- Altezza Grill
- a neons wont work
- thinking of making my own side skirts!
- D16 or D17?
- hooking up neons
- APEXi VAFC wiring illustration question
- Best method for painting the eyelids
- Just an idea..
- AEM CAI Q...
- suggestions..
- Throttle adjustments
- question.... plz help....
- Help installing Rev/speed meter by Apexi
- need pic or diagram showing bump stops!
- cat back....
- HKS Hiper exhaust question???
- Body kits .....
- ? concerning clearing headlights
- new idea for changing your interior lighting
- anyone has this problem with projectors???
- Aftermarket seats + 3pt. seatbelt, how do u do it?
- O2 simulator wiring same as 6th gen?
- from the manual in specs...
- Is my computer f*ckedup.. or do none of the dashligh dyi work?
- Tach in the LX
- Need help with sprint drop
- measurements of the lower grill
- SETTINGS FOR S-AFC
- Dc Sports header....
- DIY: Easy change of Dash light color.
- Engine Idea!!!
- OEM keyless entry
- whats the Best Sounding exaust for a the civic?
- Chassis Dynometers-G-tech and Blitz Power - INFO?
- Probably a dumb question?
- noone has ecu diagram????
- spark plugs=better gas economy: why?
- need help!
- trim painting ideas!!!!
- razzi body kit w/ magnaflow exhast
- Bigger battery needed?
- I'm bored with clear lights...how bout this?
- Trying to install windshield wiper LED's...NEED HELP!!
- aem pulley question.
- cable disconnected when my car got back from mechanic
- New Muffler, what I have to do first?
- apex v-afc
- instrument gauge and the digital odometer...again
- Steering alignment off after drop
- just an idea ??
- tech Question about the new JDM pistons ive bought!!
- HELP
- intake question
- header torque specs
- exhaust from earlier model civic...
- where to locate singel guage? single pic.....
- for any drag racers out there, help me trouble shoot.
- Suspension problems HELP!!
- oem alarm cost??
- anyone know how long your clutch is supposed to last?
- magnaflow exhaust, any problem going over speedbumps?
- headlight question
- Question about the suspension of 2k1
- *sigh* Something else that didnt work
- will 2000 civic struts fit
- Major AEM CAI intake install problem. HELP!!!
- AEM Cold Air Intake on 01 Civic LX, BIG PROBLEM..
- Cam's n Pulley's issue!!!!
- ex downpipe on LX?
- some one help (s-afc)
- Is it possible???
- E-brake power wire?
- REAL ADVICE
- Exhaust Question? Why are there two mufflers?
- screen just came in
- UPDATED!!!!!..."DIY"- Interior door panels w/ Picts
- i need help puttin inmycorner bulbs...pleeez help
- Honda Part Diagrams?
- Anyone ever try this.... Use the OEM KEYLESS ENTRY........
- Good xenon bulbs
- Problem with throttle cable
- anyone with a 2" cat-back
- Paint Job!!!!!!
- N20 claims another victim!!
- Question about dying a dash...
- OEM Bra w/ OEM Front lip...
- I cut my shifter, and I may have tranny problems will honda cover my warranty still?
- removed airbag sticker on visor
- Shaving the head
- DIY: Aluminum Door Sills
- Replace dash lights in 97 civic
- installing indiglo gauges, wont turn on
- Automatic Rpm locked at 5000 rpm
- Oil Change?
- 8k services???
- DIY for shift knob?
- power question
- air bags!!!!!
- REVO short shifter......
- Removing CD head unit
- How hard is it to?
- Where to buy???
- Tachometer
- ATTN: Updated "DIY: No More Trunk Rattle!" with pics to stop the confusion!!!
- Trunk: spring shocks?
- where to buy new light sockets
- clearing the ends
- Mobil 1 5W30.........
- Some questions about intake and exhaust.
- Zex kit on 7th gen
- EVERYONE READ- ABOUT INTAKES *IMPORTANT*
- Replaced my license plate screws...
- No not another ?? about neons
- Alarm siren mounting on EX
- installing a switch for neons
- How Much to Weld and Fix hole in Rear Trunk?
- gotta rotate tires
- Dash Kit Install
- CD Changer Install
- injen intake?
- D.I.Y Shortened Shifter
- Nos question
- racing mesh
- Amsoil 5W20...........
- OEM header needed for turbo
- need diy for prep. a body kit
- All Aftermarket springs, front should be rightside up or upside down?
- EX, HX, and LX gauge cluster interchangable?
- installing apexi rev meter
- AEM cam gear,BAD NEWS!!!
- low fuel light question...
- Throttle Body Question
- neuspeed springs settling
- soo piss
- green plug when installing my intake?..wat the?
- sedan and coupe exhausts
- Why is there an EX header on my LX ??
- Removing rear OEM Lip/skirt
- QUESTIONS ABOUT SWITCHING TO SYNTHETIC.
- My DIY emblem-removal, LED placement brake thing (vid)
- Type R Kit for Coupes?
- Help on installing autometer tach
- i need ac
- Fuel pressure regulator...anybody?
- Alarm LED
- 6th and 7th gen radios
- SRS Sensors
- Removing the Door Guards on the 4 doors
- Type R REAR VALANCE for coupes?!
- 2002 Civic Altezza install (coupe)
- Question about my Angel Eye Projectors!!!!!
- kaminari kit: keep during winter?
- How do I remove the PRNDD3D2 to change color...
- cleaning inside of headlight assembly
- DOHC swap for EX's???
- Someone please answer....might be a dumb question.
- LED's give me hyperblinkers!
- B16A swap from 00 Si to 01 Civic?
- Possible Future: Removing Tranny and so on DIY
- Please help
- So put new wheels on, then align or align then put on wheels?
- A dumb question???
- !.::DIY Front Grille::.!
- What seires tires?
- Turbo Question - Oil Lines
- questions about a muffler silencer
- quick ? about alarm installation
- Any DIY for the clear tail lamp painting...
- Help! New noises (searched and not found)
- has anyone towed using a civic?
- Good Solution to Attach Grill Mesh...?
- What is the best way to cut interior trim peices?
- smoke in air vents!!!
- Question about head light parts...
- Installing neons in car! NEED HELP!
- aem cai question, yes i searched
- Ebay Projectors...
- Koni Help, now !!!
- suspension making weird noise! HELP!
- Pulleys, alternator, power?
- Updated Again: Custom Pedal Design
- clanking noise
- Header Help!!!
- exhaust question....
- Door Trim
- Relocating Battery to trunk
- Taking off the shift knob?
- Aftermarket Shift Knob...
- Header Installation
- My DG Motorsport Carbon Fiber Hood FLEW OFF MY CAR ON THE HIGHWAY!!!
- Help with turbo sizing...
- B-Series swap + other problems
- how many neons can be hooked to a 30 fuse?
- Removing E brake handle
- Installing 2 sets of neons?
- Nuespeed springs makes my brakes click?!
- Would 5th gen moroso oil pan fit?
- Dash Kit Painting
- Flywheel nuts : Please read.
- Installed Injen CAI... Can't get battery back in... HELP!!!!!!!!!
- is it okay for springs to be upside down?!
- CAI Driving Question
- DIY: E-Brake Adjustment
- Anyone else see this?
- AEM Cold Air Intake Instructions
- got cd stuck behind 3rd brake light..
- Does anyone know where the thermostat temp. sensor is located?
- D17: Bore & Stroke = ?
- Brake lights dont work!!!!Need reply asap
- My mechanic's reply to some of my suspension noises
- Got Noise!?
- i have the chrome projectors and it seems as though my beam pattern is off
- Looking for good hyperwhites
- what are little things that i can do to make my car look better without spending money
- diy mild port & polish?
- problem......car hesitates
- Yes another Nitrous questoin
- for anyone with a harsh shifting automatic....
- trans fluid
- Considering a Swap
- Intake resonator...
- Difference Between US Model EX versus CDN Model LX?
- Lowering my car. HELLLPPP!!
- anyone cut a coil off a 2.0 drop??
- DIY CAI??
- People in NYC
- Install Door Speakers
- Need some help with wiring!!!
- Vibrating steering wheel at 70 mph
- how to fit 4 12"subs
- what do i do!!!!!!!!!!!
- How to install Eyebrows?
- <phx> a/c problem
- is it bad for the car to cut out the plastic thing in the lower grill
- Koni Help ASAP
- beam pattern adjustment
- Differences between white lights??
- Enclosures 2 12" type Rs
- V-AFC and n02
- Did I do this right? NEED HELP!
- Projectors
- turn signals
- What to use to Paint Brake Calipers? (edited)
- CAAR WONT START!!
- Driving without a air filter.
- REMOVING PULLEYS ?
- cai to sri please help!!!!!
- Injen CAI and Fuel Line Problems....
- How do you remove the Silver auto shifter trim?
- E BRAKE HANDLE
