- For those of you who have Plasma Coils - I need some info from the coil itself...
- Driver Window
- hid headlights
- odometer!
- Question on valve cover painting
- Z1 module
- Need a DIY:gauge cluster removal
- ebay scam +20 hp
- anyone want to help on a diy project with rear seat?
- 2003 headunit
- Naxos Xenon Blue
- Reupholstering seats?
- Kamikaze install problems
- Alchohol injection?
- engine diagram needed
- What parts do you take off/leave in the winter?
- Update On The Apex-i Vafc 2
- a/c compressor ???
- ok how much crap am i gonna get?
- which hose is this?
- How to remove sedan rear bumper?
- Blue light bulbs...
- OEM air filter box part #?
- autometer a/f gauge ?
- I need help with SRS light DIY
- speedo help
- what cars are slower then our civic
- Weight Loss?
- Black Headlights problem
- Intake and header dynamics
- hp 4-1 header for sale
- clutch/trans problem? maybe not
- Inyectors
- Heat Shield Removal???
- oem fog light switch
- JDM b18c in 99 EX?
- Intake came apart
- Antenna
- Autometer Tach hook-up question!
- strange plug on my dx in the engine compartment
- Plug in my engine compartment? whats it for
- What does a vaccuum gauge do?
- Weird annoying squeaking from tail light...
- What is REAL carbon fiber?
- painting emblems
- engine swap
- racing harness in a sedan?
- Halo connection? Yes I searched
- What are these red wires?
- a/f gauge how often is it suppose to....
- arguement against tinted windows
- Intakes and hydrolocking
- Car Service...
- Removing center console "?"
- Ex header on Lx fit?
- which iridium spark plugs ?
- How can something decrease torque but increase hp?
- neuspeed strut bar for manuals
- Sideskirt Tab
- who has a crank pulley ?
- Broken speedometer
- a question about the Apex VAFC2 question (100 point thing)
- EG Hatch Question..
- Installing Tsunami Front Bumper
- D17A Bore over
- what would i need to do to push more POWER outta my D17a2
- D16 intake manifold bolt up to a D17?
- Key lock pushed in?WTF
- Help w\ Hondawerx UKDM Folding Mirrors
- Poor gas milage new 2003 civic
- autometer gauges..
- Endyn Port and Polish info - PLUS camshaft question / info!
- Progress rear sway + Grey's endlinks problems
- immobilizer bypas module???
- Is your oil doing its job?
- door panel DIY (new pics)
- rear emblem removal and replacement .. easy?
- Painted chrome?
- Car won't start
- Help with K&N FIPK II installation
- IN TANK or IN LINE FUEL PUMP for RETURN Conversion
- Fuel System
- Oil filter issue
- AEM Pulley install
- Aem Short Ram Intake Install
- WTF is this Damn sound!
- painted pinstripe?
- Throttle Cable Help
- Intake Sounds and AEM V2 ?
- Need help working on halo projectors
- gas question...
- mandrel vs crush bending?
- Is it a resistor problem
- changing rear brake shoes
- New air filter shows big improvements
- k20a4 info needed
- Help from anyone with Helms manual
- Need Help Fast!!!!
- rsx fuel pump in a 7th gen?
- door handles?
- seamless speaker box diy
- Step 7 on Removing Rear Deck help ASAP
- what's this? B-Series?
- 2004 rear bumper on a 2002 civic???
- Wheel Bearings?
- Will cluster from auto tran fit manual tran car?
- Overhauling Tranny...
- Trunk Light?
- Anything other than hood pins?
- Should I be cautious of grounding kit?
- o2 sensor replacement.
- sidemarker help (wiring)
- sidemarker DIY (UPDATE!)
- adjusting headlamps
- Civic 2003 EX
- Installing a REVO . .question?
- Whitest parking and turn signal lights
- help!high beam not working
- RS Version Projector Headlights
- Slow Acceleration..
- doing 2003 Cluster swap to 2001 Car help: pin out needed
- My 2001 civic EX sedan
- Help with Decision with exhaust.
- Angel Eye Projector parking light prob..
- Hooking up PS2 to LCD
- em2 tranny
- Ceramic headers Vs Stainless
- Tyc + Hid
- Neuspeed Race...Does it matter
- xenon and goldlines..
- how bad is this? intake question
- typeS ecu in 01 civic
- Rsx type R engine Swap Air/fuel ratio sensor wiring.
- Removing trunk lid
- Strut bar and AEM?
- interior vinyl seating
- Angel Eye FINAL PICS (DIY soon)
- I need info on painting my body kit...
- Headers help
- Check Engine Light
- 2000 Civic DX Hatchback - alarm install
- o2 simulator HELP
- rvm crank pulley & aem pulley
- Front wheel alignment SPC camber bolt
- Ne'one here with Honda Club of the PI
- lowering the 2001 civic
- my battery shorted
- has anyone done a DIY for .....
- crush washer size?
- Aero kit + Tanabe RSpec
- how to install ebay intake?
- How do you remove....
- how to install lip kit????
- Interior what to do.
- alternating lights?
- 7G CAI for 5spd Cpe fit a 7G Auto Sedan?
- does any1 knows how to do hyper blinks in DIY?
- Seat swapping/adjusting
- Header Gascket...
- ground points rusting up
- Wow! Awesome info on 7th gen...
- sunroof concerns
- How do I install Grill?
- Fenders Same On 01 & 02?
- Trouble installing headlight for projector
- Factory Stereo Code
- Universal seat brackets and sliders (for those with aftermarket seats)
- Revo Ss
- change spark plugs? Pic
- my intake knocks on my strut bar
- Removing interior
- 03 Rear Upper Strut bar?
- ECG O2 Sim Diagram
- 4DR owners! HELP@!!!
- How to reset the ABS light
- painting body kit?
- performance chip?
- weird grinding noise when shifting
- adhesive to use for emblems?
- Painting valve cover/fuse box cover
- !!!!header question!!!!
- getting rust stains off of plastic bumper?
- So Cal Performance Garage
- Anybody have Civic Si seats in their 7th gen?
- Broken temp gauge!
- Civic Upgrades?? What comes first??
- Change in Clutch feather after street racing
- Noisy Belt
- Aftermarket Security Antenna
- cant get to bulb on projectors
- Stripped Header Bolt
- DIY: Red Gauge Needles (PICS!)
- help on removing pocket under stock headunit
- When jacking your car up...
- good place to buy short ram injen intake?
- How often to bleed clutch?
- every honda part you need...MUST SEE!!
- DIY: Angel Eye Repair
- vafc-2
- Replacing the fuse??
- Cam Gear Question
- TYC Projectors finally got moisture in them, suggestions?
- m3 mirrors
- replacement bulbs and touching?
- pinging - help!
- Air Conditioning ??
- 2001 EM to 2004 EM front conversion
- NOS ~ Whats Best for me??
- My cf hood is changing colors?
- HID lights
- Gauge mounted in air vent?
- VIS CF OEM hood
- Signs of bad gas?
- Need some quick help with cooling system
- Who using VAFC II or AFC II in RSX Type S.
- cam gear settings ?
- RSX rear bench latch?
- Does 03 center console fit 01 and 02?
- abs light in ex cluster?
- Suggestions on how to mold a panel?
- removing shifter console?
- gauge cluster mileage memory
- Taking off a few pieces for painting
- Denso Iridium Spark Plugs...
- Aftermarket lip fitment????
- coupe front speakers
- why is my car bad on gas?
- LED load equalizer install?
- air intake sensor ?
- remove maint required light ?
- A/C and defrost on an EP3
- Installed water temp gauge...
- HELP........aem cai.......... help with bypass valve
- Interior DIYs! lights, voltmeter (Tons of Pics)
- Service Light WTF
- Lingering minor problem...(acceleration wise)
- weird noise?
- ARE these spark plugs worth it????
- d17a2 engine swap into 95 hb
- which high flow cat ?
- Radiator Fan Switch
- whats wrong with my b+g?
- Invidia exhaust
- help painting headlights
- VAFC2/SAFC2 piggy back system?
- Hmm....I wonder....
- wher is the coil on these 7th Gens?
- Maintenance Tips needed
- How To Improve Acceleration?
