View Full Version : Honda Civic DIYs and Civic Tech Chat
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
  1. Tire Replacement=Pro-Rated
  2. what happened to the DIY Mega Thread???
  3. Need Help Installing HID Kit
  4. Removal of Rear "H" Emblem
  5. ATTN: BLUENVY01 and Others..... Question about puttin HP headers + Greddy Evo on the LX
  6. twin canister muffler.....
  7. smells like burnt plastic
  8. Honda Factory Instructions
  9. DIY: Adding Tachometer HELP
  10. I chipped some paint off my bumper...
  11. Exhaust Question
  12. Engine vibration when idle
  13. Zex Kits
  14. HELP!!!
  15. Possible to change the color of reverse indiglows?
  16. air/fuel
  17. Head Lights
  18. what's the point of...
  19. OK WTF!
  20. How difficult to install headers?
  21. DIY blue dash question
  22. does anybody know how to reset the maintenance required light?
  23. Dash light and gauge light bulb size?
  24. getting behind air vents?
  25. groundcontrols coilovers for 01 civic & 02 civics
  26. DIY Hyperblinker question
  27. Steering Conversion Question
  28. FIRST SERVICE...
  29. civic autoX racer's thoughts about Shortshifters
  30. Indiglo question...Not the normal question
  31. dimensions of trunk
  32. Installing a wireless remote for underbody neons
  33. ????
  34. Short shifter install......
  35. Can I swap this???
  36. Turn Signals
  37. Auto Trans
  38. I don't understand hyperblinker
  39. adjusting headlights....
  40. DIY Hard Wire Radar Detector for LX?
  41. OEM Shifter with Boot conversion..?
  42. Installing OEM Style Fogs - Need Template
  43. I Read The DIY On Installing Washer LED's But....
  44. Resetting the main. req'd light
  45. can this spoiler fit on the civic sedan?
  46. HELP! DIY valve cover painting (error)
  47. where do we place jack stands for the front of the car?
  48. help!!! i need a part number for a coilovers..
  49. Uneven Wheel Gap....Shocks?
  50. Tachometer?
  51. painting a body kit....
  52. in-car laptop or rackmount mp3 and vid server
  53. Whats the Diffrence???plz help
  54. My headlights stopped working ???
  55. just a quick question about our factory exhaust
  56. Tire Balance Quotes...Please help.
  57. Blinker relays interchangeable between coupe and sedan???
  58. I Relocated my rear stoplight!
  59. Anybody using over-wattage bulbs?
  60. Projector HEADLIGHTS - One is BRIGHTER?!?!?!
  61. Just Cleared out Headlights
  62. SUICIDE HOOD
  63. Pointing Fog Lights
  64. For anyone considering LED bulbs, info you should know.
  65. please, only 300zx techies respond
  66. RedLine?????????
  67. changing auto to a manual ?
  68. Help anyone (spring install)
  69. JDM Headlight Conversion???? For people with Cleared Lights
  70. Exhaust Install
  71. do you have to jack up your car to remove the bumper?
  72. Crazy idea, dunno if anybody has tried this or recomends this...(1/4 mile related)
  73. another interesting shortshifter theory.....
  74. Need Help with Installing my Shift Knob???
  75. 2 questions regarding dash trim install
  76. H3 BULBS WITH PROJECTORS BURN OUT!!! HELP
  77. Cutting plexi-glass
  78. Chilton VS. Haynes. the better manual??
  79. Just bought some bottom mesh grill
  80. Civic Convertible?
  81. Question about the tail lights on a sedan!
  82. suicide trunk hatch......engineering problem
  83. spare tire under...again....
  84. BODY KIT$
  85. Chrome gauge rings
  86. Anyone seen this?
  87. installing racing seat
  88. WORKING ON CAR NOW, NEED HELP!!!
  89. Those who have HID, Please help!!
  90. glassing question????
  91. Canadian and U.S OEM Kits
  92. Front Strut Tower Bar Install
  93. Coilovers Help Please
  94. help with kaminari kit...
  95. need help installing face guages
  96. DIY: Hood Pins
  97. Body kit painting and installing
  98. re: amp with factory alternator
  99. Somebody help Netcbc install his HID kit!
  100. DIY: CLEAR HEAD LIGHTS
  101. update: i'm ready to do my blue led dash interior, but i have a ?
  102. Anyone know how to disable the odometer?
  103. Problem with gauges...
  104. How do I install my shift knob?
  105. Shift boot sagging
  106. Want bigger altenator
  107. sorry guys sheesh
  108. REDLINE INCREASE I'LL DO IT NEED HELP
  109. diy- transmission fluid
  110. Red Line *Update*
  111. what parts are needed
  112. fuel problem solved!?!?
  113. RedLine *the reasons*
  114. headlight install help
  115. anyone have a DIY for venom 400 ?
  116. replacing intake filter
  117. When installing the front lip....
  118. Nitrous
  119. VTEC LIGHT...DO IT YOURSELF???
  120. blue led dash w/pics
  121. intake temp monitor
  122. Can cut key unlock trunk release?
  123. Please read...no cat converter
  124. Wiring Reverse EL gauges into stock dimmer switch
  125. anyone have a DIY for an RSX sway bar conv?
  126. What are those two metal bars in the trunk???
  127. Customize Turbo ????
  128. anyone know. . .
  129. installing new front emblem
  130. changing or clearing headlights
  131. Nitrous??
  132. Shift knob stuck on... oops.
  133. headlight help!
  134. Paint chip inside TYC projectors... HELP!
  135. Replacing my timing gear...I wanna know what kinda gain im gonna get, and an estimate on how much to
  136. Anyone using a EGT gauge?? NA or nitrous guys....
  137. HP header and high flow question
  138. Short shifter kind of stiff will it loosen up with time
  139. rsx sway bar
  140. Altezza tails leaking.. HELP
  141. DIY Radio/Window power door open thing?
  142. HELP~~~My transmission is FU***
  143. White glass tint
  144. My celica GTS 2001 seats are now in!!!
  145. Help! I think I F'd up bad!
  146. compression on 2k1's....
  147. Junkyard Turbo
  148. car ramps...
  149. removing the foglight blanks
  150. tyc projections bulbs help!
  151. Painting Trim Pieces "Clear" or "White" Primer???
  152. where,how many methods,and how much to do dashlights
  153. K20 Type-S Swap... in our civics???
  154. Ok i have a 2002 civic coupe want to drop
  155. Anyone familiar with Turbo timers..
  156. question
  157. a/c making a weird whisteling noise...
  158. OEM "Style" Fog templates - Here they are...
  159. Custom door panels (how to)
  160. D17 Tech Stuff
  161. revo Questions
  162. strobes and lava tubes
  163. Removing Trim Pieces...??
  164. Gauge Help, Disabling DRL Light
  165. wiring lights
  166. Why Synthetic?
  167. Fuel System Upgrade
  168. Gas problem simplified
  169. Highbeam for projectors
  170. DIY: Triple Air Horns /w Dual Compressors
  171. trunk lid mounted tool kit
  172. what's wrong with this picture?
  173. Help me please! I am fixing my car!
  174. ps2 install
  175. DIY on SRI Intake?????
  176. Bodykit Fixable?????
  177. MOONROOF QUESTION!!!!!
  178. Help, removing/replacing bulbs in projector headlamps
  179. A/F GUAGE INSTALL
  180. Tint Question(The More Responses the Better)
  181. To anyone with aftermarket Alarm
  182. floor mat screws.
  183. 1st oil change....
  184. port & polish q's, plus a throttlebody q
  185. DC Sports TCS Stainless?
  186. Cat removal on and such
  187. Please help w/HID conversion w/zero instructions
  188. Painting Altezza Grill???
  189. 2 turbo chargers on a rsx engine
  190. brakes squeeky at 18 k miles
  191. anyone know what kind of computer we have..
  192. installing kaminari kit or any lip kit...
  193. Curious: Does the ECU adapt to the type of fuel you're using?
  194. Need Help!... wiring alarm
  195. hard downshifting feel (automatic)
  196. AEM EMS Pros and Cons for who has this....
  197. IAT FOR 2k1 CiviC??
  198. how do stop spoiler from becoming loose?
  199. what to use for drilling?
  200. Exhaust
  201. Squeaking brake (i think)
  202. Painting amber bulbs for clear lenses
  203. EXACTLY WHY SRI TAKES AWAY POWER, SRI = WASTE OF MONEY.....CAI = GOOD INVESTMENT
  204. city lights?
  205. Intake install-DON"T LOCK MODS...strange problem!!
  206. aftermarket fog lights question
  207. need help with installing the type r front lip for the sedan
  208. Passing Inspection...........
  209. I need HELP with my projectors!!!!!
  210. Hi! I'm blonde :D
  211. Wiring HELP?! Should be simple question...
  212. Floor Latch Lock
  213. pic of my trunk release
  214. StreetGlow Gold Series underbody neons installation advice/help
  215. 7440 bulb
  216. Shifter Bushings Install Question?
  217. eyelid painting cost?
  218. 194 bulbs for the front parking lights
  219. Painting interior trim
  220. Radar Detector, do the cops know we use it?
  221. nitrous jets
  222. Need Help Painting Piece In Front Of Gauges
  223. Zex Products???
  224. Paint window piece
  225. Fuel safty cut off switch ??????
  226. installing taillights
  227. Looks like we can have direct port nitrous injection!
  228. Door Molding Installation
  229. header sounds like ass!!!!!
  230. got back from HASport
  231. Help! Trouble installing lip kit!
  232. how much to get body kit painted and installed
  233. need help cleared headlights fogged?
  234. switching over to synthetic
  235. Oven temp for sedan headlights
  236. pulleys, fuel rail, cam gears
  237. 10w- 30 safe to use ??
  238. Noob Questions from a senior member....
  239. is it my guages???
  240. help! el gauges won't turn on!
  241. srs light?
  242. Rigged Intake with stock intake and K&N filter!!
  243. Rigged Intake with stock intake and K&N filter!! (POST 2)
  244. did i mess up my ignition???
  245. AEM Short Ram Intake
  246. problem with fitting on injen CAI help...
  247. RSXS Sway Bar and some weird noises!!! Help!!!
  248. Check engine after exhaust installation
  249. Install: Sparco Steering Wheel, and Racing Harnesses
  250. OBD-II in civic
