- <*<*Major problem with Kaminari side skirts*>*>
- help with maint requir'd lite...
- did anyone ask honda
- how to color match if i wanna paint my interior
- Too Many KM already...Unplugging the wire running to Odometer?
- headlights?
- Quick swap question (sorry)
- Paint thinner question
- Need Help with headlights
- Turbocharger Market Survey 2001-2004 Civic
- Custom Interior Question???
- Can you adjust the vtec timing without a Chip?
- how much hp diffrence between 1.7 and 2.0 engines?
- DIY: 02 SI Hatchback Steering wheel bolted on to a 02 LX coupe!!
- Crack open Altezzas????Anyone???
- RS Front Grill Installation help!!!!
- torque?
- Injen and K&N filter bag?!?
- stealing a 7th gen civic
- bottom engine damage
- Turbocharging the Civic Ex 1.7L
- Converted my SRI into CAI!
- BLOWN MOTOR!
- Strange Noise from car, need help??
- foglight aiming
- Check engine light
- clutch burned out :(
- Some interior painting/designing q's
- removing the headlights
- Upgraded headlight harness = brighter?
- Just ordered GroundControls, Any tips??
- ported, polished, decked question
- What happened to the GroundControls DIY????HELP!
- Finished shaving emblems and removing pin stripes..
- 2000 dx hatch springs
- anyone know wat kinda bulb we use for projector lights?
- 2 members need help asap!!!!
- K20A Swap ECU Question
- HELP, how do i take this piece out???? (pics)
- Paint overspray
- What to do with a pair of ruined headlights
- Should I start my car?
- DIY muffler install
- HX OEM Exhaust fit on an EX?
- Want to run high wattage bulbs!!!!
- hp header
- 127-horsepower 1.7-liter engine to 170-horsepower?
- Flasher Load Balance Kit
- Projector Fog up
- Air Cylinders
- fuel tech questions
- Stock plugs....
- camshaft lift/duration shenanigans
- Front Emblem
- Teins SS dampers and EDFC
- One Vehical Problem Solved
- Headlight Problem
- lookTaking the front emblem off???
- what the f....
- Does 100lbs = 30hp?
- Lowering ?
- How to remove 2002 civic ex gauge cluster?
- Converted my SRI into CAI! *PICS*
- Question about trunk?
- help: interior paint
- spark plug wires??
- gauges?
- O2 problem sim maybee?
- labor cost for airbag installation???
- SRS side airbags and racing seats......
- Bodys shops..
- stock security system
- Dash light info everywhere... What about LCD display?
- What is a fair 60ft and 60mph time?
- Injectors???
- does any one have the DIY to De-Rattle your license plate?
- DIY A/C off Defrosting doesn't work for me.....
- turning back mileage
- Switched Ignition power wire
- head gasket
- Honda Civic Stereo Install Kit DIY
- o2 sim install
- What the #$#@ is that sound?
- Installing Apex RSM Rev meter, need help!
- DIY O2 Sim at ECU
- Cleaning Header Surface Rust
- Limited Slip Differentials?
- Those whistleing sound?
- Intake potential
- does anybody have a DIY on the rear bumper removal?
- Rear bumper repair
- obx 4" exhaust
- painting grill
- What to use to cover off what to paint on headlights
- Anything i can attach to rear window to boost reception?
- Magnaflow cat-back. opinions?
- do i need a torque wrench?
- Ground controls install Question, please help :(
- 01 Up Civic Headlights vs. Acura RSX Headlights (conversion)
- Need some help fellas: Maint Req'd and D light
- downpipe, exhaust set-up
- When is the right weather to clear headlights?
- Adjusting Projectors
- what paint do you guys use for your black housing?
- turn signal
- Piaa fog lights question ??
- How do i paint my valve cover...DIY link doesn't work
- Injen CAI install advice
- Horn wiring question
- NEW AEM CAI V2
- White instead of amber bulbs ok?
- Civic Sir Engine
- blinkers
- Headers 4-1 vs 4-2-1
- last turbo question
- alot of problems with head lights need help
- who makes stock alarms??? honda?
- tin can filled with pissed bees
- Does any one make a mount kit for the k20 swap?
- Painting Altezza Grill
- Point of distributorless engine
- To those who made a Flip flop trunk!
- factory spoiler
- Suicide Hood
- How to remove gear indicator on automatic
- DIY: Light Color change for mirror control, cruise control, and sunroof control
- Weird Sound??
- ac condenser question
- Queation: Bolt on Mini Turbos on cold air intakes?
- Red Gauges?
- Clearing corner question...yes another one.
- Acura RSX Headlight (conversion) Do You Think This Will Work
- pleaseeee help
- dome light wiring question
- lights on fresh air, a/c, rear defrost buttons?
- need info
- removing dash around headunit...
- Is it possible to Re-Finish My Lower Grille
- door sound
- Funky DIY: Strengthening car rack ᢠbubble gelatin
- headlight in projections
- DIY: Booty Call
- Where can i buy the service manual ?? book or cd
- Need ECU chip info
- return fuel system....
- HELP!!!! messed up my car...again...SOS!!!
- spare tire swap
- POWER BOOST VALVE
- Oil lookin headlights
- Attn: Grey.......
- What is a mass airflow sensor?
- 2002 canadian si 1/4times vs integra gs?
- custom or store baught exhaust?!?!
- 2 questions in 1 RE: gauges
- diy pics
- thiswhere is the throttle cable
- idle
- The Oil Pan
- Help real fast! Dashlight fuse blew!
- installing sedan taillights
- does the check engine light effect ur car performance?
- projector headlights
- Clear Corners & Bulbs
- Could an Oil Cooler make much difference?
- OEM Foglight bumper template?
- what is a vtch controler!?!
- bottom grill...?
- ive searched but no one knows, i know its the o2 sensor wireair/fuel
- Question about HID bulbs
- What to cover when powerwashing engine bay?
- need tunning help!
- how can i ajust my hand brake!?!?!?
- where can I connect the remote wire from my amp?
- Aftermarket Fog Light Installation
- guess what i found out....
- wierd noise from engine
- Honda Warranty Question???
- JET Performance ECU
- o2 senor help ASAP!!
- DIY: Removing Rear Honda H emblem
- need help....question about Prelude
- Changing side panel fabric
- apexi N1 exaust help!
- V-AFC and O2 Sim
- DIY: Install Altezza Grill
- Push Button Ignition
- Battery Charger Question?
- front strut bar question
- VAFC update
- air/fuel gauge installation Q
- headlight wiring
- Fog light faulty
- breather filter
- Questions about getting my block bored
- i'm sure everyones thought about this...
- Front parking lights infos..
- anyone know how to convert their cig inverter?
- Injen CAI to SRI
- whats a good sized drop?
- '03 accord HID to Civic???
- brake master cylinder
- TO ALL EX OWNERS WITH RSX REAR SWAYBAR AND TCS
- CF Hood & Drilling
- Clearing Headlights?? Anyone Wanna Help?
- Question about emblems
- seat belt noise
- srs light
- Internals?????
- N2O and FPR
- 12 Volt Outlet Problem
- RATTLE
- Xenon side skirts?
- For those with Halo Projectors.
- whats the best fog lights on the market now!?!?
- bypass valve.....do you really lose
- removing keyless entry
- WINDSHEILD SQUIRTERS
- 5W-20 oil questions
- Is there a DIY for Sedan Tail Lights ??
- Cleaning My K&N Filter...
- .just head lights
- rsx sport shift?
- VAFC!! No check engine light!
- auto tranny light, and the plate!
- I weighed the Teins vs the stock
- Removing whole front dash
- major light problem
- Intsall On Civic
- *WHICH ONE IS THE MEMORY WIRE?*
- Front bumper diagram?
- questions on aftermarket upper grill after installation?
- i need some help on installing my short ram
- Blue Lighting for window switch?
- *ANYONE KNOW HOW TO DO "LAMBODOORS"?*
- question
- ok people who think taht they know about cars answer this.
- 2k1 LX can I put headers on it
- Problem with Reverse Indiglo DIY *I Searched*
- DIY: Hose Techniques SVH Kit
- say i wanted a K20
- Front bumper cracked?
- Urgent - wiring problem with radio/door locks
- help!! Center Dash
- seatbelt chime...
- 7th gen newbie need's expert advice
- 02 Si seats fit?
- my lights are way to high...how can i lower them?!?!?
- Who's who! Best Header Civic
- TYC Headlight Watts/Volts
- SCRATCH AND DENT HOW TO FIX
