- What is the redline of a D17.....
- Does bigger piping increse or decrease the hp in 02 lx?
- Can I change the shifter on the auto?
- m3 side mirrors...
- Bumper Removal
- What Aftermarket clutch u got?
- Help Find these Parts
- torque converter
- how many HP do u lose with A/C on?!?
- Better refrigerant for your AC
- ECU OBD Location?
- is the inner fender plastic stuff needed?
- Installin Tailights
- ECU signal for fuel and temp...?
- Headers
- outside lense of headlight..
- Throttle Body Boring?
- got my new civic finally..
- For those with after market steering wheel.................HELP!!
- downpipes
- Cut off
- Mobil 1 Prevents Engine Wear?????
- K20 engine
- Has anyone here replaced an alt before?
- Seat brackets???
- quick question about new bulb headlight install
- cam gear
- Time frame for clearing headlights
- TRans Question
- how to make fiberglass
- Going to install the Top Speed Header w/High Flow Cat!
- Angel eye projector problem
- Increased Exhaust Piping (2.25")
- transmission
- help with tucking fender lip
- Sanding
- Tsunami T2001 front grill question
- Oil Pressure Gauge
- What kinda engine is the new 2k3 civic coupe?
- o2 Simulator?
- Any B series transplants
- Differential Dimensions
- Cruise Control not controlin?
- Octane Front Q's???
- How do I.....
- more hood questions
- Can I take this apart??
- confusing about engine oil
- stock B-series motor in an LS integra
- Blinker Speed Question
- where is the belt tensioner
- ViS Vader Hood......
- Hydraulic Clutch Removal?
- I know someone has probably asked this a 100 times but I'm new to the honda world
- O2 Sim = Lose or Regain Power???
- My emblem fell off
- guage cluster swap for dx
- touch up paint
- Somebody please help (installing pedals)
- ECU OBD 2 Command Question...
- Rusty Sparkplug Sleeve = ?
- Help!! Melting bumper!! (pics)
- Engine Reboring?
- Custom Hood Scoop?
- How much to paint?
- o2 sim.
- Top Speed Header/High Flow Cat Install TODAY!!
- Revo Short Shifter for SI 2000?
- How do you get to the crank shaft pulley?
- How much would a VTEC head cost
- rewired taillamps??
- Lightest Material for Sub Box?
- do pullies really do anything ?
- Resealing headlights
- exhaust question
- Tech engine question
- Cold Car???????
- DIY fiberglass instructions w/pics
- Need a little help
- Interior paint to match the dash
- Best/easiest way to jack car for exhaust install?
- Tachometer help!
- if we got intake manifolds...
- is it possible to mold...
- headlight harness
- WTF...i can't get the a/f gauge to work
- exhaust
- M3 Mirror Question Having to do with Stock bolts!!!
- How does your exhaust fit under your rear body kit/lip? ie: xenon..
- **Need Help** Oil Temp Sensor
- anyone have a diy for adjusting valves and replacing the timing belt?
- Clear TYC Projections
- How do you paint body parts?
- i need 03 civic info
- Help my brother out with a question
- Momo Diy Installs
- motor mounts
- Removing the front grill.
- Tach not lighting up!
- Door Lock Question?
- how can i make it not rattle...
- HID in stock
- HID conversion
- stock guage cluster wiring.
- Halo-Ring Issues
- Removing stock headunit (read DIY)
- throttle body rattling
- MOMO Steel Wings
- high wattaged bulbs
- spark plugs Q
- 2001 Non-VTEC Any Potiential
- sleeving the D17??
- Anyone relocate their ignition key location?
- Compression ratio? what is that?
- Relocating the battery
- no more color change in tyc's after mtecs
- Good Place to Ground Wire??
- k20 help
- DIY sedan door leather insert+cheap deadening
- MOMO Steel Wings Update
- Red Line
- 02 Si/Sir Seats in a 7th Gen Civic?
- Do you believe that this will work in our EX's.....?
- Need Help Asap Vacuum Guage
- What is a B-Pipe?
- lower grill removal DIY
- power windows
- Eurolite underdody neons
- center console removal for automatic
- DIY Brake Drums?
- Stock Headlights
- transmission guru's
- DIY: Techometer?
- age old question
- How do i take off side door panel?
- removal of rear seats
- Si/SiR side panel swap
- any internals out for our cars yet ?
- SF kit- vafc settings?
- License Lamp Switch?
- Warranty Blues
- TYC Projectors Question (HID)
- Sound?>_<
- has anyone painted the OEM mirrors?!?
- installing new carpet
- radiator fans wont come on
- RSX 6 spd tranny in 7thgen?
- Fans on a switch?
- 02 coupe EX front bumper OEM
- Tuning K20 Engine?
- crank pulley !!!!!
- Air/Fuel guage install...HELP!?!?!?
- wiring rear turn signal lights to stay on
- Apexi V-AFC II and Non-VTEC?
- Dose SI 03 rear seat Fit our 7thgen???
- Gauge Cluster Wiring
- Yet Another HID question...
- fuel system info.
- install flywheel
- VTEC button?
- Can i change oil filter without changing oil
- Ground Wire?
- diy a/c control relocate
- Will an rsx akle-back bolt up???
- CAI rubbing strut bar
- 3rd brake light
- day time running lights???
- Wiring harness
- Interior Painting
- Vtec cover
- Body kit installation question
- good cam gear yet????
- v6 accord engine
- Reseting SRS Light.....
- Im An Idiot!!!!!!
- another O2 simulator
- taken care of
- Muffler
- SPOLIER INSTALL?????
- Water Temp gauge
- Cold air intake help
- windows
- SRS light on after RSX-S seats swapped...
- rsx sway and dc tcs
- Aem Pullies (searched for 2 hours)
- Auto Civic Performance HELP
- Zex Kit
- Electric turbo
- paint codes
- Timing
- Hp Gains!!
- anyone with a helms book help?
- Header Controversy
- coupe spoiler
- how many resonators????
- Denso doesn't have an iridium app?
- S2000 steering wheel
- Gains from synthetic oil?
- MOMO Steering Wheel Installed
- MOMO Shift Knob and Boot Installed
- MOMO E-Brake Installed
- I/H/E Hp gains
- maint. required light?
- turbo timer problem
- Reset the ecu, check engine light still comes on.
- simple NITROUS question?!?!
- Honda Civic Firewall
- finding carpet for my car
- cruise control
- Variable Capacitor
- removing center console in 03 EX
- 5 Speed Remote Start Safety
- Maint Rq. Light
- Inconsistent Temperature
- About a manual swap...
- How to install a whistle??
- Catalytic Converter
- How do you replace the gear knob on the 2003 Civic
- CLutch making popping sound
- converting to manual
- high flow cat question
- searching...
- changing ignition wires on 02EX Atuo?
- Valve Adjustment: I need details...
- Driving in D3 for 1hour
- spark plugs
- 3.7 Quarts of Oil or 4.4??
- cold water on hot brake disc
- absorber
- can u turn a Lx into an EX? (aka, make it into a V-tec
- effect of rear spoiler
- can't find DIY...
- instrument cluster swap?
- taking off body kit (lips) for the winter
- Question about radiator hose
- Neon electrical question
- stock spring install question?
- engine swap or turbo?
- Helix Tower Power Plus???!!!!
- driver and passenger window removal for tinting?
- how to make a mesh grill?
- Maintance Req Light
- how to make windows roll up faster
- ECU Software?
- driving with handbrake pulled
- HID's for 03 civic
- HELP!!! Having problems mouting underbody neons...
- need help finding sensor
- rev limiter
- Howd you mount your Kit?
