams
- stock stereo and aftermarket harness diagram???
- Help! I'm installing LEDs in my automatic floor shifter, and I can't remove...
- How to get this part off? (intake install)
- Question about Trouble Code Detected?
- Did I mess up my car?
- gauge cluster swap but in Canada...
- Broke Exhaust Manifold Bolt Help!!!!!!
- HP Racing header...lagging
- the car-puter is under way
- Fitting Tanabe SMR onto UKDM Civic EM2
- Cheap way to DIY poly motor mounts
- Need some help/opinions........
- paint remover on ABS plastic help omg
- Strut bar ...modification...
- 01 LX 4Dr Cracked Exhaust Man.
- Mobil 1 EP 15K mile/1 Year Oil?
- Computer acting odd after header install?
- M.i.l.
- Exhaust Rattle/Vibration
- To buy or not to buy?
- Engine bay fuse box removal
- About time!!!!!!!!!
- Helpme....hp Header W/highflow Cat
- help with ABS and Traction Control
- Those with Revo SS and Grey's kit
- Question about tachometer
- OFFICIAL: How Fuel Injectors Work | Truehonda.com and Overboost.com
- how to remove ac vents?
- Too Freakin Tall For 01 Civic EX Coupe / Back Problems
- need air filter for stock civic.
- RPM and TPS (Throttle position sensor)
- A/C taken out?
- D16 Clutch on a D17?
- The V2 Way
- diagrams
- Safc2
- does anyone have detailed instructions replacing cluster bulbs on 01 ex 5speed civic?
- SRI Intake mystery brackets (pic)
- Gauge light out......HELP
- diff. between lx and ex headers and cat
- Help needed
- EXPLANATION to lack of response to mods
- Towing Capacity ?
- Electrical Question
- ex and lx engine difference.
- VIS CF hood install
- Help Install Turbo Timer
- Ignition key programming
- 98-01 Accord Trunk Opener with 04?
- Block/Core Heater, Plugging In
- reverse problem
- Bad Gas milage
- Help with Stock Strut Replacement
- Any Feedback on these Aftermarket OEM style Plastic Bumpers
- SRI rubbing against hood
- How do you get the Front Fenders Off?
- adjustable cam gear explanation..
- Front Bumper on Majestic Honda
- what size is the gasket between the header and the highflow cat???
- When removing the interior dash, do you have to disconnect the battery?
- how do you jack up the whole car?
- Need To Remove rear Bumper Please
- Will SAFC1 Work?
- bumper, grille removal DIY
- Replacing front let cv axle...
- Civic to Del Sol Seat Swap
- Do our cars have a black box?
- Adjusting throttle cable...
- bypass valve doesnt fit...
- Questioning on A/C window circulation
- Oil pressure gauge reading
- NEED help fast
- how to get the air out of gas tank
- Need Help... Idle Control System Malfunction
- Question about the coolant level on a warm engine...
- HELP!! Spun rod bearing
- How much more HP?
- Part # for tiny black nib that holds gas cap
- AEM CAI for 02
- Well i found two diff sets of rsx seats so i got some Q's
- intake detonation
- Valve adjustment specs?
- DIY: oem switch for oem copy foglights
- What is VTEC?
- ex sway bar
- Whats that black stuff ???????
- o2 wiring question
- Online store for Denso Iridium?
- Safe?
- maintenance light question
- camber question
- Ground wire for amp
- sparco seat belt question
- Which should I get ??????
- Can't find Front Spindle ??
- Arm rests
- What next???
- Is nitrous a mistake??
- Re Flash
- my car is overheating, need help!!!
- ub bulb placement
- Help with Auto Tranny
- dash lights are out!
- Need help with removing a dash and dash pad
- Gauge cluster test
- A/C removale
- Ignition,Ground kit, plugs/wires,coils...
- Sparco seat brackets-Somethings messed up
- OEM Spoiler: New Trunk Springs
- Dash Question!!!!
- Constant Power Source for heated seats
- Head lights
- EX transmission
- OEM Spoiler: Broken screw
- Engine seems to be outta wack(Tuning)
- Question.
- Need Turbo Parts
- em2 -> RSX e-brake swap
- Exhaust smell, rich or lean?
- Diy headlights blackout
- D17 N/a
- Gauge Cluster, printed board...
- Will a test pipe....???
- Turbo vs. Nitrous...need opinions
- Experiment RSR **.avi video added**
- dropping a d17a2 into....
- So this might be a stupid question....
- HID question! Plz help me!
- REMOVAL: outside window weatherstripping (molding)
- Where does the.......?
- AN Specification Information
- Where is this...
- Removing 'windshield trim' pieces?
- Took off my tb spacer and...
- How hot does header get?
- lambo door install
- headlights
- Is this really a "test pipe"...or....
- D17 Riders
- Sunroof Wiring Diagram for Alarm
- Suspension torque specs
- Help!
- PCV Replacement
- Manual window handle
- check engine light
- Are there any settings I can play with on my new VAFC II???
- Ex manifold on dx
- rsx front end conversion
- Dome light/Power lock problem
- exhaust sound?
- something interesting about our cars
- molding oem kit
- Oil change
