View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. fuel pump problems
  2. Fuel Signal
  3. two tachometers
  4. i need help fast this is serious PleasE
  5. wiring help please
  6. Have some ?'s about engine swap (not 7th gen vic related)
  7. Tsunami front bumper question
  8. projection head lights
  9. aem cam gears ! hookup
  10. Help My power door locks don't work!!!!!!!!!
  11. header question
  12. Fixed my exhaust-bumper problem...hope this ain't a repost
  13. Calculating 1/4 mile times.
  14. Altezza grill install
  15. Power Windows - Stock Parts
  16. Door won't close tight. Warranty Q?
  17. headlights question
  18. Will RSX parts fit 7thgens?
  19. Psuh Button Starter Igniton
  20. Just Shift Light
  21. aem cam gear cheap !
  22. cam gears?
  23. Headers: Stainless vs Ceramic...
  24. neons and fog switch?
  25. will this work?
  26. HELP - Clearing headlights at this moment!
  27. Carbon Fiber HELP
  28. Battery
  29. Chip For 01 Civic Ex
  30. Pep-boys Breather
  31. driving slow is bad for car!
  32. Front Bumper Question
  33. Condenser out!!!
  34. i need help really quick guys
  35. header for dx?
  36. blue led for alarm?
  37. removing ac and ps belts for racing ?
  38. Header Heat shield?
  39. cam shaft
  40. cam shaft
  41. how many miles can you go over after oil change request?!
  42. 99 accord headlight help
  43. alternator diagram
  44. which brake pads to buy?
  45. BIG tip on painting interior trim pieces!!!
  46. bulb color change
  47. oil pressue guage
  48. how to remove bulbs?
  49. Has any one ever tried...
  50. msd on 7th gen
  51. Longtime Since I've Posted
  52. Clearing TYC projector!?
  53. another dang guage question
  54. srs light
  55. how to paint silver trim piece around shift boot?
  56. ok.. last guage question
  57. RSX engine swap how to pull engine with minimal tools
  58. 98 accord tranny swap?
  59. cam gear install
  60. Acura HID
  61. header torque spec.
  62. aem sri
  63. timing belt?
  64. Cold air intake on HX
  65. K24 swaps
  66. Rear Lip Help!!!!
  67. Prototype Mugen digital instrument panel
  68. Custom Final drive ratio
  69. cold air intake
  70. how do i change my shift knob ?
  71. Bigger Injectors Q's
  72. Question?
  73. Which way does the coolant run through the radiator?
  74. HP racing
  75. Apexi World Sport Exhaust....
  76. Just got rear-ended. Help!
  77. Just got an oil change (used 10W40
  78. Install help
  79. ??
  80. e-brake BUTTON??
  81. Muffler shop make silencers?
  82. slave cylender???
  83. oil pan dent
  84. removing the outlet help!!!
  85. Turbo Charged V.S. Super Charged
  86. tightening trunk latch
  87. rear disk conversion
  88. rear strut brace install????
  89. Quick 12v question
  90. Torsion bars for aftermarket speakers?
  91. Weird... 92 Octane really does help us...
  92. civic si sway bars better ?
  93. Popping out a dent
  94. Hi Help Plz
  95. Revo Technica Short Shifter and RSX Shift knob
  96. Thermal and HKS rear section
  97. Turn signals
  98. vinyl decal tips?
  99. Indiglos making a high pitched noise somewhere
  100. 7th gen recall for ignition?
  101. Windshield Crack
  102. cranking sound?
  103. Where can I find Kamikase header?
  104. Where I can get part numbers for my car?
  105. Sidemarker direction
  106. Will Intake....
  107. Exhaust question
  108. help pls. asap.
  109. Installing indiglo
  110. HEader question
  111. DIY LED Gauge swap
  112. Need a new radiator, Which one?
  113. srs light w/ rsx seats
  114. DIY: o2 simulator *updated with 7thgen instructions*
  115. Help On Replacing Wheel Stud?
  116. throttle body
  117. HELP.. emrgency brake problem
  118. HALO altezza
  119. remote start
  120. Head Porting for beginers
  121. shift grinding
  122. 120 octane in a civic...
  123. trunk remote?
  124. Wings West G5 Lip Install Help!
  125. Just changed tranny fluid!
  126. do projector light come with harness?
  127. Civic Exhaust
  128. s2000 seats in 03 coupe.
  129. header rattle?
  130. Body Kit Question
  131. tint paint touch up?
  132. B series motor help
  133. check engine
  134. wheel creak
  135. Rsx piping
  136. e-bay intake problem :(
  137. ebay intake&throttle body spacer ?
  138. ECU swapping??
  139. o2 sensor bung
  140. removing stock intake box?
  141. street glow help
  142. rs grill
  143. Type A lip kit install...some general questions
  144. sidemarker install help
  145. IAC strange sound
  146. How Do You Align Headlight Beam?
  147. relocating engine bar
  148. whinning noise??
  149. Wasting Gas?
  150. D17 interchangeability
  151. installed OEM kit on sedan!
  152. My intake goes woo woo
  153. Sensor Question
  154. What to swap manual door locks
  155. Crashed-Suspension @$#%
  156. Header question-need quick answer
  157. Ceramic paint additive as insulation?
  158. NOS Jetting Sizes?
  159. sidemarker wiring
  160. Just to make sure I get this right...
  161. HELP: Need help, problem with car
  162. air bags...
  163. Aem V2
  164. o2 sensor
  165. engine noise when i shut off
  166. removing nuts on rear strut towers?
  167. HP header
  168. how to tell which wire is which in ECU?
  169. 2 pulse tach hookup
  170. ???
  171. Moisture in headlights???
  172. Both CAI and SRI?
  173. how do you take the plastic out the 01 front bumber?
  174. how to make clear taillights black???
  175. Altezzas and Projector headlamps
  176. Any way to reset the odometer?pls help
  177. Gutting the CAT
  178. DX cluster upgrades FAQ.
  179. HP Racing header
  180. New Angel Eye Question
  181. Questions about stripped lug bolt
  182. header is glowing! ahh
  183. Ram air intake
  184. Whats next in the performance department?
  185. where to buy clutch ?
  186. more performance needed !
  187. The Splash Guard shield for the engine? Fell off...
  188. Clearing headlight ??'s
  189. quick ? about hyperblinker DIY
  190. engine type
  191. stock battery life
  192. aem pulleys HELP!!!!!
  193. weird noise when driving
  194. Replacing Axle
  195. WW G5 Rear Lip (vs.) GReddy EVO
  196. Anyone Know What These Are?? (JDM Headlights)
  197. weight reduction ?
  198. plasma booster for 7thgen ?
  199. Cluster Upgrade
  200. techy question
  201. Blown bulbs *weird*
  202. HALO ALTEZZA's
  203. Reset ecu = bad gas mileage
  204. 7thGEN civic conversions!
  205. fuel pressure regulator vacuum line ?
  206. Glasspack as a resonator?
  207. DIY: Return Style Fuel System Conversion
  208. Painting Altezza's
  209. Question about tightening suspension around turns
  210. Streetglow DIY (UPDATED PICS)
  211. laptop into the ecu?
  212. IAT sensor question
  213. Does modifying the engine affect the longevity of the car?
  214. DH-Racing crank pulley question?
  215. intake manifold vs stock port and polish
  216. cam shaft ?
  217. AEM Cold Air Intake question
  218. Help!!!!!
  219. Does The vtec controller actully work?
  220. Mileage and Wheel Size?
  221. engine surging
  222. Just installed vtec indicator led...
  223. auto to manual look conviersion
  224. Fixed the play in my revo SS
  225. Need a good parts supplier tell me yours
  226. clutch problem
  227. HID + Projectors = POSSIBLE?!?
  228. High compression
  229. Headers
  230. warming up engine!
  231. would revo short shifter solve popping out of 2nd gear?
  232. question about interior lighting...
  233. Stock exhaust question
  234. Oil presure gauge sending unit.
  235. DIY: ATF Change
  236. Touch Window Switch
  237. Auto Down Passenger Window (Coupe)???
  238. DIY flaming exhaust?
  239. cutting perfect circles for sub box
  240. DIY: Power Steering fluid change
  241. Mounting an XBOX in the trunk.
  242. Aem Pulleys
  243. milage
  244. 6000 Miles on Synthetic
  245. installing RSX rear sway bar question
  246. gsr motor
  247. DC Sports 4-1 1 piece stainless header... and gasket...?
  248. Installing tenzo seats
  249. Exhaust diameter vs Volume
  250. V-AFC II settings
