- Non-EX Sway Bar Parts
- DIY Camera Mount? Where?
- Apex VAFC diagram
- HELP ME! DIY for 2k2 Coupe Tail Lights
- Coolant interval
- do we have a classifed section
- DIY Altezza Grill
- 0W-30
- Angel eye question
- painting top piece of door panel - need your help
- bars!?
- k20 swap....
- Removing rear plastic pillar
- low beams both shot at the same time.....
- racing headers?!
- Warning to all do not goto Wheel Works San Jose on Winfield.
- Removing Rear Domelight
- What's the code?
- Vee VS. In-Line cyl configuration
- are air tools needed for rear lower install
- ABS brake...how much???
- How to wire sidemarkers?
- fog lights help
- DIY - Wiring Sidemarkers to blink out of sequence w/ corner turnsignals
- DIY - EL Tape Sidemarkers (no hole drilling required)
- _____PROJECTOR LIGHT POSITIVE AND NEGATIVE Q'S_____!
- Front Upper please help
- Squeaking and creaking!
- Making the 7th gen civic shifter tighter?
- DIY Installation: RVM Under-drive Crank Pulley
- Automatic into Manual *not n00b* Honda Techs welcomed
- once again the rsx sway bar
- question on cvt ??
- Clearing Headlights Question?????????/
- Day time running lights
- Need HELP ASAP!
- List of torque specs & socket size
- tech info on swaps not 7th gen
- Having honda install a new gauge cluster......
- help with my body kit
- CF Hood problem
- Mobil 1 Syn Oil
- ? about hose for injen sri
- RSX type S rear sway bar conversion for Civic EX from Honda Werx - questions from newbie
- Kaminari kit
- > DX gauge pod swap to lx/ex is this possible???
- problem w/ brakes, need help fast!!!
- Red Dash Lights
- Fogging?
- Ex Head swap?
- Integra Seats or RSX seats
- del sol seats
- HELP ASAP PLEASE!!!!
- Hello everyone, I m new to the club
- HELP!!!!
- engine didn't start. . .
- Whats behind this panel?? PICS
- Cleared Headlights and headlight installation
- Help installing a fuel pressure regulator
- Question about high watt headlight bulbs
- Cool Place To Install Mini-Tachometer
- VTEC Head Swap
- Fluid check?
- B series engine swap
- help please
- rsx sway bar bolt turning with nut
- Could I wire one side...
- How to attach the "H"
- Ride on 7thgen homepage
- Transmission Broke Down
- Question About painting trim
- Did anyone try the Truck springs replacement DIY for 2k2 SEDAN, is it work?
- DIY: JDM B16A/B18C5 Style Valve Cover Paint Job
- Need help to wire this stuff[image inside]
- Exhaust
- cant remove my rear bumper.......
- Dash light color change question:
- o2 sensor problem
- ATF in the Intake????
- Please Help me! Friends Birthday tommoro!!!
- Adjusting TYC headlights? HELP!!!
- Need help with spring/strut question.....
- Guage cluster
- How do you reach your signal bulbs without taking off the headlight?
- Wheel Bearings???
- installing indiglo gauges
- Wiring an L.E.D. Scanner (how?)
- Where'd you put the gauges?
- Cost of Clips
- I need some help with a Sun Visor question?
- front bumper
- Question for all with painted interiors
- Acrylic....
- Car leaking fluid!!
- neuspeed strut tower bar installed question
- Question about hose next to fule line?
- Tach installed in DX
- af gauge
- Stock Headlights
- Where to find oem looking spoiler w/0 3rd brake light????
- Heater dont work no air..cruise control not working
- hanger mounts for resonator
- new custom mod, what do you guys think???
- Motor Swap Question...
- rear upper strut install
- Tranny Question?/?
- Why use T3... what about the Mitsu 16g?
- Intake Question?
- Installing headers
- Indiglo gauge wiring
- DIY Clear Head Lights?
- LED Bulbs
- Does anyone know how to install a new front bumper?
- Acrylic dash failure :(
- Injen Intake hose - SRI vs CAI
- Removing Head
- ne1 here with an s2000?
- How 2 re-align bolts on rear lower install
- I just bought a Lower Rear Tie Bar, i need some help on exactly how to install?
- Speed Sensor Question
- Any tips on removing center trim piece
- uAnyone know how to install strut bars?
- Broken Stud
- Abnormal speedometer behavior
- Would this fuel system work for a turbo setup?
- coilovers on stock strut
- Interior
- Which Kind Of Hi/Low Beam Bulbs Would I Need? 02 Civic TYC Head Lamps
- Help! removing seats...
- moving the clutch reservoir for my strutbar?
- Port work questions...ask away
- Did search, no luck! How do you adjust your projector headlamp beam?
- REMOVING TRUNK SPRINGS FOR INSTALLING OEM SPOILER????
- projector lights, left side always burn out less than a day
- what should i do to fix these 2 paint things. ~~HELP~~
- NEED HELP ASAP
- Vbration around 3000 RPMs
- Tech question on 97 civic
- Painting the interior
- Please Help
- Power Windows, a minor problem.
- Any engine experts in here?
- strut tower brace bar thingy
- I think my auto tranny is slipping..
- intake manifold?
- Need help installing RS front lip - want it to look tight! Acekicker? Niter1dah? Others?
- paint sucks, tiny scratches?
- AEM bypass valve
- windsheild repair....
- sleeving the block vs block gaurd
- How to remove the 12V outlet?
- Window Switch for Nitrous
- Intake cone air filter rotates or fixed?
- Help on Headlight
- Cv joints
- Remove intake manifold?
- DIY Seat Removal?
- 1/4 mile !!!!!!!!
- Easiest way to remove rear H?
- 18 psi on a D17...
- What is this for? (pic)
- SpeedLimiter
- fender well
- VAFC Check Engine Light ?
- !!!!!!!SPEEDOMETER DEAD!!!!!!!!
- What to use to cut door panel?
- APC 7443 LED's don't work!
- Santa is bringing a remote start / keyless entry.
- Has anyone tried this
- still bored and more ideas
- Remove Exhaust resonator? Sound?
- Washington Civic Owners: Where'd you get tinted at?
- the science of destroking an engine.... any questions?
- Help Quike please
- How to get wires through firewall?
- Seat install question
- how to remove front pillars? att*beamer and other DIY'ers
- REVO SS HELP!!!
- Compression Ratio -- S2000Man or anyone else...
- Carpet Removal
- DYI installation of O2 Simulator in 7th Gen EX
- ? about DIY Angel Rings
- I NEED THE TORQUE SPECS. ASAP
- running lean
- Advanced timing?
- installing tie bar, help!
- Oil?
- Strut Bar Problems
- Engine in 7th gen Ex or Si (canada) is H17a? or..
- Removing center piece of dash...
- v-afc (people that have them please read)
- dont need any parts or anything you just need to remount it with the stock screws or something if an
- ATTN: CivicPunker17
- How to turn off maintenance light???
- help please!
- Denso Iridium Sparks
- v-afc help needed
- blue headlights
- AEM Short Ram installation...
- NOS in a bottle
- euro tails
- painting the brake capliers
- Cheapie Oil Cooler Idea...
- hyperblinkers
- door panels *help*
- How to tell what is draining the battery?
- Painted exterior parts...
- Removing Gauge Cluster - Advice
- headlight adjustment
- interior color?
- Blue Dash Light DIY???
- DIY Oil Gauges (with Pics)
- Help me install Remote Start/Keyless Entry please =)
- Connecting iPod to stock HU
- 7G civic engine swaps...
- Sorry, another clearing quesion
- need help with sealing new projectors
- 5 Psi boost EX
- Cruise Control for 2k1 Civic EX
- THOSE with HID, how did you adjust your beam?
- Getting 19's and need some Spring advise
- Showoff Krypton White/Purple Bulbs....
- What is the "BG Service Kit" needed at 30K mi?
- transmission?
- Dummy asking warranty question
- I did a search But...Shocks/struts
- "Back up" fuse???
- fog light problems...
- Are all transmitions comparable with V-tech and non V-Tech engine, can you swap?
- Remote Start Pictures...help
- cold air intake work for hx coupe?
- GSR engine?
- Not your typical tranny swap question...
- HELP QUICK!!! REMOTE START
- Window Roll Up
- 02 Parking light wire....
- Sedan rear seat removal
- help with gas door
- DIY Alarm Q
- diy painted headlight
- DIY dash light (sort of) help
- Rear 6x9 install?
- _HELP_sqeak coming from somewhere under the car
- Power Steering Fluid
- I hate dealers...burning smell.
- AEM Pulleys = No Beats?
- I Need Help Fast!!!!!
- Windows UP Module
- Indiglo Burnout....
- 01 EX manual transmition ECU and Automatic Transmition ECU the same?
