- What does this mean?????
- Installing an o2 simulator on a testpipe?
- ex cai on an lx?
- oil filter wrench
- getting oil changes at honda dealer
- Injen heat shield
- exhuast goose chase
- PIAA Wiper Blades
- How is a warrenty Voided
- I NEED HELP BAD!!!!!
- How many beeps do u here when u turn d ignition on???
- how different are the coupe fenders then the sedan fenders
- clutch / tranny problem
- Intake Question
- throttle body spacer
- TYPE R UPPER FRONT
- Skunk2 Front Strut bar?
- timing on car mess up?
- remote start for civic?
- i have 2.25" pipe and i wanna change it...
- Door Handles
- Will this hurt my engine...
- how do i....
- Questions Regarding the Steering Wheel
- Broken retaining pin in wheel win.
- How Does VTEC Work?
- FACTORY RIDE HEIGHT???????????
- AFTERMARKET steering wheel??
- Apex Update for V-Afc
- H1 bulb into H3 slot?
- vtec head for sale?
- Question about the stock gauges
- DIY : Install EX door handle on LX
- DIY In-Dash Tach for DX?
- DIY!! AC power for your civic ooOooOOooo
- How to fix "DING" on door?
- question about resonator???
- Headlight Brackets ( Am I missing Screws)
- REALLY REALLY BAD PROBLEM HELP !
- Big Problem plz help
- DropZone Coilovers
- Storing car for winter what should I do
- ALL MOTOR???
- UNDERDRIVE PULLEY?
- Duble pumpin
- glasspack-resonator???
- Type R steering wheel???
- DIY: Spark Plug Installation (part II /w tips)
- Anyone ever installed 6" Hi power lights?
- Cherry Bomb
- mounting factory spoiler?
- Reground cam shaft from crower
- Rotten eggs, smelly smelly. Any suggestions?
- ABS LIGHT ON AFTER CHANGING CLUSTER
- Best Car Cover for the winter
- Headlight wireharness
- Trunk Popper Installed! (edit:PICS)
- OEM headlight MELTED
- engine manegement system
- 5 speed fluid change
- Squeeling Noise, HELP...
- How to install neuspeed upper front strut
- What all is involved in installing a Carbon Fiber hood?
- Removing Rear Bumper...How do I do it
- Injectors for hondas
- Piggyback on the OBDIII
- headlight question.....
- removing rivets from door for power window motor
- wats some of the things i need after i install aftermarket springs?
- Sneaky Pete (nitrous system)*opinions*
- Field Hyper R on LX Coupe
- help wiring the angel eyes halo
- M3 Mirrors w/turn signals
- Air/Fuel Ratio Gauge Install help PLZ
- Need Help w/ DC TCS Exhaust
- How to jack up rear side of car?
- awkward question...please help
- leaking apc tails
- Cleaning Your Engine
- installing NOS questions
- anyone know how2 add a tube to shoot water from the back of the car?!?!
- Parking Break Porb......
- help help help, someone broke in my car
- Headlight Aim
- What could be wrong
- injen cai install
- can i replace the 2door side mirror with the 4 door mirror?
- SRS light---> Searched respond ASAP pls!!
- DC TCS not center
- Help with removing trim piece
- I there a DIY for rear camber
- Does anyone know where i can get ex gauge cluster?
- what are the dimensions our trunk
- DIY KAMINARI BODY KIT
- WHY CANNOT WE TURBO CHRAGE OR SUPERCHRAGE??
- Reverse Indiglo Gauge question?
- Valve Cover HELP
- NEW TRUNK!!!!?!?!?!?
- This is why you need a rear camber kit
- installed Konis for rear on Sedan need help.
- how to install air/fuel guage??
- Help with mounting/changing tires
- just removed my a/c
- best way to fix fogged out projector lights
- apexi v-afc or s-afc placement
- removed intake resonator
- how to get the silencer out of N1 exhaust
- CENTER CONSOLE SWAP FROM DX TO EX 03"
- Intake Brands, Which is better?
- Heatshield
- BOLT ON HP GAINS
- New dashboard lights on 2003 into a 2002?
- 03 Center Console (more responses the better)
- Power/Rate Ratio....
- air/fuel guage question
- Can anyone answer these two questions quick.
- How to take Vinyle Decal out?
- where is o2 sensor?
- 20 K Service??
- Acura 1.7 EL backend conversion on civic sedan
- altezza grill
- jack spot
- CAI Intakes
- Where is the best place to let the car during the winter?
- Best spot to ground indiglo gauges?
- ENGINE SWAP WIT H RSX TYPE-S MOTOR??
- Grinding Sound Near Front Passenger Tire
- 3 point double release safety harness...
- <az> something funny
- Resonator?
- Stock Shock Diagram anyone?
- SRS
- INJEN CAI or K&N FIPK?
- Fixing the rattle
- Auto Down Passenger Window
- ·&%/)% pot holes!!
- AEM/Injen CAI vs. K&N FIPK
- Transmission out on 2k1 at 25,000
- 2002 center dash console panel removal
- 2k3 Civic HX/DX no longer get anti-sway bars...
- New car, how long till i can get on it
- Flat Smoked Tail Lights, help!
- Need some advice on winter storage...
- Question reguarding nitrous and turbo???
- New 03 Civic
- Lower Grill removal
- Nasty Rattles
- a/f gauge diagram?
- Silicone to reseal cleared headlights? don't need it.
- What kind of silicone to reseal headlights?
- Deep Tone Muffler
- oil pressure guage edit* attn honda techs
- accord leather seats
- Painting Front Lip
- Cat location....
- Help VAFC need help setting
- Custom Header.....
- Install sidemarkers? Watch out for rust!
- De-badging my EX coupe.. use dental floss?
- exhaust is knocking anyone got any ideas??
- Stock Tire + Rim lbs.
- HELP!
- Can i put synthetic motor oil in my manual tranny?
- Any Danger of Leaving a CAI on over the winter!
- Voltmeter???
- Ok to run steel wheels without hub caps?
- General Spoiler Info
- LX engine swap
- custom 5spd shift gate?!?!
- Leather seats how to???
- Can Someone Explain Gear Ratios?
- turbo and computer???
- Interior question
- MSD??
- Honda techs please help
- turbo theory
- plastic thing
- o2 simulator install?
- Rear seat question
- RSX Rear Sway Bar
- Is that IAT Sensor Trick safe?
- Rear Lower Tie
- Stut bar and CAI
- Springy noise when closing doors....
- correct me if i'm wrong
- Does the 2003 guage cluster work with 2k1/2k2's?
- Shifter Help
- Mex's Headlight Mod, DIY, PICS...
- Power Windows
- map sensor how to keep it from seeing boost??
- Need help please, 6 color indiglo, Z3 fenders
- DX to EX rear sway conversion
- APEXI VTEC CONTOLLER
- Start Up Trick???
- question about waste gates
- REMOVING THE CENTER CONSOLE!!!
- To remove my DRL's or not...that is the question?
- Hi! I'm blonde :D
- Blinkers dont work
- D17 engine map
- Just installed my rsx sway bar I love it.
- some q's on block guards
- Camber Kits
- racing seats...
- header making funny sound
- Headers....i know i know its been talked about before
- Daytime Running Lights
- ruined gauge needles instaling indiglo gauges-help
- GrillCraft
- Need Help....
- Modifications for EX header?
- got my car back after two days...
- Fog In projectors!
- Question about Cup holder cover for 2k2 civics
- replacing the camshaft
- Does this Turbo Really work?
- metal bracket on injen cai
- sub question...
- Coupe and Sedan Springs The Same?
- DIY: K&N FIPK install
- Just a theory
- LX with cam gear???
- Ultra Start/Alarm
- Port & Polish
- HELP!!!: REVO SS!!!
- where to get oil changed?
- Help! How do I put on my new m3 side mirrors?!....
- how do you....?
- Turbo Kit Parts List
- Need Help With my Angel Eyes
- Installing Subs, need help
- lx to ex exhaust conversion question
- side marker install?
- What would give me more power??
- Installing Help
- Clutch ?
- Door Handle Trim?
- Car won't start up when..............
- AUTOMATIC TRANSMISSION EXTENDED WARRENTY
- tightening the ebrake cable
- I NEED TO KNOW THE BEST WAY TO MOLD A....
- Does Helms manual have dash removal stuff?
- sedan crome grill piece
- anyone want swaybar endlink brackets for LX/DX? ((UPDATED))
- After CAI install
- can i put coupe 2 doors OEM headlight into my 4doors civic
- If i change my header what abouot my O2 sensor ???
- lower tie bar & upper rear strut bar
- Anyone know how to install M3 mirrors ?? instructions and pics
- Angel Eye headlight problems.
