- Vtec or not Vtec? that is the question
- What would be the best way to paint these wheel areas?
- Original ride height for Si(Ex) models.
- Build up automatic tranny or manual swap?
- How to disable VTEC kick-in ALLTIME to save gas
- Sedan/Coupe Headlight Assm. Difference?
- taking off headlights w/o removing bumper?
- 4 to 5 lug convertion.
- What is the proper way to relearn RCM/PCM idle
- i feel dumb...
- Exhaust?
- HX to LX Swap???
- Auto Transmission
- Megan Racing High Flow Cat!!!
- tsunami front bumper
- fix shield?
- off the line accelleration diff between LX and EX?
- Off the line accelleration between LX and EX
- DH race pulley
- Alignment (Help!!)
- stock throttle body question
- Rotor minimum thickness
- engine type
- Can someone help me with my exhaust rattling problem?
- anyone have DIY rear bumper removal?
- Does the engine clear the tranny
- Things To Know Before Tinting?
- If I wanted a switch... electric guys, please read.
- can na civic be fast?
- How to activate Day Time Running Light
- need help to install a tachometer
- Does anyone know the weight of the stock flywheel??
- Civic Alternator
- Getting Rid of Interior Neon Cigarette Adapter (connecting to fuse box?)
- Nawz
- Going back to my stock air box...But...
- Taking out passenger airbag??
- DIY Painting Interior
- Can I have some opinions please?
- DIY mirror help
- OBX Header
- Dash Painting(not trim pieces)
- graphics kit removal
- Alternator belt. Help please!!!
- Would removing the divider in the air filter housing...
- Fuel System Evaporation!!!
- DIY Black Housing Headlights
- CEL goes off again!!!
- This should be a quick No answer, regarding a Head Swap D17 Mini Me?
- F'd up car
- Hx to Ex Will it be noticeable
- Custom Intake?
- Flywheel removal
- Help with header install!
- mil eliminator universal?
- MIL Eliminator DIY
- A/C belt
- DIY: Dash Removal
- exhaust question...........
- headers
- Automatic Transmisson, car throw in reverse while moving forward
- kamikaze header do u have modifications
- How to Remove B pillars?
- Truth about performance crank pulleys
- header with stock piping and muffler?
- Checking oil, trans fluid
- Shifter is out of wack.... Read please, searched....
- how to reqire wire harness for new gauge cluster
- Aftermarket Sunroof
- Tricked out trunk
- lowering the stock seats any more?
- some help w/ wiring indiglow shift knob
- Help me with octane!
- aem intake diameter
- car running sluggish, plz help!!
- Fawked up my dash!
- socket size of rotor bolt
- Hondata For D17
- TRUEHONDA.com
- Spoiler Install
- Help with DIY Turbo set up...
- M3 Mirrors
- HP header and O2 sim. question
- 2k2 Short Shifter
- Quarter mile times?
- rsx seat install questions
- Here we go again
- DIY: Autometer Digital Voltmeter???
- need help
- Oil Pressure Gauge Fittings - Need Help
- Bad Throttle responce HELP!!
- sway bar links
- header to exhaust match
- DIY: Black Housing Headlights *UPDATE - Fixed Pics*
- My friend has a problem w/ starting his car
- clutch diy?
- DIY:01-03 Headlight Aim Adjustment 56K WARNING
- m3 mirrors(help running led wires)
- Need an ecu NOW
- Internal Parts
- Side Airbags?
- Removing tint????
- Taillight tinting question.
- Cam Gear
- maintence light is on
- Remote Start Problem! HELP!
- electrical switches
- Fuel and Vacum Lines...
- URGENT Help! EBC Rotors + EBC green stuff pads
- Are our cars being monitored (black box)
- ABS plastic question
- IAT Sensor
- Reprogram your ECU for only $900....
- WTF - D17A from japan on ebay....
- I read the DIY for the dash, is it all really necessary?
- paint supply
- Question about cooling system?
- how much power steering fluid do i need for reflush??
- did i mess up bad and how do i fix it???
- which is better?
- Would this (from ebay) fit in our cars?
- muffler madness
- bodykit install/fiberglass molding
- Coolant
- Unorthodox Crank Pulley
- Eccentric Finger ??
- HELP!! Please.
- Evo 5
- 2001 Civic alternator belt adjustment
- Mini Me with D17 Head??
- Wash windows befor tint?
- The Myth that driving faster uses more Gas
- blacked out taillights
- Anyone know the part # for this!!!!
- !!!!newb In Need Of Help!!!!
- Help Needed!!!
- Civic SI Ep3 Front Seats and that 4th bolt
- Right hand Drive conversion
- Yes I have searched it...
- throttle body heater bypass
- shift knob question
- Valve clearence adjustment...do or dont...and when?
- SRS light... already did the DIY SRS light
- 96-99 question
- removing mud guards
- Oil Light problem
- exhaust manifold install
- lx header
- power steering removal?
- My AC smells like Cow sh!t!!!
- Are there really any hp gain in any engine mods?
- hahah got $3 cone filter... now what?
- Big Josh MIL Elim Wiring?
- Paint Removal....
- Need help ASAP - 1.7L noise
- What the hell is this noise?!
- porting exhaust manifold?
- MOMO Steering wheel Install Question?????
- removing rear deck.
- malfunction indicator lamp
- How do you tell if ?
- how to replace this molding?
- Need HELP with the MOMO steering wheel install??
- manual/auto center console question
- Wiper Fluid Warning Light
- Breaks
- Help, Keyless Entry Messed up
- Apexi V-AFC II
- APEXi Turbo Timer
- Required Maintenance, What Should I do?
- Leaving out airbox???
- need help with diy flip flop trunk
- Sub frame?
- jack points
- headlights don't light up
- O2 Sensor - Diagrams
- No parts for the 2004 model?
- anyone have pics?
- Back To Honda Again
- re: i need some help
- removing stock headlights
- dimensions of stock intake breather hose
- anyone have mil iliminator installed on high flow cat ?
- how to install 5" tachometer
- Vtec Engagement??
- Vaccum Lines
- is a 2003 ecu the same as the 2001/2 ecu
- Fuel injector cleaner interval?
- Removing the Cat bolts?
- K&N cone filter question
- DIY: Ported exhaust manifold gasket
- Anyone ever reuse the OEM shift boot?
- Computer Upgrade?
- More Grounding Kit Install Pics (56k Warn)
- Seatbelt question...
- valve cover breather question
- Okay quick battery issue, PLEASE HELP Me!!
- blue headlight
- turbo
- throtle cable
- Valve Cover Temperature (Not the Wire Cover Noobs)
- Ecu Programming
- Clearin the headlights and smoking the tails!
- Adding SRS Seats to a non-SRS seats civic..
- Autometer Oil Pressure
- Why dont our cars have a WOT A/C cutoff?
- Removing Rear Seat Cushion?
- Ww G5
- Draining Tranny Fluid?
- Window tinting...
- Hid Wiring Expert Help Only!!! HELP ASAP!!!
- this is the funniest thing ive ever done...
- Cold cathode angel eyes
- Transmission Help
- Grille Inserts
- Driver's Power Lock Broken...Again!!
- oil change
- Transmission Help
- Magnaflow exhaust hitting frame
- Drive Shaft Seperated
- Buzzing/humming sound
- Removing Sedan Bumper
- 150 hp please
- RETRY: Door panel DIY fabric
- Fuse Problem ?
- DIY: manual shift boot on A/T
- Synthetic oil and VTEC engagement issues?
- Just Installed Revo Short Shifter!
- Engine Problem
- installing header, hi-flow cat, and cat-back...
- 2001 Civic 1.5 VTEC, Auto Trans
- Manual Tranny Fluid change on an 02 civic ex. What tools are needed?
- Help: Oil Change Question
- 35000 kms what should be changed?
- Greddy Blue Box?
- Rear bumper clip
- fog light install??
- 1% too fast or 2% too slow?? What would you prefer?
- how to change Stock Headlights?
- de cat pipes
- How much can I deck my cylinder head?
- What am I to do Now!?
- Torque specs for calipers???
- Front Spring Problem
- installing an OBX header on 2001 LX w/out a catalytic converter
- cotter pin removal and upgrade kit
- stripped bolt, need help ASAP!
- My ultimate intake hose!
- Nimrod mechanic told me this about 5W20
