- D16 head on D17
- I'm sure most of you have also done this..
- how to lower clutch engagement?
- rear sway bars for RSX will fit the ex models right?
- stock intake
- dimension question with 03 civic
- Weird Question about shift linkage
- wiring gauges
- Trying to install power door locks.
- How hard is it....
- D17 Gearbox fits older models
- Removing Passenger Front Seat ('04 2dr Ex)
- *PICS* tub of paint vs my civic
- *PICS* Look what i found after class
- stock fuel pump flow
- Question About Exhaust In 01+ Civics
- custom fender flares
- shaved door handles
- brake help
- Alternator Check
- Benefits of bored Throttle Body?
- AHhh..Help..RusT!
- cd player help
- Clear Headlights?
- Need a new D17 engine? You can for $53!
- Tranny Fluid...
- superchips or similar
- simple intake Qs
- A/C Whistling
- ps2 placement
- v-afc hack
- need info on intake
- Radiator Cap
- RaDio Code.....
- JET v-force
- which exhaust to choose.
- Making our stock intake cold air?
- Honda Manual
- proper throttle cable adjustment?
- how many belts?
- Headers...it's a standoff.
- making a dx vtec
- Check Engin
- Intake Filter Question...
- Changing Clutch Fluid
- Removing rear bumper (sedan)
- Who has an intake and has any problems?
- Trunk Carpet mold removal
- Door on Dash Removal????????
- Exhaust question
- Carbon Fiber Hood Problems . . . Need HELP!!
- Water on the driver side floor
- need more power!
- Anyone ever change the oil in manual trans?
- AEM vs Stock compromise
- E-Manage.........Gettin a better understanding
- a/c light not working
- Real Time OBDII Logger
- Different batterys.
- 04 ex, 7400 miles, are my shocks bust?
- How can I lower the hood latch so I can shut my C/F Hood?
- question about my window..
- trying to make an AT to paddle shift
- DIY Paintin' HeAdLights
- idea for headlights
- A quick question...
- Any way to stop the seatbelt chime in an 04 EX
- For those of you with a Xenon kit
- Crank and Harmonic Damper INFO, very important! | Truehonda
- Alarm DIY??
- '03 Civic EX turns into Christine
- plug & socket jelly/oil/goo; electrical
- I need help on how to get the front lip off factory hood to install on c/f hood...
- wet sanding question
- auto tranny cooler lines? help
- CAI... and high water.. need some help
- HP Headers Rattling
- DIY: Glowing gauge cluster
- Hyper blinker trouble
- stalling
- Exhaust Problem when it rains!!!!
- whats the performance increase when adding a cold air intake?
- OBX 9006 Hyper white/blues.. will these fit?
- Anyone know the screw size for the OEM kit?
- Speed meter swap
- Turning vtec back on with vafc
- Update for EMANAGE: WORKING SETUP FOR EXs!!!
- Streetglow Idea
- steering wheel
- Woah! Has anyone thought about this idea on our cars??
- vafc installing problem... need some help
- HELP!! Problem with revo ss (b4 installing)
- DIY: How to wrap your side control panel in Carbon Fiber Vinyl.
- Remove Lighter
- cutting fenders
- safc hack??
- clutch squeaks
- help out a DX civic owner
- clutch
- reset maint light?
- turbo problems
- TB ported! PICS/REVIEW (www.maxbore.com)
- Bad Evo...
- mounting a tach
- Integra Swap Question - 1991
- im depressed and upset...
- Octane v. Power
- CEL and air/fuel?
- New Intake Manifold Design
- Help! Somebody
- Question about head studs
- check engine light that stays on
- Solution to hot header?
- horn stopped working.
- cig lighter wires
- torque specs
- DIY needed for speakers to amp wireing?
- stock air box
- Need Help.. My fault? or their fault?
- Oh crap, how do I take this apart?
- Just installed TYC headlights...now my left blinker is out. Need help..please read
- k20 help
- well my ecu is fUXORED. (FRIED)
- does your RSM work?
- Ex header on Dx engine
- Direct Power System???
- Revo SS & Stock shifter assembly
- SRI rubbing throttle cable?
- Question about Clearing Headlights.
- the oil filter
- Started car on first gear and e-brake up.
- Shaving Emblems...
- how much weight can our car support?
- manual shifter piece
- Problem with indiglo needles.
- Oil Changes
- How big of a deal is losing PS???
- Techies Delight!
- Disable VALET Mode
- spare tire ring broke
- dounut gasket
- sri to cai
- Are pedals removable?
- AEM Tru-Power Pullies Installation
- Make A Fuel Magnet
- Carb question
- neon wiring (no more cig adapter)
- alarm receiver question...
- messed up front end
- Upgraded grounding wires fixed my radar detector!
- help
- how to do timing
- HELP!! my fuse keeps blowing
- lx/dx headers?
- help with gauge lighting
- Tips for welding
- ukdm fold in mirrors
- my GROUNDING KIT SUCKS!
- MTranny neutral wire?
- short shifter?
- VIS carbon fiber hood
- A/T plastic shift panel thingy on center console
- angel eyes color change
- some ECU wiring quetsions...
- o4 civic header and exhaust
- Water Temp install
- hasport
- Engine Light Stays on
- HELP!!!!! light behind fuel gauge has gone out, how do i fix
- are Ebay pedals any good?
- relayed/door triggered neon setup problem.
- Fuel Pump Fuse
- ABS Light On?
- SRS Computer Installation ?
- Who makes Honda's Electrical Parts..! !Need help ASAP
- Can I do a DIY or do i have to have permission
- 50 points for finding DIY for Apexi VAFC 2
- opening up altezzas?
- High Pitched Sounds After AEM CAI Install
- DIY - VTEC LED - Issues?
- HELP!!!.....Apexi VAFC 2 problems
- Maintenance Required Light?
- where's the DIY rear bumper removal?
- egr valve?
- How to remove throttle cable?
- clutch bleeding
- Help passing the new PA emissions inspection
- Transmission from previous civics?
- LX Ignitor coils
- switch power?
- sanding down paint on intake
- can anyone tell me where the pops are that hold in the headliner?
- Has anyone tried to make an SRI into a cold air setup?
- Generation years??
- OMFG !!! Dont ask how, dont ask why! Just try it on your intake!!!
- Moving Console knobs and buttons...
- I-pod...
- Air bag info..
- need help boosting problems
- 03 Civic Bumper Removal
- Switchin out the parking brake handle. (update with pics)
- DIY: Make speakers sound better!
- Performance exhaust problem
- alternator whine?
- How much water is needed to cause hydrolock?
- oil filter removal made easy
- Check engine light on
- Break in period
- Angelina - Lovely Girl from Eastern Europe
- AUTO tranny slipping cause of vafc
- Need help with tie rod bolt!
- Suicide Doors
- paint lip kit costs
- AEM CAI instructions?
- new ECU..do i need to reflash KEY?
- Help! in my civic all the lights are off
- AEM AIR bypass cracked
- e-manage question
- Motorized rear seats?
- new 04 civic 4dr ex auto, need power mods
- Foglights?
- H.I.D. mounts for Telly
- Need help on Booty Call thingy
- Learn about intake systems
- I think my axle is breakin@@@@@
- 1 to 1 ratio for dyno pull
- Throttlebody Bypass Mod- Gains?
- painting methods unleashed
- little info
- Grease on upper strut mount
- altezza in oven temp.
- Thinking about custom intake
- Stock Radio and FM modulator
- which is which
- Any way to reset the Main't Req`d light?
- Trouble releaseing key
- ANyone ever stick your intake in the freezer for a few hours??
- Thoughts on the coolant bypass mod after 3 days.
- Best possible performance parts for ze Civic 04+
- $$$ for E-Manage maps!
- DIY: Garage door opener - move it to cig lighter!
- Performance exhaust tuning tip.
- Autometer Pro Shift lite install? Coil?
- changing air filters
- Whatever happened to Exospeed Racing?
- Remove Resonator ?
- Clearing Headlights: Check List
- help me tune vafcII
- DX LX vs. EX
- Odometer abnormality
