- Installed Injen CAI, Car Keeps Stalling : Help
- drl light comes up?
- Installing Bypass?????????
- what makes our cars ulev?
- Stripped screws ?!!!!
- ECU newb question
- engine ques.?????????????
- AEM brakes + Wilwood calipers
- SubWolfer Power Cable
- My attempt at clearing headligts
- Where's the Blue Dash Lights DIY?
- DIY short shifter...
- clearing codes?
- Relocating Radio DIY
- I now know rim weights, how about tires?
- Got some problems...need advice
- resetting ecu
- freakin head lamps
- SMOKED CLUTCH??
- Iimmobilizer canadain civic dx
- who's running with no resonator?
- good info here
- Need Help on exaust
- Sedan Taillight help
- 2000 civic type r cluster
- DIY DVD in Glove BOX????????
- Headlight Eyelids install help
- gauges in glove box diy and custom interior?
- Removing windscreen wipers
- turbo maintenence
- audible tick from denso plugs
- auto to manual tranny swap?
- Cleaning Chrome
- Anyone have a custom intake manifold?
- mpg loss with new intake?
- leather steering wheel cover
- kamakize header
- Shift Knob; There's a clip...
- New exhaust..
- Electrical help
- DIY: Trunk Shocks
- Easy Turbo question?
- ugggh...im mad
- Tech Procedure: EM (01-02) Civic Torque Converter for AUTO (From HondaTuningmagazine.com)
- Koni Squeaks?
- enigne swap
- How to cut through a welded bolt
- DIY: Spark Plug Install
- need help with engine..
- TURBO COST?
- Help with HID Conversion kit installation
- Painted Int, will it last?
- custom fitting parts
- Why do Ground Control Coilovers Squeak so much?
- Taking car in for Tranny bushing problem, leave Injen on or off?
- Shaved molding
- cargo net hooks removal
- revo technica short shift kit help???????
- NEED HELP...NOPI SHOW IN 2 WEEKS!!!
- used springs on a new car?
- Kaminari Kit Question
- ROCHESTER, NY
- Help...odd question
- Is there a easy way to fix this?(cracked kit)
- PLEASE HELP ASAP tech advisors
- silly gas tank question
- Has anyone heard of a IC chip???
- Arm rest mounting bracket
- Where do the wires from the interior light go?
- Just heard back from the dealer (RE: Sticky tranny)
- Water Building on Driver Side Carpet!!!
- got type r springs
- TRANNY SWAP.....questions on the ECM wire harness
- OEM style fog lights.............installation?????
- May be getting my internals done at KMS
- How to wire power M3-style mirrors?
- ??-Clearing out headlights for an '02 civic
- Put a lx/dx cluster in a dx?
- we need more DIYs
- Clearance with Eibach Sportlines?
- DIY: SPC Front Camber Kit
- WANTED: Horn wiring schematic diagram...
- Clearing Altezza tail lights
- Headlght problem
- Rear Section HELP!!
- dual exhaust
- Resonator?
- Tokico RSX???
- RSX Muffler on Civic ?? Hmm
- good adhesive removers?
- DIY oil change link is dead?
- Grill Painting
- VAFC Question!
- quick question about strobes
- ### DIY Blue interior lights....
- [HELP] Need 12V power supply...
- taillights
- need to learn the clutch shift dance
- 2 Questions Guys
- What are these?
- Short shifter mess up syncro's over time?
- DIY: CUSTOM Short Shifter
- will prelude gauge pod fit my 2k2
- How to get the panel behind the door off?
- help on installing octane kit
- Just finished retro fitting Audi A6 HID projectors in to TYC Projector
- Over torqued lug nut
- Does anyone have tech info about the torch specs on the head??
- Removing the catalytic converter
- Changing the Cluster DX TO ... Any one with a tach
- OEM Fog light kit?
- What is Hard Anodizing?
- Angel Eyes = HELP
- SRS LIGHT
- 2002 Civic LX Sedan Alternator rating
- Spare Tire Space
- Just Installed My K&N FIPK!!!
- is rear section's muffler same for 2dr and 4dr??
- Adjusting the aim for OEM Foglamps
- Tie bar usefulness?
- installing an alarm......
- Suicide Trunk
- Rear deck help ASAP!
- Need Help: Console Removal
- k20a/k20c info???
- Setting the clock
- Maintaince Required light Help??
- SRS LIGHT TROUBLE
- removing middle dash
- Dash Lights DIY
- *Removed 3rd BRAKE LIGHT*
- T-25 turbo on a 2k2 civic lx
- HeeeelllllPPPPPP
- The key hole in the rear deck.
- Abs light is on??
- side airbag
- dilemma !!!!!!!!!!!!
- For those who want to know about the Saab "variable compression engine"...
- Funny engine noise.
- SI's STEERING WHEEL ON EX COUPE
- Does it hurt my transmission?
- Anyone have a stock intake manifold they can sell me?
- i dont know how you do it
- ACURA EL TRUNK LID ON A CIVIC SEDAN
- rev hard
- civics can be fast
- header and random technology cat??
- Bolts to the rear strut towers
- Problem with new CAI i just bought and installed...help quick please!
- ghetto remote start/pushbutton start
- Projector lighting problem...
- Radar Detector and Tint
- D17 vs D16 intake/exhaust ports... same?
- Help... Can't get oil drain plug out!
- Front Door Speakers
- MPG Tach
- Oil Change w/ side skirts ?!?!
- Nitrous Question
- Sedan OEM skirt+Exhaust
- Vibrating sway bar and tcs
- PLEASE, help if you can
- I think I dun did it now...
- foam
- rear camber kit
- difference between injen's intake & race division
- Anyone know how to install Splash guards?
- Unhooked Battery...Help!
- Downpipes???
- Painting Altezza's Black Need Help!
- possible belt problem
- only on the 2002 models? what is it?
- Altezza Grill for 2drs
- www.jdmhondaparts.com
- *Edited* My experiances w/ removing/installing cat back exhaust
- HELP ME!!!
- Winter question ...CANADA TEMPERATURE
- accord keyless entry???
- launching a manual
- trim pieces
- Speedo Clear Plastic Guard...
- on fender rolling....
- [ Turbo and Intake ?? ]
- easy upgrade
- engine paint
- engine question
- 2003 Civic Fuel System
- Lower dash removal.
- PASSWORD FOR our cars
- honda brake fluid or other brand dot3?
- Spoon Sports radiator cap
- RSX parts in the Civic???
- Removing kick panel?
- pin stripes
- putting in a rear strut tower bar for 4dr EX
- Pillar mount pods for 02 civic's?
- crank pully help??
- o2 wires.....
- How much drop with Koni yellows????
- Shift Knob Installation
- can factory tail lights be openned??
- turbo/Header
- "Drain Pipe"
- Quick answer if you dont mind.
- Oil Change Question
- PIAA fogs no longer working, anyone know? Blown fuse?!
- Should I use 5w20 or 5w30 oil?
- help got big problems
- Need help with exhaust work...removing custom cat back...
- Question about interior paints/dyes
- Question for front brakes.
- 14,000 miles now what??
- Someone help me out please... So confused...
- Custom sub box help
- Need help with my HP header
- for those with the evo. how loud is the greddy evo???
- Need tech help..
- The torque on Upper Front Strut bar?
- Turbo? Does this really work?
- Removing carpet in trunk
- clear headlamps and intake intsall
- ecu's
- E Brake Aluminum Handle from eBay, How to Install?
- much faster
- Don't know where to post this...anyway ... it is some tech stuff... =)
- what happened to my valvecover DIY...it doesnt work
- Removing engine mount for HP Header
- removing carpet in trunk
- Rattle sound when accelerating
- So is it bad to get the first oil change @ 6500 miles?
- custom box help in the DIY secton on
- Pullies
- dash cluster swap from dz to ex
- port and polish?!?
- engine swap
- Engine drop....
- Aem bypass valve question
- Windshield wiper delay?
- should i get a camber kit? (alignment form pic)
- Help with catback.
- AEM CAI filter cleaning
- just installed cam gear
- Installing ingiglo emblems
- Rotating Wheels....Torque
- RSX Sway Bar DIY
- Header Torque
- diy si headlights?
- Smoked Tail Lights - Clear Coat???
- Odd question about wheels....
- Block Heater?
- Doing a oil change for the first time...
