View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Dash Wire Harness?
  2. My experiences with installing the E-Manage....
  3. Need some help from alarm PRO!
  4. Lowering springs
  5. Semi-DIY Water Temp Gauge (PICS)
  6. irritating noise?????
  7. V 2 Lowering springs
  8. rsx auto tranny swap???
  9. o2 censor on straight pipe taking Cat. converter off
  10. Help me spend $2000 to go faster
  11. first gear selection in civic auto?
  12. Will it fit?
  13. Steering Wheel Vibrations
  14. cam gear tuning
  15. Magnaflow cat-back clamp ? air leaks
  16. Flip Flop Trunk
  17. FiberGlass Interiors.
  18. help me get my endlink bolts off
  19. Changing LEDs for shift indicator?
  20. Auto to Manual Conversion question
  21. Injen CAI install on auto
  22. All of the sudden...my CEL turns OFF!!
  23. Alternator
  24. Dash Harness?
  25. Fuel Filter Replacement...?
  26. 30 thousand mile checkup
  27. integra seats
  28. SRS light
  29. Need Help Check Engine Plug
  30. Need speed ideas
  31. o2 sensor question
  32. creative sidemarker help (PICS)
  33. Turbo Plus Extras?
  34. Driving light glass paint?
  35. fogged
  36. garage opener inside the car..
  37. left hand drive swap for and 01 civic 2 door ex
  38. Exhaust bolt breaks
  39. removing bottom seat cover
  40. strange idle and cel
  41. problem w/gauge light DIY
  42. steering wheel shake...
  43. Will my front air bags deploy?
  44. weight difference between k20 and d17?
  45. Shave
  46. DIY: weight reduction question
  47. aem pulley kit worth it ?
  48. aem cai vs ebay cai
  49. How hard is it to install an aftermarket TACH?
  50. Road raged Corolla; help me out guys.
  51. where to install turbo goodies
  52. question on zex nitrous bottle placement
  53. Car Rattle?
  54. Gel coat and fiberglass
  55. P n P job vs. re-sleeving
  56. Automatic Transmission
  57. E-manage VTEC wiring
  58. where to connect to o2 sensor?
  59. O2 Sim Question
  60. EX headers
  61. Straight Header
  62. horn
  63. Push button switch question
  64. auto shift sounds like manual sometimes
  65. check engine light flashing when i start car
  66. Lower Bottom Brace DIY
  67. Power mods...good or bad for resale?
  68. short ram vs cold air intake
  69. New interior DIY
  70. help hp racing 4-1 header questions?
  71. 2001 lx brake pads fit ex ?
  72. question about heat shields
  73. Throttle Cable Question
  74. vafc2
  75. vtec, what exactly happens with ours?
  76. 01 Eclipse
  77. Could VTEC being disabled hurt me?
  78. Need a quick answer for a quick question
  79. what kind of engine mods will affect (not pass) emission test?
  80. Auto Transmission Question
  81. Broken Air Filter box.
  82. Blue gauge needles and hyper amber interior!!
  83. Help with Crimestopper CS880S Wiring
  84. apexi safc be used on a na car ?
  85. wires connected to seat?
  86. the governer
  87. Looking for DIY to hold stuff in place in trunk
  88. Question on Gauge Pods
  89. Convert from H4 (oem) to H1 (tyc) headlights.. good results?
  90. Hella 90MM projectors... where to get them?
  91. VAFC II problem has been solved!!!!
  92. Does the inside of your intake look like this?
  93. Those with grey's endlinks...post some pics
  94. Need Help From Sedan Owners...
  95. Need Help From Sedan Owners...
  96. Gas Milage w/ 205/50/16 Tire?!?
  97. CIVIC 96-00 AEM PULLEYS New
  98. Driver's side floor is wet??
  99. Our 5spds compared to the old b-series 5spds...?
  100. Thermal R&D ST system Specs.
  101. Intake Manifold and Throttle Body removal DIY
  102. well now im looking for an alarm
  103. Where to mount gauges?? pls post pics
  104. OEM Part #
  105. Pin out for Factory Alarm Plug (Green)
  106. Powder coating Question
  107. VTEC Controller
  108. Turn off Seatbelt Beeping
  109. what bulb size are in the OEM heads
  110. Megan Racing Hi Flow Cat
  111. Possible mounting positions for your VAFC...Pics...
  112. JET V-FORCE not working right
  113. gauge wireing
  114. Newbie DIY for Replacing Air Filter Box...?
  115. Side moldings
  116. Apex'i RSM Question..
  117. check engine light HELP
  118. HKS Hi Power exhaust, Will it touch body kit?
  119. Attention Everyone With BODYKITS!
  120. How do u make the clutch softer?
  121. EP3 Rear seats in a EM2
  122. bolt pattern conversion
  123. DIY: Making Dash lights brighter
  124. arias pistons
  125. 04 Gauges in an 02 Civic?
  126. Dracing PNP flow rate before and after?
  127. uniwiper diy?
  128. throttle body question???
  129. How to put stock intake back on?
  130. Need Help Fast!!!
  131. Article on oil -- frequent change is bad??
  132. Removing Cemented on Bodykit lol...
  133. help on door panel removal ! plz!
  134. DIY: Power Windows for DX/HX...now with pics!
  135. Headers on an LX
  136. Gas door adjustment
  137. who said removing the dash was impossible?
  138. Applying Body Decal, how to around door handle etc
  139. Need help quick!!
  140. LOssing the AC
  141. how hard do you think this install would be?
  142. securing car for the holidays
  143. washer nozzle question
  144. Ebrake removal from a 2003
  145. removing passenger/driver side window
  146. need wiring dig. for fog light switch
  147. installing jdm grill
  148. VTM wire?
  149. Intake Manifolds??????
  150. exhaust setup...
  151. About to Clean the Throttle Body..
  152. Lost FM reception all of a sudden.
  153. DIY for tranny removal
  154. cam gear belt?
  155. Question about throttle bodies
  156. 2k1Civic Engine Rattling Noise, Please HELP!!!
  157. Clutch noise
  158. VAFC 2 settings
  159. Ecu
  160. Holy Crap... my gauges
  161. Note To All Regarding Gauge Calibrating!
  162. Help! Quick Style! Anyone With Zex Nitrous
  163. monitor in the rear view mirror?
  164. Parts list, and instructions + pics to install K-series in 2k1 coupe/sedan
  165. help!! need a solution to an srs issue quick
  166. why bulb filters don't work
  167. Adjusting TYC low beam...
  168. question about DIY
  169. silencer removal methods
  170. Please help!!!!!
  171. TYC - Low/High beam help
  172. bottle heater
  173. HELP! Rotor Install
  174. Shaved rear "H"
  175. door switch wires
  176. Anyone have an old fuel rail laying around? I think I am going custom!
  177. which chasis is the lightest? (EG, EK, ES)
  178. Air Intake Owners! Ppl With Bad Gas Mileage..cel Wont Turn Off?check This!
  179. ECU and OBD version?
  180. aftermarket intake "INJEn"
  181. maintence light.....how serious?
  182. check engine light?????
  183. 01+ Si hatch steering wheel
  184. PROBLEM with my car...HELP!
  185. FIPK 2 help
  186. smoothing out trim pieces?
  187. cat back flanges clearance?
  188. can stock air box get hydroflooded?
  189. Dropped a washer in my engine..
  190. high/low beam
  191. v2 intake
  192. Diy grouping question
  193. Synthetic ATF ??
  194. exhaust pipe hits sway bar! HELP!
  195. Stupid Oil filter question
  196. nothing turns on but the lights (inside and out)
  197. hybrid gauge lights?
  198. Aftermarket oil pan...
  199. Cleaning the Throttle Body..
  200. need help quick
  201. the Injen works
  202. just hit 40k... what should i service
  203. Maintance Light Solution
  204. s-afc 2
  205. silencer removal
  206. Have any of you had this issue?
  207. Field Vtec Controller Installation and Comments
  208. Skunk2 D-series Intake Manifold.......
  209. restarting car when its on already
  210. Steering Wheel Removal Problem
  211. for the techies! ignition system ???????
  212. Front Strut Tower Brace & Intake????
  213. Problems with Apexi Vtec on 7thgen
  214. tuning a 2001 honda civic lx
  215. oil change question
  216. what clutch to get
  217. stock lx exhaust specs
  218. Air Filter directly on Throttle Body
  219. Why do people hate on air intakes?
  220. Turn signals
  221. autocross tuning
  222. change antifreeze help
  223. Prepping polyeurathane
  224. Gauge vent mount DIY?
  225. service soon light again
  226. scratchy sound by wheel...
  227. Rear Spring/Strut Install Question
  228. advance ignition timing ?
  229. which downpipe ? high flow cat ?
  230. taking off oem spoiler...diy:filling the holes?
  231. sequential gearbox
  232. look at high flow cat !
  233. Short Ram Intake Question
  234. Help for my Headlights!!
  235. Popping outta 3rd Gear
  236. Euro lights
  237. AEM V2 and rain
  238. Spark Plug Replacements..
  239. DIY: Polyurethane Motor Mounts
  240. Honda Diagram need help
  241. broken bolt HELP!!
  242. Cleaning the Engine..
  243. repairing headlights?
  244. short shifter problem?
  245. will this work well?
  246. Best oil or most commonly used?
  247. vtec HELP!!
  248. How to turn off SRS light?
  249. 02sim-AFG
  250. okay yet another post on the 0W-20 oil
