- another hood question
- Want an SI Repair Manual?
- door poppers on lambo doors
- Is downshifting bad?
- How do i get [paint off plastic light ?
- hmmm NA?
- Fuel amount when EMPTY light comes on...
- Port n Polish Exhuast Manifold
- Headers on an lx?
- Jet Performance V-Force?
- SOHC Non-Vtec Engine Work worth it?
- wiring BMW 3 series side markers
- no clue
- SPC Front bolt question
- AEM replica short ram
- Changing the color of the lights
- wires under the front seats
- weird noise - a/c related
- Cruise control 01 dx
- Where to buy momo HUB for 2002 Civic DX? Also with questions.
- DX instrument panel
- For those of you with Alarms
- clutch problems
- burning smell
- DC headers, how good are they?
- Cleaning cone intakes.
- DIY needed for Angle eye hookup.
- ?'s about custom intake manifold install
- 04 fit an 03
- The Roar Of the 7th Gen???/
- plastic intake mani
- head bolt tourque specifications
- Dont have a gas cap hanger? Alternate solution
- V-AFC II vs V-AFC
- Hyper Blinker Help?
- How to disable the SRS system / light
- Auto Shifting?
- Will d16 headers fit a d17?
- D17 performance intake mani
- ecu...professional help please
- whats our ECU code
- SRS lights
- Are CAI's really worth getting?
- lagging on oil change improve gas mileage
- Trunk popper relay wiring
- Hi-milage cars. Who's got 100k miles +
- How do I remove this piece (pic)
- Explosives straped to the Seat.
- Site to Print out Recall for rocking chair
- DX Shifting
- Sloppy, Sluggish Shifting
- fuel milage
- Alarm system with extra channels?
- CREAK SOUND PROBLEM FROM LOWERING 03 Civic
- front bumper removal
- Ecu Help
- VAFC II what are your gains youve gotten?
- DIY Valve Adjustment *EASY* Stop the Clicking
- Has anyone tried OBIT ECU?
- Computer Issue
- what relay for kill switch?
- removing trim on trunk?
- short shifter
- 1st gear possible?
- sound
- Halo Headlight Projector alignment
- Timing Belt Question?
- Take this CHECK THIS OUT BMPer
- Center Conole Lights
- check engine light
- Are 01 seats compatible with an 02
- need help with cigarrette lighter removal
- SRS reset ?
- Grounding Kit wiring
- coming back to stock & other Qs
- top dead center, how do i find it? tdc?
- ECU Jumper
- Headlights
- Replacing clutch after 30,000 miles.....nice!
- Got my new exhaust
- gauges
- Chrome Trim Painting
- Throttle Body Heater ByPass
- Im Deperate
- EXHAUST that sounds OEM
- Need help from someone with a HELMS*URGENT*
- How to install a/f gauge the right way?
- How Exaclty Does One Delete The Sunroof?
- Esuperchargers, wow what is this about any ideas?
- Help with HALO's
- Spoiler Question
- Strut and spring removal
- Mind Of A Car Theft
- Noob kind of question.......
- how do you install HID's?
- RS VS SI ... and intake question???? ASAP
- got a squeaky clutch? I fixed mine today **pic added**
- Oil Leak
- Better Aerodynamics!
- aftermarket resonators
- Fog Lights help
- Got my ingalls camber kit....
- HX --> EX tranny swap details
- RSX seats
- Diy: Remove Stock Front/rear Bumpers
- gutted OEM cat (ex)
- your exhaust: bolted or welded?
- Gas pedal poping noise after installing Sportlines
- supercharged AUTO????
- Undo Battery Or Not
- Would driving w/out PS belt cause any damage?
- Newby wants advice!
- Xenon low beam only problem
- o2 sim. install HELP
- How do you burn rubber w/ a auto trans
- intake silencer
- malfunction indicator light
- Tools needed for header install ? ? ? HELP
- Should a car with 13k miles need an alignment?
- DIY black
- DIY: Tightening E-Brake
- Timing Belt? What if it Breaks??
- short shifter
- honda warranty
- 04 carbon fiber lip and jdm sides
- need help!!! car not starting
- b&m shifter install issues?
- shift light
- Air Intake / RPM questions!
- screwed with auto??
- just bein stupid.....
- Wht do some post like in here get locked??
- Rims size (bolt pattern)?
- 04 coupe grill on an 02 coupe?
- Rev Limiter....
- Don't be Angry With Me
- need honda p73 ecu pinout
- check engine light?
- less weight and simple clean JDM look...???
- have a question help!
- 5th gear keep slipping help
- Short throw
- help installing oil gauge... and boost gauge
- Fiberglass??
- SRS light with aftermarket seats ????
- I-Vtec for dummies
- Altezza Grill
- Tein S-Tech Spring Questions
- Intake Silencer
- VAFC II Tunned people
- Initial impressions after removing power steering not bad at all
- Removing belts to reduce drag..
- How much oil?
- Headers for 2003 Civic LX ????
- exhaust shake..
- Well, I removed my PS belt too and...
- Engine miss
- need help
- The best way to remove paint (touch-up paint)???
- Clearing Headlamps?
- Steering Wheel Lock
- Just installed reverse indiglo gauges. need help
- bigger injectors.
- HELP ANYONE!!!!!!!!!>>>>>>>
- Wow, EX final drive = 4.411, LX=4.111 - big difference!
- headlight plasma questions
- clearing headlight diy Q
- Help! Ex mirrors on Lx
- how hard to rethread oil pan?
- full tank
- Turbo Timer?
- Malfunction Light/ engine cutoff
- Alternators ?
- Backlit gauge ??
- Side marker pics????
- Quick defrost light question
- painting rims
- CarChip OBDII data logger?
- LEDS burnt out in brake light.... what to do??
- Dual Exhaust Question?
- Lx Whp---ex Whp
- Does anyone know how to prep bodykit??
- Engine Sttutering.........
- Engine trouble.......
- a word of caution removing power sterring belt.
- factory head unit removal 02 civic lx
- Gear Ratio
- Neuspeed Strut Bar
- Our cars run rich from the factory right?
- WTF?! Energy suspension REAR motor mount WON'T FIT - Blame Honda!
- miss shift
- Got a Newb Question
- Changing oil...
- Tap Splices for side marker!!
- stock 1/4
- Steering Wheel Noise
- How to take off rear lip???
- Did i mess up my Ground Wire DIY
- 01 hx header swap
- Wireing Diagram!!!!!
- Another Crazy thought popped into my head. Looking for feedback.
- GSR Blades and Wheel Spacers...
- primary o2 sensor fell off?
- Micro Polishing??
- Sounds like water stored in my engine bay
- RSX center console into Civic 2dr?
- Fiberglass boxes??
- VAFC-II Whats your Tunning??
- Spoon Thermoswitch
- Oil weight question!!!!
- Transmission Coolers?????
- Help with REVO SS install
- Braided Line Fittings?????????
- Earls Plumbing
- Exhaust bushings
- DIY.. Reducing Weight in Door Panels
- Redline MTL (MTF) and spark plugs?
- Shift Points
- i hit 10k miles
- Throttle Cable Installation who has done it?
- What is the output of a Civic stock alternator?
- Replacing timing belt... help!!!
- DIY needed for Radiator flush and fill
- Matinence Req Light
- Car not starting if not in 'Park' completley
- how to do oil change?
- Intake poping!
- HP With new mods???
- Advanced Timing
- Clutch Install Tricks
- Altitude
- One question about coolant flushing?
- HEY GUYS! Newbie Questions??? Sorry
- To cut or not to cut
- HP wise, whats the best I/H/E combo?
- Dyno Results for ALL products?
- oil cap and radiator cap fitment
- spark plugs
- Muffler rusting
- rear lip problem
- M3 type mirrors How to Wire?
- what kind of welder needed for exhaust and headers?
- Cluster question
- P1259 VTEC System Malfunction
- Can torque converter be removed/installed w/o dropping tranny?
- NEED HELP on removing rear dash board
- coupe headlights in sedan.
- Help qUICK
