View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Belts and Fan Belt
  2. Clearing my headlights....question about DIY
  3. Body Kits
  4. Stock Ex Fuel Cut
  5. EX Fuel Cut
  6. Can't turn off alarm HELP!!
  7. Special tool for rotor removal?
  8. Tips for removing stripped lug nut?
  9. driver door problem!
  10. what type of engine?? vin number on engine??
  11. Tech Help Needed: How to Remove DBL Sided Tape!
  12. vent removal
  13. 2001 2dr civic ex exhaust questions/problems
  14. taking apart lens half
  15. What is the Apex'i S-AFC & What does it so exactly?
  16. lowering my car
  17. V-AFC, settings
  18. first and second gear lil lose/soft
  19. Aftermarket catalytic converters - how did some of you get around EPA regulations?
  20. Taking off front fenders
  21. How fast does a 2000-2004 Civic EX go to 0-60???
  22. Help Now Please!!
  23. Help, ASP
  24. lx high flow cat ?downpipe?
  25. Apexi VAFC II **Complete Fix**
  26. type B rear lip modification for coupes
  27. RSX exhaust on a 99 dx?
  28. help? turn check engine light off
  29. Just install my v-afc 2
  30. stupid vafc!!!
  31. stupid vafc post #2
  32. oil change question
  33. cleaning an injen cai filter?
  34. im haveing trouble putting on my coilovers
  35. car swaying after replacing wheels and tires
  36. Where is Manual Transmission Fluid Reservoir in the Engine Bay. ??
  37. AEM SRi???????
  38. What size pod do I get for this Boost Gauge?
  39. AEM V2 Question
  40. Painting parts under hood.
  41. DIY servicing
  42. 99 civic bolt on exhasut
  43. n2o kit from a different...
  44. Internals done pics
  45. Intake manifold
  46. Need Help (Oil Pan)
  47. ECU Upgrade Program 65001
  48. Can I make this fit my car?
  49. 2003 civic si tech info
  50. who has xenon
  51. 911 911 911 hp header help
  52. help
  53. need help putting on a str cam gear
  54. ame pulley
  55. Questions about clearing lights...
  56. Dhracing Group Buy Is On Tonight!!
  57. question about our gauges.
  58. passenger lock does not work
  59. skunk2 coilover install help!
  60. AEM cam gears and stuff?
  61. Installing Header! Need help now!
  62. nitrous/02sim/airfuel gauge
  63. LX-EX exhaust swap people!!
  64. For all you DIYourselfers out there
  65. Painting Exhaust????
  66. Is this possible??
  67. push button start!!
  68. Pistons
  69. DIY Clearing headlights Question
  70. Timing Belt Tq Specs
  71. tech @ honda suggested i would (see for details and Q)
  72. Civic si seat swap
  73. 2001 Civic defrost/air conditioning
  74. carbon fibre altezza grill question?
  75. price for kamninari kit ??
  76. header touching the frame
  77. WHY? WILL it?
  78. K20 swap or Turbo w/D17 ????????
  79. DIY Indiglo gauges (94 accord)
  80. Locks kit to alarm
  81. clutch shaking?
  82. Spark Plug Gappin'
  83. Bolt started to round-off
  84. 2004 Foglight Install
  85. spark plugs?
  86. what is different?
  87. spec on camshaft????
  88. valve springs and titanium retainers?
  89. engines out the ying yang
  90. Help~~~DIY for Reverse Glo Gauge (Manual)
  91. SAFC2 wiring diagram
  92. Need Help Locating The Fuel Injection Air Control Valve
  93. Just need a yes or no answer if I HAVE to take off front bumper 4 headlights...
  94. Engine Swapping
  95. stealing car
  96. Push button start with no key?
  97. Anyone know the specs for all civic models?
  98. Has anyone paid Honda to do valve clearancing?
  99. engine swap question??
  100. !!!o2 simulator question!!!
  101. Aem Fliter Cleaner?
  102. Serious Spark Plug DIY question..
  103. NX Express kit part # and best price
  104. do you have this?
  105. Anyone with Unorthodox Crankshaft pulley
  106. engine code
  107. clicking....
  108. air bag light
  109. Grounding the alternator??
  110. Please Look 2001+ D15B??
  111. SRS Unit
  112. 60' times (sorry for Repost)
  113. help..car wont start
  114. focuz high flow cat?
  115. auto start DIY?
  116. Need Help Asap
  117. tranny
  118. can i get colder air
  119. DC sports headers work on DX/LX
  120. LX headers
  121. Help! Chip in paint on hood.
  122. Installing my tranny cooler
  123. first time I come to you for Help...
  124. performance without the $$$
  125. Piston specs
  126. ABS light on in the snow???
  127. Any info on trans coolers?
  128. revo SS
  129. lighten flywheel?
  130. Copper head gasket
  131. Speed governors
  132. Exhaust system question
  133. taking off the head
  134. re-aim lights after bulb install?
  135. Really cold weather performance?
  136. oil pressure dropping
  137. question with gauges?????????
  138. How do you get rid of the "maintence required" light?
  139. cam gear
  140. Help with Torque
  141. Header Question!!!!!!!!
  142. SOHC Throttle Bodies
  143. Can you take out the black part in the front bumper?
  144. are the internals the same?
  145. headlight install....no keyless entry???
  146. Voltmeter power source?
  147. CEL, I know the code, what to fix?
  148. oil pressure dropping part 2
  149. rear disc conversion
  150. Help interior paint removal
  151. putting fiberglass over your dash
  152. I need an intake manifold/injector base gasket NOW!!
  153. Need Help with intake?
  154. How-To Paint your Tail Lights!
  155. Need some help installing generic cai...
  156. need help with hood pin problem
  157. stripped out civic
  158. tranny fluid
  159. Pulling
  160. Driving w/o front sway, bad?
  161. Eye lids welded on the hood.....
  162. dash replacement
  163. ECU q's
  164. "Parking light" fuse
  165. bore
  166. How much brake fluid do I need?
  167. tyc tails and lights
  168. Good news from MSD!
  169. Got bored so did some wiring/installing!!
  170. the technical side or RSX seats and SRS??
  171. lambo doors..
  172. apexi silencer hardware install
  173. apexi auto timer
  174. Battery and Digital Capacitor question
  175. Is it better to buy black or primed?
  176. Projector to Stock Head light
  177. Adjustable Fuel Pressure Regulator
  178. In need for someone with a 2001 civic Helms Manual
  179. What is wrong with the security system.....?!
  180. halo damage prevention
  181. Fuel tank = Upside down Triangle
  182. wheel shaking when turning right
  183. diff on EX and LX muffler
  184. Has anyone replaced their fuel filter..
  185. coupe tails on a sedan?
  186. C.A.R.B. E.O. certification
  187. Help with odometer
  188. VAFC 2 on my ECU?
  189. DEI 555I or DEI 555H?
  190. Bulldog remote starters....
  191. CLEAN oil filter removal?
  192. Steering
  193. Prepping a used kit question.
  194. New at this: I need member's HELP!!!
  195. DIY?: Glovebox LED Lighting
  196. Transmission Cooler?
  197. Quick Headlight Clearing Question
  198. VAFCII lights
  199. gauge question
  200. help with mounting vtec controller
  201. Quick Help Please
  202. whole gauge panel?
  203. 2 or 5 wire door lock actuator?
  204. Steering Wheel Emblem
  205. weight of our d17a2 w/ manual tranny
  206. A How-To on Shaving your emblems
  207. Lights behind console help pls
  208. tach for 2004 DX
  209. window washer tube
  210. Auto shifter mod to lock between each gear??? P, R, d, d3 etc.
  211. Oil Question
  212. broken latch?
  213. headers
  214. knock sensor
  215. Halo Headlight burns Bulbs....?
  216. Changing Manual Transmission Fluid
  217. tinkering around with stock intake...
  218. rpm vs mph chart available?
  219. Cutting your shifter down
  220. Maintenance Light...
  221. What Helms Manual Version should I buy?
  222. HP Gain?
  223. i bought a ebay intake
  224. N/A D17 Numbers?
  225. Removing Steering wheel cover
  226. question about exhaust problem
  227. All in one gauge??
  228. iat sensor
  229. Clutch went dead!
  230. How do you switch to Synthetic?
  231. test fit spoon n1 on 7thG civic
  232. 2003 rear deck lid
  233. Car Jack Points
  234. Engine question.....
  235. spark plug swap
  236. V2 intake???
  237. oem fogs
  238. Tranny overhaul?
  239. intake physics/operation crap question...
  240. Intake pipe being lead thru head light
  241. o2 sensor problem
  242. How tight should I torque 5 bolts such as alternator, transmission....
  243. hello.. can anybody help
  244. internal VS external wastgate
  245. need help bad!! for aftermarket mirrors!!
  246. compatable parts
  247. need a donor car
  248. Wiper blade chatter
  249. vss sensor
  250. 2004 owners
