View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. ohmysac, trunk popper
  2. HELP! SPEEDO NOT WORKING!!!
  3. Splash Guards Paint keeps chipping off...
  4. Sidemarkers
  5. Shift light install help...
  6. LX guage cluster
  7. rubbing or thumping?
  8. HELP!!! AIR/FUEL gauge Question!?!?
  9. engine swap
  10. where can i find the parts number???
  11. installing nitrous
  12. dry nitous system
  13. might be a really stupid question... which wire is 12V
  14. Guage Bezel
  15. colored dome lights -info needed
  16. D17 performance parts?
  17. Interior Trim Prob?????
  18. K20 Engine Pricing
  19. Oil Pressure/Temp 2" Guages install??...
  20. Turn signal bulbs
  21. nx kit installation
  22. Codes for Auto A/C on/off
  23. outside black pannel?
  24. Angel Eye Headlights
  25. ACK!! Another warning!!
  26. painting m3 style mirrors
  27. good service place in OC
  28. supercharger?
  29. can i get this to fit?
  30. can i put EX exhaust system from header to tip in my LX
  31. poll: Does your driver's seat rock?
  32. Dual Turbo's?
  33. indiglos question
  34. tie-bar installation?
  35. front upper strut
  36. help with a cf hood
  37. DX GLOW GAUGES
  38. removing/installing side view mirror?? help
  39. Intake prices and results
  40. Installing headers
  41. Blown Motor...Does Honda Replace it??
  42. Roof Rattle
  43. Swap EX gauges to LX gauges??
  44. 3 Replaced Valves...will it be the same?
  45. aem cam gear
  46. How to bleed brake fluid?
  47. fuel rail...
  48. M3 Wires into Fuse Box
  49. quick engine swap question
  50. Buildin' the Block
  51. 7440 to fit into 7443
  52. 1993 Del Sol Clear Corners?
  53. Changing Front Upper Grill
  54. I need help THIS INSTANT: THIS IS VERY VERY IMPORTANT! (about s-afc and ecu wiring)
  55. GTI VR6 vs Honda Civic Dx
  56. want to turn your auto into a stick?
  57. Another Indiglo Guages Question
  58. MID PIPE
  59. aluminum dash trim....
  60. WTF - "H" Emblem
  61. ROD, SUBFRAME PERFORMANCE in 01 LX
  62. Where to find aftermarket Clutch for LX
  63. '03 civic
  64. 2002 ex coupe dashboard removal HELP!
  65. Auto Meter Vac Gauge
  66. itrous help needed
  67. Just changed air cleaner - what's the large...
  68. Mandrel bent or Crushed bent?
  69. ..so what is it?
  70. Problem with ignition solutions coil
  71. trunk struts
  72. Sandpaper??
  73. for those who have H1 in your projectors...help!
  74. apexi SAFC tuning tips
  75. K&N FIPK???
  76. u turn it or what. trying to install new bulbs in head lights
  77. need opinion on obx axleback exhaust
  78. water pump= hp?
  79. what do you use to pump up your tires?
  80. sidemarker help!!!
  81. side impact molding on sedan
  82. Problem with ignition solutions coil (pics)
  83. Strut Tower Brace? [I'm new so bear with me]
  84. Removed intake resonator...no sound difference.
  85. Gauge cluster swop?
  86. Did you have to cut your back bumper to clear your magnaflow cat-back on your sedan?
  87. Need help finding a wire
  88. My Gauge Lights Wont Work??
  89. head gasket?
  90. want to install cobra eyes....
  91. where does most road noise come from?
  92. Question when you hit a year or 15,000 miles
  93. speeding up the blinker
  94. Up or Down ????
  95. Intake question: upper-pipe bend angle ?
  96. OBDI versus OBDII
  97. click me please!!!!!
  98. 03 gauges in an 02?
  99. CAI and reverse light sensor?
  100. What is the Impedance of Stock Speakers?
  101. jet ecu upgrade and nitrous
  102. header heater shield
  103. removing door edge guards?
  104. urgent maintenance questions
  105. Standalone
  106. indiglo reverse gauge info...
  107. What brand and model of aftermarket clutch is anyone using?
  108. 02 EX coupe pass. door window install.. tips?
  109. RSX cluster?>
  110. CHANGING THE STEERING WHEEL ??
  111. Cam specs
  112. **Making a Custom Intake manifold**
  113. HONDA TECH please help w/tach
  114. How do you remove the rear seat in a coupe?? Help quick
  115. Torque Specs for Strut Tower Bar Needed!!
  116. Need help?
  117. How do I fix the horn contact
  118. Flywheel theory...
  119. wiring question
  120. Damnit! Messed up my air filter!
  121. crx engine swap
  122. radio still flashing!!!!!!!!
  123. lx head swap
  124. possible to replace new bulb 4 low beam without removing fender?
  125. best place to bolt down...
  126. Injen cai
  127. HELP!!!!!!..I broke my needle:(
  128. Headers
  129. Computer Reset
  130. Lowest 2k1
  131. VTEC-E / cam --- Q's for the experts
  132. grey - explain the whole return fuel system to me
  133. HELP! How can I make RSX seats fit in my EX coupe
  134. hybrid piston/rod combo
  135. lx or ex gauge cluster
  136. Has your car ever farted? (backfired?)
  137. cutting shifter vs purchasing short shifter?
  138. Throttle Plate Edging
  139. Light Question...
  140. Quick exhaust question.
  141. anyone have pics of FIPK in our car?
  142. Wiring diagram PLEASE!
  143. Intercoolers
  144. Inverter don't work
  145. Help! Split in one of my stock firestones!
  146. VAFC settings...
  147. Head Work
  148. Nail in tire
  149. size of in-dash TV??
  150. Cleared headlights painted black and blacked out tails
  151. need suggestions on painting interior
  152. Do i chip or put on my V-AFC, relating to Nitrous
  153. O2 sensor....What wire is the signal wire
  154. How easy would it be... [shift light question]
  155. Installed revo ss
  156. OBX strutbar+ OBX intake....
  157. DIY on Installing Chrome E-Brake Handle Please
  158. how much horsepower could...
  159. Do we have a OBDII diagnostic connector for our cars?
  160. Cruise Control button constantly on???
  161. Got into a small accident, please help
  162. bad smell
  163. mental property theft aka "he is gonna copy me!"
  164. Urgent help please - Taking Instrument cluster off
  165. PSI range for oil pressure guage
  166. Installation of OEM body kit?
  167. noise from exhaust
  168. Remote Start
  169. power windows
  170. Help with Platinum White Bulbs
  171. Turbo question?
  172. Oil Numbers
  173. Full Size Spare
  174. I / H / E
  175. Trouble after CAI Install
  176. DIY: Hood Pins *Updated*
  177. how long does clearing headlights take?
  178. Anyone know which fuse is for tha hazzardS?
  179. HKS Mushroom filter on Injen CAI
  180. h1-h4 conversion?
  181. gas mileage gone south - any ideas?
  182. are headlights on EL the same ?
  183. Ractive Coilovers
  184. Where Can I Get Double-Sided Tape For My Kit? (Checked HD Already)
  185. 0-60?
  186. exhaust
  187. InJen CAI
  188. side mirror
  189. Help, cars Chirping
  190. Seat Harnesses
  191. FUEL PRESSURE REGULATOR
  192. Q with clearing headlights..
  193. Type R seats...
  194. Custom Axel back Exhaust question?
  195. Removal of stock radio
  196. Port and Polish (not your usual question)
  197. 4k RPM vibration
  198. high compression valves
  199. Alarm settings - How to change?
  200. diy throttle cable?
  201. Which Jet sizes to use?
  202. custom paint !!
  203. Need everyones help, Checked the DIY's allready
  204. NX wet kit wiring problem! HELP!!!
  205. Door Fabric
  206. Anyone have a VCN400
  207. e-brake "boot" and handle removal
  208. boooooo my 1st rattle
  209. top speed sucks
  210. hey civicvtec1ps.... and others....
  211. Rear H emblem
  212. anti theft for fog lights
  213. air vents flop around :(
  214. eed help on what 2 do???????
  215. How'd you get the lights to fit?
  216. Service Manual: Idle Speed
  217. Greddy Catback w/ OEM EX muffler
  218. HP 4-1 Header w/ OEM Header Heat Shield
  219. DIY Upper Grille
  220. Turbo manifold...
  221. Installing rear lower tie bar.....HELP!!
  222. will s200 motor with tranny fit in our cars??
  223. How many point to raise insurance quotes?
  224. help!!!!
  225. How do I change my interior color?
  226. Help on painting housing on headlights
  227. our abs system....is it different?
  228. Temperature inside a projector beam headlamp...?
  229. Yet Another Angel Eyes Projector Question...
  230. no bracket arms
  231. question about tweeter pod??
  232. springs thump
  233. Rear upper strut bar install
  234. Idle speed off
  235. Very Nice Place To Install Switches
  236. SOMEBODY PLEASE HELP IMMEDIATELY!!
  237. Dent Removal?
  238. tranny gear choices?? can you change them??
  239. Weight on stock 15" Alloys
  240. need help quick - easy answer
  241. DIY: Manual Shift Boot on AT
  242. clearing headlights dot sae?
  243. For those with a shaved trunk...
  244. My rear camber kits..need help
  245. does anyone know who makes good interal stuff in a good price??
  246. DIY's for previous generation civics
  247. open deck and close deck
  248. Can't get strut tower bolts off to install front upper strut bar... WTF?
  249. grinding sensation coming from brake pedal
  250. turbo question..revhard
