- Condenstaion In Halos!!!
- exhaust help???
- which cam?!
- DIY Air/Fuel Gauge
- Boring the Throttle body
- Challenge for all DIY gurus (attn: Grey!): one-touch moonroof open/close
- Dyi for hp header??
- Projector HID Conversion
- Autometer A-Pillar pod
- 2000 si ecu chip work on 7th gen ??
- vibrant axle back~
- Throttle Cable Adjustment Help!!!
- Power Windows DIY yet for the DX?
- Piston specs?
- none vtec to vtec
- Warranty question
- INSTALLING ANGEL EYES
- CAI, Hydrolock, details?
- ANGEL EYES
- 2001 civic fan & radiator
- Need Help On Removing Back Seats?
- Need info on HID's
- DCsport header with my setup? Opinions needed
- DIY for gas trunk shocks.. Mex's style
- rebuilding the transaxle
- 1993 MB 300e
- How hard is it to retro fit Audi A6 Projectors in to Halo Projectors?
- UNDERDRIVE PULLY Help!!
- EMERGENCY HELP!!!!!!!!
- shaving handles
- odometer fraud
- Camshaft from d16 work on d17?
- Mugen EK civic front lip
- help with header fast
- splash guards 2dr = 4dr?
- Replacing SRI Air Filter?...
- Help with Painting Trim Pieces
- DIY VTEC Light 2?...
- Ive got a weird question
- alternator?
- answer
- Gauge Needles Sticking
- Need help on removing silencer out of exhaust! Tried everything!
- To the people who have installed Revo, OBX.....HELP!
- OEM BODY KIT QUESTION
- LED BULBS ON SPOILER
- Wet Filter Type vs Dry Filter Type...
- cleaning out fuel tank?
- to all those with DIY "How To Paint Trim Pieces"
- SENSOR NEAR INTAKE
- Engine Swap (RSX-s) Question...
- Altezza grill question
- trim pice ?
- my smoking AC, wft happend?
- MAKE STICKY!! DIY REAL ALTEZZA UPPER GRILL
- DIY: DX OWNERS, HEADS UP! POWER LOCKS!
- Front Hub Removal????
- Open Pod Monster Flow Air Filter
- Clutch Install?
- Gauge Cluster Removal...
- O2 simulater for Kamikaze header
- Electrical load
- Need some help finding the right wire....
- Draining the cooling system
- Drain bolt for automatic tranny fluid (ATF) change?
- Octane sides help!
- trading in my car..questions
- How do you center the steering wheel?
- Fox Whistle/ Alarm Siren
- OEM foglight kit and under spoiler compatible on '03?
- tranny help
- Fog Light Install
- tranny question
- problem with shap turns
- Question about painting trim pieces
- Kamikaze head/Magnaflow catback
- diy/aem pulleys
- muffler...
- How to remove upper bolt when changing radiator coolant?
- Clearance issues?
- Re-Painting Trim Pieces
- Glow Kit???Any Idea???
- trunk springs
- ummm... ok. i cant tell if this is a rice liar or not, but it sounds good...
- RSX intake into Civic EX?
- Alot of questions Please help
- Axle nut problem (HELP!!!)
- street glow UB kit, how do you install the sides?
- Painting guage bracket?
- Help w/ Voltmeter Install
- Diff. year, same intake ?
- Diff. Brands of Indiglo Gauges...
- after intake manifold - upgrading fuel system
- NX kit Installed and running?
- Rear SI Brake Swap
- maintenance req. light?
- black housing lights
- need help with NOS AND V-AFC
- Help with reverse glow gauges!
- DIY EVO look alike
- What the best brakes pads?
- I DID IT, Thanks all for the advice
- Adjusting rear camber w/out camber it?!
- spoon's EK civic kevlar Direct flow pipe
- shifting an auto :p much wear?
- haha RSX intake in my Civic *now w/ pic*
- Grill/rad. cover help...
- License Plate
- AEM CAI & 1/2 a CAI (SRI) speculation.
- What kind of ATF should I use??
- Gauge wiring question
- How do you recharge filter?
- Anyone know 95 Eagle Talon n/a motor code?
- Injen SRI DIY?
- RXS Type S muffler fit on '01+ Civic coupe?
- Seat brackets?
- Regarding new headlights
- does anyone have pics of...
- Maintence Required
- Intake, Header, Exhaust
- rsx-2 engine on ebay
- AEM intake vs V2 intake
- 2002 EX Interior Questions
- single windshield wiper blade???
- speed limiter
- honda gave me a datarecorder...
- A question for anybody that has dx with swapped cluster....
- DIY side skirts
- problem clearing lights. PLEASE HELP FAST!
- Stained glass or Vinyl?
- Changing Manual Transmission Fluid DIY and Micron Filter DIY ?? DIY's needed
- Dripping Water Under Car????
- DIY: Gas Door Lightening
- HELP ME PLEASE!!! alarms
- Extending Intake Sensor Wire?
- magna flow muffler rattles..help!
- Cooling fan switch
- B18 in a 7th gen
- ATTN: H4 HID Owners
- Keyless Entry Won't Work
- apexi auto timer
- what the best strut bars?
- 92 bmw corner lights?
- Gauge cluster lighting question.......
- Taking off trim on the hood
- Maint. Light came on?
- HID ?'s
- How hard is it to remove gauges?
- DIY Reverse Indiglo Install help
- Just installed a Injen RD CAI
- Burn hole in the clear plastic gauge cover
- Big updates to my DIY fog light install
- Lambo style doors?
- Installing Parking lights?
- side skirt is falling off
- Custom Catback
- Clearing S2000 Headlights
- please help fast!!
- Clearing headlights using oven
- INtake removal
- Cheaper Lambo door kit?! will it work?
- INtake filter
- VAFC and o2 sim
- installing kaminari side skirts and rear lip
- Valve cover difference
- Modifying TYC's?
- silver housing headlights??
- Oil Change
- Struts for hood any help.
- Question about trunk lid.
- does anyone know how?
- Need lightbulbs
- Help with Bolt on Header!!!!
- DIY: Connecting your Halo/Angel eye
- How to Check Code for Check Engine Light
- Full HID Conversion
- kinda unique tach question
- Shift light without Tach
- Problem w/ Clearing Headlights
- Throttle Bearing
- Flip-Flop trunk question....
- Do not know if this is NORMAL!
- Help. Problems with starting car!
- Erratic Fuel Guage?
- paint interior plastics
- Best way to get to PCV valve on 96 Civic?
- help wit exhaust`
- RSX-S sway bar
- PLASTIKOTE VINYL PAINT
- Another Question about Clearing Headlights?? (Not a repost)
- HELP!!! Transaxle removal instructions
- HELP Rear brakes
- need diy on hid
- Taking off Mirrors...
- How easy is RSX seat swap?
- DIY: Turn your Headlight to Blue Color
- Flowmaster series 60 muffler
- HELP! Dashboard Removal (Dash pad only)
- Rev's dont drop?!?
- Does anyone know what this is???
- How can i smoke up my tail lights?
- Rear SeaTS
- Reset ECU help!!!!!!
- Honda OEM Factory Alarm
- apexi
- what tools are needed?
- 4wd 7gens?
- whats the best legal h.i.d.?
- DIY custom grill?
- HOW TO!
- Turn your SRI into a CAI (or at least prevent HAI)
- 12V Power Question
- updated! paint for autometer pillars/pods
- quick, help, workin on headlights right now
- dealer aim my lights for me? i have switched my bulbs.
- 1st gear hits 7k RPM!!
- whistling noise in reverse
- Hello :) & What wrench do I use ?
- Clearing Headlights
- Injen CAI intake Problem HELP!
- How low can you go...?
- Clutch Engagement
- What Voids You Warrenty?
- cam gears, pulleys, fuel pressure regulator
- 2k2 clear corners
- Fog Lights to run with Park Lights
- TSX into a civic
- drive types question
- How can I open my TYC tails to paint them?
- removing the top lining of the roof
- HELP!!! REMOVING BROKEN BOLT
- N/A power, no FI
- Need Help with Hard Wire Radar
- alarm
- how can i remove my arm rest?
- Toyota Swap?
- Hydraulic trunk
- Hydrolock because of intake
- exhaust piping...
- Another E-brake question
- 2003 ex headlight removal
- 2003 headlight removal?
- Turn off A/C on defrost, etc...?
- CREATIVE INSTALL
- Console question
- Question about the AEM SRI...
- k20 swapping for 01 civics...
- DYI: hp racing header2
- 2000 Type R steering wheel ????
