View Full Version : Honda Civic DIYs and Civic Tech Chat
  1. Flip Switch Mounting Spots
  2. Painted Tails
  3. H & R Springs for EX 4dr?
  4. Getting that piece out that in front of the gauges
  5. wheel colors for black ex
  6. Unable to find answers for shocks and camber kits after searching; Need questions answered...
  7. Cat back exhaust
  8. SEMI ACCURATE WHEEL/TIRE WEIGHT
  9. Fuel return line
  10. Rotor and Brake Pad DIY Updated!
  11. help...want to purchase Spring
  12. 2k2 Civic Hyperflasher-searche forims, not find >_<
  13. coilovers vs. air bags or cylinders?
  14. severely bad hyperblinker problem!!
  15. Seat belt tensioners
  16. Replace fuel system?
  17. How do I shave my door handles and trunk???
  18. H emblem
  19. Vapor line
  20. Installing Rear Strut?
  21. Anyone ever install an alarm sys?
  22. Sparco Pedals
  23. Reverse Indiglo adhesive???
  24. Rims and tires
  25. Nitrous Install DIY for 2001 Civic EX
  26. Exhaust Installation
  27. lowering
  28. How do I cut down my shifter?
  29. trunk lids
  30. i was thinking......rear disc brake conversion..
  31. Shaving emblems
  32. indiglo gauges hard to install ?
  33. Gauge Panel Remove?
  34. Transferring rims from one car to another and painting rims
  35. LED wiring ?
  36. I drained and refill transmission fluid.
  37. Skinny OEM OIL Filter vs Fat OEM OIL Filter???
  38. I know it's stupid, but i want to know........
  39. Anyone do a DIY on lowering?
  40. Wiring HID help!
  41. WARNING MAGNAFLOW
  42. how far will it go
  43. Will AEM CAI for EX fit on an LX???
  44. Fuel control settings
  45. v-afc vs s-afc
  46. ABS on 17s
  47. 2k1 vs 2k2 indiglo
  48. Intake Answers?
  49. Diff between HID and plasma blubs
  50. lowering car - bad?
  51. TURTLE: How did you remove the carpet on the door panels and put new on?
  52. Want to install rear sway bar, but will car fall apart?
  53. Not addressed: AEM LX auto SRI
  54. I dont know how to describe this problem....
  55. difference between 6th gen EX & Si exterior
  56. BREATHER!!!!!!!
  57. where is INDIGLO DIY???
  58. flame throwin' exhaust
  59. Whats the Filter type for the 2k1civic sedan a/t
  60. Lighted ignition ring swap
  61. need help now!!!
  62. Question about neons
  63. EX head and ECU
  64. My buddy installed springs and now his wheels are golly poggled
  65. cleaning injen filter...
  66. Open Deck Question...
  67. FIREBALL SPITING EXAUST
  68. DYI Taillights
  69. headers for LX coupe
  70. Hookup 747 landing lights to car
  71. clickin shift knob
  72. Camber Question.....?????
  73. Another Solution for trunk rattle
  74. Octane
  75. does oil really matter?
  76. spring upgrade
  77. WeaponRcoilovers on LX?
  78. dc sports tcs exhaust?????
  79. Changing Headlights
  80. 30,000 mile service maintenance $400
  81. Painting Stuff on the engine
  82. removeing air vent trim
  83. Is it really necessary to remove the reverse light switch when installing AEM CAI?
  84. Rear dome light bulb solution!!!
  85. MY CIVIC IS TOO SLOW! NEED WAYS OF MAKIING GO FASTER AND MORE HP!
  86. Short throw adaptor or kit?
  87. how to open tail light lens?
  88. Chamber question
  89. rear tail light does not work now, any help?
  90. Question to my straight pipe brovaz!
  91. Cutting sheet metal?
  92. How to wire a power outlet...
  93. Rear Upper Strut Bar
  94. ATTN: Anyone with a service manual
  95. DIY: Hyperblinker
  96. in need of CAI info
  97. how much is it going tocost me to get my new muffler welded on?
  98. ?? Help Car sits to low in rear??
  99. Is there a way to wire out headlights to turn on when unlocking doors?
  100. How to Customize Interior?
  101. V AFC Will work
  102. Has anyone switch throttle bodies?
  103. Bad Wobbling/Shimmy...
  104. z3-m3
  105. I have a couple of questions...Please Answer !!
  106. DIY: Upper Grill?
  107. Free 10W 40 fully synthetic
  108. reverse lights as turn signal?
  109. Help me with tire choice plz
  110. 205/45/17's???
  111. Rear Suspension in 2002 vs. 2001
  112. Help with NOS Install
  113. Strobe Fuse
  114. Stock Dash!?
  115. removing stock "H" emblem
  116. Bulb Chart for projector lights
  117. windshield lights
  118. Just installed DC Ceramic 4-1 Header...I can help out anybody if they got any questions!
  119. umm water in exhaust
  120. AC Reverse El Gauge Help!!
  121. Pinstrip removal
  122. axle back system (exshaust)
  123. AEM CAI Filter change??
  124. Ground Contorls make noise
  125. New project/A Couple Questions
  126. Nitrous in a Lx?
  127. Lower Grill DIY
  128. honda oem alarm help
  129. home made air freshener?
  130. Rear Upper Strut Bar Problem!
  131. engine question.
  132. How do i get the radio out of the dash?
  133. HEADER?
  134. VCN 1000
  135. wow this site Rules maybe you can help me?
  136. another question from the newbie
  137. blown shocks?
  138. OEM ALARM
  139. high pitched sound in my engine bay when car is not warmed up, what is it?
  140. need Help installing AEM Air Bypass.....
  141. 5w20 oil to thin for summer
  142. I cant find the DIY thread for shaving the emblems?
  143. Boxer sfc, vtec controller
  144. ATTN: Delacapmos....
  145. rims and calibrations
  146. resonator...with or without???
  147. OBX Strut and Sprayers, NEED HELP!
  148. Intakes for 2001 Civic LX??!?!?!?
  149. COMPUSTAR - Any problems ?
  150. do i need orange bulbs?
  151. does a bypass valve for an injen cai require cutting of the pipe?
  152. APC Hood?
  153. Matrix Projectors
  154. why spend $100 on Revo?
  155. anyone have nos on a EX
  156. Tap Into Fuse Box
  157. fog lights
  158. Remote starter for 5-speed???
  159. painting engine stuff.. need details
  160. maintenance lite blinks
  161. Interior power wire.
  162. how do you reset
  163. Stock Head Unit Light Question
  164. how low can i go?
  165. SRS reset... WHY?
  166. Center Pillars on Interior?
  167. Programable Siren?
  168. For those intere in SS and SS Adapter!!
  169. Fried Motherboard for blinker relay!!! need help!
  170. Weapon R Rear upper strut bar ?
  171. FULL CAT BACK Exhaust? / Chrome or Ceramic ?
  172. Quick question on Civic hoods.
  173. Computer chip????
  174. body molding??
  175. Seporating Streetglow wires
  176. How do you wire extra speakers?
  177. Cam for Dx?
  178. More HP?
  179. DIY flip/flop trunk !!!!!
  180. DIY sidemarker install???
  181. HYPERBLINKER on sedan,anyone?i tried but i failed
  182. when you put your springs in...
  183. ex to dx swap?
  184. What happened????
  185. where the diy hyperblinker for the ex
  186. [ Possible to use NSX auto-trannie's? ]
  187. Problems wiring to Ciggerete lighter
  188. AEM CAI, Problems???
  189. changing gear ratios on 5-speed?
  190. adding a tachometer
  191. problem w/my nos
  192. If you have a Type R shift knob on your Civic... HELP ME!!!
  193. Painting Spark Plug Cover, HELP!
  194. Camber?? Ground Control?? WTF
  195. black sh*t on the chrome (clearing headlights)
  196. trunk springs??
  197. Wiring question...
  198. ATTN: ToastyGhosty
  199. Paint bezel or visor. Does it reflect light ?
  200. shave emblems
  201. how to install euro tails!?
  202. can i change my spoiler
  203. Found unkown part...help?
  204. Regarding the "auto trans hack"...sorry guys
  205. Neon Tube Placement
  206. Taking out stock CD player??
  207. HELP ME CLEAR MY HEADLIGHTS!!!
  208. whells/springs Q's
  209. Intake NEED HELP!!!!
  210. When will the CAI become...
  211. front strut bars and intake fit
  212. cutting the AT stick?
  213. stock wheel weight?
  214. i need help with my nx kit!!!!!!!!!
  215. HELP!! Curbed My Rim!!!
  216. how low can i go
  217. Installing Hose kit on Lx sedan
  218. A/F Guage problems
  219. Apex-i Rev/Speed Meter
  220. Taking out inside roof?
  221. Stripped Screw
  222. 3 pc. racing hart damage
  223. Gauge Cluster Help!
  224. 4dr Tail Light installation help...
  225. raceing seats!!!
  226. Injen Race Division Installation
  227. EX head on LX?
  228. Grille Mesh Install???
  229. Ingalls rear vs. shimming
  230. SMOKE KIT ANYONE?
  231. ???Projector Help
  232. Just an FYI...Because it freaked me out !!
  233. What's the deal with the a/c DIY???
  234. Removing the stock headunit
  235. Concerns with HX lean-burn system
  236. finally completed my major mods.. can help if needed
  237. Wiring Harness
  238. Spinning Tires?
  239. Need help clearing headlights
  240. Tricked Trunk question
  241. Another Nitrous Question
  242. stuck front bumper!!!!!!!!!!!!!!!!!
  243. Attention all BC Members I need your help
  244. Front upper grille
  245. HOW MUCH WOULD A NX NITROUS INSTALLATION COST?
  246. air bypass valve
  247. Interior Help
  248. EXTERIOR PAINT
  249. Sealing DIY Headlights?
  250. to change automatic to manual
