View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Paint and home depot...
  2. New Idea for Coupe Mod
  3. Contac info and job #'s for internals plz
  4. DIY Air filter replacement
  5. Injen RD for AT MT
  6. best way to remove?
  7. Help!! Steering Wheel Swap!!
  8. oil
  9. Clearing Headlights - Removing Bumper
  10. Relocating Stock Ground Wires
  11. DIY: Steering wheel removal and MOMO wheel install
  12. adjust ignition timming
  13. I need help
  14. Smooth Shifting....
  15. 95 Talon BOV DIY?!?!?
  16. PB Blaster + Water = ?????
  17. help with aem cai install
  18. Intake patch question...
  19. rev-matching
  20. creak after installin fipk II
  21. Starter Swtich Help ASAP!
  22. Need a DIY. I'm a newbie!
  23. nice paint need help?
  24. Paint & VIN # (Solved)
  25. found an extra part in my engine bay?? help!
  26. Intake with stock fuel lines.
  27. Stock cat size
  28. Are There Reverse Gauges For Dx?
  29. high volume fuel
  30. headers
  31. 2001 EX - oil splatter underneath hood
  32. Horn Relay
  33. Standard ATO Fuses or Mini Fuses?
  34. jdm Integra wheel...
  35. sidemarker wiring question
  36. Aem intake problems: shakes, and clutch line
  37. K20 swap Q
  38. Your An Axle!!!!!!
  39. 02' center console swap in to 01'
  40. Double Sided Tape!
  41. Hose Question... Someone help me out
  42. can a amp blow an altnator?
  43. cf hood cracked
  44. STR cam gear
  45. DYI - Dying stock seats two tone
  46. Can anyone tell me......
  47. AEM CAI filter question
  48. service manuals
  49. headlight bulbs
  50. SRS light Honda FIX!!!
  51. OEM Spoiler lightbulb size
  52. Best Exhaust/Intake MAKE STICKY!!!!!!!
  53. Problem with shifters break relay
  54. Like Copz...
  55. CF Hood in winter
  56. Need help correcting timing
  57. Denso Iridium spark plugs
  58. Returning to stock
  59. need help with install header
  60. Racing Seats
  61. Will it match?
  62. CVT transmission in an LX?
  63. 24,500 miles, What kind of oil now?
  64. clicking or creaking question... help!!!
  65. Relocating ignition start???
  66. body kit issue
  67. Throttle body spacer and SRA AEM
  68. no power steering
  69. Need pics of flip flop trunk (DIY)
  70. question about paint and clearcoat
  71. modifying urethane body kit
  72. at/mt aftermarket intake?
  73. 6th gen swap
  74. RSX Type-S Gauge Bezel
  75. what kinda paint should i use?!?!
  76. Short Air Intake
  77. my short ram intake is pelling off!!!
  78. need help a.s.a.p. - drilling gas pedal
  79. how in the hell do i get to my headlight switch?
  80. Too much oil....
  81. header or nitrous?
  82. SRI question
  83. Diamond Plate Floor Mats
  84. To need or not to need hood pins?
  85. AC power for your civic?
  86. stock spark plugs
  87. aiming stock headlights higher?
  88. S2000 engine push start DIY
  89. Dc Strut Bar Problem
  90. replacing all stock lights with LED's..
  91. intake for lx auto
  92. stock clutch and flywheel
  93. Fuse blown?
  94. Angel Eye Projector: Beam pattern
  95. upgrade my Tranny
  96. can't get the oil pan plug out!!!
  97. Help
  98. Wiring HELP!!!!
  99. ? about UUP(unorthodox underdrive pulleys)
  100. 03 coupe ebrake
  101. 03 Dash removal impossible?
  102. Wire go from hood to interior. HOW?
  103. Whats the Color of 03 dash lights?
  104. k20a oil
  105. ex cluster into dx?
  106. foggy light arhggg!!!!!
  107. JDM RS grill
  108. Headers...!
  109. EX Head on Non-Vtec Block.
  110. shaving roof gutter
  111. Water in my Cold Air Intake!!!
  112. water in engine
  113. OEM Parts
  114. air intake -for ram air hood
  115. what happens if i ......
  116. Removing 2003 center console
  117. light beams high/low....
  118. Painting engine head
  119. question about 03 ex vtec...
  120. howdo i install a casper o2 sim
  121. RS Lip Install Instructions
  122. does any one know?
  123. another stupid & fast CAI question?
  124. How do I take these things off?
  125. Engine
  126. valve cover torque
  127. o2 Sim...
  128. Used AEM Intake Good or Bad?
  129. What parts to use for HX?
  130. Stock Exhaust Pipe Size
  131. i need help bad
  132. Will 03 si guage cluster swap with 03 lx???
  133. cel header
  134. shaved emblems...
  135. 02 si axle question for swap
  136. how do o2 sensors work?
  137. anyone wann help?
  138. power steering
  139. Article on intakes
  140. Timing Belt Change Questions
  141. Body Shells
  142. Cutting the Shift Bar
  143. Molding ABS Plastic
  144. Rsx Type S Seats..?
  145. i need HELP with my exhaust
  146. A'PEXi Digital AFC V.S A'Pexi V-AFC ....?
  147. spanked by a eclipse?
  148. can you pull the gov...?
  149. Injen Race Division CAI
  150. Horsepower Gain's
  151. Header install.. quick ?
  152. i found an ECU programmer heheheh!!!
  153. civic exhaust on volvo?
  154. POWER steering removal.....
  155. 1.7el kit on a 7thgen?
  156. 50hp gain?
  157. Accord 2003 Coupe "5 Lug"
  158. DIY: Cruise Control Relocation
  159. how did you get it out?
  160. Steering problem on '02 Civic? Please help.
  161. help the winner??
  162. RSX headlight conversion?
  163. Does tilitng the sunroof open increase downforce?
  164. motor mounts
  165. Tweed
  166. Dash lights not working!!Please Help
  167. Problems with SRS light
  168. installing a new stereo
  169. Bypass valve for injen intake
  170. shift boot attaching to new knob?!
  171. check engine light
  172. Help with Injen CAI install
  173. what paint to use.......
  174. removing glove box (yes i know im an extreme noob)
  175. DX with no tach... We got to stop that!
  176. UPDATE* de-winging my car
  177. 02 simulator
  178. EX head conversion....?
  179. Will RSX-s exhaust fit?
  180. Code Alarm
  181. carbon fiber wholesale ??
  182. next mod ?
  183. under idling, please help
  184. removing trim pieces?
  185. How bad is it to rev your car
  186. Egr?
  187. Aem Cai??
  188. dimming dash guages
  189. Question on painting interior pieces
  190. Headlight Clearing Question
  191. Gas Question
  192. is this worth $60 ?
  193. k&n filter vs heatshield filter
  194. DIY: Make SRS light gone without airbag install ( racing steeringwheel )
  195. kms install question
  196. v-tech convertion
  197. is this good ?
  198. Mounting Fiberglass Bumper
  199. Header install help....
  200. Bypass Valve on DX Intake
  201. whats an O2 simulator
  202. Can I connect the pos. of my LED washers here..
  203. Is this where the fog lights go?
  204. Any Suggestions or Answers>>??
  205. running car w/o 02 sensor?
  206. gear ratios??
  207. aiming washers
  208. Honda OEM Brake Pads
  209. where to buy this........
  210. need help???
  211. stock downpipe size
  212. fuel pump
  213. Garage door opener?
  214. The Little Bolt That Could
  215. correct way to drive with Nitrous...
  216. painting the headlights black
  217. how do you paint a grill?
  218. anyone change pads on a ford ranger?
  219. removing factory hood prop?
  220. OEM civic keyless entry
  221. New windshield wipers???
  222. Front axle noise???
  223. nitrous windowswitch
  224. Yet another "paint your headlights black" question...
  225. Which sensor monitors heat?
  226. where is the temperature switch in my 95 civic dx hatch -
  227. AEM intake
  228. help with S2000 pust start ignition button
  229. Concern about our oil system...
  230. I need a confirmation of my thoughts on removing valve cover issues...
  231. Belt Noises
  232. Drag Racing X-mas Tree
  233. Body Kit Installation Question
  234. Anyone know how much HP the stock axles can take?
  235. Several ?'s about Rust and Jacks
  236. 5w-20 oil - Necessary or Recommended?
  237. double clutch....Good or Bad?!?!
  238. Engine shaking?
  239. how is this kinda dash done?
  240. problem with the vcn1000 kit
  241. Mid pipe, B pipe question?
  242. Pop Trunk ? Impossible?
  243. Venom in my A/F ?!?
  244. cd player
  245. Clearing Sedan Headlights...
  246. Hydrolocking
  247. HP Header Problem!
  248. needle color on gague cluster
  249. Owners of a Kaminari Rear Skirt!
  250. 2004 civic
