View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Oil Filter on 02 si
  2. Smoking my tails. Need your help! Might consider replacing lens
  3. Which car is the DC5????
  4. clearing my headlights
  5. RSX Steering Wheel?
  6. DIY: K&N Recharger Filter Care Service Kit
  7. 2002 centerconsole????
  8. crank angle sensor
  9. Stripped screws, help!
  10. the factory immobilizer...
  11. Passenger Door Lock Switch
  12. Push button start
  13. Just got a new set of
  14. Reverse Synchros
  15. HELP!!! please!! quick question about JDM Cluster
  16. Steering Wheel Question??
  17. Side-View Mirror Installation
  18. Magnaflow + Honda Aero Rear Skirt
  19. Complete Noob: Help with keyless entry please
  20. Aiming OEM Foglamps
  21. installing coilovers
  22. GAS TANK LOCATION?
  23. **HELP** WITH TYC AIMING...
  24. ***boost controll***
  25. INTAKE and EXHAUST tech long, very long
  26. If I biuld it do you want it
  27. Q about clearing headlights
  28. !!!!Help!!! Headlight Clearing
  29. sparco seats ??
  30. *what does this fuse do?*
  31. quick question
  32. S-AFC/V-AFC idea
  33. Honda and its returnless fuel system..Why!
  34. How to install air/fuel gauge
  35. Cleaing engine w/ intake???
  36. For anyone familiar with ford engines or engines emmition parts
  37. nitrous line length question...
  38. CAM GEAR + PULLY!!!!!!!!!!!!
  39. How do I remove...
  40. how can i connect neon lights to/.......
  41. body kit install question
  42. Camshaft Info Please...........................
  43. Magnaflow muffler + Rear Lip : Part 2
  44. stock headlights draw how much current?
  45. z3 Fenders
  46. Regarding interior lights
  47. do you prefer installing a bodykit urself or taking it to the shop
  48. V-Tec Controller question
  49. Hi-flow CAT for Turbo Setup?
  50. JDM Headlights
  51. Help...CAR problems...expired warrenty!
  52. Will she know if.......?
  53. Turn signal
  54. aftermarket sunroof
  55. Gold piece in the auto tranny's?
  56. I need help!!! My Dash Lighst are out!!! Which Fuse is it!!!
  57. purpose of o2 sensors
  58. Has anyone installed "oh sh*t" bars?
  59. warning lables
  60. would is300 eyelids fit the rx300?
  61. DIY Trunk Bar Just Finished
  62. Removing Pinstripes?????
  63. what fuse controls, dash lights, blinkers, and park lights??
  64. DIY: Ignited Push Button Start
  65. Thoughts on Custom Supercharger
  66. Painting trim peices question
  67. question about intake... kinda technical
  68. swapping to a v-tec head
  69. Removing passanger airbag
  70. Painting and Polishing Strut Bar
  71. Drivers with 3 pedals.....
  72. Swap...
  73. Spark plug question
  74. Headlight sealing
  75. Learning to drive 5-spd
  76. My coolant level is low..Can i use....
  77. Synthetic Oil
  78. Hyperblinkers?
  79. vafc with nitrous!!!!
  80. VAFC-->No VTEC Settings?
  81. New Idea for Kit Install
  82. Trust e-Manager
  83. Torque Convertor Question
  84. SHOULD I PAINT REAR TAIL LIGHTS???
  85. Header quesation...
  86. CAI
  87. electric problem
  88. Many problems installing indiglo gauges.....help.....
  89. about the apexi n1 catback system
  90. Angel Eye LED Wiring
  91. Gauge Lights?
  92. build quality
  93. diablomotorsports.com site down
  94. Oem Kit Removal
  95. DIY Fuel Kill Switch
  96. SRI and CAI article Very Interesting Details On Intakes
  97. another VAFC update
  98. Check Engine light
  99. o2 simulator question
  100. Center Trim Piece
  101. OEM Rear Lip Install Question
  102. shift boot question?
  103. Center Piece
  104. apexi s afc and aem cam gear
  105. Center Console?
  106. Center Console
  107. Center Console?
  108. DIY quick help
  109. Installing a Varad LED Scanner
  110. Gear Ratio's, Speed and RPMS, Torque, HP...
  111. Strut tower bolts (3)x2... TQ rating?
  112. DIY quick help
  113. Type RS front Lip Installation
  114. paining engine components
  115. SRS hook up???
  116. Painting Engine Parts
  117. How To Installl M3 Mirrors??
  118. Removing Top Lining?
  119. acell dfi ?????? need some help.
  120. What HID Bulb Fit into TYC PROJECTORS?
  121. Headlight Removal...
  122. Removing Pillars
  123. Intake & Exhaust valve
  124. K20A With Sports Shifter?
  125. Am I getting this right?
  126. SRS Reset Help!
  127. Tenzo Rally Seat install help!
  128. whats this?
  129. Dealership BS!!!!!
  130. Installation HP header & Race Downpipe
  131. Valve Springs?
  132. Positive Blinker power lead
  133. Installing generic intake??
  134. clearing stock tailights?
  135. interior work.....
  136. indiglo gauges, yet again....
  137. shaved handles
  138. how do i remove this piece
  139. How To Un-Seal TYC Tail Lights
  140. Installing Gold Series kit
  141. alarm
  142. Under Glow
  143. Fuse question
  144. power windows?
  145. Does anyone know?
  146. K20 swap some ?'s about it
  147. Need Help ASAP (Neuspeed installation)
  148. H22 in 7th Gen is possible
  149. Adjustment Screws on angel eyes
  150. Putting on eyelids
  151. Skunk2 knocking noise
  152. HELP w/ installing splash guards
  153. paintign pillar pod
  154. Nitrous bottle placement.
  155. tyc projector bulbs....
  156. How to take out metal bar on trunk??
  157. Help with adjusting light beam on Projector Lights
  158. S2000 Saddam locks thread because he can't handle truth
  159. AEM short ram intake
  160. Gauge Question....Need some quick info
  161. Any parts for Civic HX
  162. Tinting headlights?
  163. speaker question
  164. Custom Windshield Washers
  165. Apexi Rev Speed Meter
  166. sparco speed seats
  167. Turn signals are acting really weird. Help needed
  168. diy side view mirror
  169. Vertical Suspension Travel
  170. Aiming Gunmetal headlights
  171. connecting neons to alternate source
  172. ATTN: mechanics: overheating help
  173. Regarding gauge cluster
  174. ECU Upgrade?
  175. help on under seat neon wiring
  176. Everything on my Right Side blows? Why? (headlight bulbs, fog light bulbs, hid ballst
  177. ppl w/ OEM Replica Fogs (help)
  178. Should I get a torque wrench?
  179. can i change my lights w/o removing the hole set again?!?
  180. Whats up with Apexi's V-AFC settings?
  181. sun roof
  182. Fixing ding/dents???
  183. CPU upgrade
  184. DX Gauges!!!!
  185. transmission question
  186. Power Braking.......
  187. Required Maintenance????
  188. 2001 Honda Civic Service Manual?
  189. Custom Fender Flares
  190. Ebrake and boot DIY???
  191. hood mod
  192. cd player
  193. side door mouldings
  194. Need Help, Alarm wiring messed up
  195. 94 octane?
  196. Blue Stock Gauge
  197. Dyno Tuning
  198. Headliner Removal Help!!
  199. Indoor car show
  200. Is Castrol 5w20 oil what you use on civic?
  201. Reverse Indiglo Gauge help.
  202. removing inserts in door?
  203. Stock Alarm System
  204. ?????? question.
  205. VTEC Light on Dash
  206. cylinder head
  207. Installation of brackets/sliders/tabs on Sparco Torinos
  208. Taillight conversion
  209. Struts need to be replaced?
  210. Neuspeed front strut bar
  211. auto to manual, worth it????
  212. quick question - stock piping
  213. cai????
  214. Does Octane Matter?
  215. e-brake boot
  216. suicide hood, hood pins????
  217. Help Instatlling Headlight Harness
  218. What paint to use?
  219. wanna black out stock taillights
  220. removing paint
  221. headlight switch
  222. VAFC Update by A'pexi
  223. Taillight Bulbs Rattle????
  224. Changing H1 Bulbs in my TYC's..
  225. headlights
  226. Question about driver side mirror damage (and replacement)
  227. Upper strut Bar
  228. how to change the guage light color?
  229. For those with an RSX rear sway and aftermarket exhaust...
  230. Doing class presentation on ECU
  231. safety feature for Viper esp550
  232. help!!!!
  233. VAFC fix needs to be posted
  234. Civic 01 center console
  235. Thinking of this conversion
  236. Gasket work for 40+ horsepower
  237. AEM Pulley system... worth it?
  238. cabin lights
  239. Just installed my HID
  240. shift light wiring
  241. dome lights
  242. DOING PROJECT ON ECU
  243. question on after market throttle bodies
  244. RSX Type-S parts that fit Civ's
  245. If I cant change my intruments cluster panel of my civic dx with one of the ex
  246. power door lock quetion
  247. Red Tail Lights?
  248. For Those with TYC Projectors, Worth Changing Bulbs?
  249. Installing Fibreglass body kit??? Help
