- 98 honda civic ex
- removing stock HU in 2003 civic EX SEDAN
- camshafts
- Do I actually need torque wrench to install neuspeed strut bar?
- How to rev VTEC-E 1.6 up to 7500RPM..?
- how much $$$ for 160hp
- Hood OEM Spec and trunk etc.
- Anyone with a rev speed meter
- 02 coupe headlights
- port polish heads
- Need help with Bomex Mirrors
- Helms Manual - which version for a 2001
- Part Swapping
- maint. light
- Rotor Resurface Question
- Xenon front question?
- 2K1 grill swap with 2K4 grill???
- are sedan & coupe mirrors the same?
- need help with squealing belt
- Problem w/ DIY Auto Locks Complete
- Can we use a different headrest??
- will AC compressor on LX fit EX?
- Tranny oil??
- ATF Replacement on a CVT tranny help
- ARP studs...
- DIY on changing tranny fluid??
- Dual Exhaust On A 4 Door
- does a pulley system effect the stereo.
- transmission cooler install
- 04 civic
- Help!! Vafc 2
- Power Outlet accessory Mod "always ON"
- unplugged egr valve
- Intake question
- Civic Si (Canada SIR) swap of seats
- Help Installing Wings West G5 Side Skirts
- Thoughts about intake manifold designs for the newer civics....
- Got VAFC2 - No wiring diagram, please help!!!
- problems with keyless entry
- four on the floor
- Need opinions for body work
- Any1 have dyno charts?
- Breaking in Motor
- ignition system conversion
- Rear Dash
- Where to place jack stand?
- throttle body spacers
- ac blower motor....a bit louder than usual...
- More then one resistor???
- Increase 20 Hp
- Need Help
- Alarm not locking / unlocking
- gauge cluster
- Can you buy painted bumpers?
- RSX-S steering wheel swap completed!
- Detailed smoked out taillights DIY w/ pictures
- People with Bomex mirrors/ wiring experience
- Underdrive pulley's... increased milage?
- SRS Light just came on
- Maint. Light Q.
- Loose seat setting off SRS??
- SAFC2 wiring diagram
- SRS Light
- will this fit a coupe?
- Same chassis for....
- Lambo doors on 2004 civic!
- Pulling Engine
- Tune up
- Turbo or Bags?
- Removing hood trim
- Header Torque Specs
- PnP Clarification
- DIY for headlight
- Battery wiring
- +12 Volt Dash Lighting
- V-afc II ***completely Useless***
- ANgel Eyes Wiring
- low end torque
- How to check air:fuel ratio?
- Can I remove the heat shield from my manifold safely?
- Check Engine Light?
- CompuStar Security
- More Airbox Ramblings...
- Angel Eye Projectors
- o2 simulator and A/F gauge
- How do you remove the louvers in the corners on the front facia on 04 EX?
- Side mirrors wiring color?
- ECU Code List?
- OK. Enough $hit. WHat is the TRUTH about Engine Breaking?
- push button ignitions stuff???
- remote start and push button start?!?!?!?
- 2004 Sedan Grill Removal
- break in question
- Repairing Ceramic Header
- 04 Grille on 03
- 0-W30 ok instead of 5W-20 in 04 EX?
- My Car is loosing power
- DIY front strut tower bar?
- gauges
- I need the belt sizes for... **HELP**
- exhaust for 2004 civic ex coupe...
- MTF plug washer?
- A-Pillar removal
- will bomex mirrors fit sedans ??
- just orderd rsx seats and????????????
- JDM b16A SiR2 swap done muhuahahaa
- Problems with Headlight DIYs?
- reupholstery
- jdmb16 SiR2 pics.. finally got it
- Overheated engine
- Overfilling crankcase
- greddy evo 2 for 04 civic
- Does oil weight have any effect on VTEC engagement?
- Any1 know exhaust port size
- Side Skirts
- Help with homemade induction on 04 EX.
- weird knocking noise
- We have a serpentine belt i assume? and sprkplug question.
- engine problem, help please
- Will this catback system work on an 04 EX?
- WOW - Check out this clutch!!
- Launching my Civic
- exhaust tip too hot
- MODIFYING ECU: Is it possible for the tach to show up to 2 decimal values?
- S2000 5 lug ???
- AWD '01 civic
- A lil more tranny info needed..
- YES There is a RECALL!
- Attention 04 civic
- If SOHC VTEC is made for eonomy, then why...
- Anyone opened up a stock resonator box?
- painted cf hoods
- Fuel Injector info - you can use whatever you want, as long as it fits the boss....
- Steering Wheel
- Nology Hot Wires
- Header and Mil elim not workin HELP!
- Clunks In Tranny Searched
- Brake bleeding order
- throttle body question
- what is this?!
- Intake pipe size? 2-3-4 inch? why not?
- Easiest way to change MTF?
- Hyper Voltage Regulator
- What options do I have to raise my rev limiter?
- OEM brake pads break-in procedure
- Light Switch Assembly
- Serious info--torque specs!!
- Gearbox Problems
- Styrofoam Piece Behind Front Bumper
- Added Boost Connect to ECU
- HO2 Sensor Mod for hi-flow cats/ CEL on
- What should i buy for an exhaust
- Dealer says i cant reset my ECU?
- EmErGeNcY!!! HELP!!!! ASPA
- Which foglights for Xenon bumper
- SRS Light on 92-95 models
- D16V1 mods?
- Should I put higher octane in my car?
- Freakin clutch!!! Need help ASAP!
- Autometer water temp gauge?
- Is the exhaust size different between LX and Ex 04?
- Need help with Headers
- Hx to LX transmission
- Spring Rate ?
- Installing racing seats into coupe with srs
- problems with downpipe and cat.. installation
- 02 Si seats install?
- drivetrain problems...
- Differences between EX and HX head?
- My bumper is punched in... need help
- 2002 Honda Civic EX SEDAN Door Panel Removal
- how about those parts?
- OEM fogs not working....need help
- DIY rear tie bar
- Fender roller
- 1-2nd shift grinds on b-series
- I Need Help From Any Of The 2003 -2004 Civic Ex Lx Hxowners
- DIY shift boot for a/t...
- Does anyone know where I can get an Amber OEM Foglight switch?
- fuel injector flow rates
- Question for cam gear owners
- Auto Tranny fluid
- Pillar gauge pods-Where to run wires and cables?
- I just got my BCII kit in
- projector headlights angel eyes
- Wondering about a good header
- neon inside
- help w/ maintenance light
- 2004 Mazda3 W/ Xenon - Strong At First But Fades To White...
- DIY: sedan door panel removal
- Wiring Diagram for SAFC2 PLEASE!
- vafcII setup info?
- Ex parts on Lx
- Good transmission?
- Goy my DNX exhaust...Wht does it hang crooked??
- fuel injector help
- projector headlights fogged up
- Integra Airbox Conversion finished
- cutting stock shifter????
- DIY cluster swap 2003 - 2004 dx also available for other models
- Anybody heard of a VTEC-E?
- any hope in automatics
- Have question about swapping out exhaust?
- needle removal/LED info on 03+ coupe AT gauges
- How can this be possible? Exhaust sound-
- Is it a Sunroof or a Moonroof?
- how to install projector Light ???
- I need help so bad!
- Amsoil Dealer told me..
- Clearing Headlights, need help in NYC
- Oem airfilter housing crap!
- Stretching sound from rear drum brake?
- Jdm Headlights??????
- Removiing the torsion bars
- sidemarkers .. easy or hard ???
- Buddy Club Piggyback and VAFC2
- Tranny problem...has this happened to anyone else?
- moisture in headlight assembly
- Greddy EVO II Install
- K&N FIPK vs K&N Typhoon
- V-AFC2 problem!
- Cold Air Intake Systems Installation
- CVT tranny -Dont understand...
- Detonation???
- wooohooo! VAFC2 installed!
- HID help(projector don't bother)
- So, whats really so special about Honda?
- HELP w/ SAFC2
- rsx seat install, version beta 1.0a...
- removing fender/wheel well?
- Integra Seatbelt Question
- AC Belt removal
- installing gages
- Should I get rid of the resonator?
- how much for lamborghini doors
- Help solve a mystery shifter problem
- Spark Plugs, WTF
- Some dyno sheets- before and afters
- synthetic back to dino
- Just Did the DIY VTEC LIGHT!
- Hood vibration: caused by cushion hood?
- Setting the timing?
- Changing the oil (first time)
- quick question
- how to fit universal sliders in my car?
- DC5 steering fit our cars ??
- How To Remove a Rusted Screw?
- Oil cooler install????
- maintenance required light
- Autometer Oil Pressure Gauge?
