View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Painting Nitrous bottle
  2. my problem about jacking my car~~
  3. VAFC II install
  4. Transmission fluid level -- help!!!!!
  5. Int. gear Lighting
  6. battery dies....need help solve this problem
  7. Help!!!!
  8. front bumper clips
  9. Clutch make squeaky noise
  10. DC2-R seats
  11. VAFC II install and tuning prices
  12. ebay "speed" chip "OH MY 20+ HP" rofl
  13. Question about the RS*R ExMag GT-II series catback
  14. Just installed Air Intake and now a problem
  15. Painting Springs
  16. The best way to turn off battery?
  17. 2000 accord v6 chip?
  18. wiring for tyc angeleye/halo
  19. cutting/rolling fenders
  20. Is this worth it?
  21. Grrr Metal
  22. Clutch Help PLz
  23. Spark plug wires
  24. Air Intake question (more than standard question)
  25. short shifter
  26. Power mirror wiring question?
  27. iPod car charger
  28. whited out my headlights last night
  29. 03 bodykit on a 04 civix lx coupe
  30. Need some quick help installing my hayames...stripped bolt...
  31. very good find
  32. just a simple question i cant find
  33. AEM CAI info
  34. Coupe / Sedan Exhausts
  35. Question about my new cold air intake
  36. Drive Right CarChipE/X
  37. Auto Power Window Switch...
  38. How much can we deck our heads?
  39. Removing sideskirts that are glued down with epoxy
  40. anybody ever install Sonar Halo Headlights?
  41. need TSB printouts!
  42. K&N Air Filter
  43. Hardwire radar detector DIY
  44. Fyi!
  45. any specific order??
  46. I know this may sound kind of stupid but...
  47. bad throttle cables
  48. lx/ex intake ?
  49. tuning the engine
  50. Heat shield
  51. Noob Word List
  52. New Distributor - Now Long Cranks and Engine Light
  53. safty first
  54. Rad Hose size
  55. remove dashboard?
  56. D17 Intake Manifold Conversion
  57. i need help
  58. installing struts
  59. need a favor
  60. why NOT to use dino 5w20 oil!!!
  61. How to replace rear speakers
  62. best shift for peak hp
  63. MAP Sensor and VAFC2
  64. 2005 HX has VTEC??
  65. VACUME LINE?? where is it help!
  66. Powersteering Fluid
  67. intake air temp
  68. How much does the stock battery weigh?
  69. megan racing high flow cat
  70. stock clutch question
  71. ---Need Help With Cigarette Lighter---
  72. CD Player Destruction!
  73. Car Parts
  74. What gauges look OEM? (RPM gauge needed!)
  75. Someone explain why we need coolant circulating the throttlebody.
  76. Is a HUB required for aftermarket steering wheels?
  77. another engine oil thread
  78. O2 sensor problems
  79. Help with exhaust
  80. air bag 'H' emblem removal
  81. Unorthodox Racing Underdrive Crank Pulley
  82. Maps/Sensors/VafcII/Wiring/VTM
  83. Front and rear crank seal leak
  84. vtec to i-vtec conversion<--fantasy?
  85. Intake Opinion
  86. Power windows instalation
  87. Honda protects me from my own CD Player
  88. VTEC Lobes
  89. High beam wires?
  90. Question regarding doors.
  91. question about turbo
  92. frosty
  93. using safcII + injectors in general?
  94. caliper painting quick question
  95. throttle cable
  96. Replacement light bulb
  97. Spoon Front lower bar
  98. a n00b question on spark plugs
  99. Oil lube and filter...? What's Lubed?
  100. K&N FIPK II Fitment?
  101. Headlight help =\
  102. Headlight problem
  103. Smog Q&A
  104. Honda vin #'s
  105. Will this 01-02 Civic RS Front Grill Fit an '03 LX?
  106. Weird rattle only on right turns??
  107. k20a2 head fit d17?
  108. Door Handle Painting
  109. DIY Headlight Black Out
  110. stereo and removing
  111. Check Engine light for brake fluid?
  112. Fast turn signal
  113. Roof Liner?
  114. Exhaust Scrapin
  115. Check Engine Light HELP!!!!!
  116. water in engine f**k
  117. I need instructions for removing the stick
  118. Maintenance Light
  119. k24 in EX?
  120. Noise from axle?
  121. New intake setup
  122. A/C paneling
  123. Skunk2 Coilover Creaking and Poping when turning wheel
  124. ebay "speed chip"
  125. O2 Sensor extended
  126. making 02 EX into AWD
  127. tach install prob....
  128. B16A [jdm] vs. B16A2
  129. weird sound
  130. CEL Question
  131. Just a question about a clutch.
  132. rattling
  133. Headlight aiming
  134. Noises on a brand new civic
  135. '04 guages change?
  136. 93' DX w/ oil on plugs
  137. rca's on 01 ex
  138. vtec head swapped into an LX been done before???
  139. [HELP!!]Drive Light Blinking
  140. pulling the headlight..possible w/o taking off the bumper??
  141. Should I bore out the diameter of my header's gasket??
  142. o2 sensor problem (HEADER)
  143. 2500 Mile Trip Towing My Motorcycle.
  144. S&B cone filter measurements
  145. An interesting swap question.
  146. Final Drive
  147. oem body kit installation
  148. properties of aluminum tape?
  149. maint req at 53,000
  150. i hope people respond to this one
  151. Whistling sound...
  152. Installing new clutch and flywheel!
  153. cig wire splicing (important)
  154. short ram intake
  155. Can anyone help, I stripped my nuts!
  156. A/T excusion removal help
  157. Question about Torque Wrench
  158. about ex heads swap to an lx
  159. I need some help...
  160. auto to manual conversion...BOOYA, its DONE.
  161. Throttle Body Bore??
  162. Crank Pulleys
  163. Check engine light when turning...anyone?
  164. Idle Noise When Turning Wheel
  165. lambo doors pistons
  166. fuel pump install help?
  167. Vtec on my EX seems dosn't work???
  168. Fog Lights DIY????
  169. Does our ECU reset the Apexi SAFC2?
  170. Kamikaze header questions and answers
  171. SRS Module
  172. Fast Blinkers
  173. 01-04 civic interiors panel for sale on ebay
  174. Help!!!!
  175. reducing backpressure
  176. my left rear window wont roll down
  177. Pinout For 14 Pin Connector On Stock HU
  178. Dumb Question<----Here
  179. stupid question!!!!!!!!!!!!!!
  180. ATF vs MTF
  181. I need your opinion???
  182. Anyone got a detailed diy for this?
  183. large magnet 04 civic
  184. Doughnut won't fit on Kami. header. Please help...
  185. gauge cluster dimensions
  186. Adjusting Headlights need help
  187. Any advice for exhaust?
  188. Throttle Body Question
  189. Airbag question
  190. Clutch Suggestions Needed!!!!
  191. Question about Transmission Cooler install
  192. blacking out the headlight housing
  193. Remote UNlocking, hatch separately???
  194. Why would an Engine Misfire when accelerating on a winding onramp.
  195. Which is a better exhaust?
  196. Anyone needs to know how to take off anything from interior? Ask me!!
  197. AEM CAI to short ram?
  198. Tranny Problem
  199. Auto oil change
  200. Tail light Assy
  201. Need a CAI, for an 02 Ex AT, Any Adive
  202. Tokiko shocks release date for 03-04 models.
  203. I need help with my shift knob and my head lights
  204. Diy : Sonar Tails Painted!!
  205. Engine Noise... manifold???
  206. Starting to like 04 headlights!!!
  207. RSX-S Shift Boot
  208. individual throttle bodies
  209. Change autometer gauage color
  210. Just wondering...............
  211. leather boot for auto tranny
  212. 800 dollars to spend, But on What?
  213. power steering fluid foaming out
  214. Removing AC?
  215. Installing Sparco seats
  216. No wheel well gaurds into engine bay???
  217. VTEC / ECU wire gauge?
  218. VAFC II works well
  219. Parts # for shift boot
  220. Factory Security System Question.
  221. fuel return help!!!
  222. How vtec works....
  223. Odometer Help
  224. question
  225. anyone know how to intall a starter motor?
  226. diagnose
  227. keyless entry
  228. The lower... the more noisier.
  229. What hapenned if I take out the Catalyst?
  230. radiator drain plug
  231. 95 prelude hot/cool switch problems
  232. Clutch Question
  233. Couple questions about installing M3 mirrors.
  234. LX to EX exhaust conversion
  235. DIY: Reset SRS light - '02 Civic???
  236. Wiring help, very technical
  237. diy cleared headlight question
  238. what to do first??
  239. body kits, drops, etc...
  240. Need help fixing a pulley/belt related prob
  241. OBD-II <-> PC Interface! ***FINISHED!***
  242. Got my S&B filter..guess what the tech told me when i called?
  243. apexi-safc?!?
  244. Fiberglass reinforced bondo.
  245. Hood question?
  246. Help w/ emanage
  247. black out headlights 04 coupe
  248. Help with dome lights...
  249. Intake Manifolds
  250. Subframe HELP
