- in car pc monitor??? electrical engineers welcome ;)
- Guage Cluster/Mileage Differences
- Injen SRI installation - Tools required?
- Need Input on Exhaust
- 2003 EX Headlight Bulbs??
- vinyl seats
- Is there any difference?
- Radio code help
- lx ex Intake manifold
- Nitrous Systems
- quick question, car feels like it lags
- Where is the PCM?
- how to get rid of shut off
- No cat?
- Wiring power windows into dx???
- DIY: Blacked out headlights
- grills!
- relocating a/c controls
- WIPER ARMS...
- convert an auto to stick
- Convert Stick to Auto
- Need some help???
- Lamborghini doors 6/7 gen
- put back in place, TPS HELP!!!!
- Seat Help
- Engine Check Light, PLEASE HELP....
- Question on ignition
- To: Black99CivicEx regarding fuel reg
- Help installing air horns...
- PAINT FOR HEADERS
- Removed stock intake resonator
- can i run a 5psi turbo with no fuel mods ?
- full length header
- Rear Camber Kit/Toe/alignment angle Questions; *not n00b*
- relay question
- Code # P1456.......
- Help with Intake
- i need help on a blow off valve.
- fram oil filter
- question about our heads
- Xenon kit installation?
- d16 question
- Oil pressure gauge install...
- What K&N replacment filter for AEM CAI?
- Need Help!!! Problem with my face gauges
- Dead DIY link
- Crankcase breather & AEM CAI
- swaybar attachment measurements?
- will coupe lights fit sedan
- what is best glue/cement to use to bond skirts to paint(w/o stripping paint)
- muffler silencers
- Final Turbo Parts List
- Custom interior ?'s
- help with door actuators
- 2003 guage cluster in a 2001+2002...nice!
- will this exhaust fit 02 civic??
- So what is the correct bulb size for reverse?
- exhaust help
- question about **FOCUS** door panels
- HID Conversion in an '03
- H&R Sport in sedan - Why not?
- more turbo Q's and weight reduction?
- DelSol seats in a 7th gen Coupe
- Speed Calibration
- tranny swap
- is ur car as low as mine
- Speedo, and Tach Calibration?
- K series motor #s?
- Making a custom intake mainfold...questions
- Someone w/ pic of APEX'i V-AFC installed (NOT S-AFC)
- anyone know how to remove the rear bumper? any help would be appreciated.
- Fitting new seats
- CF hood pins question?
- installing neon rods
- Hood Trim Piece Removal Help
- anyone take off their fenders?
- Question about installing ecg o2 simulator
- Apexi' VAFC update
- How Stuff Works
- Sedan Headlights into Coupe
- Exhaust Size If Turbo'd Up To 8psi
- Power door lock question...
- JET ECU vs AEM Cam Gear
- ODD Swap
- Any ideas? PLEASE!!!
- Hyper blinker.
- Quick questions about Nitrous
- Jacking up car, jack stands, hi-lift, etc
- rotor screws
- Tach Question
- Door Handle Install?
- DC to AC convertor Question....
- Spare tire relocation
- is the turbo performance kit all inclusive?
- GROUND CONTROL,SKUNK2 OR GR MATRIX COILOVERS
- converting amber to white
- Problem after hard braking.
- MISSING LINK VALVE Q
- power door locks question
- Will a D16 header fit my D17?
- DIY: Disable Daytime Running Lights (Canada Only )
- Which Intake Brand should I go with?
- AF gauge problem...
- How to gap spark plugs?
- BODY KIT question!!!
- Beating a dead horse: 7440 LED's
- 03 center console removal help! *searched...
- Where does EX get its extra 12 HP from?
- How to Remove Console with the metal trim?
- HEADLIGHT DIFFUSER??
- Put in my RSX 19mm Rear Sway today...
- WIRING DIAGRAM
- HP 4-1 Racing Header w/High Flow Cat Help Please. Need It in a Hurry. In the middle of the install!!
- Racing Seats and SRS light
- injen loose cast head....
- DIY on installing Alteeza Tail Lights?
- O2 Sim at ECU
- Using lift with Xenon kit?
- modifying stock tail lights
- Fiberglass Help/DIY/Info
- new transmission...
- Question about molding and Fiberglass vs. Urethane
- will urethane kit fit better after painting it?
- Important question about TYC Projectors.
- Sound coming form wheels???
- Car Won't Start
- Which Valve cover?
- High flow cat and emission test
- Front indicators on when headlights are switched on
- cleaning mositure in head lights
- auto tranny reliablilty?
- MaintReq light on!
- Do these Projectors have to be resealed......
- dual intake?
- Quick question on lights, dont have time to search
- What should I use to clean air filter?
- Custom Exhaust Project, could use some help...
- Header
- Turbo oil lines!
- where is the water pump?
- Rx-7 Motor
- Maintenance Light. Turn it Off DIY
- Where's the Gas Cap DIY?
- resetting ECU ?
- SRS light on
- engine internal help needed
- I know we are all sick of this, with the lx to ex switch does the check engine light come on!
- NEED help I/H/E 2002 DX
- Throttle body Spacer
- magnet fuel saver
- MoReEe TuRbO QuEsStiOnS
- struts poping
- cutting shocks?
- need help! need wiring diagram!
- DIY M3 Mirrors???
- what are these
- who did custom internals on their D17?
- Best oil????
- Inaccurate Tachometer
- another koni question lol
- after market shift knob
- changing oil
- custom cat back exhaust!
- remote lock
- AEM CAI FILTER QUESTION
- ECG o2 SIM at ECU CONNECTION
- Where to buy upgraded H4 wiring harness?
- Valve Cover painting
- RSX shift knob in 2001 civ coupe..
- 03 Center console really sucks!
- HELP QUICK weird fuzzy stuff in engine bay
- Installed AEM SRI and check engine light.....
- resetting ECU
- short shifter vs. adapter
- Possible?
- AEM Tru Time Cam Gears
- This is the Part needed for installing altezza grill or RS grill
- fuse question
- Neon Electrical Source
- old Clear headlight question, ><
- Quick question
- Dome Lights
- ppl with octane sides please help =)
- RSX-Type R Engine ??
- Question about the Apex'i V-AFC
- injen help please!!
- DIY Short Shifter
- this car is slow...
- side marker rust prevention
- k20 swap question
- I need help...
- o2 Simulator again!
- Will aftermarket bulbs void warrenty?
- Bad clutch? help.
- water injection
- Need everyones help on this one
- BUzzing sound coming from intake...
- Question on JDM tail light for sedan
- TYC projectors... pls help...
- positive crank valve
- ECU- VTM & Vtec Signal Wire Questions
- A bunch of smoked tail lamp questions
- Return fuel system... A good question!!!
- Throttle DIY trouble
- Need pics of tires and rims
- MAP sensor
- ticking noise
- What are the best kinds of shocks for 2k1civic?
- sensor for the s-afc
- Grill
- Need some help guys (keyless entry problems)
- SMELL after RUNNING CAR HARD
- help i need to build a car
- - - - - IS IT POSSIBLE? - - - -
- paiting calipers
- malfunction indicator lamp still not turning off!!
- 5% tint on the back and 20% in the front?
- hose wont hold intake pipes together...
- DC Sport Ceramic Header
- Engine Malfunction Light
- DIY: blue/red/green/yellow center dash lights
- Pop-up headlight washers
- Please help me guys!!!
- OEM cd player
- Wing Shaking
- POPULAR SCIENCE....tuning issue?
- DIY...Black Headlights
- Help: Convert ft/lbs to N/m
- Rust spot on the door..anything that will help get rid of it?
- Why are the RPMs high when the car first starts?
- pulleys and alternators
- how can i turn my head lights like this one?!?!
- JET Performance ECU where can i upgrade my?!?!
- shootin flames?!
- I need Audio installation advice
- DIY: Custom Water Spit (make ur civic pee!)
- Turbo...undoubtely an old subject
- k20 swap question
- Revo Technica Short Shifter Rattle Problem Solved!
- NEED HELP ASAP, Car wont start
- Turbo BOV needed?
- OMG!!!!
- Hollowing CAT
- just got my pedal covers, no instructions :(
- what paint code for the aluminum dash
- Air Bag question
- Which computer upgrade is better?
- DIY for HYPERBLINKER...**DETAILED**
- Adding a simple ignition kill switch?
- installing side skirts
