View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. For those with burning smell...FIXED!!!!
  2. Change Odometer Color?
  3. Does here have DIY to install new fenders?
  4. H22 engine swap
  5. Steering noise
  6. whos got a car alarm...just got an Aladdin
  7. Gauge Problem
  8. p/s and ac removal
  9. Rear window Defrost...
  10. got vafc installed 2day
  11. Painting Interior and Needs help ASAP
  12. How long does it take for Stainless or Chrome headers to change color?
  13. Color burned off bulbs!
  14. nitrous oxide
  15. For those who have changed or removed dash
  16. Heat sheild
  17. would anyone buy/use a Racing intake type headlight housing for the civic if i made one??
  18. removing rear tail lights on 7g sedan
  19. Is this possible?
  20. Car keeps dying, looking for insight.
  21. aem intake
  22. Anyone bought an Alarm online?
  23. Turbo Questions...
  24. battery
  25. Headlight Bulb Out, But High Beams Work?
  26. 195/60/15
  27. need help finding?
  28. 1/4 mile times
  29. hp header problem
  30. new day, new problem
  31. Exhaust step by step
  32. Downpipe Question
  33. Any one with an auto tran remove there resonator?
  34. Fog Light DIY
  35. the next engine for swaping in the civic....maybe my red coupe????
  36. Lamborghini doors a.k.a. paper cutters
  37. need advice on my ignition setup
  38. tranny vibration
  39. Check engine light
  40. power for fogs?
  41. SI seats
  42. REVO help
  43. HELP!!!
  44. Pros & Cons; Revo SS
  45. has anyone thought of this?
  46. Scratched interior
  47. How do I remove back seat panels?
  48. Pistons/Rods? Intake Manifold?
  49. ADVANCE TIMING ANYONE???
  50. d16 manifold
  51. Adjusting Cam Gear for Optimal Gains...
  52. Installation of a Varad LED scanner
  53. plug wires
  54. is it ok to disconnect the intake sensor ?
  55. a/f gauge help
  56. Calculating pressure coming out of compressor
  57. blue angle eyes
  58. wiring subs, need help
  59. Front Bumper Removal Q?
  60. Why the D16 manifold won't work (pic works now)
  61. Helix Power Tower
  62. Oil Leaking... need suggestions
  63. vafc check engine light
  64. AEM Intake question
  65. Installing Map Lights in DX?
  66. ECU for Turbocharging... (Grey?)
  67. Nos shot
  68. Compression on d17
  69. Installing Ground Wires
  70. CHECK THIS OUT!!!! LOW PRICE
  71. M3 Power mirrors
  72. Ground wires.... please
  73. Tightening the handbrake
  74. Vortech supercharger?
  75. Chipped center ring or alignment?
  76. Nitrous from a ford probe?
  77. Do larger rims make your car slower?
  78. supercharger
  79. DIY Custom LED needles
  80. has any one ever
  81. Somethings in the way?
  82. resetting Maintenance Light?
  83. Turbo questions?
  84. 2 1/4" resonator
  85. Torque specs for rear sway bar?
  86. Aftermarket fogs with stock switch?????
  87. anyone replaced timing belt and spark plugs yet?
  88. Need Major HELP with CIVIC ASAP!!!!!!
  89. I NEED HELP!!!! ASAP!!!!!
  90. Side Skirts
  91. maintenance required light
  92. Auto to Manual Conversion
  93. blue dashlight question
  94. Has anyone done Manual Conversion
  95. someone on this site has done it
  96. DIY building a custom trunk ?
  97. Camber Plates
  98. Panic add-on?
  99. what is?
  100. Fast and the Furious Supra Paint Code
  101. Custom Turbo -- Bill of materials...
  102. help please
  103. homemade turbo w/MSD ignition questions???
  104. Sucessful headlight clearing, but.......
  105. rear disc brakes suspension sqeaks
  106. Vtec light install questions
  107. 30K Scheduled Maintenance - How Much?
  108. sub box carpet
  109. Si Instrument Cluster?
  110. Intercooler: Top-to-Bottom -OR- Side-to-Side?
  111. The $1500 question!!!
  112. Need Help!!! Sun Visor Question
  113. Little screw on the door?
  114. WTF (tail light question)
  115. 9003 = H4??
  116. alarm options
  117. How to remove stock spark plug?
  118. wher'd you mount your bottle poll?
  119. Best bang for the buck?
  120. integra b series swaps
  121. has anyone attempted governor removal
  122. I need some help
  123. Highflow cat/dp
  124. 4-1 hp header w/ high flo cat
  125. Injen CAI & Air Horns DIY/Pictures?
  126. Painting My Tail Lights
  127. turbo performance
  128. Gas Milage
  129. Will this work?
  130. Pistons meltdown...
  131. Body kit question.
  132. 02 EX 2 door engine #
  133. Shift Boot Question Part 2!
  134. Great Big Problem....VAFC...Help fast!!
  135. Got a question about the motor...
  136. doesnt anyone SEARCH?!
  137. headlight clearing
  138. How often should you clean your intake filter?
  139. Motor Oil.. The Best?
  140. I need some brakes, where should I look?
  141. Supercharger?
  142. Pondering about something...
  143. I WANT THIS.. How can i do it to a sedan?
  144. Nighthawk black paint....
  145. Sticky tape underneath pinstrips&badge?
  146. tyc projector ?
  147. REAR BUMPER REMOVAL
  148. Painted tail lights
  149. removal of OEM front lip??
  150. anyone have any idea where I can find engine info?
  151. fuel setup for turbo?
  152. Greddy EVO on a 2003?
  153. angel eye wiring question
  154. Springs upside down?????
  155. Lower tie bar question
  156. sneaky pete NOS nitrous question
  157. cleared headlight problems
  158. headlight wattage?
  159. The Exhaust Question!!
  160. head light short prob
  161. help!!!!! guage question
  162. question on tach install
  163. Note: To guy who complained about DIM headlights
  164. Black Box?
  165. 2003 EX Cigarette Lighter..
  166. HID Question
  167. cant take front bumper off to clear headlights HELP!
  168. Alarm siren for horn
  169. Best alarm
  170. DESPERATLY need v-afc help
  171. Need help with throttle cable adjustment
  172. Where can I ground my fog lights?
  173. Computer in your car -----
  174. Tranny Work: Clutch and Flywheel
  175. IMPORTANT Question for my Car!!!
  176. Dry nitrous system?
  177. trunk mounted tool kit
  178. Need Help DIY Headlights
  179. Clutch Pedal Question
  180. srs warning labels
  181. VTEC? When Exactly is it?
  182. Backseat Removal...Please Help
  183. Nitrous in an automatic?
  184. Anyone taken apart TYC projectors?
  185. Stock Airbox.....
  186. Throttle Body
  187. Any way to recalibrate Gauges?
  188. Alternator?
  189. DIY computer in the car?!!?!?
  190. venom nos fit for our car?
  191. 450cc DSM injectors? Good deal?
  192. Springs creak in cold weather???????
  193. Unorthdox racing Pullies and light weight flywheel
  194. DIY : Installing the ZETA Wide Arm Rest
  195. 5 Speed PC - In-Vehicle PC Forum!
  196. Gauge Lights blew? After Installing Bezel
  197. DIY: Throttle Plate Edging / Throttle Plate Screw Countersinking
  198. Jdm H22a or JDMB18c Gsr for civic hb??
  199. installing door panel lights- electrical help plz
  200. Painting the kit...
  201. amp mounting on rear seatbacks?
  202. Maintenance Light
  203. Adjusting headlight aim after clearing
  204. about the HP header and Race cat w/downpipe
  205. Crank Pully?
  206. Transmission
  207. PEOPLE WITH BODY KITS
  208. idn't come wshort ram install
  209. AEM INTAKE HELP!!!
  210. ground wire install help?
  211. hood struts
  212. Side Marker light installation?
  213. help---reverse indiglo gauges
  214. how much for a manual swap?
  215. just need to know
  216. DIY: CapYoda's PreciseShift Shifter Progress Kit
  217. how to install altezza grill
  218. Trim around window switches?
  219. pulleys
  220. How do i swap auto for manual tranny??
  221. ALL of Grey's DIY's...
  222. Re-Progamming Immobilizer / Keys ?
  223. Reverse Indiglo Problem...
  224. For all yah monkeys who think that Japan runs on 100 octane gas and such . . .
  225. H22 engine??
  226. what's the diameter of stock piping?
  227. Location of Fuel Pressure Regulator?
  228. Turbo Wishlist
  229. my car dont drive
  230. Silly Question wanting a serious answer
  231. Additional Injectors for Turbo (RiceBurnerEX??)
  232. I thought it was easy?
  233. Popping from suspension?
  234. 2001 civic ecu??
  235. complete interior panel removal guide
  236. anybody kno about DIS ignitions?
  237. <<Anyone that knows engine numbers HELP!>>
  238. Reverse Indiglo Problem
  239. PIAA 1700x replacement bulb help!!!
  240. quick question...help
  241. how to measure for trunk gas struts?
  242. Floor Brace...help
  243. help: HP RACING HEADER
  244. What could this be??
  245. where to put Racing Harness?
  246. Apexi AFC controller not work on 2001 ex civ?
  247. throttle position sensor...
  248. Adding AUX input to HU.
  249. diy/installing underbody neon?
  250. My temperature needle is at H
