- Hood Pins w/Carbon Fiber Hood
- Racer Design Coilover Kit Installation
- dyno charts for FI and NA cars
- buying a catback or a muffler+custom piping
- Shifting in a/t
- dont want to spend too much...
- plz help
- question about windows
- 3 In 1 Fog Lights
- Convertible CAI
- recarpeting the WHOLE trunk
- interior question
- Another Mid-pipe crisis
- Reaching out for help before i go crazy
- hp gains with certain mods
- Question about PKH3-II starter wire
- Slanted Steering Wheel? Help!
- Door Panel Coloring, or replacing..
- help plz
- Changing OEM Steering Wheel
- exhaust..
- best headers?
- Help
- mounting RS/type A sideskirts
- gauge cluster swap
- Head Swap?
- auto want go into drive unless i reset ecu.
- Head work real HP gain
- how to tell?
- ** HELP **I've searched and searched.......
- Aftermarket VTec?
- Color help
- Good Temperature For Painting?
- SRS Light after MOMO wheel
- Connector for 16-pin wire
- Header Help ?
- Please help with my VAFCII
- 5000 rev limit?
- 01-03 civic coupe parts in an 04 civic coupe
- how to set a VAFCII
- question about intakes...
- clearing sedan reverse light?
- HP gains from headwork?? & Tranny Upgrade Q's
- 04 gauges.....
- Injen RACE DIVISION CAI for 2002 civic will fit my 2003 lx c oupe?
- small light fuse
- vafc2 settings!
- rsx-s sway bar?
- Coolant Leak
- Starter Motor
- what are the smptoms to a bad O2 sensor
- 04 gauge LED temperature...
- ignition coil
- Diagram of OEM sideskirt??
- securing hood
- the link
- RSX/Civic clutch assembly interchangeable?
- No interior lights, blown fuse? help
- Fog light switch
- Misfire after mods
- tranny gear's pops out of place...?
- How Does a Shifter using cables work?
- battery keeps dying
- Question for Engine Light
- Need Part Number
- automatic transmission upgrade?
- motor mounts
- ecu chip ?????
- popping sound at high revs
- sparkplugs.
- noticeable difference in spark plugs??
- DHR RaceCams/Manifold.. is it worth it..?
- Vehical Warrenty's Questions!
- Stock AUTO
- air inlet paths in intake design
- How do you shield your CAI?
- Automatic Transmision Stalling
- newb question about spark plugs
- shaving trunk lock?
- Security System installed in DX
- My AIT Sensor not connected to my intake, whats gonna happen?
- Has anyone?
- Air/Fuel ratio install???
- INFO: Honda Engine Codes.
- need help on racing seat install
- Amp Problems
- Vertical Door Conversion
- Exhaust Question
- Unsprung Weight?
- DIY: Paint Chip Repair
- Revving above 7 g's
- 2004 Si Cams??
- WHY WOnt it Just STAY!
- Torque Converter upgrade help plz!
- oem spoiler question
- the driver side (left) is lower than the passenger side (left)
- Protect Your Car NOW!!
- DH crank pulley belt measurements?
- LX ACT clutch fitting an EX?
- Custom Intake Idea...
- Compression test
- Shifter Mechanism Junk??
- Ive searched and think I got it but maybe not?
- Best Synthetic Motor Oil?
- Stock exhaust size for EX?
- How do you adjust the steering center?
- how deliver more fuel to engine?
- Bridge Motorsport Ground Kit DIY/Review
- Turning on stock alarm?
- how do i get my cam gear off?
- How does the sf fuel managment unit work?
- Water entering trunk!
- pushbutton start?
- best service manual ?
- engine measurements ?
- Tips for Installing a Clutch
- A whole shiz load of Honda manuals online..
- Tranny
- primer difference and more??
- Does Mine look diff. than yours?
- Need help quick OBX
- Air seeping in . . .
- Need Help
- clutch and flywheel questions
- headlamp circuit
- driverside headlight off
- DOT/EPA Approving
- question on tach wire
- split fire plugs sucks
- Help with cleaning piston rings
- LX to EX exhaust conversion, need help!
- service maintenance and after market suspension
- Fenders from sedan...do they fit coupes?
- issues with putting on rear oem lip (or any other lips) when peeling off tape
- need some one local to help me.
- installing camber kit need torque specs
- Thoughts on bypassing rev-limiter using E-manage...
- weird sound......need help
- clicking???
- stock -> stacked internals
- How to check timing on our cars?
- I have Indiglos but want to make them Reverse
- Oil filter sizes?
- DIY For Tranny, Clutch, Flywheel
- Side MArkers Installed
- msd ignition wires
- Universal shift knobs
- Torque converter stall speed
- Tach Help
- rev speed meter
- stupid question, but worth asking
- Is it recommended to seal TYC's?
- Losing power after installing Apexi V-AFCII
- what type of oil should i be running right now?
- Clutch Fluid...
- exhaust help please
- Hood shocks
- GReddy SP2
- Wiring Diagrams
- How hard is it to mess with the upholstery?
- timing belt broke! what to do!
- parking light relay
- 03+ Gauges
- evo question
- Will New Accord V6 struts fit our cars?
- where to find DIY
- Maintenance
- Bulb ?'s Help Plz
- Redline limits
- Installing new Clutch?
- 60,000 Miles!!
- Pnp Head Install Torque Specs
- Best Cai Filter?
- RSX moonroof control
- removing spare tire?
- e-brake install
- vtec light
- Help!!!!!! I really fu(ked up now.
- Exhaust
- Transmission HELP!!!
- Rear/back license plate holder...
- how fast can you guys go??
- signal tappin...
- engine codes ?????
- STRANGE PROBLEM: Heat only works when moving.
- Help in buying a truck
- Calculate Quarter Mile Times and More Online!
- Repair manual
- Help: Moist In The Headlight
- windshield crack
- D17 Wiring Pinouts
- Help!!!
- Need help fast. My car keeps dying
- Turn Signals Don't Work Plz Help
- Will stock rear struts from a 02 ex fit on a 95 civic dx?
- DH RACING's PNP DYNO RESULTS WILL BE HERE
- clearing headlights
- Mugen grounding kit
- Diy Strobes
- 2001 civic Parts List/wiring diagram
- thx for the pointers
- Eclipse 430cc injector do they fit
- Does anyone have a Kenwood KNA 2100 Nav unit? Please Respond.
- Recomendations???!!!???
- Iridium Spark plugs causeing (audio) Engine Noise?
- Grey's Kits for Revo SS
- Car Alarm
- Radar Detecting Monkey!
- I NEED HELP, PLEASE!
- Diamondplate floor mats
- anything wrong with....
- torque spec for power steering pump bolt.
- cna u mold on urethane?
- Maint Req light on...help!
- Greddy E-Manage Wiring for EX / VTEC
- how to lower the seat
- NEED HELP with shaving emblems ASAP
- DIY: Double Rear Turn Signal *Warning 56k Users*
- diy oil change link
- DIY-REVIEW: Ground wires and HVS! (UPDATE)
- help with duplicolor or plastikote paint
- DIY: Angel Eyes
- I need a measurement...
- Does anyone know if our fuel injectors are Saturated or Peak and Hold?
- Need Help. Ignition Problems
- Battery Dead?
- help with lights
- Help!! All Keys Locked In Car, Roadside Assistance?
- will the TPS fit??
- Intake swap
- Side marker exact placement
- main brain computer of our civic..
- 04 front and rear bumper on 02 civic
- How to install rear bumper?
- Air Bag Light
- 2001-2003 Civic Recall?
- I need help quick
- Vibrate problems new exhaust
- 3rd gear grinding synchros ?
- Headlights? Is it neccesary?
- can I change from synthetic to standerd motor oil
- Installing side skirts??
- D.I.Y. AEM cai.
- evo?....
- Problem with rear squeak
- Intake Question
- Magnaflow......POS
- safc2 install
- Remote Start Problem
- those with greddy evo and progress
