- how do you put on injen heat shield on filter
- Right Hand Drive
- Exhaust Smell
- NOS and Our cars
- puttin my laptop in the glove compart. need help
- burnt gasket, backfire, stripped threads.. hmm. lil help. lol
- Lip Bracket
- Changing Headlights...
- Painting Trim... Need Help
- it's funny. haven't you noticed when you're driving w/the AC on...
- SRS light question
- AEM Replacement Air Filter?
- how do you remove 3m double sided tape?
- Venom 400 Installation
- I'm approaching 20K and haven't had any service done besides oil changing...
- DIY Seat Install????
- ECU question?
- Removing the parking brake?
- Block pic
- Exhaust System Question
- CAI or SRI??
- rsx sway/evo cat combo
- DIY: Carbon Fiber Hood Install
- aem cai manual
- DIY: Hood Pins Install
- Opening Tailights
- Wings West G5 Rear
- removing gas door
- auto for std tranny swap??
- Pulling out timing?
- Gauges sticking, please help!
- help again
- cold air intake
- what kind of 4 point harness
- Q: Venom ECU and NX nitrous...?!?!
- Will an RSX Type S Head fit our engines?
- Mileage question
- need DIY for automatic shift boot
- m3 mirrors
- do i need any special tools?
- e-brake handle removal
- Rev Limiter Removal Or Extention
- Torque on DC Sports TCS Exhaust
- Fans
- has anyone changed out there seats?
- Opening Taillights?
- D17A2 swap question
- Which Helm service manual do I need?
- pillar gauge pods... how to?
- retail of stock EX seats
- anyone kow how to change door fabric of a sedan?
- 2k2clutch into 99si?
- keypad ignition
- How to install Type B front lip (pics)
- 2 questions
- So Are 7440's illegal?
- do our cars have this
- Major tune up project
- CAI and Water
- Intake mod
- flip flop trunk gas struts?
- Can a "Universal muffler" be modified into a mendrel bend exhaust?
- Injen cai
- Ecu
- INTAKE differences
- Oil temp gauge?
- Suggestions on exhaust setup....???....
- Fan Dimensions?
- DIY: A'PEXi Rev/Speed Meter Install
- XENON Side skirts
- how much HP do you think i have?
- power source???
- VTEC set in?
- parking bulbs to match H4 sylvannia silverstars
- Dyno on a laptop
- ok to not run 02 sim?
- Transmission Gone OR CLutch GONE? HELP!!
- ECU Chips
- A HID Question
- Wire through firewall?
- HELP!!!! altezza grills install
- Painting Atezza tailights
- How to install shorty header?
- 03 Cluster Swap into 02
- leather installation
- 03 JDM CIVIC Type R steering wheel fit in my 02 civic ?
- Rattling in the engine
- how do we remove this piece for sedan?
- 01+ Honda Civic Spoon Sports Rear Strut Tower Bar
- Anyone have a DIY to change steering wheels
- Fiberglass or Urethane
- might clear heads in a second, need a lil info
- CF hood
- M3 Mirrors Install?
- AEM brake pad problems
- Quick foglight help.....
- No more cracked/broken Fog's
- Removing Windsheild Washer System
- I Need Your Help
- catalytic converter
- What's the Difference
- is this dyno correct
- CF hood won't lock into place
- Hey Guy`s , I Need Your Help , Thanks !
- Installing RAZO RA89 auto shifter, please help!
- Exhaust back pressure
- O2 sensor
- Headers
- 3 O2 Sensors on a D17A6!!?
- paint ratio measuring cup
- The K20 Questions
- Ebay cold air intake, can I follow the DIY for it?
- DRL
- apexi v-afc
- civic si radiator
- RSX 5 lug conversion with rear disks
- Will I Get Dominated?
- Leather Installs
- cheap and fast
- B-series question.....
- V-AFC Vti on/off?
- ECG O2 Sim
- Required 4 YOU!!!
- wiring question? help quick!!
- BOOM!!
- Advanced Impurt Tuning
- exhaust probs
- cleaning filter?
- Help!!!!
- skirt install??
- can you take
- throttle linkage DIY'ers, quick question...
- 2003 Maintenance Light?
- Header from NOPI
- interior change
- Urgent: KDC Mirrors!
- Is this normal with a 7th Gen Civic?
- Fuel Injector cleaners...?
- Opened hazard switch pictures??
- what do u think
- Dent Wizard/ding King?
- Ecu k20 question
- Intake
- Right way to increase idle?
- Nirtous Bottle
- how do i ajust my headlight (projector)
- battery question
- did AEM cam gear work a lot
- Speed sensor location
- revo technica instal
- Trim DIY?
- Exterior
- bomex mirror... wiring help!
- B4 i get started
- Wanna Go Manual From Auto
- Idea #1
- making a kit
- lower grill question
- those with kamikaze or hp header
- Where's the stock temp sensor?
- drilling thru RAZO pedal
- Head Light Wiring Question
- i have a question!!
- temporary solution to cleared headlights
- DIY water temp guage?
- How to wear out a pressure plate?
- which iridiums????
- Grille Craft Front Upper Grille
- Neons and relays and parklights oh my - HELP PLEASE
- universal mufflers... any difference?
- DIY Throttle body heater bypass
- Do I have to use the donut gasket when installing a shorty header?
- Smoke rising from newly installed header?
- projectors broke! help!
- I made my own "Ground Wire Kit"
- Is this worthy of a DIY?
- intake question? did a search!
- how do i remove that plastic around the shift?
- find these 2 wires
- OEM fog light problem
- e-brake change in 03 coupe M/T
- cutting head cylinder
- rear disc break conversion
- ECU upgrade for the civic DX yes or no?
- header and exhaust for the dx
- ACT Clutch Problem
- Help!!!!
- Car shakes when A/C on
- univeral muffler choices
- standalone
- Has Anybody opened up their taillight assembly?
- RSX 5spd Shift Mechanism
- Injen Installation HELP ME
- Installing new seats, need help...............
- head and tailight problem..
- how do u get your headlights out
- HELP with Tail Light / Rear Bumper
- hid install
- what is the use of a resonator???
- Subwoffer question
- For Members Already Done With K20 Swap
- Head Torque Specs Plzzzzzzzzzzzz!!!
- DIY : air filter replacment
- diy : throttle plate adjustment
- Exhaust Hitting Sway Bar, How To Fix????
- Made my own ground kit! Woohoo! W/pics...
- Skeleton Key?
- What is the voltage range of..
- Needle removal..
- **help**projectors might be broken.
- side airbag light w/ racing seats
- help! paint my oem headlights
- Anyone know?
- alternating parking and turn signal bulbs
- Vibration
- Help with Razo Up shift indicator. What setting to put at?
- evo exhaust and progress rear sway? need help!!
- need help on revo short shifter ASAP
- NEED HELP!!!!! S-AFC and GEAR PROBLEM
- Removing Interior Roof Panel?
- Aem Pulleys does anybody have a problem with them ?
- bulb - headlight
- digital rpm and speedo led readout
- friend put a dent in my hood
- zc?
- DIY Rear Bumper
- sliding ragtop
- Should I get bigger piping for my exhaust, or get cams and pulleys?
- JB Weld = Good
- Blue LED Gauge Swap complete
- engine questions..(noob questions)
- question about watershield layer
- hood pins needed?
- Where can I buy a SCS Service Connector?
- VTEC conversion
- DIY for Revo SS
- Connecting Rods
- oil
- K20A vs. K20A2 --> (differences?)
- Help My Car Wont Start!
- Opening up a Tanabe a lil' bit
- Need help finding the right main bearing....
- heatshield
- Help w/ TYC Projectors
- fogging
- what's a brake booster?
- automatic transmission shift point changeer thing
- car problem HELP!!
