- head unit question on EX....
- Swapping to a 6 speed tranny
- Need Shocks Information
- interior trim DIY Folly
- Anyone with Tsunami front bumper
- Coilover Question?
- LX and EX stock wheels & tires
- Location of your Street Glows
- tire balancing
- AFC controller
- EL Gauges install
- 2k1 to 2k2 cupholder converstion
- DIY: Hard-Wired Radar Detector (EX Only)
- New Interior Ideas
- How to Book...
- Gauges...
- Altezza tail light CONDINSATION!!
- droppin the civic
- DIY Remove Resonator Box
- Question for 2k1civic.com
- OEM Paint Supplier
- HELP ME WITH MY ALARM
- Skunk2's
- Fuel Filter Question
- blew a fuse w/leds
- Duplicolor Paint for engine bay trim?
- People with Reverse EL gauges!! PLEASE HELP!!!
- Front type r upper grill - painting
- Need some suggestions - automatic shift knob
- painting interior
- Washing with an AEM CAI
- Glow Pedals
- manual knob on auto
- ECU, need help quick....
- Question AEM CAI w/Bypass
- GTR Kombat Spoiler??? Help (Sonsonzai)
- CAI Problems
- Painting exterior trim pieces
- Attn: Boosted... I need knowledge!!!! Please??
- window tint...need help asap
- port and polish?
- how do you get tha handle off
- Strut Bar Question
- DIY: Rear Deck Spearker installation
- Do your CD's Skip ??
- Who has H&R springs?
- Attn Civic Punker 17
- Painting Interior Trim Pieces (In Canada)
- air filters
- [ 4-5 lug conversion : via RSX swap ]
- DIY: Throttle-Body Heater Bypass
- Map Sensor??
- maintanence light
- Problem with my Eibach Pro-Kit
- 2k2 LX-G .......factory stabalizer bars...hmmmm
- Wiring To Park Lights
- throttle body
- vtec switch point
- Safer?
- DIY on trunk????
- insulation
- DIY:make ur own CAI/SRI
- Trunk Light
- What type of lug pattern do we have?
- Power shifting Q's
- why 2.25 inch piping
- PIAA Fog Lights
- muffler mounted weird? need help!
- Push Button Starter ???
- what about smaller pipe?
- HKS turbo results question
- Turn Signal question
- Tranny?
- HOW DO YOU DUE YOURE DASH BLUE?
- Look what i found in are civicssss
- trbomax, turbonator, spiral....etc
- switch install, need help
- FLASHING!!!!!!!!
- kaminari and lowering
- AEM short ram intake
- how do i get that sound when i shift?
- DOES ANYONE HAVE PIC OF BLUE DASH BLUE SPEEDO?
- HOW DO YOU GET THE EBRAKE HANDLE OFF???
- Camber Kits
- shift boot for auto
- NOS HELP!
- ~*<> KeYLeSs EnTrY <>*~
- no muffler=performance??? or rice????
- Safc on civic ex/si!!
- Where do I wire a neon in my trunk?
- installing tail lights
- ss adapter install
- NEUSPEED UPPER FRONT STRUT BAR INSTALL HELP!
- OBX B3 Bomb Exhaust?
- What's the diff for healights bulbs!!!
- Headlight Aiming
- Tuner Lug Nuts?
- 17's and speedometer
- anyone have a repar manuel for a 2001 civic?
- TIRES!!!!
- DIY DC INTAKE & EXHAUST
- Who was getting the turbo?
- led lights on the dashboard!
- Change The Climate Control Light Color
- Question About Installing Koni Yellow Shocks
- Installing Racing Seats?
- spare tire under the car
- ATTN: All those with 215 width tires
- has any1 adjusted their koni height? Attn: mwwhonda
- Noob lookin to lower his car...
- Anyone cut there shifter down themselves yet?
- Need help on neon wiring in trunk! Won't turn on when it's supposed to!
- sub instalation
- ATTN: THOSE WITH KONI STRUTS
- throttle
- two big black boxes under the hood
- I need mad HELP
- Help Mesh grill!!!!
- Should I really try it.
- AEM CAI sound?
- DX/LX to EX Cat swap?...Grey
- ?17" Wheels/Tires?
- Stock Fender Gap???
- Suppension
- Neuspeed Sport Spring Installation Question
- resetting the ECU
- Cat and Streight Pipe
- QUESTION ABOUT BODYKIT AND LOWERING
- Coil-overs vs. springs
- WW Side Skirts coming off :/
- match PIAA Xtreme Whites..
- Need Some Suggestions For Friends Tranny Problem
- Questions about R1 Racing Single Coilovers & Tokico Shocks
- Hp Header "New distributor Post" READ-Retitled by ALLMAN
- where did you put your dimmer switch?
- PROBLEM WITH CLEARING HEADLIGHTS, TWO VERSIONS OF HEADLIGHTS
- JUST RECIVIED PULLIES: HOW DO I PUT THEM IN
- coilovers???????????????????????????????
- leaking strut
- help
- Throttle Cable Adjustment *HELP*
- HID Shield Question
- Tach test connection
- MPG Tuning question
- Coilovers-- again
- Ignition wire....
- Dropping your car / rims...
- idea for returnless fuel system
- ATTN Grey
- Port and polish
- are lightweight rims strong enough for everyday use?
- S2000 steering wheel?
- M3 signal wiring
- shift boot for 5-speed
- AEM OE Brake Upgrade Question
- What size rims?
- if i see another "what size or kind of rims?" post again
- exhaust hurting performance!?
- exhaust question
- OK...let me get this str8 (about N2O) Experts please post.
- where is the parking light fuse!!!!!!!??????
- HOW TO ADJUST HEADLIGHTS
- HX => EX?
- DIY: Installing Apex'i S-AFC
- EGR valve
- ATTN: POGI/anyone that's gone through the firewall
- DX DASH HELP!
- headlights
- Squeeky Springs ???
- Dual Exhaust??
- Magnaflow Exhaust
- Problem with magnaflow....if you have one, please help!
- DO RIms have a Load range?
- ractive turbine exhaust
- took out my resinator
- how do i shave
- Apexi VTEC AFC
- how low is my car?
- Wiring Help
- Pics of Undercar Neon Mounting...?
- Pulleys
- Anyone installed the factory Fog Lights???
- Which wire for gauges?
- Can this be done?
- wheels humming....and tuner lug question!!
- Can you put Koni shocks on with stock springs???
- tell me if im getting ripped off
- will double-sided tape remove my paint?
- Help! Wiring Question.....Fixed
- can't find it
- installing OEM body kit?
- Do I have to remove my steering wheel to install indiglow gauges?
- not too bad for Altezza lights
- backseat removal...
- H emblem got jacked, now what?
- will these fit our 2k1??
- K20c swap
- The light ....The light !!
- Side mouldings or pinstriping!
- Help with an upper grill
- Question: Everybody read!
- Which strut bar do i get??
- Custom sub box not mounted over spare tire.
- need help removing automatic shifter cover
- Cearing corners?
- Spark Plug Wires?
- Automatic Shift Knob
- gauge cluster conversion
- LEDs IN VENTs?
- new Rims...rest ecu?
- I just got my indiglo R shift knob
- new Rims... rest ecu????
- What is a Muffler Silencer? Muffler & Torque?
- What's up with my wheel?
- DIY Injen SRI Extension & NEW "revised" DIY Spark Plug Cover w/ Pics
- Xenon blue lights
- Exhaust & Intake SRI
- Blue dash lights
- forced induction?
- Speaking of the APEXi S-AFC.............
- Indiglo install PLEASE HELP!!!!!!!!
- DIY: Subtle Lower Front Mesh Grill
- anybody have problem without headlight wiring harness
- how do you install a v-tec light????
- ohh ohh, paint is chipping off
- Problem w/ painting Tsunami bumper
- Radar detector install
- Problem with trim, please help!
- Weight to HP ratio???
- fog lights went off
- Roll fender walls out?
- strobe lights
- Hydrolock?
- Question for yositoco Only!! please =)
- OBX Lower Strut Bar?
- Clearing Lights, Cut Black Seal?
- Painting valve cover
- need help with seat install.
- Good Foglamps
- where to ground indiglos?
- HELP PLEASE: NO MORE SOUND
- O2 Sensor?
- BIG "H" On THe Grill
- A 2ND BATTERY?
- question regarding ground control coilovers
- CAN SOMEONE PLEASE ANSWER MY QUESTION
- Oil Change - how easy?
- anyone with DIY dash lights HELP!!!!!!!!
- Aftermarket Alarm Wiring... Help?!?!
