View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Question on custom axal back......
  2. Need help fast w/ problem!!! Installing Koni's & can't get the control arm part of the strut ho
  3. Positive V-AFC will not work!!???
  4. stupid intake question
  5. Different intake for different models??
  6. DIY trim is a little rough?
  7. Custom Grille...
  8. injen intake
  9. o2 sim problems?
  10. Intake Blower?????????
  11. anyone install tsunami front bumper?
  12. help!!
  13. Nitrous under back seat....
  14. Crimestopper alarm system for 2001 civic lx (2dr) Please help!!!
  15. DAYTIME RUNNING LAMPS
  16. wiring an LED??
  17. DIY: Custom Pedals
  18. mural
  19. gsr seats
  20. Installed Mobile 1, gas mileage is getting worse
  21. HELP! my car is running like garbage
  22. Do I need to reset my ECU?
  23. whriling sound from timing belt
  24. finally got it done!!!!
  25. Wiring Fog Lamps into Parking Lights..
  26. Engine Bog Down between 3 & 4k rpms
  27. exhaust
  28. springs makin noise
  29. WHen does VTEC kick in
  30. Fluorescent tube
  31. how sensitive is yours
  32. Where's the computer in the 7th Gen?
  33. Trunk removal and spoiler LED question
  34. Anyone w S-AFC tested on dyno and ...
  35. question on gels for dash,
  36. Can I cut this off my car, I don't think I need it, (pic included)
  37. Hit Different Limiter
  38. repairing dent in front bumper
  39. Painted Headlights
  40. scratches
  41. AEM bypass install
  42. Yea i've searched... Injen CAI pipe size?
  43. Got a problem about changing around parts
  44. Need help with trim paint…
  45. Indiglow Wiring??
  46. AEM TruPower pullies???
  47. boost controller question
  48. Help! Changing bulbs on m3 mirror!
  49. indiglo gauges, needle doesnt work!!! need help
  50. our civics are 4 door isolated???
  51. Shaved Door Handles
  52. Differences between D17 and D16??
  53. Removing Paint on DIY trim pieces.....
  54. Can't find a K&N Air filter, any substitutes?
  55. how to remove glovebox?
  56. WTB: Spring Compressor
  57. DIY Idea: Turn Signal Mirrors
  58. HP/DC sports header/cat question *HELP*
  59. i know people have asked about this but...
  60. Another DIY version of spare under car w/large pics...
  61. idle RPM???
  62. Question about Headlight Flasher
  63. HELP PLZ MY GAUGES ARE MESSED UP
  64. shaving
  65. Recharging A/C
  66. HELP! Air/Fuel gauge install....
  67. Anyone else have a warped rear bumper?
  68. Which Engine will Fit in my 2001 civic?
  69. air ducts
  70. DIY Bezel Paint
  71. Shaved emblems
  72. Headlight/remote entry question.
  73. Resetting Maint' Required Light
  74. Powder coating?
  75. Does anyone know the real answer?
  76. Went to the track yesterday with my EX
  77. ?? how do i get the unlock part off of the glove box?
  78. how do i install a Valet 551T on my Viper 600? alarm techs look
  79. RSX-S Anti-Sway hitting
  80. Got my aftermarket shift knob...how do I install? It has wires for indiglo light!
  81. MTEC high intensity bulbs
  82. bad noises...
  83. Chrome trim question.
  84. Can you do this??
  85. QUICK IN NEED ADVICE
  86. another question
  87. Stock SI CD player in EX?
  88. engine dress up
  89. SRS light
  90. Dash Board help!!!!!! Fast
  91. Could this be used as a turbo manifold?
  92. Maintnance Required light
  93. k24 2.4L in civic
  94. HONDATA!?!?!?
  95. parking light off
  96. More S-AFC Settings help
  97. WET OR DRY, I Searched!!!
  98. Roof scoop on 2k1
  99. HELP... Can't wire damn fog lights
  100. Shift Boot Question.....
  101. ecu
  102. Need info on turbos, psi, and such
  103. Shift knob doesn't screw on!!! HELP
  104. Xtreme Imports
  105. anyone near Tampa?
  106. EX exhaust on LX ??? would it work?
  107. failure
  108. Shifter has some play in it...
  109. RSX-S rear section exhaust on a 7th gen?
  110. flip flop trunk
  111. Need help on installing S-2000 Push Start????
  112. Any body with real HID projectors in stock housing or TYC Projectors (Exbauer......any body)
  113. Have a 1996 to 2000 civic manual??
  114. maint required light
  115. Neuspeed Sports or Eibach Sportlines?
  116. headlight isnt working
  117. heated seat and mirrors...
  118. I searE Brake ????
  119. Help with front turn signals
  120. DX To EX Cluster
  121. injen cai rd...automatic
  122. Headlight Wont Turn Off
  123. Anyone know where the temp sensor is?
  124. REQUEST: Pic(s) of bypass valve on InJen CAI
  125. 194 bulb LED problem
  126. k20 swap asap
  127. how to clear water spots in a leaking altezza?
  128. I need LOTS of HELP!
  129. plasma booster
  130. can anyone tell me how to install ...
  131. attn: people with aem cai for LX
  132. TYC Projectors, and wiring harness. NO PW!!
  133. Will "Liquid Nails" adhesive work to seal cleared headlights?!
  134. O2 sensor on header?
  135. Governors?.....
  136. brake lights dont work
  137. fog light install?
  138. Tips on installing OEM Spoiler
  139. Follow up to warped bumper thread...
  140. CAI = Better Gas Milage
  141. Civic sits uneven
  142. jet chip / venom 400
  143. AT to MT
  144. my lil theory.. prove me right..
  145. Parking lights HELP!
  146. How much does gasoline weigh?
  147. bad struts?
  148. turbo
  149. painting cf hood
  150. APC super whites
  151. !!! Injen Intake... did they forget a part? Now what?
  152. mait. required light?
  153. NEED HELP WITH STOCK CD PLAYER
  154. Maint. Required Light
  155. Different Question w/ Factory CD Player
  156. ...removin back seat
  157. Wilwood brake install on 01 civic in SCC
  158. need help with rsx sway bar
  159. Internal engine mods vs engine life
  160. torque on wheel lugs nuts
  161. Need Help, Police,EMS,EMT,firefighter or anyone who might know
  162. Good light bulbs to use with the TYC projectors...
  163. HID in TYC projectors
  164. Another question on the stock cd player
  165. help please =)
  166. DIY for underbody neons
  167. PLEASE HELP ME!!!!!!!=(
  168. <phx>i need to post this again
  169. venom doesn't work? hah your wrong!!!!!!!!
  170. Need a DIY to remove shift boot on 2k2 Coupe
  171. Changing guages of a DX to an EX
  172. Where is the Auto Tranny Fluid Change DIY?
  173. VTEC light
  174. trim pieces
  175. need help with jiggy rigged cone filter
  176. ATTN: Those of you with aftermarket Tach!!
  177. how to paint headlights
  178. Header question
  179. NOS & Venom 400?
  180. Interior Neon Schematics
  181. Anybody have their headlights explode on them?
  182. fuel system question
  183. Maintinance switch
  184. my car is possesed by an evil demon
  185. Need SRS Help
  186. D.I.Y. For Revo SS
  187. Honest opinions
  188. Does the computer record the cruise control?
  189. APEX V-AFC Fuel Controller question
  190. Replaced My Trunk Springs With Gas Struts
  191. alarm sensitivity
  192. Stock Alarm Sensitivity
  193. Apex-i controllers...
  194. My Engine Is Running Funny...
  195. GGGGGGGGGGGAAAAAAAAAAAAAAAA
  196. Removing Rear Deck
  197. ATTN: Auto Meter Sport Comp owners?
  198. Civic Turbo
  199. No matter what product I try, it doesn't work!
  200. Engine Swap
  201. indiglo aftermarket shift knob trouble!
  202. dual exhaust??????????
  203. Angel Eyes Halo hook up
  204. Flip Flop trunk question (again)
  205. K20 Swap into a 2002 Civic Si
  206. DIY tricked out hood safety question.....
  207. Shift Boot replacement... 2 Hrs or less?
  208. smoked tail lights help
  209. odometer is kinda off
  210. Empty Gas Tank Question
  211. DIY Caliper painting??????
  212. o2 simulator
  213. Anyone taken rear deck out?
  214. painting trim
  215. O2 sim
  216. Oil Pressure Gauge
  217. intalling power locks on Civic DX
  218. filters
  219. what happens @ 1,000,000 miles?
  220. Engine Start Button?
  221. Once again: B-Series swap
  222. help with reverse indiglo gauges
  223. Installing Windshield Wiper Nozzles on a CF Hood...
  224. Need a pic of someone's back seat!
  225. Hub Rings and Clamping Force
  226. Hey clear tail lamp!
  227. Question for those with Turbos
  228. 2001 Acura EL Question
  229. Did anyone measure the throw of the shifter?
  230. Front Upper Strut Bar ????????
  231. DC Titanium Strut Bar?
  232. Where's the sound??
  233. Full Synthetic? Blended Synthetic?
  234. Cutting H&R springs
  235. You guys with the Momo wheels - I really need your help.
  236. illuminated pedals
  237. how do you remove cover for OEM tails???
  238. Cut Neuspeed Race Spring
  239. **Help from the pro tuners please**
  240. how do i remove chrome grill covering
  241. [Request] InJen CAI, oh no flamming too.
  242. tranny and shifting question
  243. Vibration in stick when shifting?
  244. How to jimmy rig a shift knob?
  245. Those with the AEM CAM GEAR (I know there's a few of you out there...)
  246. Synthetic 5W-??
  247. Header installation issues... some help or ideas appreciated. (with pics now)
  248. HONDA EMBLEM
  249. Shift light for tachs
  250. door poppers: where did you put the solenoid?
