- Booty Call With Alarm Help
- my car died..
- non7thgen--> acura lenged/NSX airbox?
- VTEC Activating time??
- RSX shift boot: Will it fit??
- what WHP? what 1/4 mile time?
- 2002 civic LX mods
- valve cover bolts
- Cost to install kit, already painted?
- Anyone have the DIY for clearing headlights?
- How do I reset the ecu?
- My airfilter box wont come off?
- DIY: Passenger Door Lock Switch
- How to hook up wire to constant 12v line
- Clearing Tail Light????
- New sound I hear after intake?
- Any good products to insulate metal intakes?
- Underneath carpet?
- Gauges in AC knobs?
- K&N FIPKII question
- Is TCI a good company?
- Tranny re-build
- Need Help on RS Style Grill DIY
- '04 coupe front "H"
- Parts List
- Integra dead (attn: mechanics)
- Help installing volt gauge
- allen wrench problem
- Adding velocity to intake ?
- any one with a full gauge pod pillar in their car?
- Rattling from rear wheel
- Racing Timing Belt
- gauge test mode?
- Will a B16B fit in my 03 LX
- 04 Civic Intake Question
- Push button starter
- 10k mile oil change
- HP gains from AEM V2 on '02 LX
- Low Fuel Light. Not working
- Problems with belt noise
- Side Airbag Sensors Question, please help ASAP
- AC Condenser for a 2004 Honda Civic LX
- Which spot in engine bay has cooler air?
- better gas mph on highway
- Need help with HKS exhaust.
- o2 sensor
- Aem Sri
- VAFC Problem
- For those with service manuals
- Engine Wear?
- Major Cat-back problem
- Major Ecu Problem
- Emblem Help
- clean AEM filter?
- autometer volt gauge...
- Heavy engine mods - what size injectors to use?
- gauge cluster ?
- Where is the odometer reading saved?
- Increasing intake sound?
- will this fit my lx auto?
- Cruising in second gear?
- Removing airbag sticker on front of visor...
- Turbo kits
- Cone filter cleaning/oiling
- Auto Tranny Fluid
- too many miles
- Power Steering fluid
- Engine cuts out between 3900 & 4000 RPM
- AMSOIL FILTER - Question!
- wrong tint????
- Auto to Manual Conversion
- ECL goes off after changing Spark Plugs
- tail lights
- will AEM make a fuel rail ??
- Cruise control install
- oem side skirt problems
- Full A Pillar Gauge Pod....
- srs light is on
- How Can you change the Gear Ratios........
- My stupid alarm. Please help me quick.
- i got my denso today !
- help with rough idle!
- NEED HELP ASAp!!! Cam gear bolt!
- emblem shaving tragedy
- '00 oil filter size in '01 civic
- Ecu
- Cat. Converter Gone??
- Mini-me swap...
- problems with my 98 ranger
- Will bondo stick to plastic?
- blow off valve making a rattle sound in between shifts
- What is this bar?
- 100K What needs to be done?
- EX -> DX header?
- heat sheilds...
- EP3 seats into an EM2?
- performance axles?
- What should new tranny fluid feel like?
- Intake Air Filter?
- k&n fipk
- Repair Manual Civic 04 LX
- quick Q and A about paintjobs
- copression test numbers
- i need some help
- air filter
- ex exhaust into dx model
- o2 sensor (pics inside!)
- CAI or ram
- RSX Console Into Civic
- What's the difference?
- Radiator/ ATF flush
- Apexi RSM question (help please)
- Need Rallye Red paint
- Question about Torque Wrench?
- help...m3 mirror install wiring question
- strange intake sound help
- Relocate moonroof / sunroof switch?
- S-AFC II or V-AFC II for 03 Civic?
- Ordering 04 Tails from Majestic
- help with cai
- SRS light is on... and won't turn off after audio system installed...
- Rsx Instrument Cluster In 02 Civic
- Question about eletrical issue
- Catback Exhaust Install Help
- tach testing green wire...
- How to run wires inside the AC vents?
- How do i fix this suspention problem!?
- Can't believe this about K&N
- Lx with v-tec
- Help-- Clanking noise from gears... I think
- k24b??
- Frankenstein K20/K24 story in SCC mag
- Will RSX type s leather seats fit in ours?
- Adjusting sensitivity on alarm???
- Catalitic Convertor is Toast. What are my options?
- removing bottom rear seats ??
- coupe OEM headlights in a sedan
- Seat question
- AEM v2 intake FILTER!!
- 03 Center Console Removal - Need Some Clearification
- Front Door Courtesy Lights
- How can i quiet my exhuast down for a short period of time?
- Drilled a hole through my gas tank.
- repainting costs for shaved trunk
- vtec apex afc settings
- D17Y8 Hybrid Motor
- bodykit's tape is loosening.
- Is there a recall for the door locks? Anyone know the steps to remove door actuator?
- NGK Iridium Part number?ASAP
- 3rd brake light
- halo ring problem...
- Vtec
- throttle cable
- tapping RPM signal wire in gauge cluster...
- Need help with strut bars
- HELP! Need to pop front bumper
- Thanks Opto isolator !
- Revo SS Install Info.
- 15K or 50K
- how to remove the automatic shift knob?
- Final Reduction Gear Ratio change
- Any Perform Diff btw Universal & Model Specific Muffler?
- stock cam gear noises?
- Help on what to get
- Hardwiring Radar Detector... And best place to position it.
- Is there a replacement knob for auto shifters?
- my check engine light does not come on. anyone know how to fix it? is the light out?
- What the different?
- GSR Seats
- engine error with de cat hi flow
- Paint job
- autoshift knob doesn't move
- Hyper Voltage System v.s. Ground Kits
- angel eye headlights
- Rattling/Popping noise under the car
- Lowering Automatic Shift Rod?
- Whats the speed sensor's pulse number?
- lower console (w/ cigarette lighter) removal for ipod install... help?
- anybody car without their cat
- V-AFC II vs. VENOM 400 HELP!!!
- Advice needed on Exhaust Mod for EX Auto
- Rattling noise in tire
- quick ? about relocating my battery
- Question about Automatic Transmission Fluid Change?
- Another SRS Light RESET ?
- Cooler Air?
- How to change power steering fluid?
- Key duplication?
- relocating cruise control question
- Updated FINISHED Attempting return fuel conversion soon(pics inside)
- DIY: Rear Brake(Shoe) adjustment(tightening)
- DIY: Manual Transmission Flush/Replacement
- complete a/c system???
- side molding
- Aem Cai Trouble!!!!
- A few questions about changing coolant?
- Penzoil Fuel Injection Cleaner = 100km more
- ATF change more often...
- Anyone have experience information reguardiing body paint?
- Air intake Tempature?
- What messes up a car?
- uncapping exhaust
- need someone to help me out with this
- Attention Emanage users - new firmware available! V1.39
- FIre wall question
- help me :(
- Timing belt
- If you have problems with your door lock, ask me.
- Noob Question
- O2 sensor on the ECU
- RSX Base Gauges in civic?
- door lock passenger side
- need help fast
- 04 sedan fit 04 coupe headlights?
- Casper 02 SIM question!!!
- how to replace the A/C filter?
- 1995 civic service manual website. Close to our car in some areas.
- header nut size
- keyless entry problem???
- Evaporative Canister Location?
- Hey guys....I need the diminsions of a stock wing to install KTR II wing!
- need help with alarm
- v2 on automatic?
- Ok another dumb exhaust question.
- 6 speed trans for d17
- hybrid auto temp in a non electric
- Help with Header Back Exhaust
- just trying
- sparco 4 point seat install
- Civic 01' vs 04' rear suspension bounciness!
- relocation:::
- Rear drum adjuster too tight!!!
- Overfilled engine oil affect mpg??
- Primary 02 sensor wire on the ECU?
- exhaust manifold gasket
- need some ideas and knowledge
- Timing Belt Change Problems
- 01+ ex tranny question
- fipk question
- What part is this?
- JET's Computer Upgrade
- H E L P--Engine Maintenance Required Light
- a-pillar removal
- no center console=better shifting?
- Quad Bucket Seats.......
- Clutch and FlyWheel!!! need your help
- mobil 1 motor oil
- not going past 4000 rpm
- i need a lil advice about installing mugen racing seats
- installed gauges and now srs light is on
