- YELLOW REVERSE GAUGES
- Wheres the fuel line?
- 5 lug conversion?
- Altezza Sedan Installation
- Good news!
- AEM vs Injen CAI's
- Headlight bulbs
- What is this?!
- DIY: Amp Install With Pics
- Interior Horn for Stock Honda Alarm
- shunk2 good?
- Coolant
- revo technica and dc adapter
- Shaving the "Civic" and "EX" embelum
- DIY Color Dash Guages
- CAI's Q
- what r some good struts to buy?
- Anyone know if I can........ ??
- People with Black Projectors
- Projector/Bulb Problems
- changing the interior dome light (front and rear)
- How Do You Remove The Headliner?
- Fuel system
- ZEX nitrous
- install a remote starter...
- Removing Dashboard Cluster??????
- PIAA 1900X are not working, is it the FUSE OR BULBS?
- Wiring in a couple of neons
- Clearing Head Lights
- anyone have OEM body kit??
- HELP Clearing Headlights!
- skunk2 upper strut fit?
- battery tie down
- Resonator
- interior neon wired to dome??
- Quick Intake Question
- 2002 foglight installation
- z3fenders, can you see in the slits>?"
- AEM and warranty
- TEXAS LAW?
- Anyone with alarm, please help!
- install vtec controller
- Headlight Clearing!!!!!!!!!!!!!!
- Throttle Cable Pics
- Headlight Clearing Complete :)
- DIY install of moonroof visor - not as easy as it looks
- Calibrating Speedometer?
- total Plans for 2002
- whistling noise from cold air intake
- throttle cable went nuts on me!
- Relay Under Stearing Wheel (DIY: HyperBlinker???)
- whats so good about carbon fiber hoods?
- DIY: Painted Winshield Wipers???
- DIY: Lower Grill Anyone???
- How do i take off the trim around the window control??
- How does hood Locks work?
- help on removing
- Airbag question - SRS
- turbo and gas mileage
- Need mod suggestions - not just bolt ons
- HELP ME
- Compustar Alarm
- help on taking out trim parts
- new brakes?
- man do i have a problem!!!!!!
- Skunk2 front bar fit?
- what upper strut bar will fit with injen short ram?
- FOR THOSE INTERESTED IN A SWAP FOR THEIR 2K1
- indiglo installation..
- Turning off trunk light - the solution
- Info on head swap
- Help!! With lower grill installation
- 03 si head
- Struts
- are jackstands really needed to remove ft bumper cover?
- OBX Type-R Racing pedal problems
- where 2 buy REVERSE INDIGLO??
- installing fuel press., volt meter and H2O temp gauges
- Prelude Engines?
- Spoiler Question
- stock spoiler add-on
- problem with interior neon
- What miles is it best to change ur oil at?
- Intake Air Bypass Valve
- installing coilovers on 2k1 coupe?
- Anyone Have Problems With Eibach ProKit & Ingalls Kit?
- HELP :)
- purple headlights
- 'nother neon question
- re-calibrating Speedometer
- LED BULB REPLACEMENT
- some questions on spring rates & coilovers
- LED Washer ?
- How many valves?
- DOHC head swap?
- DIY: Rotor and Brake Pad Install
- lug pattern
- Exhaust installation
- strobe light positioning
- Shaved Door Handles for 4-door civic
- I just crashed. Need help
- Spinning Tires?
- swap: long version
- Rear Bumper Alignment
- DIY : Headlights
- how to reset Maintenance reqd light
- brake pads????????????
- installing new headlights...help please?
- After SRI install....clock won't set
- Springs for sedan. . .
- D16 swap
- Light sizes
- Found the Headlight Adjustment
- fog light switch change for 2002?
- Intake reset ECU
- exhaust's effect on gas mileage..
- Flange bolt question.
- Cat Converter
- Important recall//////seat belt latch
- Fog Light Condensation
- Exhaust on Sedan
- Fuel Delivery
- RSX crap
- I NEED MORE FUEL!!!
- diy:dash light
- diferences in the rsx suspension?
- When my tires shakes......
- civic specs?
- clearing headlights harder than you think!!
- Painting interior?
- CAI for auto?
- what's to be expected from a turbo?
- turbo 2002 civic ex?
- Rear upper strut bar... Does it fit in the trunk well?
- Fuel Injector Cleaner?
- Gas Line Anti-freeze?
- Connecting to the battery
- Questions about 18's
- Hood light attached to OEM alarm
- Can you install a "memory device" for passenger seat walk-in feature?
- need carb sticker for aem intake
- pulley
- So, what is happening with Htown's swap?
- DIY: COILOVERS?
- Factory Camber Adjustment?
- 17's in front, 18's in rear?
- Strut Bar Help !
- Who has installed a remote trunk release?
- Cleared Healights but still problems??
- Rear strut bar or rear tie bar?
- All Venome users
- Does anyone know the average labor cost for installing lowering springs???
- Possible to DIY a rear lower tie bar?
- Civic Intake?
- Pics of DIY lower grill after cutting out the black crap
- Rear Wiper Conversion- possible?
- 4DR and 2DR Spoiler ?
- Tach for youre dx!!!!!
- Can I lower my civic manually?
- Custom Pulley
- Problem with AC after installing a CAI
- in need of some help here
- THE nitrous post
- 5 lug conversion?
- Parking Lights Fuse
- [ Possible Motor-Swap ]
- Shaving off stock "Tint dots"
- Bypass valve and an Injen CAI intake any other way besides cutting the pipe??
- Painting Parts?
- Removing doors w/ roll down windows
- wanna custome make cai intake and other goodie!!!!!!!!!!!!!
- B18C5 WILL BE DONE
- Have you Advanced the Timing?
- Headlight aim adjustment...
- Someone with the honda service manuel =)
- Fog Light Switch Wiring Diagram
- Will rims off a....
- Question on Rims with Eibach Pro-Kit....
- for those of you that DIY oil change... what about other maint.?
- Neon lights in the interior
- port & polish piston & rods
- lower grill help?
- 40 series or 45 ???
- Torque?
- how the F@#k do i get this off
- Automatic Shiftknob
- diy springs?
- HID Ballasts
- any one know what color wire is for the tach
- NOS
- Lowering car?
- fog in altezza...
- ???rapidflash??????
- Question about synthetic blends oil.
- why only 120
- Need head work
- Interior Neon Wiring
- sideskirts
- maybe just maybe ????
- anyone paint their tweeter pods?
- The noise from the engine compartment after shutdown.
- Rims
- Good news, aftermarket oil filter magnet not needed.
- How did turtle make his trunk do that.
- Auto Transmission Hack!
- Service Manual?
- Removing Resonator
- cruise control?
- SPEED LIMITER !!!!!??????!!!!please help!!!!!
- 7th Gen Model Code?
- Intsalling short ram intake
- gauges
- gauage kit
- Injen CAI intake instructions figure #8 and step #5 making a 3" opening?
- Nos setup
- The intake makes me think VTEC
- Is This Bad?...some advice...sorta new
- RSX chassis parts
- Online VIN checker, without the Calculus involved.
- Atten: Grey
- Pro Shops
- When puttin altezzas in...
- Air bypass valve question
- what RPM is fuel cut?
- engine braking
- Intake Question
- has anyone put a tach in middle of dash?
- people with 2k1 civic ex manual, please help!!!!!!!!!!!!!
- Strobe ?
- Automatic Transmission Driving in D3 above 40mph and no redlining is it safe?
- Atte: ALLMAN
- Heated Mirrors?
- someone please HELP!!!!!!
- Vtec controller?
- Grey here's an oilchange diy for the the megathread
- Washer LEDS - please help - basic questions
- lighting installation
- engine swap......
- Automatic question???
- How much do your wheel/tire combo weigh?
- Cheapest rear camber solution yet.
- Returnless Fuel system ?
- Who Has Painted Headlight Trims?
- Shop in Houston...NEED TO KNOW........
- Cold Air Intake in the Winter
- air cylinders?
- What kind or motor oil is best
- header question!!
- exhaust question?
