View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Looks familiar!
  2. The D Series Engine?
  3. Torque on šPlugs
  4. Brake Bleeding Pattern !! Urgent
  5. Push Button Start Help
  6. vafc settings
  7. Help With Valve Adjustment
  8. Is there a way ?
  9. Lx to Ex header/cat conversion
  10. Silicone Adhesive
  11. Front Suspension Q
  12. Sqeaking Brakes
  13. Brakes?
  14. sans passanger seat...
  15. bigger fuel injectors?
  16. Holy Fu@#!!!!! Hydro Lock???
  17. Engine Light???
  18. lights behind the a/c controls
  19. Help???
  20. Ebay: DC5-R Injectors
  21. !!!!!!!!!!!HELP !!!!!!!!!!!!!!!!!!!! :cy:
  22. Clutch time folks
  23. Rumbling Exhaust
  24. ex header to lx
  25. custom V2 intake
  26. DIY: Change your Transmission Oil
  27. Oil Change
  28. Location of throttle cable
  29. initial setup for v-afc
  30. "Cold"air intake through headlight in progress w/ pics.
  31. P1457 error code
  32. What is the Difference between HX/EX???
  33. Paddle shifters
  34. Where is the starter located?
  35. E-brake
  36. How Do You Test The Door Lock Actuator? ( To All You Technicians )
  37. Quick Question about Battery Cable Information ( Parasidic Drain Test )
  38. Help With Specs!
  39. Torque Specs for TB???
  40. Help! o2 sensor prolbem
  41. Help getting a OBDII Reader thing
  42. Funny noise coming from trans
  43. Speed Governor
  44. vtec dis-engaged?
  45. What type of intake?
  46. Torque vs. horsepower
  47. s2000 steering wheel
  48. custom LEDS
  49. fluids
  50. HID install (Clean up) Help
  51. Good Battery?
  52. headlights.
  53. how do they work?
  54. LED question
  55. Srs Light ?
  56. clearing headlights
  57. Exhaust rattle.....suggestions?
  58. RSX Steering wheel questions
  59. Front Strut Bar; Neuspeed
  60. Jump Starting Another Car.....
  61. DIY: [Easy] Ignited Push Button Install
  62. Coolant 101
  63. S2000 HID in OEM headlights??
  64. differences between ex and lx
  65. A little help guys!!--where to set boost controller
  66. those of you with honda service manuels...(please come in..)
  67. slow off the line
  68. Complete Build up with turbo question.
  69. Awakening from hibernation
  70. How do you remove trunk??
  71. blown intake manifold
  72. Cold Air Intake DIY
  73. Air Horn DIY?
  74. high idle problems?
  75. Fuel Filter?
  76. How much does a valve clearance adjustment cost?
  77. Jerking/Sputtering
  78. Bosch Oil Filter Life?
  79. Shift boot squeaks.........anyone else?
  80. Hate HOODPINS?? Look in here!!!!!!!!!!!!!!!!!!!!!
  81. New Exhaust
  82. Swapped Immobolizer
  83. head swap question
  84. Buying the Revo SS
  85. Interrior paint
  86. Exhaust Installation Question
  87. Shock Trunk
  88. OEM fog light install?
  89. saturn turn signal conversion?
  90. taking my car to the shop
  91. Port & Polish... worth it?
  92. removing washer fluid reservoir?
  93. Installing Venom400
  94. relocate oil filer
  95. Torque specs for manual tranny fluid change?
  96. why does this happen?
  97. Repair Manual "PDF" version
  98. Functional Tunnel ram
  99. Turn signal bulbs
  100. high beams
  101. AEM short ram intake
  102. Could you wire your high and low beams together?
  103. Something to make the Civic run better= Sea Foam
  104. t3/t4 turbo
  105. can't see my gauge needles
  106. hey i forgot what part num for bulb!!!
  107. Lsd
  108. Rwd
  109. Factory Headlights
  110. Cheap Mods for Hp Gains
  111. Who has an aftermarket steering wheel?
  112. seatbelt buzzer
  113. Bumper Damage
  114. How many watts
  115. Removing the rear bumper!
  116. Installing Mugen COld Air Intake Help!
  117. Eibach Sport lines HELP
  118. cel light - megan test pipe - my 03 ex
  119. More range for radar detector
  120. LX exhaust on an EX...questions
  121. Question about 7thgen's Ignition System?
  122. VAFC Controller insructions
  123. Calling Diy Gods )( Buttons!
  124. Trunk wrap DIY?
  125. Drum to disc brake conversion?
  126. Sanding plastic?
  127. Best type of non-synthetic oil for a So Cali 2k2 owner?
  128. Painting the bumper grille inserts
  129. Shifter
  130. Denzo Uridiums (spark plugs)
  131. '91 CRX trans in a '96 Civic?
  132. when getting cams installed...
  133. Hp Full Race Header
  134. what is this sensor?
  135. what is this censor?
  136. Help! Where Is This!
  137. Question... =-)
  138. doble spring on valve!
  139. Hey I got a ?
  140. Would anyone be interested in Eagle Rods
  141. question
  142. Is it possible/worth it? (gauge cluster question)
  143. RSX Cluster
  144. 01 aftermarket grill
  145. Stock exhaust hangs to low....
  146. Speed Governor
  147. 2002 and 2003 gear ratios
  148. i need some help
  149. How to change the lights on buzz sound
  150. MSD ignition
  151. side mirrors
  152. Reseting the SRS Light in an 01 Honda Accord??
  153. new tires
  154. M3 power mirror wiring help!
  155. E-Manage FAQ!!!!!!!!!
  156. DIY Custom Turbo
  157. Tightening Cable Problems
  158. Wheel Wall Lights
  159. S2000 Guage
  160. '02 Civic Automatic Transmission Fluid Change
  161. Automatic Trans Fluid Change
  162. Hondata ECU-Show Support
  163. Unichip Piggy Back ECU
  164. 2005 LX with rocking front drivers seat
  165. Silicon on headlamp/XENON corners?
  166. srs light aghhhh!
  167. Enzo doors
  168. Transmission Slip
  169. Gauge Cluster
  170. P0401 EGR Flow Insufficient Detected
  171. Question about engine blocks
  172. airbox
  173. brake light rattles
  174. brake light rattles
  175. small dome light
  176. Interior Dome Light - '02 Civic LX
  177. newbie question (air silencer)
  178. where's my distributor?
  179. Gauge cluster problems
  180. DIY Aluminum floormat
  181. Throttle Positioning Sensor problem.
  182. Coupe exhaust on a sedan? YES
  183. Cam shaft swap?
  184. Looking For Wheel Well Lights?!?
  185. Transmission Fluid Cooler Help!
  186. o2 sensor size?
  187. replacing dome light..
  188. Exhaust pipe diameter
  189. 2002/2003 fit on 2004 ? or swap
  190. 04 ex where's O2 sensor located? pls help me out
  191. Slight idle wierdness.
  192. question on 04-05 fog lights
  193. I.D. of fuel feed line?
  194. Installing an aftermarket CD/DVD Deck
  195. installing new gauges
  196. Does anyone know how to remove the side door panel
  197. does anyone know how to remove the side door panel
  198. 04 Vp clusters
  199. can you bondle urethane side skirts to the body of your car
  200. Compression Ratio
  201. breaking honda bond???
  202. Does DX catback fit EX?
  203. What Nexted??
  204. Is there a problem with my car??
  205. exhaust questions
  206. power window problem
  207. factory plugs
  208. dose anyone know???
  209. 03 Cluster Conversion (Q's) If you own a 03+ EX Please look!)
  210. JDM: Stock Turbo Honda
  211. Are my spark plugs okay looking like this??
  212. Injen SRI vs FIPK II
  213. ABS light
  214. Rearview Mirror Rattle?
  215. AMSOil Drain interval and product
  216. seatbelt reminder light
  217. What's the difference btwn misfire, knock, detonation, pre-ignition?
  218. Question About Installing Oil Pan???
  219. Oil Change?
  220. aftermarket seats with srs system?
  221. vafc for 2001 civic lx
  222. SOHC VTEC Explained
  223. Does anyone have a wiring diagram of gauge clusters for the 01 dx -> 03 ex?
  224. Stolen
  225. 2001 lx sway bar conversion
  226. Install Alarm Scanner
  227. Ported/Polished/Decked head is on. Now whats up?
  228. Transmission fluid
  229. Tunning Safc
  230. led install
  231. Window modules
  232. So i reset the ECU....
  233. Heating system
  234. wiring a tv
  235. Sorry, I know this has been asked over and over again, but are the sockets for the 03
  236. spark plugs make a difference?
  237. Head Gasket issue?
  238. does anyone know???
  239. taillight smoking paint
  240. valve seal change
  241. Recommended oil change is every 3000... Why did Honda say 5000?
  242. odd question
  243. Window issues
  244. tape or glue?
  245. new key problems
  246. problem with taking off door handle pc
  247. Wiring Diagram
  248. New Member Help.
  249. Door lock problem
  250. air con on civic type R???
